so on my way to the AX saturday i noticed a "clunk" sound from the frontend, like i had lost something.
i had this happen before, bolt came lose on the swaybar droplink, so i thought that was it ...
when i get to the AX site and change tires, i see the droplink hanging all weird so i take a closer look and the lower hime joint has broken. the thread just snapped off the joint.
i then continue to change the tire on the other side and it's exactly the same!
both hime joints broke in the exact same location. that seems too odd to be coincidence.
i must have hit something *really* hard for that to happen, but i can't remember running over any bad potholes etc.
anyone else had problems before?
Andy
Didn't you weld on the u-tabs rotated 90 degrees from the stock orientation? (Stock = the bolts run fore-aft)
my rant on "everybody else's" 8mm-5/16" droplinks is on record here multiple times (with pictures).
you broke the Tarett 10mm joints!? zowie...
does this look like compressive fracture (are the droplink shafts bent?)
do have spacers on each side of the Heim joint to account for the misalignment and keep the joint centered in the shackle? if not, i can see that it could get cocked in there...
(and in focus, please!!)
Seriously, though--what do the drop-links look like now? Bent, as Rich asks? How do the actual breaks themselves look? Are there "broach marks" that look like ripples from one spot?
It's a good idea to talk to Tarrett on this one, see what they have to say.
--DD
QUOTE (ArtechnikA @ Jul 25 2005, 11:25 AM) |
my rant on "everybody else's" 8mm-5/16" droplinks is on record here multiple times (with pictures). you broke the Tarett 10mm joints!? zowie... |
QUOTE (ChrisReale @ Jul 25 2005, 04:11 PM) |
Yea, doesn't Smart Racing use the smaller 8mm ones? |
Sor Ahndie,
Show us a picture of the break!
Might be able to determine what caused the failure by the shape of the break and where it started.
Ken putting on his Mechanical Engineer hat and looking around for his copy of fracture mechanics....
QUOTE (Dave_Darling @ Jul 25 2005, 12:38 PM) |
![]() (and in focus, please!!) |
QUOTE |
Didn't you weld on the u-tabs rotated 90 degrees from the stock orientation? (Stock = the bolts run fore-aft) |
Ive heard the people at Tarett are very good and stand behind their products. You may try sending Ira an email with pics. Who knows, it may be a product flaw and he'll correct it
Hi Andy,
Was it the upper or lower rod ends? I’m guessing that it’s the lowers. Not sure if I agree with rotating the mounting tabs. Check to see if they got bent. Rotating them will probably cause binding when the car is jacket up and the front suspension drops. They may also bind when the suspension is compressed. Please PM me with pictures and your address, and I’ll send you new parts. Then we can figure out where the binding is coming from. I’ll also need to know which thread you need (right or left), and if you need new drop links too.
Thanks,
Ira
Ira's stuff rocks....
i snapped a Utab off on a pothole - and it pulled the lower heim with it....
ira stands behind his stuff.
QUOTE (Ira Ramin @ Aug 2 2005, 07:25 PM) |
Rotating them will probably cause binding when the car is jacket up and the front suspension drops. They may also bind when the suspension is compressed. |
Andy,
Your explanation makes full sense, and I’ve heard of 914’s not being able to be set full soft before. I’ve also heard of them being set full soft without any problems, so I’m not sure what the problem is. It may just be on the edge of working, or not working in this case. Anyone else seeing this, please let me know? It looks ok on my 911, but the 914 swaybar may be in a slightly different location to clear the gas tank.
Here is the drop link at full tilt. The rod end is hitting on the spacer before it can touch the bracket. This is on of my brackets, but the factory one is similar. If your bracket is higher and hitting, maybe it can be shortened. If the spacer is causing the problem, maybe I can change it to allow for more clearance.
What do you think about a compromise of rotating the bracket 45 deg.? Either way, we need to get it back together and figure out what the problem is. Let me know what you need and where to send the parts. No charge, I just want to solve this. I’ll be out of town next week, so let me know soon if you need parts before then.
Thanks,
Ira
Now, that, my friends, is what I call Customer Service!!!
--DD
Way to go IRA! Your stock just jumped big time in my book. This is the way to run business. Lots of companies ignore problems like this. You rock man.
I was considering a Tarett bar for my car,now I know I'll get one!!!!!
SteveSr
Yep, that'll do it for me too. The RS is getting one of Ira's bars.
