After having enjoyed several 911’s over the past 40 years, I decided about a year ago that my next project would be a 914-6 GT Tribute car. I had been thinking for some time about a mid-engine open car but the Boxster is just not my cup of tea. I am more of a 70’s air cooled hot rod type and I love my ’73 Signal Orange 911 RSR tribute car. So a 914-6 GT seemed like an obvious choice. It ticked all my boxes and I have always admired the ‘70’s GT race cars.
My friends at Auto Associates in Canton, CT knew I was considering a 914-6 GT project so when a customer’s ’73 914 2.0 became available there last fall we put it up on their lift, took a close look and deemed it an acceptable starting point. The project plan is to follow the same process I have used on my RSR and my ‘70E restoration projects. I strip the car in my home shop, send the shell to Auto Associates for the metal work, chassis stiffening and paint. The painted shell comes back to me and I do the mechanical work and reassembly.
My plan is not to do a 100% accurate GT tribute but rather to build a car that looks, sounds and drives like a street friendly GT. I am not planning on any serious track or autocross but more of a fun spirited street hot rod. I know there is a ton of expertise and experience on this forum so I will be looking for some sage advice as I document the build in this thread. So here are my thoughts:
Exterior
GT flares front and rear. I will likely leave the decision of metal vs FG to Auto Associates. I would like the car to be as light as is practical. I have FG flares on my RSR and they have held up very well over the 15 years since the original restoration. I am also planning to do the lightweight, balsa reinforced front and rear trunk lids. I also would like to do the GT style double grill engine cover. Not sure if anyone makes these or if I will have Auto Associates fabricate one from my existing cover. I will go with the hood pins front and bungees rear for lid closure. Not sure whether to go with the motor operated headlights or if the cable operated system is reliable enough. I do not plan to do a lot of night driving. For wheels, I am thinking Minilites on the rear and Fuchs on the front. I also want to keep the removable top as open air driving is one of my key objectives. I am liking Mexico Blue for the color.
Interior
I plan to go with a 911 steering column and LHS 911 ignition switch as well as 911 turn signal, wiper switches and clamshell. I am also thinking of a reproduction 911 style hockey puck steering wheel. Door panels would be the GT style with strap operated pulls for door opening. I am also thinking of a pair of GTS Classic vintage seats perhaps the LeMans series. Gauges will mimic the GT type.
Drivetrain
I have a 3.0 L SC long block that I plan to use as a basis for power. I am thinking 9.5 CR with ModS type cams and a twin plug distributor. I am also toying with the idea of EFI. I am thinking 200-225 HP. I will stick with the 901 gearbox and the special 215 mm 9 bolt flywheel. I would use 911 output stubs, Sway Away free floating axles, and 911 stubs axles & hubs. I will use a front cooler and oil plumbing similar to the GT. Not sure which option to take with regard to the motor mounts.
Suspension
Other than 911 3.5” caliper spaced front struts, and 911 front hubs, I have not given the suspension much thought as yet. I do not want the car to be so stiff and jarring that it knocks my fillings out on the pothole strewn roads here in CT. That said, I also do not want the car to roll and lean like my stock ‘70E. I like the stock type of front and rear roll bars, maybe a little bigger than the stock size. I am thinking early 911S Aluminum calipers in the front. No sure about the rear calipers. I like the 15” Michelin TB’s for tires.
Chassis Stiffening
Like all 914’s this one is not rust free. After the rust repairs, I am planning to have Auto Associates install the chassis stiffening kits for the front torsion bar area, sills and rear suspension including the rear trailing arms. I am also planning on a weld-in roll bar with diagonals tied into the door sills that will allow for reasonably easy entry and exit. I want the chassis to be as stiff as possible yet still allow for the removable Targa roof.
Well…That is the current plan. I am very interested in suggestions and input from those of you who have been down this road before me. I plan to post progress with photos as I go forward and I look forward to all your comments.
Some of us will be watching, think I want to do the very same, only I want a 916, best of luck...
I was thinking of the exact same thing....forgot, just did that. You are going to have so much fun, post lots of pictures often. Best, Mark
Tom, a lot of people will want to see this build. Should have Admin move it to Garage. Mark
Sir Andy, can you change this to 914World Garage. Mark
[quote name='Tom1...That's a beauty...[/quote]
+1
Please consider a stiffener kit for the longitudinals. The 914 flexes badly through the middle because of the open top.
Brad Mauyer makes a great kit that goes on the outside of the longitudinals. The original structure is a zig zag piece of steel on top of a flat piece of steel. The kit adds another layer on top of the zig zag, making it like corrugated cardboard. And we all know how stiff corrugated cardboard is.
I have that kit on my big six, and it is on the repaired chassis for Betty's car.
Also, there are some kits to re-enforce the front sway bar holes and the area around the rear shocks. Both are recommended kits for high horsepower cars.
Sounds like a nice build. Like Clay said, I think you might consider a chassis stiffening kit. I have the inner chassis stiffening kit that goes on the interior side of the longs and the firewall. It is invisible once the car is carpeted and in my opinion really stiffens the chassis. I chose not to reinforce the trailing arms because if I lose control and slid it into a curb, I would rather the trailing arm bend and not the chassis.
I think the front sway bar reinforcement is a must. I went with stock later 914 F&R sway bars as well as Bilstein shocks/struts and Elephant Racing rubber bushings all around. I have 140 pound rear springs. My car rides very nice and does not lean and even more importantly, does not squeak.
I have a 3.2 with Motronic injection, 964 cams, Steve Wong custom chip, large-tube SS heat exchangers and muffler. I am at around 240 HP running through a 901 with a side-shifter conversion. My car runs great and pulls strongly. Of course, with Ben's exhaust, it sounds terrific.
I know you are leaving it to the body shop re the flares.....personally, I would go with steel flares. The increase in value is well worth the extra cost. I love Mexico Blue and that will look great on a flared car.
Here is a picture of my steering wheel and gauges:
Let me know if I can help. I make a good amount if parts for these cars and conversions.
I currently have the front 911 hubs/ new SC brake rotors and even SC calipers listed for sale. I have an early 911 steering column and a wiper switch available listed as well. Just a start for what you are looking for. Ben makes a great oil tank, bumper modification for oil cooler cut out, Hard GT oil lines to plumb cooler in the front nose. Jim. jdorociak@gmail.com
Sounds like a great plan, looking forward to follow it
Antoine
Hey Tom,
You have like-minded company close by. I'm North Jersey. My white car has many of the features you've focused on. A 3.0 is in the works right now. http://www.914world.com/bbs2/index.php?showtopic=310032 I'm glad to talk anytime.
