Hey everyone!
Please don’t roast me if this has been asked before. I spent several hours searching the site… But if it has, a link(s) to any thread(s) would be appreciated…
I have a ‘74 1.8L barn find - sitting 10-ish years due to FI issues. The flapper box is definitely tango uniform and literally in 4+ pieces. Other parts have been removed and am sorting through the rats nest of hoses and pieces. The entire system is in question and I really don’t want to try to find hard to find parts.
The engine was only a quart low and amazingly had very few leaks. The odometer shows 15k miles (115k according to PO). After pulling the engine, I put a ratchet on it (after oiling, etc) and compression “feels” good with no grinding, squealing or grit feel. Will be checking compression officially shortly. The engine’s rebuild history is unknown, so am doing a thorough check. If there’s any hint that it needs rebuilt, it will become a 2056 with microsquirt. If it’s useable as is, I’d like to use parts I have to get her on the road - namely a djet FI system. I would then run her (her name’s Saphira) with the 1.8L until I get a 2056 built. As it’s been said many times here - a 914 going down the road is always faster than one on jack stands!
I have a full ‘73 1.7L djet system and most (missing mps) of a 76 2.0L djet system. I would get a new harness for either djet and rebuild the mps. Assuming I get whichever djet system refurbished, is it a simple remove ljet and replace with djet (distributor too)? Or will the different compression/displacement of the 1.8L cause issues? Any electrical connection issues to the rest of the car? I really appreciate this community and everyone’s helpfulness! Any hints, tips or suggestions are appreciated!
Cheers!
They are completely different systems from the oil cap to the ECU. I’m not sure you’ll be able to mount all the D-Jet parts without the appropriate manifold and intake as well.
Also, I don’t recognize the stamp on your engine tin… @http://www.914world.com/bbs2/index.php?showuser=24231
If you decide to press, I’d like a shot at your L-Jet parts please.
Easier to sell the D jet parts and buy the Ljet parts you need. Fuel Injection Corp in CA can rebuild your AFM.
D-Jet is the very first production EFI built. It is the most primitive system out there. Yes, it works well, the Bosch engineers did an amazing job creating it.
The L-Jet system is the next generation. Bosch took all they learned with the D-Jet and made improvements on the system. No special distributor with trigger points, no multi-wire throttle switch, no MPS with it's diapharam issues, etc. What they built in the L-Jet system was licensed to Nippondenso and put on millions of Nissan, Toyota, and other Japanese car maker's vehicles. It is by far a better system. It even evolved into the Motronic system still in use on current production cars.
I would suggest you fix the L-Jet system. I have kept one running on Betty's 914 for 37 years now. It is robust and very reliable.
Clay
Although I think you could do it if you had the plenum and all the bits, I think it would be easier to fix the 1.8.
Will chime in with the others to replenish the LJet system. @http://www.914world.com/bbs2/index.php?showuser=8571 B and @http://www.914world.com/bbs2/index.php?showuser=24231 have identified several alternate parts for use. Injectors are different, too. Be sure to have your dual relay and capacitor pack. Very reliable and works even with multiple system errors ( @http://www.914world.com/bbs2/index.php?showuser=8571 B knows) but sensitive to vacuum leaks. Lots of LJet help here.
Both the DJet and L-Jet are plug N play as long as the systems are complete and functional. If using the 1.7L DJet, you may need to tweak it for a 1.8L displacement application - such as increase fuel pressure slightly
LJet is a solid and reliable FI system as has been described. It is the original FI system for a 1974 1.8L 914 and I would consider it a primitive FI system. Parts are available though not 100% cerain about Fuel Injection Corp anymore - one of their main techs passed away recently and you should check with them for specific items. It delivers fuel as needed, where needed - well manintained, its great. Every part is available or substitues such as the 123 dizzy can be used. The 1.8L FI harness is $908. because it is much more complicated than a D-Jet FI harness.
DJet is a solid and reliable FI system and one generation more primitive than LJet - a fact yes, but is that important no. Original FI to all 914s, except the 74-75 1.8L cars. It delivers fuel as needed, where needed - well manintained, its great. Every part is available or substitues such as the 123 dizzy can be used. The 1.7L DJet FI harness is $556. and only fits a 1.7L 914 (same price for a 2.0L 914 DJet harness). If you were to source a complete 2.0L FI system, hardware, new harness and everything, it can be used on your future 2056. Cannot say that for the 1.7L or 1.8L setup.
Not a microsquirt fan for the everyday 914 owner, because it is not a plug N play FI solution. Unless you are exceptionally skilled with custom fabrication, electronics and software and have significant hours available to design and build a harness, and adapt the system to your car, we will look for your car for sale in about 10 years after it being on jackstands all that time, after numeous unsuccessful frustrating attempts to make the MS work.