Hey Ira, how about a group deal? I bet you could sell 20 of these today.
QUOTE (914RS @ Aug 4 2005, 08:25 AM) |
Yep, that'll do it for me too. The RS is getting one of Ira's bars. Hey Ira, how about a group deal? I bet you could sell 20 of these today. |
QUOTE (Mueller @ Aug 4 2005, 08:30 AM) |
oh no...the dreaded "group buy"...run...run.... I guess Joe was not around for "that" one...got a little ugly... |
QUOTE (914RS @ Aug 4 2005, 08:45 AM) | ||
Yeah ![]() |
I see. Well that sucks.
I had already pretty much decided that the RS was getting this bar, but I haven't done much pricing. Who has the best prices on these?
all about the same; if you really want to support Ira buy direct. he won't undercut his distributors with lower pricing but he won't have to pay their cut either.
i will be running a different bar in the 911 (it a preference thing...) but i will DEFINITELY run Tarett droplinks. they're the only ones who "get it" that 10mm hardware is required. there is no question that the Tarett bar is a much nicer part than the WeltMeister it is frequently compared against.
alright, let me say first that i really apprechiate Ira's offer of replacing the parts for free,
but i will have to kindly decline.
obviously, whatever happend, it had nothing to do with the material or quality or layout of his swaybar and i feel if i took him up on his offer, i'd be cheating him out of some well deserved money.
so, whatever parts i'm going to need, i'll be more than happy to pay for! (gee, what a concept ...)
now here are the blurry pics ...
drivers side:
note how the hime joint is stuck all the way towards the outside of the car. it was so much in bind that i could move it back by hand ...
this is how it's supposed to line up with the car on the ground ...
closeup. NOTE: how the U-Tab is bend to the left but the joint broke at full tilt to the right!
i am guessing the tab bend to the left when the car was on the lift with the weight of the wheels and the joint hitting the top of the tab.
then, when i hit whatever pothole it must have been, the joint moved all the way to the right under compression and snapped ...
pass side:
same here, hime joint was stuck towards the outside of the car ...
nuther, showing how it's supposed to line up ...
closeup, again, the actual u-tab is bend the other way ...
one more, more sharp this time ...
and out of the car ...
I wonder if moving the link out .25" to .375" would help any?
I would be a little concerned of "twisting" the arm with the link out too far.
so it looks like all i need is two lower hime-joints with the set screws, one left and one right thread ...
also, how important is it to keep the "arm" of the sway bar level with the ground (i heard that is the optimal position) because if i make my droplinks *longer* it'll take out a few degrees in angle and i might clear the u-tabs better ...
oh, and the bushings had marks and were deformed on the top on both sides, so the joints were definately in a bind. but that could have happened with the car on the lift.
as you can see from the pics, under normal load, the joint were nicely centered on the tabs ...
Andy
QUOTE (Mueller @ Aug 4 2005, 11:55 AM) |
I wonder if moving the link out .25" to .375" would help any? I would be a little concerned of "twisting" the arm with the link out too far. |
I've been running Ira's bar in the front of my car for a couple years....set on full soft.
The venue I AX on is god awful rough, but have had zero problems. If I ever get an LSD, I'll spring for his rear bar....if I have any money left
Hay Andy: Them pics ain't bad. I guess there's hope for you after all
QUOTE (J P Stein @ Aug 4 2005, 12:00 PM) |
I've been running Ira's bar in the front of my car for a couple years....set on full soft. |
Pics of the actual failure site may be able to tell us if it went all at once, or if it fatigued into failure over repeated cycles. Not sure that is valuable info any more, because it seems pretty obvious what happened...
--DD
QUOTE (Dave_Darling @ Aug 4 2005, 12:13 PM) |
Pics of the actual failure site may be able to tell us if it went all at once, or if it fatigued into failure over repeated cycles. |
other side ...
one more ...
Maybe you bent the tabs on a full decompression (go off any jumps lately?) and then broke the heim joints on full compression.
Got me thinking that when I went to put the mounts on the A-arms for my race car someone (forget who) told me to align the bolt holes fore-aft and not crossways as Andy has his. Wonder if that makes any difference? I agree about the upper mount moving out slightly with a spacer since the heim joint looks like it is bolted solid against the arm?