-Rory
@http://www.914world.com/bbs2/index.php?showuser=8039 - Hi Tom, Original steering wheel, padded and wrapped. Also, Hartmut at Palo Alto Speedometer in Palo Alto, CA did my gauges.
http://www.914world.com/bbs2/index.php?showtopic=269606&hl=
This is my build thread check it out for my GT Tribute.
Updating his thread....
I had to put the car in the basement as my lift space is occupied by my '70E and my RSR tribute for winter storage and there is no extra room in the garage.
All the take-off parts will be available for sale.
Over the past month, I have slowly been stripping the car down and discovering the rust.
More rust
I think I have gone about as far as I can with stripping the car until I move it into my garage and onto my lift. Then I can remove the engine & gearbox and the suspension and get a good look at the underside.
No surprises there. The CA car on my lift is worse.
BTW, did you get my email reply last month?
Let me know if I can offer any advice Tom. You’ve been helpful with parts over the years. I can make a custom engine harness for you, when you get to that point.
Tom
Happy to help in any way possible.
I was fortunate to start with a car that was an abandoned project and already flared and painted. 3.0 engine Webers. I recommend metal flares.
I have a thread which may help with some of your build.
http://www.914world.com/bbs2/index.php?showtopic=261197&hl=
I have been able to source some cool parts for this project.
Early sandcast 250 mm fan/shroud & 2 bolt strap to go with the 3.0L I'll be building
"69-73 911 rear hubs
Pair of Early 911S front calipers
Unused pair of Ben's heat exchangers
Bilstein front struts with early 911 hubs
For anyone who doesn’t know, Tom is an invaluable resource in the early 911 community and an all around great and generous guy.
Tom, we fabricated this roll bar that ties into the longitudinals but has a low ‘climb over’. It also fits under the targa top. It works wonders and doesn’t make getting in or out measurably more difficult. I’m sure you can find a competent welder to make you one too.
Hi Tom, here’s my first post on 914World … I’ve been reading some amazing threads here for the past few months. Didn’t realize you’d started your 914 journey; will be watching with much interest.
Tom was instrumental in helping me with my 82 SC which I bought disassembled in 2014 and had on the road two years later.
I still have the SC and am also rehabilitating the other VW/Porsche lovechild, a 924, albeit an 87 S.
Kind regards,
John, also in Conn.
I still think a roll bar in a street legal car is dangerous
Why would someone put themselves into a “make re dangerous vehicle?”
Unless your wearing your helmet on your coffee run
Tom,
Excited to see how this build turns out.
If people want a little preview of what's to come, the RSR in Tom's signature was featured in Excellence in December of 2006. Armando also has a some nice pictures of his 911 on PBase.
Kelly
Agreed, a roll bar is dangerous without a helmet. So too though is driving a 50 year old car that was designed and built before crumple zones and high strength steel in a world of 6,000lb SUVs driven by people whose attention is partially focused on their phones. We all accept a certain amount of risk when enjoying our cars.
I modded my roll bar in a similar fashion to the above pix, and during a discussion with the race shop that welded it, decided I would add roll bar pads in the areas around my head and neck. It may not look pretty, but I’ve seen what a TBI injury can do to a family, and it’s not worth the result of having my pretty shiny roll bar.
To each their own. Now back on the topic - fun project to follow. I’ve completed my 3.2 and nearly done with my 2.7 twin plug. Ben’s tank and heat exchangers and muffler are in my 2.7 and his sport GT muffler is in my 3.2. Lots of great help here on the forum, and shout out for Rich Johnston’s motor mount and throttle assembly, Eric at PMB, and Tangerine Racing’s shift rod kit, fuel lines, and brake lines, and folks like Bruce Stone and Rich at 914werke who have provided odds and sods parts.
And of course the incomparable Bernie Buschen who has thoughtfully and methodically built both engines and assembly - what a real mensch.
[/quote]
Why ride a motorcycle? Or a bicycle on a public road? This kind of talk is silly.
[/quote]
Nope
A brain injury is not silly
On a motorcycle you should also wear a helmet
Just like a car with a roll cage
Not silly
Actually smart
[quote name='brant' date='Apr 15 2022, 07:43 AM' post='2995390']
[/quote]
[/quote]
Nope
Not silly
Actually smart
[/quote]
You are less likely to be hurt in an accident when not wearing a seat belt than you are getting into an accident on a motorcycle while not wearing a helmet, but we still have mandatory seat belt laws for cars. And you are way less likely to be hurt at an Autocross than you are when riding a motorcycle on the street. But we still wear helmets when running in an Autocross.
Personally I think the people who get on a motorcycle in shorts, a wife beater t-shirt, flip flops, and sunglasses are stupid. And we as the general public have to support their long term medical care when they get squished by an 18 wheeler on the highway and somehow manage to live through it.
My $.02.... To ride a motorcycle without a helmet should require you to sign a waiver stating that you agree that you or your family will pay all medical costs resulting from injuries that could have been prevented by wearing a helmet.
Sorry.. this is one of my pet peeves. In Texas it is perfectly legal to ride a motorcycle without a helmet, but if you don't put your seat belt on in a car, you get a ticket. That is hypocrisy of the stupidest level. I am a seatbelt fanatic. They save lives. And when I did ride a motorcycle on the street, I wore a helmet. But I think they should either repeal the seatbelt law or re-instate the mandatory helmet law.
I will get off my soap box now.
Clay
Getting on a motorcycle or bicycle, even with a helmet, is always going to be a less safe choice than a car when it comes to being in an accident. That is an undeniable fact that I think we can all agree on. And yet every day millions of people choose to ride on public roads. They make a risk/reward choice and the pleasure they derive from something is strong enough that they are willing to accept the risk.
I think it’s safe to say that no one here has only their 914 as transportation. If your other car was built in the last 30 years, it has airbags which make it dramatically safer than our old Porsches. And yet, we all accept the fact that we are choosing a less safe alternative when we drive them, because of the joy we get. Everyone’s threshold is different and no one is denying that a roll bar is less safe.
A car with a roll bar is indeed dangerous.
Several times I have cut myself on one of the zip-ties used to hold the roll bar padding in place.
Hey guys, you know we are kinda walking all over the OP Tom’s 914-6 GT Tribute Project thread here…(me included now)
Good lively discussion, but he may need some space for some project pictures:)
Time for an update on my GT project. After a long delay while waiting to clear garage space, I sold my 1970 911E restoration and moved the 914 from the basement to the garage and onto my lift. The car is now stripped to a bare shell. After consulting with Ken (body shop manager & co-owner) at Auto Associates, we have decided to send the shell out to be dipped, stripped and E-coated prior to starting the chassis restoration at Auto Associates.
