Posted by: robkammer Mar 18 2022, 12:49 PM
Hi Teeners. For those of you who have seen everything 914 related, please have a look at the hack connection I found on the back of my fuse panel. I'm assuming this is the hazard relay? Why would it have needed a half assed jumper like this? My flashers do not work by the way, but I believe everything else does. I feel like I'm jumping into a rat hole here.
I also found another hack attached to the #8 fuse that ran to the non functioning A/C, I pulled that off the board.
Any and all input is appreciated, not judged!
Thanks
Posted by: ClayPerrine Mar 18 2022, 12:54 PM
QUOTE(robkammer @ Mar 18 2022, 01:49 PM)
Thanks
That is actually the high/low beam relay. The hack is probably to make it work with the replacement relay that has an extra pin.
And it is a crap hack.....
There is a thread somewhere on here that will tell you how to fix it right.
Clay
Posted by: mepstein Mar 18 2022, 12:55 PM
Better to deal with it now than some night far from home.
Posted by: Superhawk996 Mar 18 2022, 01:12 PM
QUOTE(mepstein @ Mar 18 2022, 02:55 PM)
What a fine
show that "hack" is. I can't fathom what people are thinking with a "fix" like that.
Remembering
@http://www.914world.com/bbs2/index.php?showuser=20845 scenario --
mountain curve no lights
Posted by: robkammer Mar 19 2022, 02:15 PM
Thanks fellas. Maybe that explains why the fog lights turn on when the high beams should, and the reverse happens when the fog lights should light. I would like to bring it back to original if possible. Is an original style relay still available? If anyone has a link to that fix please share. I find it pretty difficult to search the forum. Sir Andy had a hack a while back that messed it up I think.
Rob
Posted by: Superhawk996 Mar 19 2022, 03:23 PM
QUOTE(robkammer @ Mar 19 2022, 04:15 PM)
Rob
Use Google. Format -- to search for relay board
site:914world.com relay board
I've got to admit though, it seems to me, this doesn't work as well as it used to. Google probably doing something with its algo?
Posted by: FlacaProductions Mar 19 2022, 05:03 PM
I've used that google search formatting for a long time but it doesn't seem to work like it used to....
Posted by: Superhawk996 Mar 19 2022, 05:41 PM
QUOTE(FlacaProductions @ Mar 19 2022, 07:03 PM)
Glad it's not just me . . . . . Google fact checkers not able to keep up with 914world.com in order to make sure we don't get relay board misinformation.
Posted by: robkammer Mar 20 2022, 08:48 AM
Found the thread, should have looked at Georges tips book first. It's a jumper to convert the new style 5 pin relay to to replace the NLA 4 pin version. The proper hack is to jumper it to the incoming power lug with the red/white wire. This guy just took it to the panel instead. I'm going to try to find a four pin.
1 down, plenty left to resolve.