QUOTE (john rogers @ Aug 4 2005, 12:28 PM) |
Got me thinking that when I went to put the mounts on the A-arms for my race car someone (forget who) told me to align the bolt holes fore-aft and not crossways as Andy has his. Wonder if that makes any difference? I agree about the upper mount moving out slightly with a spacer since the heim joint looks like it is bolted solid against the arm? |
QUOTE (SirAndy @ Aug 4 2005, 12:36 PM) |
huh? moving the upper mount outward would make it even worse ... |
I figure the lower heim joint broke off while it was pointing inward, at full compression.
This is hard for me to explain, but I think the problem is the 90 re-orientation of the u-tabs and I think the axis of the heim joint on the a-arm needs to be parallel to the axis of the a-arm itself.
If you put a big plate (green lines) into the rotated u-tab, you'd see that the plane of the plate (especially the top) move inward and outward through the a-arm travel. However, the top of the droplink in fixed in its left-right orientation, and at some point the droplink tries to bend.
The forces on the utab (yellow) push down, but since the u-tab is at an angle, 'down' is also 'inward'.
(The left side of the picture is at ride height, the right side is my interpretation of a-arm, u-tab orientation at full compression.)
QUOTE (john rogers @ Aug 4 2005, 11:28 AM) |
Got me thinking that when I went to put the mounts on the A-arms for my race car someone (forget who) told me to align the bolt holes fore-aft and not crossways as Andy has his. Wonder if that makes any difference?(snip) |
QUOTE (Cloudbuster @ Aug 4 2005, 12:00 PM) |
This is hard for me to explain, but I think the problem is the 90 re-orientation of the u-tabs and I think the axis of the heim joint on the a-arm needs to be parallel to the axis of the a-arm itself. |
QUOTE (Cloudbuster @ Aug 4 2005, 01:00 PM) |
I figure the lower heim joint broke off while it was pointing inward, at full compression. ... |
QUOTE (SirAndy @ Aug 4 2005, 01:16 PM) |
again, my question would be, how important is it to have the "arm" parallel to the ground? if i could make the droplinks much longer, i'd be able to get around the problem, but then the arm would be up in an 45 degree angle with the car on the ground ... |
how about having 2 sets of U-tabs?
It's tough to tell from the pics (mostly due to the rust or whatever is there), but I don't see the "broach marks" that signal a progressive failure. Then again, my main examples are from Carroll Smith's books, and those may have been spiffed up for photographing. Anyway, it looks like a one-time catastrophic failure to me.
Would it make sense to trim town the tops of the "U" to get back your full range of adjustment, once the tabs are the correct way around? Or perhaps to make them wider, and use thicker spacers? I'm just trying to toss ideas around.
--DD
Has anyoner snapped a bolt off? Remember what heppened? There was a large amount of kickback and I would almost bet that is what happened here. The threaded part broke at the other extreme and the shock/force of the snapping action caused the heim joint to wedge the other way. In looking at the picture above with the A-arm compressed, that is a huge amount and I would think the inserts would have bottomed well before hat could have happened? From the picts of the car if I remember it is already sitting low and I would bet the compression is not that great, but from the looks of the suspension travel I bet there is a large amount of extension when lifting that inside front wheel. If it were me, I'd pull a strut insert to see what kind of rebound and compression the insert has?
I don't think heim joints are compatible with this bar's full range of adjustment. Mueller has the right idea - two or more sets of U-tabs (assuming there is room on the control-arm).
-Ben M.
ps - I think it's a good product (the bar) and I wish there was one on my car. I think we're just trying to get too much adjustment range out of this design and taking the geometry to the extreme.
Even if the droplink is shortened, the mounting point need to go forward, so...
I'd take a block of steel and drill / tap it for the droplink crossbolt. Weld the block onto the top of the a-arm with the bolt hanging off in front of the a-arm body. Orient the bolt fore-aft. This gives all the articulation space necessary to get the swaybar to full soft, and solves the issue of too-long droplinks.
Problems are:
1) the bolt in in single shear instead of double. A real shoulder bolt that fits inside the mounting block would help
2) there's even more binding on the heim joint trying to set the bar to full stiff. This should not really be a practical concern, unless you are running a prototype rear swaybar (2x stiffer than stock) and 200 lbs springs.
Maybe the solution is a different diameter bar???
Avoid this whole mess...
i like the idea of U-Tabs that are simply wider plus using wider spacers.
that would give me all the room i need to use the full adjustment of the bar (with the u-tab back in the stock rotation) ...
stock: |_||_|
wider: |___||___|
that should solve the problem, right?