Ken recommended a shop in Livonia, MI that does a multi step process consisting of:
1. Hot tank cleaning dip
2. Pressure wash to remove all dirt, gunk and paint
3. Acid dip to dissolve all rust
4. Neutralizing dip to stop the acid process
5. Epoxy primer for rust protection
The hot tank cleaning dip will dissolve anything that is not steel on the shell. This would include the longitudinal heater tubes. So we have decided to cut out the inner longs prior to the dipping and then replace the heater tubes and the longs as part of the chassis restoration. This should give us a chassis that is completely devoid of any rust and is also protected against any further rusting.
This will require an 11 hour one way drive from my home in CT to the shop in MI. I have searched and tried to locate a shop closer to my home that offers the cleaning, de-rusting and E-coating but have not located one. If anyone knows of a shop within a 6 hour radius of Hartford, CT that offers this process, I would be interested in checking them out.
As long as that trip will be, it will be well worth it once you begin chassis work, metal work, etc.
There’s a chemical strip shop west of Harrisburg PA. 3S chemicals llc. They quoted me ~ 3k for my 912. 3-6 month wait and 1k deposit. I ended up shipping the car to - pro strip Indy in Indianapolis IA. They had a good rep from people I know and I was very happy with their service. They charged $2300 and took 2 weeks once they received it. The other reason I sent it there is because there is a company near by that e-coats the chassis in a tank. Both companies have been great to deal with and only take money when the job is done.
If you chemically strip a chassis in a tank, I believe you need to e-coat it in a tank. The chemical strip removes everything including every bit of metal protection in between the seams and in all the hollow chambers. There’s no way to coat the metal between the seams unless you dip it. Normal paint is too thick. Cavity wax will coat the cavities but only a thin liquid like they use for e-coat will actually get between all the seams. At least this is what I have read, researched, experienced first hand on other cars and have decided is the right process. I also believe the past problems with chemical dip “leaking out of the seams” month later is not actually chemical leaking but moisture attacking the bare metal and rusting it. Chemically stripped metal starts rusting immediately, even neutralized, because it’s bare metal. The only way to protect it is to dip it again to get to all the metal that is raw.
So to get back to my car, the 912 is at the Ecoat place and should be done by the end of the week. It’s a 12 step process to clean the metal of all the flash rust and then e-coat. The chem dip exposed some additional corrosion but we’ll fix it when it gets home. The e-coat process is ~$3,500 and it was $900 each way to ship and $500 to ship between shops. Not cheap at all but I want a solid car that I can trust not to have issues down the road. I wouldn’t have minded trailering it out but having to make a second trip to pick up means I really wouldn’t have saved any money when all was done. Plus that’s a lot of time to make two up and back trips.
The thing that was in my favor on the early 912 is it has steel heater tubes. After 67/68, Porsche moved to the paper tubes.
Tom, Like most people here, I can’t wait until next update, keep them coming
[quote name='ClayPerrine' date='Apr 15 2022, 09:23 AM' post='2995420']
[/quote]
[/quote]
Nope
Not silly
Actually smart
[/quote]
Clay
[/quote]
yep
my business partner has been riding motorcycles for 40 years.
high powered high end italian bikes.
never gets on without full leathers, boots and full face.
he has hit the deck several times. and has always gotten up intact!
whenever i ride around in the car with him he is always commenting on the delicate asian university students getting about on motor scooters around here, in sandles, t shirts and non full face helmets. his standard remark, she might look pretty now, but she isn't going to be attractive with only half a jaw.
i can still remember my time in chicago. guys on big harleys and gold wings would thunder past with no helmet and wearing a t shirt. on the interstate.
used to blow my mind. not in a good way.
seat belts are not even debated in australia. its been mandatory to have them and to have them on since the 1960s. no big deal. but each to his own i guess. i am surprised to hear its law in texas as i can still recall all the hoo haa in the USA in the late 80s over compulsory seat belt laws. as far as i can remember you guys did not have those laws back then. i remember the cars with those wacko auto seat belts that ran on tracks around the heads of the doors. i laughed every time i got in a car with those things.
you need to pad cages inside a car. even on the track. at least down here. no such thing as an unpadded roll cage in this neck of the woods. street or track.
@http://www.914world.com/bbs2/index.php?showuser=10825 - Mark, I love that you are preparing that chassis to last forever. The end result will be a stunning example that will age perfectly. A bit of cash up front, but well worth all the effort and expense in my opinion. Cheers, Michael
Just got done e-coat
That is really cool Mark.
What happened to the guy building a GT tribute 914?
I got to “I’m dipping it”
I’m at that decision, so please update the choice, Heater tube solution…and how things are going with the 914 please.
Rich
The shell has been stripped and mounted on a custom cart for transport. The car will go next to Auto Associates where the inner longs will be removed along with the Al heater tubes. In addition, they will install longitudinal braces. Then the shell will be shipped to International Paint Stripping in Romulus, MI. They are the closest shop that does the Hot Tank/Acid/E-Coat Dipping all under one roof. Once the dipping has been completed the car will go back to Auto Associates for the chassis restoration and GT conversion.
[quote name='Tom1394racing' post='3038974' date='Nov 1 2022, 01:14 PM']
Be sure to let us know how it goes. I am very interested in the process.
Good luck.
Since my last posting, the external longs were opened up and the heater tubes removed. Stiffening diagonals were also installed and the car was shipped to Livonia, MI for the triple dip process.
Inner longs don't look too bad and the heater tubes should be reusable.
Have to wait and see what it looks like after the dip. Sometimes it's just light corrosion, sometimes it's swiss cheese.
JR, not sure what you are hoping to accomplish spraying muriatic acid (HCl) on your car. It will not strip paint or any other typical automotive coating. It could remove rust but it will most likely cause more damage than it will prevent or remove. It is also a very corrosive material to healthy steel not to mention living tissue.
Actually the whole term " acid stripping" is a bad misnomer. Immersion paint striping is actually done in alkaline solutions, not acidic ones.
Most rust removers are based on phosphoric acid. It is much less aggressive on clean steel (and human tissue), has some preference for attack on iron oxide and leaves a phosphate coating on clean steel that provides some flash rust protection and enhances paint adhesion. It does not remove coatings including oils and greases.
Not a chemist (maybe you are) but have a lot of real world experience using organic acids and metals and.... I have stayed in a Holiday Inn Express.
rust 911 appears to be a chemically engineered phosphoric based product.
The chassis has now completed the dipping/E-coat process. One of our fellow 914 World members was kind enough to drop by the shop in MI to snap a few pics. It will be shipped back to me in the next week or so. So far I am pleased with the overall process. More to come once I get it back home. Anyone who would like details on the shop, please PM me.
I just talked to Neil the other day. Our cars might come home together.
Yes Mark...I spoke to Neil this afternoon.
