Printable Version of Topic
914World.com _ 914World Garage _ 914 interior fashion
Posted by: ahycaramba Oct 15 2020, 05:12 PM
I am contemplating on interior design on an open canvas of a 914 interior. Looking for any ideals. I am wanting to know what the RS inner door handles look like. If anybody wants to chime in and show me what you have I would gladly appreciate it. My color scheme is black, gray, and red.
Thanks
Al
Posted by: RolinkHaus Oct 15 2020, 06:10 PM
I like it aaaaa lot
Posted by: Costa05 Oct 15 2020, 06:32 PM
Mine are about done here. Lots of hours but redid the entire door panels with it. Ended up fabricating the door pull mechanism too. Not an easy task. Fiberglass trim pieces to cover up my mechanism, but turned out nice. Have not cut out the window cranks yet.
Posted by: VegasRacer Oct 15 2020, 09:16 PM
Door latches were flipped to allow for clearance with the roll cage.
Posted by: Mikey914 Oct 16 2020, 01:53 AM
I’m doing up a set now for a customer and will post up Monday.
Posted by: Krieger Oct 16 2020, 09:31 AM
Here's mine. I don't know if the vendor is around anymore. He advertised in Panorama.
Posted by: ahycaramba Oct 16 2020, 08:37 PM
I am loving the look gentlemen! One thing the strap. On Costa05's car he fabricated the pull strap. (nicely done BTW). Let me get this right... The pull strap is not plug and play you will have to figure out how to intertwine the door lock and release lever to make it work. Am I correct?
Posted by: Gint Oct 16 2020, 10:02 PM
QUOTE(Costa05 @ Oct 15 2020, 05:32 PM)
@http://www.914world.com/bbs2/index.php?showuser=20535 That is
very nice.
Posted by: Costa05 Oct 16 2020, 10:15 PM
QUOTE(ahycaramba @ Oct 16 2020, 09:37 PM)
I am loving the look gentlemen! One thing the strap. On Costa05's car he fabricated the pull strap. (nicely done BTW). Let me get this right... The pull strap is not plug and play you will have to figure out how to intertwine the door lock and lease lever to make it work. Am I correct?
Thanks
Definitely not plug and play on mine! Someone likely has the perfect easy solution already that I missed for the loop style pull strap... like you, I would love to see their ideas.
Posted by: Maltese Falcon Oct 17 2020, 01:23 PM
VW Beetle door * pulls , I had covered in black leather. Flipped over door handles...easier to actuate when the side (cage) bars are bolted in; and shorty window cranks to operate with the interior verticle bar.
West Coast Metric* in Harbor City, Ca.
Posted by: Maltese Falcon Oct 17 2020, 01:44 PM
...closer pic
Posted by: Maltese Falcon Oct 17 2020, 01:52 PM
QUOTE(ahycaramba @ Oct 16 2020, 07:37 PM)
Any custom door pull will require the Action of pulling on the spring loaded arm in the door mechanism. Check out the way we did a basic door pull on our current build*...the red Rennline key strap to the rescue !
*the white 9148 gtt, I think that you just got to see the body parts of it when you visited with your Son
Posted by: Costa05 Oct 17 2020, 02:45 PM
QUOTE(Maltese Falcon @ Oct 17 2020, 02:52 PM)
Clever solution! On mine I recreated the mechanics of the stock handle using metal pivot arm and the existing rod. Then had to hide it somehow. It was a bit complicated and time consuming.
Posted by: Mikey914 Oct 22 2020, 09:45 AM
And we can do a double stitch in a diagonal pattern but it would be a special order
Posted by: eric9144 Oct 22 2020, 09:50 AM
Yet another version
Posted by: RFoulds Oct 22 2020, 11:09 AM
QUOTE(Mikey914 @ Oct 22 2020, 08:43 AM)
Took a little longer than planned as we are down an employee. She got a better job offer so can't fault her there but finally done -
Shown with handles not attaches as we will leave that up to the customer for how and where they want to mount and it should really mount to the metal.
Love these. Perfect for my race car when I convert it back to a street legal hot rod. especially since I have no windows or window cranks.
HOW MUCH??
Posted by: Mikey914 Oct 22 2020, 11:33 AM
We just charge for the kit and a set of panels We currently combine at no extra charge. May take 2 weeks but times will get better.
https://914rubber.com/upholstered-door-panel-set-for-914
Just need to note smooth and order the Kit too
https://914rubber.com/rs-inner-door-handle-kit
Posted by: rgalla9146 Oct 22 2020, 07:27 PM
QUOTE(Maltese Falcon @ Oct 17 2020, 03:23 PM)
Marty those are the same seat emblems as mine.
And the only others I've seen.
My originals were shot
I had a screen made and then made the buttons.
Posted by: Maltese Falcon Oct 22 2020, 08:08 PM
QUOTE(rgalla9146 @ Oct 22 2020, 06:27 PM)
Get 'er Done Rory ... there was a guy in my graphic arts class (decades ago) that could free hand the Scheel logo
Posted by: eric9144 Oct 22 2020, 08:39 PM
@http://www.914world.com/bbs2/index.php?showuser=2755 did you make or buy the shorty window cranks? I need those
Can't unroll past the cage with the doors shut
Posted by: Maltese Falcon Oct 23 2020, 10:17 AM
QUOTE(eric9144 @ Oct 22 2020, 07:39 PM)
Nope...I don't mfg / or sell these, but not hard to build;
Just take a couple of these (same as beetle or vanagon) , drill out the small rivet at the round knob. Remove the vinyl cover off of the handle (not reused). Measure where you will need the knob for roll bar clearence then bandsaw the Metal stem and deburr. Center punch the stem, drill a small hole / for a small screw , nut and washer, loctite.
I think that some of the VW knobs had a pop-out plastic disc...makes it easier to set the new hardware in the handle. Otherwise you will need to drill a small hole through the knob to do this.
I painted the assembly with satin black Krylon, and a bit tricky to spin>>but they work !