Andy
QUOTE (jkeyzer @ Aug 4 2005, 03:04 PM) |
Maybe the solution is a different diameter bar??? Avoid this whole mess... |
QUOTE (SirAndy @ Aug 4 2005, 03:07 PM) |
stock: |_||_| wider: |___||___| |
Another consideration is that the lower heim joint range is not the issue - it could be the upper heim joint. I'm going just by pictures here, but the way that the upper joint is mounted it looks like the big washer severely restricts the amount of side to side motion of the drop link. If the top one binds (under decompression when the A-arm is extended which pulls the lower mounting point inboard), it will try to bend the drop link, and that could cause the bottom joint to fail.
Demick
here's another observation ....
the way the top hime joint is mounted, without spacers and large washers on each side, it's *very* limited in how much it can move ...
maybe adding 2 spacers like on the bottom would help getting more movement out of the top joint ...
Andy
QUOTE (Demick @ Aug 4 2005, 03:20 PM) |
it could be the upper heim joint. |
QUOTE (SirAndy @ Aug 4 2005, 03:24 PM) |
damm, you beat me to it ...![]() |
QUOTE (Demick @ Aug 4 2005, 03:31 PM) |
Hey Andy - as long as I'm 1 second faster than you - I'm happy. Especially on the Autox course. ![]() |
Is our application different than a 911? I'm confused as to whether or how this is a 914 only problem.
Interesting discussion.
The upper mount being tight against the sway bar is what I was refering to as there is no sideways movement it appears. If you get some new heim joints, I'd say to put the car up on jack stands in the front and test the A-arm travel with the bar hooked up on both sides and also with one side unhooked to see what is binding and what kind of clearances there are. This might mean devising a way to push the A-arm up to simulate full braking compression and pull the A-arm down to simulate a hard corner. This would be the only way short of mounting a video camera down there to see what is happening. I did this 6 years ago when we put the sway bars in the race car to make sure nothing was binding.
QUOTE (john rogers @ Aug 4 2005, 03:39 PM) |
This would be the only way short of mounting a video camera down there |
QUOTE (SirAndy @ Aug 4 2005, 02:43 PM) |
a video camera, eh? ![]() |
QUOTE (airsix @ Aug 4 2005, 04:26 PM) |
If you can't run the the bar at the stiffness you want without putting the heim joints into bind then you need a different weight bar. |
The problem is that the upper heim joint is fixed in space inboard/outboard wise, but the lower end in moving in/out through its travel. Added spacers to give the upper joint greater articulation doesn't really change the geometry. As a matter of fact, pushing the upper heim joint outboard would make the situation worse.
As for why this is a 914 specific problem, I think the target application for the bar was the 911. It just happens to fit in a 914. Mostly. As long as you don't run the u-tabs sideways.
Did the heim joint run into the UTab or the spacers?
Seems like if the spacers weren't so large, you'd gain another 5-10 degrees of freedom.
QUOTE (McMark @ Aug 4 2005, 05:08 PM) |
Did the heim joint run into the UTab or the spacers? Seems like if the spacers weren't so large, you'd gain another 5-10 degrees of freedom. |
On the bottom. The top seems irrelevant, since it's not binding.
This picture seems to clearly show that the UTab isn't the problem, the spacers are. At least from where I'm sitting.
QUOTE (McMark @ Aug 4 2005, 05:27 PM) |
This picture seems to clearly show that the UTab isn't the problem, the spacers are. At least from where I'm sitting. |
QUOTE (SirAndy @ Aug 4 2005, 04:38 PM) |
the car is also my daily driver and on the road i like to have some understeer, however, for the AX course, i like some mild oversteer. i adjust the bar frequently. for the street usually full soft (which put the hime joints in bind on the stock setup), on the track stiffer. |
Lets keep in mind that my picture is with my u-tab. Andy’s may be different. So are you saying that the rod end is hitting both the u-tab and the spacer? If so, then there should be room to cut the u-tab back enough to clear. Additionally, I may be able to modify the spacers to get enough additional motion to fix this. I think that it will at least help, if not resolve the problem completely.
It appears that some cars have no problems and some (two that I know of so far) do. I’d like to figure out why there’s a difference so I can come up with the best solution. The other car that I know of, with the limited adjustment range, is local to me. Maybe, if I ask nicely, he’ll let me come by and check it out.