We had to take your car off the truck to get to mine. So it’s touched ground in Landenberg PA for a moment. Then back on the truck.
Had to pull mine up my hill to get it into the garage.
Mine is back home as well. I am pretty happy with the overall process. Car looks really clean but now all the nasty sins have been exposed.
Here are some examples of the nasty hidden sins that will be corrected by Auto Associates
After the extensive rust repair, the GT conversion punch list for Auto Associates looks like this:
1. Longitudinal stiffening -inner-longitudinal-stiffening-kit
2. Front sway bar reinforcement
3. Chassis stiffening - GT-chassis-stiffening-kit
4. 914-6 bulkhead motor mount
5. Rear suspension pivot point reinforcement
6. Front cooler ducting & cooler mount brackets
7. GT style roll bar with sill diagonals
8. Bulkhead access panel
9. Steel GT flares
10. Fiberglass/Balsa reinforced F&R lids
11. Through holes for oil tank & oil cooler lines
12. Modify front lid and gas tank for through lid gas fill
13. Firewall seatbelt anchors
14. Oil catch tank holding bracket in rear trunk
The dip and e-coat make the good metal look really clean and the bad metal look terrible. I’m sure it will all look great when you are done. At least you didn’t not have to worry about flash rust while waiting on paint.
We replaced a lot of body panels on my car but there are still some touch ups before paint.
Update - The car was delivered to Auto Associates last week along with the chassis stiffening kits and bulkhead motor mount from Mad Dog. First up will be rust repair. This will be followed the GT chassis stiffening and GT mods with the exception of body panels and flares. The plan is for the car to come back to me for mechanical and electrical reassembly before installation of the doors and flares and final paint. Ken (co-owner and Body Shop Manager) would prefer to have wheels and tires mounted to properly install the flares. He also prefers to have the chassis weighted with gearbox and engine to set the door gaps.
[attachmentid=873438]
[attachmentid=873440]
The rust repair has started with removal of the rusted firewall, 4 cyl engine mounts and the improper repairs to the hell hole area. Luckily, Ken was able to source a NOS replacement firewall panel.
Oh, this is going to be fun to watch.
So the plan for the car is as follows:
Engine
3.2 Short Stroke based on a '78 SC long block
10.5 CR, 98 mm Mahle Motorsport P&C set
JB Racing twin plug dizzy
DC 60 cams
PMO 46 Carbs
Ben Mcfarland heat exchangers and oil tank
Mocal front cooler with Patrick Motorsports front cooling duct
Gearbox & Clutch
Rebuilt stock 914 side shift with Aluminum intermediate plate
Kennedy Engineering 915/901 clutch conversion kit
Front Suspension
Late model 911 Bilstein struts
911 front a-arms
19 mm Sway Away torsion bars
Bilstein HD shocks
Stock 16 mm front sway bar
914 Steel front crossmember
911 vented discs
Rear Suspension
Ground Control adjustable rear coil overs
150 lb Eibach springs
Bilstein HD shocks
Stock 914 calipers
911 non-vented discs
Sway Away custom axles with 108 mm 911 CV's, hubs and stub shafts
Wheels & Tires
Front - Minilite 7X15 with Michelin TB 15 18/60R15 tires
Rear - Minilite 8X15 with Michelin TB15 23/62HR15 tires
Cockpit
911 steering column with 911 switches
911 ignition switch
Custom 3-way oil temp/press/fuel level gauge
380 mm hockey puck steering wheel
GTS Classic Lemans seats
Color
I have been wrestling with different color options. I had settled on Lizard Green (2019 GT3 color). Then this week I saw a new Speed Yellow Cayman GT4. So for now the color will be Speed yellow.
Looks like a great combo.
Maybe think about M calipers on back with 911 e-brakes and tangerine conversion kit. Not very pricey, especially with your parts supply and would compliment the front brakes.
Wow- that 3.2 combo is going to produce a very nice engine that should pull strong to 7K easily.
Looks to be a formidable machine. Best of luck. Will be following.
Here are some photos of the repairs in the rear bumper mount area
Thanks Tom for the updates. Looking at the metal repairs makes me smell welding fumes...mmm. Time to head to the shop to work on the 6.
Have you started on the engine yet?
More progress on rust repair at Auto Associates. Engine bay L&R (hell hole) side rust repaired. Heater tubes reinstalled and outer longitudinals being replaced. Interesting note on the acid/e-coat dip. We have found some spots where neither the acid nor the e-coat penetrated. Fortunately, these areas also had only light surface rust.
I was able to find some good replacement panels. A LHS sail/rear quarter at Carlisle and a rear panel from our friend Chris Foley. We will use only the taillight section of the rear panel. However, if anyone has a good RHS sail/rear quarter panel like the LHS I found, we could make good use of it.
Front fender well repairs are also completed.
In the meantime, the original '73 side shift gearbox has been rebuilt with a billet Al intermediate plate and 108 mm output shafts to mate with sway away axles and 911 108 mm CV's. The intermediate plate was drilled and tapped to accept the 914-6 throttle bell crank. The gear box will also get the Tangerine Racing precision shift coupler.
Rust repairs are continuing at Auto Associates. I thought it might be useful to post more detailed photos of the process. Here are repairs to the right front corner.
Thanks for taking the time to post all these pictures, watching the progress is really fun. Your cookbook sounds great, can't wait to see it all come together. BTW, I know the green color that was your first choice - I would vote for that!
Here are the repairs to the RHS outer longitudinal.
Intense restoration on the chasis. Love it.
WOW! Going deep on this one.
Here are the repairs/replacement of the rear floor jack points.
All of the prefabricated replacement panels used so far have been supplied by Restoration Desing and have fit nicely.
While the chassis rust repair has been ongoing, I have been restoring and procuring the mechanical bits.
Rear springs and shocks. Ground Control adjustable 150 lb coil overs with helper springs and Bilstein HD's
Restored headlight buckets with MittleMotor GT release kit. Auto Associates will do the welding and cutting and test fit in the headlight area before paint.
Bilstein front strut with HD inserts and PMB restored early S calipers.
Rust repairs are continuing at Auto Associates. Here is the repair of the L/F bumper support.
The front lid headlight and trunk seal channels also needed repair. Here is the L/F headlight seal.
Also, the rear floor in the front trunk compartment needed replacement.
Moving right along; nice work.
Great progress and clean work
Antoine
Fantastic, you have to love new shiny bits!
Nice job on those bumper mount areas! I just did mine a couple months ago and it’s a pain in the ass place to work, there’s really no room in there.
I love the hellhole repair method.
Step one: remove firewall.
Great work
Rich
The car is now on the rotisserie and Mad Dog's chassis stiffening parts are being installed.
Meanwhile I am continuing to restore the components and getting ready for reassembly.
