Printable Version of Topic
914World.com _ 914World Garage _ turbo tie rod wrench
Posted by: dax1969 Oct 14 2020, 03:58 AM
Hi guys,
I am going to install the turbo tie rod kit on my 74. Read all I could find but had a question on the flat key to be used. The one on autoatlanta is square but I can't seem to find them here. Would the below "rounded" one work ? Size is 32 mm so that should be correct
thks
Dax
Posted by: betz Oct 14 2020, 09:44 AM
QUOTE(dax1969 @ Oct 14 2020, 02:58 AM)
Hi guys,
thks
Dax
I'm no expert, but I didn't really need any special tools to do the tie rod conversion. I might've used a knipex wrench? But I imagine a crescent wrench or appropriately size box wrench would do the job just fine. I'm sure the tool you have will work as well.
Posted by: bdstone914 Oct 14 2020, 11:30 AM
Hi guys,
thks
Dax
It needs to be a thin 32mm the flat part of the turbo tie rod is very narrow. A crescent wrench will not work
Posted by: 914e Oct 14 2020, 12:45 PM
Snap-on sells thin blade wrenches, of course at a Snap-on price.
Posted by: Luke M Oct 14 2020, 12:50 PM
Check your local bike shops. I purchased one from such place and it worked great on two turbo installs . Save yourself some cash too.
Posted by: digit3 Oct 14 2020, 01:11 PM
QUOTE(Luke M @ Oct 14 2020, 11:50 AM)
Yep. 32mm headset wrench (also you can search cone wrench)
Posted by: mbseto Oct 14 2020, 02:25 PM
Surprised you can get those anymore. Everyone uses sealed bearings. My old bicycle toolbox is filled with all the various BB sizes needed to repack all the bearings on the old Cannondale.
Posted by: iankarr Oct 14 2020, 02:35 PM
Got mine on amazon...
Park Tool Headset Wrench... https://www.amazon.com/dp/B001VRF0TM?ref=ppx_pop_mob_ap_share
Posted by: mepstein Oct 14 2020, 04:56 PM
QUOTE(mbseto @ Oct 14 2020, 04:25 PM)
Cheap bikes still use the old standards.
The park wrenches are good but not designed to crank down on the hardware. When you use them on a bike headset, you hold the 32mm flat on the bearing race while you crank down on the top nut with a large adjustable wrench. If you put a lot of torque on a thin spanner wrench, you end up rounding off the edges.
Posted by: Olympic 914 Oct 14 2020, 06:42 PM
I went to a local bicycle shop and used their wrench.
Posted by: bigkensteele Oct 14 2020, 08:30 PM
I don't recall who, but a member here was selling laser cut wrenches for stock and turbo tie rods. I bought one and it is great. You might want to search the member vendor forum.
Posted by: mgp4591 Oct 14 2020, 11:20 PM
I bought my set years ago to replace Chrysler inner tie rod ends... I recently used them to change my turbo tie rod ends.
https://www.google.com/aclk?sa=L&ai=DChcSEwiB2M6s7LXsAhVkHq0GHdYwBDIYABAFGgJwdg&sig=AOD64_09VfiLqUtruTwPTAO1x4a45wE6RQ&ctype=5&q=&ved=2ahUKEwiiq8Ss7LXsAhVGXc0KHdUmBnoQ9aACegQIGRA9&adurl=
Posted by: dax1969 Oct 15 2020, 01:38 AM
The one shown in my picture is actually used for bikes and is very thin. Will give it a try, cost is cheap.
thks yr feedback guys
