Printable Version of Topic
914World.com _ 914World Garage _ Rennshifter with center console and leather boot questions.
Posted by: Luke M Feb 23 2021, 12:35 PM
So while I wait on some sheet metal to come in I've been working on some interior stuff.
I'm going to run a RennShifter with a center console. I do not like the shifter boot supplied. It looks like a cv joint boot to me. I'm thinking of a leather boot for it. Anyone running the above setup that can post a few pics and where you may have gotten the boot from?
TIA,
Posted by: Mark Henry Feb 23 2021, 01:10 PM
It is a CV boot
Posted by: Mark Henry Feb 23 2021, 01:15 PM
Just take an old leather boot and the rennshifter to an upholstery shop, tell them to make you something as close as possible.
You want leather, I think the AP shift boot is the only interior 914 item that's real leather.
Posted by: Luke M Feb 23 2021, 01:21 PM
QUOTE(Mark Henry @ Feb 23 2021, 12:15 PM)
I was thinking if there was one from another vehicle that someone retro fitted.
I could always take it to an upholstery shop but wanted to see what else was available first.
Posted by: Mark Henry Feb 23 2021, 01:28 PM
That's quite the dogleg, if it sewn it will likely need something custom for that bend.
I have a Rennshifter as well, so please post your solution when you find it.
Posted by: Luke M Feb 23 2021, 01:36 PM
QUOTE(Mark Henry @ Feb 23 2021, 12:28 PM)
I'll have to wait for my custom console gauge and shifter plates to come in. Once I have those in hand I can start messing with the boot. Right now I have the cardboard templates the I can mess with to get some measurements. I'll keep you posted if I come up with something. Meantime anyone else...
Posted by: mepstein Feb 23 2021, 01:37 PM
I would make one out of vinyl from the back of an old 914 seat and then have an upholstery shop or fabric shop reproduce it in leather.
Posted by: ClayPerrine Feb 23 2021, 01:59 PM
QUOTE(Luke M @ Feb 23 2021, 12:35 PM)
TIA,
Luke...
You have no pedals, no steering gear, and no wiring. You have WAY more things to worry about than a shifter boot.
Posted by: mepstein Feb 23 2021, 02:03 PM
Things that keep you up at night.
Posted by: Van914 Feb 23 2021, 02:11 PM
Use on for a 986 Boxster. Plenty on eBay. You can even chose your color.
Posted by: burton73 Feb 23 2021, 04:48 PM
Custom is the way my brother
Bob B
but try http://www.dallassteeringwheel.com/sb.htm
Posted by: double-a Feb 23 2021, 05:05 PM
QUOTE(Luke M @ Feb 23 2021, 10:35 AM)
TIA,
i also have a center console with a Rennshift, and although it was fairly tricky, i was able to solve this problem last fall. you will have to build a customized bottom panel. here's how i did it.
first, i used a 911 SC-style boot — much better appearance, and they can be affixed to the underside of the panel as a final step, similar to how the factory 914 center console shift boot is attached.
to build the panel, i made several iterations using foam core panels at first. then i used the most accurate of these templates to trace and cut a version out of 1/4" plywood, and iterated a couple times on that. if you intend to cover it with thin foam + vinyl as i did, remember to account for the extra thickness. i found the install to be pretty tricky due to how close the larger diameter shifter body is to the inside of the left console panel. it's TIGHT in there. i will get some pictures for you.
Posted by: yeahmag Feb 23 2021, 05:36 PM
I don't see the shift adjuster window on the back of that Rennshift. How do you adjust it?
Posted by: Luke M Feb 23 2021, 06:10 PM
QUOTE(ClayPerrine @ Feb 23 2021, 12:59 PM)
TIA,
Luke...
Thanks for noticing that Clay...
My metal work is on hold while I wait on some sheet metal to get here from out West.
Engine is on hold waiting for parts but the trans is done.
So I went and messed around with the interior stuff.
Figured chip away at the list even if it's not on the chassis.
Do it now or later, either way it needs to get done.
Posted by: Luke M Feb 23 2021, 06:15 PM
QUOTE(double-a @ Feb 23 2021, 04:05 PM)
TIA,
I had the same issue with fit too. It's diffidently tight on the left side. I have a cardboard template made up and seams like things will fit ok. When you get a chance post your pics. Thanks.
Posted by: ClayPerrine Feb 24 2021, 08:06 AM
QUOTE(Luke M @ Feb 23 2021, 06:10 PM)
Luke...
Happy to be of service..
Clay
Posted by: VaccaRabite Feb 24 2021, 08:19 AM
I made the boot for my shifter with about $5 worth of vinyl from JoAnne's and maybe 10 minutes of sewing time.
Just make a paper pattern first and its no problem. Super super easy.
Zach
Posted by: double-a Feb 24 2021, 12:12 PM
TIA,
sorry for the delay. here's a shot of the template, and the finished installed panel. it was extremely tricky to get right, and i'm about 95% happy with it. getting the panel in and out requires some careful prying of the console left panel, plus plenty of cajoling and the use of not a few colorful metaphors.
Posted by: Luke M Feb 24 2021, 12:27 PM
QUOTE(double-a @ Feb 24 2021, 11:12 AM)
TIA,
I ran into the same issue getting the template on/off.
I'm gonna go with a leather shift boot now that I see yours installed with the center console. Thanks for adding the pics.