A few more pieces restored and ready for assembly. The axles are the Empi free floating with '69-'73 911 108 mm CV's. These will match up with the same size rear stub axles and differential output shafts.
Coming along very nicely... great work.
You might want to add the fuel pump cut out in the frunk while your at this stage
Really like to follow your progress, that is going to be one really cool 914!!
Antoine
A few more restored parts ready for reassembly.
Gauges from North Hollywood and steering rack for 914 Rubber.
Rear trailing arms along with '69-'73 911 rear hubs and stub axles.
These parts are too dirty to install. I think i saw a spec of dust on one the gauges...
911 A-Arms and 914 crossmember. Elephant racing rubber bushings all around, front and rear.
Great work.
Meanwhile at Auto Associates, Mad Dog's stiffening kits have been installed.
Good work!
Antoine
Restored dash from Just Dashes arrived today. Looks flawless as you would expect from them.
Fuel tank has been cleaned, sealed, pressure tested and painted. I may decide to give it a final satin black coat before install.
The dash looks terrific Tom, what was the cost and turnaround? Any fitment issues?
Work of this quality and detail makes me want to barf. You are doing a way too nice job on everything. It is going to be great!
Charlie
46 mm PMO kit. Once I get the case back from Ollie's, I can start the engine build.
[attachmentid=885738]
Soooo nice, restored to new (or better) state. Want to finish my car
Bottom side rust repairs and chassis stiffening had been completed and the repairs dressed and e-coated.
Front and rear trunk compartments. Still to do:
1. GT Roll bar from Tangerine Racing
2. Front cooler ducting
3. -6 Engine mount from Mad Dog
4. Shoulder belt anchors on firewall
5. Engine access panel on firewall
6. Rear suspension pivot point reinforcements
7. Through holes for oil tank & oil cooler lines
8. Front truck mods for Mittlemotor GT headlight cable release system
9. Modify and install 911 steering column
10. Paint bottom side, both trunks and cockpit in Lizard Green
The car will then come back to me for partial reassembly including electricals, engine and gearbox, suspension and interior components. Then back to Auto Associates for mounting of the flares and final body and paint.
Installed the Tangerine Racing side shift bracket on the gearbox yesterday.
Last Friday I had the pleasure of visiting Rory Gallagher (rgalla9146) to pick up a set of NOS rear quarters and front fenders and look over his pristine GT clone. It turns out that Rory also had an original 914-6 throttle bracket. I will be using the rear quarters and the throttle bracket for this project and the front fenders will be for sale sometime in the near future.
[attachmentid=886987]
Project moving great,thanks for sharing !
Antoine
Rory has some great treasures along with invaluable knowledge. His build has a bunch of special features that he’s helped me make aware so I could steal borrow.
Balsa reinforced front and rear lids from Getty arrived last week.
Nice, steady progress Tom... final product will be worth all the effort.
I went looking for Armando's GT Build he featured on the Pbase site. It seems to have been removed from the site, but after poking around it's still there; here's the link:
https://pbase.com/9146gt/the9146gt
I always liked the oil cooler reinforcement he did here:
https://pbase.com/9146gt/the9146gt_front_oil_cooler_install
He also did the windshield frame reinforcements that you rarely see:
https://pbase.com/9146gt/my9146gt_windshield_frame_reinforcements
The Pelican site GT build thread is here:
http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/632760-last-new-914-6-gt-project.html
Seems like he ran out of steam on the project around 2014.
I talked with him on the phone several times while buying parts he was offering in the 2018-19 time frame. We did not specifically talk about what was going on with his build.
He had a boatload of Porsche racing parts - a lot of engine stuff for 906's etc. maybe somebody made him an offer he couldn't refuse?
Hi Tom,
Project looks good. I see you went shopping at Rory's place. He has a pretty good stash of nos parts. I sold him the chassis that he turned into the GT clone. How I wish I kept that one.
One thing you may want to do is remove that blower fan bracket on left engine shelf. It'll get in the way of installing/removing the oil filter. I ran into that issue on my brothers 6 conv but didn't find out til after the engine bay was painted...
Things are moving forward quickly at Auto Associates. Here is the engine access panel along with the center mount for the GT roll bar.
The front cooler reinforcement has been added and the cooler & ducting test fitted.
Also, the early 911 steering column has been modified to fit the 914 chassis.
Tom
Your work on this gives me indigestion………it is above and beyond great! Process shows a level commitment I’m having trouble finding.
Question……
What was your procedure for restoring plastic parts of ventilation system?
Thanks,
Terry
Tangerine Racing GT roll bar installation in process. This will be welded in and will get diagonals from the bar to the inner longitudinals.
Rear quarter prepped for installation of the NOS quarter panel.
Sergio's GT engine lid with the diagonal removed for a more authentic GT look.
Fantastic project and thanks for sharing the details with us!
Antoine
Another trip up to Auto Associates today to check on the project. The chassis is getting some final touch up before another coat of epoxy primer, then light undercoating on the floor bottom and backsides of the inner fender wells. Then the undersides, front trunk, engine compartment and rear trunk will get final paint in Lizard Green. After that, sometime in October, the car will come back to me for mechanical and electrical assembly including the engine build and installation. The plan is to get the car in running condition before it goes back to Auto Associates for final body work and paint including the installation of the GT flares, both trunk lids and doors. This will ensure the flares are properly aligned with the wheels & tires and the door gaps are set perfectly.
The doors and NOS rear quarters have been primed. The "Dent Magician" will make sure all the panels are perfectly smooth.
The engine lid is getting some final touch up and the GT Roll bar is awaiting the installation of the longitudinal diagonals.
The rear suspension pivot point reinforcements have been installed. The support rods are adjustable and removeable.
The kit for the through lid fuel filler funnel had arrived.
We also had to move the wiring harness through hole in the engine shelf to align with the Mad Dog engine mount.
Here are the front through holes in the front trunk and cockpit for the oil lines to the cooler.
Making nice progress; looks like it is going to be an epic build.
connect the holes = oval....be happy
BTW, you'll want one of Ben's @http://www.914world.com/bbs2/index.php?showuser=9892 very tidy oil line covers:
My engine parts came back from Ollie's yesterday. Nine months turnaround time. Now I have almost everything to start the engine assembly.
Cam towers and valve covers. Lower covers were drilled for twin plug, and the ribs were milled to allow added clearance for ease of removal. Both upper and lower covers were tumbled and resurfaced. The cam towers got new plugs and spray bars and were also tumbled.
Connecting rods. The rods were inspected for damage, resized and re-bushed. These will get new ARP rod bolts.
Chain boxes and covers. These were cleaned, tumbled and re-surfaced.
