My BB does not have a front tow hook or loop, evidently it was sacrificed when the A/C was installed in 74. I would really like to put a ring on the front somewhere and the front subframe mounting point seems to be a great spot for this.
I've seen pictures of 914 track cars with a loop at that spot. anyone out there know where to source one of these?
And then, can I just remove the subframe bolts to mount the ring without the torsion bar ruining the day?
yes you can do that - just look on any site that sells racing parts - most race venues require them - usually they will be RED - scca requires a 2" loop
- you could just buy a stock type that almost fits, then cut a U into it & drill 2 holes to mount it at the front susp point where the torsion bar connects
- OR buy the ones that fit 911-914
picture of type that Rennline sold - maybe still does
I have those on the wife's teen, I was going to put them on my car but IMHO they suck because they hang too low. The things are brand new and one is already bent. They also offer no protection like the stock part.
I have a similar need. I’m concerned about the day I might need a flat tow… how to get it on the flatbed without messing something up.
I’d like one that clears the LE spoiler like on the #64 car in this thread: http://www.914world.com/bbs2/index.php?showtopic=337038
Another tow hook thread: http://www.914world.com/bbs2/index.php?showtopic=91455
Here’s what I found online but no joy as yet. Wish someone would make one similar to Jman version with SCCA style loop that clears the spoiler:
Jman (wider loop and low profile, but out of stock) - like photo shared by @http://www.914world.com/bbs2/index.php?showuser=65 : https://jmanporscheparts.com/custom-parts
Track arm plate (for 74 911, unclear if this fits 914): http://www.autoatlanta.com/results.php?partnumber2=911%20341%20037%2002
Rennline for Porsche (not listed for 914; a smaller loop than Jman and taller – could catch curb or driveway?): https://www.rennline.com/Rennline-Front-Tow-Hooks-and-Tie-Downs-set-of-2-Porsche/productinfo/E03/
Pelican offering same as Rennline for 914: https://www.pelicanparts.com/More_Info/RENE03R.htm?pn=REN-E03-R&gclid=Cj0KCQiAmL-ABhDFARIsAKywVac_c_IA5-JdNJ-MkFuvK-oEyggbMAkNvUak_uB63jZw70Ud84IwOSAaAjrVEALw_wcB
Ebay offering same as Rennline for 914: Set of 4 tow hooks $95: https://www.ebay.com/itm/Porsche-911-912-914-930-Front-Tow-Hooks-Rear-Tie-Downs-Set-of-4/293812904870?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20190920091355%26meid%3D95335b6b1ffb4a73815d663e63c2707b%26pid%3D100036%26rk%3D3%26rkt%3D12%26sd%3D124558616023%26itm%3D293812904870%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic&_trksid=p2047675.c100036.m2109
914werke flat tow bracket $159: https://914werke.com/shop/ols/products/flat-tow-bracket
Racetech tow loop might work in a pinch: https://store.windingroad.com/racetech-tow-loop
HTH
I dont think any of those will clear the front valance.
@http://www.914world.com/bbs2/index.php?showuser=25049
I slipped one in between the bottom of the front bumper and the front valance. Just a flat ~12" long red tow hook and then bolted it to front trunk. I have a 75 though and used the old bumper mounting spots.
I have see a 911 protection cap for the torsion A-arms with an integral loop.
Some good options on this thread... I like this one by Brant:
http://www.914world.com/bbs2/index.php?showtopic=23300
We have a tow bar may help. It will offer more lateral support and more area to hook onto.
$125 comes with mounting hardware
We made it to work with the LE air dam
Made from 3/8" steel plate
My solution.