I wonder if this is all just a matter of the factory U-tabs not being uniform but good enough for factory sway bars?
Thanks to Ira for giving this proper attention and not taking our comments as criticisms. Sometimes group engineering can be a good thing (but not usually).
QUOTE (Demick @ Aug 4 2005, 06:10 PM) |
You've got something backward. |
QUOTE (Ira Ramin @ Aug 4 2005, 06:20 PM) |
I’d like to figure out why there’s a difference so I can come up with the best solution. |
sideways
QUOTE (jonwatts @ Aug 4 2005, 06:24 PM) |
I wonder if this is all just a matter of the factory U-tabs not being uniform but good enough for factory sway bars? |
so clearly the heim hit the spacers before hitting the u-tabs. That's some pretty good deformations.
Demick
QUOTE (Demick @ Aug 4 2005, 06:59 PM) |
Remember that Andy's are not factory u-tabs. Are we sure that Andy's u-tabs are placed properly? |
It looks as if those u-tabs ARE too far inboard. According to my (3rd) spare set of factory a-arms, the bolt hole should be even with the inside corner of that tubular brace on the a-arm. (No camera, so I get to play with Paint some more)
Those U-Tabs look to be about 1/2" too far inward from "both" of my cars with stock tabs.
To try to explain... my outer edge is almost directly over the a-support that comes into view on those pics and is welded to the arm. (does that make sense? )
Both my cars have the factory mount placed "outward" by what appears to be 1/2". NOW... they're "both" 911 A-arms on the GT and the RS so... I don't know if that makes any difference.
I'd go take some pics but I don't want to piss off the Sir with my clearly superior photographic skills
(actually, I'm too fuching lazy... I will if you need or request "Oh Sir One")
QUOTE (Eric_Shea @ Aug 4 2005, 07:31 PM) |
I will if you need or request "Oh Sir One" |
QUOTE (Cloudbuster @ Aug 4 2005, 07:27 PM) |
It looks as if those u-tabs ARE too far inboard. According to my (3rd) spare set of factory a-arms, the bolt hole should be even with the inside corner of that tubular brace on the a-arm. (No camera, so I get to play with Paint some more) |
ask and you shall receive.....
Here's a pic of my passenger side a-arm with factory tab. The two lines represent the centerline of the u-tab where the bolt goes through, and the centerline of the bracing where it intersects the main part of the a-arm. That distance is about 1/2" (the u-tab being inboard of the CL of that brace)
Demick
And roughly 6" from the torsion tube to the edge of the U Tab. That is the distance between the two, not including either. (Wouldn't that be called the exclusive distance?)
Mabee a new mount on the bar area of the control arm. This will move the mount foward. This is what I needed for my bar (Weltmiester) on full soft.
I copied these from a friends 911. I don't know who makes them.
Don't pay any attention to the spiders!
QUOTE (Demick @ Aug 4 2005, 08:27 PM) |
ask and you shall receive..... |
QUOTE |
how about a lower mount that goes around the small round support rod on the a-arm with a top that can move freely and won't hit anything? |
Here's the lower mounts installed below the stock u-tabs.
You can buy just the lower mounts from Smart.
KT
QUOTE (trekkor @ Aug 4 2005, 10:03 PM) |
here's the drops attached to the stock u-tabs. |
I have never raced with the stock u-tabs.
When I showed up with the Smart bar installed for the first time Rich Walton of SRP happened to be there and helped me set-up the lower mounts.
The nice feature with the Smart mounts is you can aim them at the bar so you always have bind free operation.
Buy a set, no matter what bar you run.
KT
Ok Andy, I have an idea that will solve your problem. When you install the new u-tabs in the stock location and orientation, angle them forward enough to get full forward adjustment without binding. Just prop up the back of the tab a little when you weld them in. Make sure it’s not too much, or you could loose rear adjustment.
Ira
QUOTE (Ira Ramin @ Aug 5 2005, 06:48 AM) |
Just prop up the back of the tab a little when you weld them in. |
here's a pic of the location of the stock u-tabs
QUOTE (Jeroen @ Aug 5 2005, 12:42 PM) |
here's a pic of the location of the stock u-tabs |
I just took a look at my tarret droplinks (have been installed on my 911)
The spacers on the bottom rod-end have been slighly squashed, but only in one direction
(I'm trying to visualize in what position that is)
I'll post pics of them later on...