Most important...The crankcase. The case was inspected and resized to std. Through bolt holes were spot faced, oil squirters were cleaned and replaced as needed, the oil plugs were replaced, and the case was tanked and tumbled.
That engine case and those parts look beautiful; going to be a great engine.
Great project! And some beautiful work.
More progress at Auto Associates. The NOS rear quarters have been welding in place and have made a beautiful repair. Also the engine lid release cable tube has been modified for the GT type release.
The MittleMotor manual head light release parts have been added. I will tweak these and get them working once I get the car back at my place.
Another trip up to Auto Associates today. More progress. The hood & fuel filler have been fitted and the final pieces for the headlight kit have been welded in place. Next up will be paint for the bottom, front & rear compartments and cockpit. Then delivery to me for interim assembly.
It looks a lot different from what I saw in your garage a year ago Tom.
Amazing progress. One of the prettiest things is a chassis coming together for body work and paint.
Great progress, thanks for sharing !
Antoine
Tom were those dents in the rear fender ?
This is looking so good. Well done on the progress. Like the details you are doing. That engine should be quite strong now. Peace of mind doing what you have done. So nice.
The Phase I rust repair and chassis stiffening is now complete at Auto Associates. The car is coming home to me for the Phase II assembly work before going back to Auto Associates for final, phase III GT body work, roll bar installation and paint. The color is Lizard Green.
My plan is to start with the electrical first. I will be installing a new 914-6 wiring harness. I plan to get all the lights fit checked and working using my 12V DC power supply. Then I will install the front crossmember, rebuilt steering rack and converted steering column along with the dash to allow completion of the wiring for the T/S, wipers and gauges. After that, I plan to install the front and rear suspensions as well as all the through tunnel fuel lines, brake lines and cables.
The final step in phase II will be the engine build and installation. Ideally, I will have a running chassis before the car goes back to Auto Associates for phase III. My target for phase III is late spring 2024.
Any constructive comments or suggestions on the plan from those of you who have down this road before will be appreciated.
Love the color!
Great color!!!!
Nice progress!
Looks great. Very nice
Now that I have the car back home, time for phase II reassembly.
My original plan was to start with the wiring harness, When I unpacked the brand new 914-6 harness from Restoration Design, I found that they had not relocated the fuel pump wiring to the front trunk for the GT dual front fuel pumps as we had discussed. Peter at RD was very helpful in agreeing to expedite return shipping and correction of the harness at no cost.
In the meantime, I decided to begin installation of the front suspension, in particular to check to ensure the modified early 911 steering column would fit and work with the rebuilt 914 steering rack. No problems here...Butter smooth turning action. Note the Momo steering wheel is only temporary as I have a good 380 mm original style wheel I will be using once completed.
So what is the deal on the thru hole for the steering rack shaft? It seems there should be some type of grommet to close up the hole?? I could not see anything on the parts diagram. What do we do about this?
Looks great!
Tom the black collar/bearing that slips over the first shaft on the rack should press
against the tank side of that hole. I has a small lip to form a seal there.
Could it be reversed ?
I think you'll have to lower the rack/crossmember
It is not the bearing it is the collar above it.
Calling @http://www.914world.com/bbs2/index.php?showuser=865 !
I bet he has 100 of them
91434770601
I emailed Garold to see if He has any of these. I am not inclined to disassemble the front suspension to slide this on to the streeting column. I bet I could split it and fit it over the end of the column and then glue it back together with weather stripping adhesive.
I looked around my shop but didn't find one. I'll take a look around my garage too.
No luck on finding a replacement steering shaft bushing/seal so I improvised and tried a rear shock top bushing pair. The ID matches the steering shaft pretty close and closes up the hole nicely. Since I had gone ahead and completed the front suspension, I split the lower side of the bushing and fitted it over the steering shaft. Seems to work OK.
Next I will move to the rear suspension while I await the corrected new wiring harness from Restoration Design.
With the front suspension together and torqued to spec, I moved to the rear suspension.
Yesterday I installed the rear bearings and hubs in the trailing arms and proceeded to install the RHS arm, shock and brake rotor.
All seemed to going as planned until I tried to install the brake caliper. A significant misalignment problem.
It seems like the rotor is a good 1/2" too far outboard to align with the trailing arm tabs and the caliper. The combination of parts is:
'69-'73 911 hubs and stub axles
Early non vented 911 rotors with the diameter trimmed as recommended
Stock '73 914-4 rear calipers
I based this combination on recommendations from our members with previous experience.
http://www.914world.com/bbs2/index.php?showtopic=363935&hl=
I was not expecting a problem. Any suggestions? I am stuck at this point.
Tom if I remember correctly the hat of a 911 rotor is shorter than that of a 914 or
914 6.
Also, if you intend to run dust shields the bracket has to be included.
Tom,
You'll need the 914-6 rear rotors as the 911 offset is different.
If using the 914-4 rear calipers you have to turn down the o/d of the rotor to clear the caliper. Pretty sure that's how it all works together. Maybe Eric can chime in on this to confirm.
I have a sets of 911, 914-4, 914-6 rotors around. I'd have to dig them out and see what's off with all of them.
Otherwise looks good.
Luke and Rory
Thanks for chiming in. I was aware the solid rotors needed to be turned down 3 mm. I did that to these rotors. I did not realize that the 914-6 rotors had a different offset as compared to the 911 rotors.
The 911 solid rotors I am using have an offset distance (from the inside mount face to the inside friction surface) of around 62 mm.
Luke or Rory....If either of you could check the offset on your 914-6 rotors, that would be most helpful.
Another update...I checked the P/N on my rotors and found that I am using the SWB 911 version of the solid rotor (P/N 901-352-401-10). I was advised that the LWB version of the solid rotor (P/N 901-352-4-1-17) for the '69T and 912 would work. I am guessing that this rotor has the same offset as the 914-6 and is very different that the SWB rotors I have now. I do not have one of these in my stash to check.
Having solved the mystery with my rear brake rotors, I went on the complete the rear suspension minus the brakes.
So now I need a pair of non-vented rear brake rotors. I think either the 914-6 rotors or the '69 911T or 912 rotors will work. I think the 911T/912 rotors will need to be reduced in OD by 3 mm. What is the difference between these and the 914-6 rotors?
Anyone have a NOS pair to sell?
Hi Tom, I have a new pair (but need to doublecheck tonight that they are true 914-6). Do you ever get near north of boston? These are heavy to ship
OEM 6 rear rotor no provision for ebrake shoes.
Sorry Tom, no spares to sell.
As luck would have it, I was up in the Boston area this weekend visiting family and was able to meet up with Mark. He sold me a nice NOS set of 914-6 rear rotors that fit my hubs, calipers and trailing arms perfectly.
I will clean this up, reinstall, torque down the suspension and move forward.
Thanks for all the help and suggestions!
dust shield bracket ... thickness ...missing
I figured out my rear brakes and got the spacing correct with thin washers instead of the dust shields. Fitted a set of SWB 911 drilled pads to the LHS but the RHS inner caliper piston needed adjustment to slip the new pad in. As luck would have it, no inner adjuster gear in the caliper. PMB did the brakes. Called them, no explanation why, but they are sending me near gears.
In the meantime, my corrected, new 914-6 wiring harness came back from Restoration Design. Thanks to Peter who corrected it for the front dual fuel pumps and had it back to me in less than 2 weeks. I am very happy with the quality and workmanship on this harness. The installation YouTube video made it a breeze. I am in the process of finalizing the exact placement especially in the front trunk where the original wire routing will clash with the oil cooling system.
Outstanding progress; that is going to be so beautiful.
More wiring pics. It seems like every factory GT did things a little differently with regards to the front trunk wiring.
Looking great, I love the color and feel like I need a bright green car in the stable.
Wow, paint looks beautiful, you are doing a first class job! I also love the color, perfect for a -6.
Sweet ! really like the car without seam foam sprayed all over the place. Supper
Tom - did you use seam sealer on the car or are you leaving it bare?
Car looks fantastic! Colour pops against the parts being added. Yes i'm sure there is a significant lack of seam sealer on the R cars as weight saving was the name of the game.
cheers
Had a chance to spend a few hours on the car today. I fit the front turn signals and rear taillights. These will of course be removed before final body work and paint but I want to complete and check out the electrical system first.
I installed the front headlights and then decided to fit the mechanical GT headlight kit to make sure I had all the pieces and understood how to make the system work. I had purchased a partial kit from a member of our board but it was missing all the wire cables, a couple of the cable barrel keepers and any assembly/installation instructions. The detailed photographs provided by Armando Serrano in his epic 914-6 GT posting on Pelican saved my butt and more than made up for the lack of instructions.
I used spare 911 hood release wire cables that I have in my stash of parts and was able to fabricate the missing cable barrel keepers for the cable splitter. It was a trial-and-error process with many assembly/test/disassembly cycles before I finally managed to get both headlights to lock and release.
Wow...I can't believe it has been a month since my last posting. Holiday get togethers and a post-Christmas bout with Covid kept me away from the car for a few weeks.
Since getting back into it, I have focused on the electricals for the dash switches and gauges. The detailed wiring diagram provided by Restoration Design that came along with the new harness I purchased from them is making the job much easier. Next up will be the turn signal/high beam switch and the wiper switch. I expect that I will need to make up some custom harnesses to make the connections from the 911 switches I am using to the 914-6 harness.
One question for the experts....I have (3) wires that I have yet to identify. I circled these in the last photo. I am guessing that the red wires are unswitched power leads for things like an alarm system or a clock. The single black wire is a mystery to me. Behing the black wire sheath are twin brown leads that do not connect to ground. I do not see them in the wiring diagram and I can't trace them to the fuse box. Any ideas what these are?
What's the best way to re-attach the gauge wiring. Mine sure looks like a rats-nest of wires after removing them for rebuild.
Tom - just found this thread and "binged" through it. Excellent build and great color choice! For my own GT build, I chose Gelbgrun as a color, not too far from Lizard green I suspect.
The pix of the metalwork alone was complex enough and made me thankful for how solid my starting point was on my build. Keep the posts coming!
- Tony
I found the insulator block in my stash and installed it. All good now with keyed power to the switches and gauges. I also realized that the black wire is for the door switches.
Thanks All!
Finally finished up the electrical wiring today. As always, one of the more challenging tasks to get everything to function properly. The job was pretty straight forward with the new 914-6 harness and wiring diagram from Restoration Design. The most challenging part was creating a custom harness to mate the NOS 1969 911 T/S switch to the chassis harness. It took several days of head scratching and studying the wiring diagrams to get it right. I had a nice, bare 12 pin connector and 6 pin plug in my stash that allowed me to create a mating harness without having to modify the 911 T/S switch. It looks ugly but it works. The 911 wiper switch was straight forward plug and play into the Restoration Design 914-6 wiper harness.
Next up will be fitting and possibly modifying the 911 clamshell to fit the steering column and dash.
I did a trial fit of my 911 steering clamshell onto the 911 steering column today expecting that I would need to modify it to fit. Many of the threads I have read mentioned modifying both the top and bottom sections. I found that the clamshell fit nicely without any need for modification. I am guessing that the dash trim fascia plate will need some trimming to clear the bottom of the clamshell or that there may be a problem with interference with the dash kneepad. Am I on the right track with this or am I missing something?
Well.... I found out, as did many before me, that the 911 clamshell interferes with the dash facia plate and the knee pad. I ended up having to trim the fascia plate and the bottom of the clamshell to get everything to fit properly.
Tom,
I missed why you swapped to a 911 steering and clamshell?
Very nice. Love the color
Tom looks good. I need to revisit this on my car. It’s time to finish up some things I saved for later. Well it’s later.
Moving forward, I started the install of the oil cooling system. After some persuasion and fitting of weather stripping, I got the ductwork to fit over the chassis reinforcement bar near the inlet cut out and seal up nicely. I'll be using some stainless steel mesh screen to cover the outlet in the floor.
I am using two 11 foot sections of 12AN steel braided hose to run from the cooler to the T-stat. This seemed like the simplest solution and the hoses fit nicely in the enlarged openings in rocker sill brackets. I’ll be using a Mocal T-stat located somewhere in the lower RHS of the engine compartment.
Very clean
My seats from Stefan at GTS Classics finally arrived yesterday. They are the Spa Francorchamps model. Well worth the wait!
Hi Tom,
The Gt project looks like is coming along great.
Question about the front oil cooler install.
Are you using the PMS/Setrab oil cooler kit?
It looks like the cooler itself is mounted to the upper cooler housing (per post #192)
is that correct? Reason I ask is that I've seen it where some coolers are mounted to the chassis side vs the cooler cover. I purchased a steel replica GT oil cooler cover made by Mittlemotor in Germany to use on my 6 project. I never really saw a full install of this cooler setup being installed from start to finish. I've installed a cooler in my brothers 6 GT but mounted the cooler to the chassis side. I did use rubber insulators on my brothers cooler mounting points but still feel like that wasn't the correct way to do it.
I'm just wondering which way would be best or the correct way to do the install.
Thanks,
Hi Luke
The cooler is a Setrab 464 that I purchased from BAT. The cooling shrouds are fiberglass from Getty.
The cooler is bolted to a custom mount bar that then bolts to the top FG shroud.
Fitting this system to the chassis did present somewhat of a challenge as the added stiffness bar behind the cooler opening did interfere with the lower shroud. The FG construction did allow the lower shroud to be bent over the bar. The resulting gaps in the fit between the upper and lower shroud were filled with weather stripping form Home Depot.
After some adjusting of the seat rails, I was able to install my new seats from GTS Classic. They look and fit great especially with the 380 mm repro steering wheel and new retro Repa belts.
Car looks great Tom! I wish I was this far along...I should have it back from paint next month and I can start the reassembly process.
Tom - I went for a similar plan & routing for the oil lines to/from the cooler; flexible AN lines from the thermostat (rear LHS in my build) up the rocker panels and popped through to the frunk. Less in-line connections to fail/weep than the hard lines.
Nice seats BTW! Keep the posts coming,
- Tony
Production sixes had the black goop on the front strut towers for water ingress; in the photo records, I have noticed NO goop on any factory built GTs. FWIW,
- Tony
Love the seat choice
Seats are looking fantastic!
Antoine
Time for another update. Lots of distractions the past couple of weeks have kept me out of the garage.
Since my last update, one of the seats had to go back to Stefan for a headrest correction. I have to say that he was very responsive and turned the seat around very quickly.
I installed all the tunnel lines, cables, the Tangerine Racing shift bushing, the pedal cluster and the brake system. Just waiting on the rear soft lines and some crush washers to complete the system and do the bleeding. I was pleased to see that all the components seemed to fit nicely around the Mad Dog engine mount.
With the electricals now sorted, next up I plan to remove the metal dash, paint the cowl area satin black, complete the dash fascia, install the restored dash top and reinstall the dash. Once those tasks are complete, I plan to build the engine.
Looks super clean.
Is this for the tangerine kit?
I am planning to use Ben McFarland‘s kit for the engine oil lines. The case suction line runs around the back of the engine and over the gearbox to the thermostat. Just like the Early 911. I’ll be using a Mocal thermostat . I know it’s a little tricky making some of the connections to the oil tank. My plan is to mount the engine first and then finalize the locations of the thermostat oil lines, CD boxes, coils, fuel lines, and throttle cable.
Another update.
With the electricals mostly sorted out, I decided to remove the dash and install the dash top and dash facia off the car. Everything I've read and seen says it much easier to install these on the bench. The dash top is the original that was restored by Just Dashes, Very nice. Since I am going with the GT look without the glovebox door and radio, we removed the lock surround on the dash and I fabricated a radio delete plate.
I also painted the dash cowl while the dash was out.
Had the chance to spend a few consecutive days in the garage this week working on the 914.
I reinstalled the dash, reconnected the gauges & switches and rechecked the electricals. All good.
I then focused on the ventilation system. A lovely control panel from Dion arrived last week and found a home on my restored dash. I also installed the control boxes and cables following the great writeup from ElectroClassics EV.
https://914electric.wordpress.com/2011/03/18/take-the-heat/
I had to belt sand some of the plastic surface on the bottom of the LHS control box to get it to fit without too much force. Now I am looking forward to the control box holding clips courtesy of John Hora
The challenging task of installing the fan and fresh air plenum will wait until after the car has been painted to avoid any overspray through the cowl grills.
Looks fantastic! Just curious why the wipers were installed before paint?
That looks beautiful Tom; great work.
The Dash looks awesome!
Just beautiful work.
One of the best colors
I finished installing the seats & dash and then put the car on roller wheels & tires for some photos. Starting to look and feel like a car again. Next up will be the engine build.
Wonderful seats!
Antoine
A few odds and ends before starting the engine build.
Made the AN connections to the front cooler. Also installed a pair of aftermarket horns (you can't see them through the grills...Right?). I also found a nice pair of Hella TN4's in my stash and installed them as well.
Started the engine build this week. As a reminder, the engine will be a 3.2 short stroke base on a 3.0 SC case and crank. I will be using new 98 mm Mahle Motorsport 10.2 CR P&C's along with a JB Racing twin plug distributor and DC-60 cams from John Dougherty. The case, rods, cam towers, chain boxes and valve covers all went to Ollies for refurbishment. The heads were rebuilt and twin plugged by Bob Hirst at Anchor Atlantic and the SC oil pump was blueprinted by Glen Yee Motorsports. The crankshaft was cleaned, crack checked, cross drilled and micro polished by Armando at CCR. At Armando's recommendation, the main bearings were coated by HM Elliot to bring the main bearing clearances into spec. Induction will be 46 MM PMO's.
The first order of business was to check the main bearing clearances. I used plastic gauge and found the clearances were all between 0.002-0.003" right on target. I then reinstalled the crank without the plastic gauge and check for smooth even crank rotation. All good here as well.
I moved on to check the rod bearing clearances. For these I used the dial bore gauge rather that the plastic gauge. I am using coated Clevite bearings from Auto Associates for the rod bearings. I installed the bearings in the rods, torqued them to spec using the old rod bolts and then measured the inner bearing diameters with my dial bore gauge zeroed on the average rod journal. Clearances measure between 0.002-0.003". Right where they should.
I then decided as a verification double check to weight each rod. I was not expecting any significant variation as they had been refurbished by Ollie's. To my surprise, one rod was heavy by about 10 grams. I removed the bearings and reweighed them and the results were the same. So goes the old saying, "Trust but Verify".
Needless to say, the rods are on their way back to Ollie's who promised to expedite and rebalance them at no charge.
Odd question for you - about your crank from Armando - I see the tag, but does Armando etch or otherwise permanently mark either crank end with any markings?
I have a motor supposedly with one of Armando's cranks and would see if there is a way to verify.
With the rods back off to Ollie's, I moved on to inspecting the pistons and cylinders, Installing the rings on the pistons and installing the pistons into the cylinders.
Everything checked out nicely on the P&C inspection as expected for a new Mahle set. Minimum variation in piston weights, good cylinder bore roundness and minimal taper Also good piston to cylinder clearances.
I then installed the piston rings and very carefully installed the pistons in the cylinders.
I continued on the engine build while waiting for my connecting rods to come back from Ollie's.
I checked the IMS backlash to make sure it was within acceptable limits. I got 0.05 mm movement on the dial gauge.
I then moved on to check the compression ratio using my CC burette volume checking setup. I checked each freshly rebuilt cylinder head to find the combustion chamber volume. All (6) measured between 89.5 and 90 cc's as expected for a 3.0 SC cylinder head. I then checked the piston dome volume using the same system and found piston #1 to be at 40 cc just as expected for this particular Mahle Motorsport piston. I only checked one piston assuming that the variation between brand new Mahle pistons will be insiginificant. Assuming I get 1 mm deck ht once I seal up the case and check, this will result in my target CR of 10.2:1.