If it were me, I would go with the ljet but be very smart about it. isolate everything you need to make it work, figure out what you need to replace (perhaps the afm) and figure out the price/time factors (that is, if you care). If the cost and time just don't justify it I would consider a lame carb solution for fun. I have an article from the 80s in VW magazine that describes how to just slap a 2 barrel on that plenum and call it a day.
You have the motor out. Put 96 barrells on it stock cam is fine....the 1.8 heads are great heads.
Use the L-jet system the components are still relatively easy to find and that FI system is easier to tune than the D-jet stock FI. IMHO.
MS is not for the light of heart and it's NOT cheap to do.
Nowdays...if it's a barn find...I'd keep most everything stock as possible.
With the above combo you will be able to smoke the tires.... and drive like you stole it.
Yeah smoke the 50 year old 165s maybe...
Fuel Injection Corp. is still rebuilding AFM's but no longer doing ECU's. Their ECU specialist passed away from Covid.
Good evening!
Thank you, everyone for the replies and information! I have been following GregAmy’s blog and Microsquirt build and been in contact with him. (Thank you @http://www.914world.com/bbs2/index.php?showuser=15565 for all the info and questions answered- super nice guy who deserves to be bought lots of beer!) While it is not a plug and play system, he has done all the heavy lifting and I would shamelessly plagiarize (permission was given) what he has done. I like the idea of being able to tune and have a more modern system. He reports that it starts easily, runs super smoothly and he has confidence in it to run several long (7 hours iirc) trips with it.
My Denver cousin (who will be rejoining 914World soon - I hope), really knows and likes the D-Jet system(s) and has been trying to convince me to “slap the D-jet on and go”. At this point, I think that any of the options are going to take a similar amount of time. I will be refurbishing either the D-Jet or L-Jet components to like new condition with new hoses and harness, or building up the Microsquirt with new parts and fabricating some brackets and the harness. Price-wise, the Microsquirt is pretty much known to be around $1700 give or take depending on tools and part fabrication costs. The known D-Jet and L-Jet replacement parts I need are at least $1500 and that doesn’t count any other issues or parts that pop up or new hoses.
The other, very real, consideration is keeping it stock with the L-Jet. A new development is that I found a complete airbox in the bottom of a box. As I posted previously, I only had found pieces (4+) of one. And to be honest, I had not done a lot of research into the L-Jet.
I did find a “606” on the driver’s side engine tin and a “I.0” on the passenger side front. (I have pics but can only load one due to size). That makes sense as this was originally a California car and wandered to Michigan approximately 15-20 years ago, spending the last 12-ish in storage with the FI torn into. Sticker on driver’s side engine compartment shows it being an “A” engine (verses the later “B” version).
So… Next steps…
1) Inventory all pieces/parts and determine what exactly is needed to have a complete one each refurbished 1.7L D-Jet, 2.0L D-jet and 1.8L L-Jet systems. I may be closer than I think to a good L-Jet system.
2) Compression test (starter gets here Tuesday)
A) If the compression is bad, then will rebuild to 2056 (have all hardware and would rebuild the 1.8L heads) and go Microsquirt with 2.0L intake manifold per GregAmy’s set up.
B) If the compression is good then it will be a little tougher decision. I will make a fact-based decision based on research from #1 above and weighted for all the factors (cost, time, availability, originality, etc. - all the great considerations everyone has weighed in with!).
With this being Springtime in Michigan (snowed this morning) and my garage unheated, I have about a week to research and get my ducks lined up. I definitely don’t want to sell Saphira (that’s her name) to Mr Bowlsby (or anyone else) because she’s sat on jack stands for years! The goal is to have her running by July and on the road a few weeks later. There’s some front turn signal and bumper work to do as well, and more than likely a fuel tank to flush/clean.
Thank you everyone for the great information! This truly is an awesome community! Will keep everyone posted on progress.
Dual Webers FTW
Something strange about that intake boot. Doesn’t look the same as a ‘74 or ‘75 9141.8L intake boot.
@http://www.914world.com/bbs2/index.php?showuser=19114
thanks very much for taking the trouble to record those numbers and post up image.
according to material we have found you have a california spec 74 1.8
if it still has its original throttle body it will only have one port for vac connection.
low down on front facing side (front of car side).
but it might have a different throttle body on it now.
all your maths on the $ numbers sound right.
i was going to say after jeff bowlsby posted up cost of 1.8 harness that d jet sounds better way to go $ wise if you got enough good components.
if you have a good afm, good harness, good injectors and ecu the L jet might be ok to use for a bit of low investment rolling fun. but all those things need to be good or $ stack up. and its only got 76 horses. fun horses, but minimal horses.
i got one so i am not putting them down. i really like it. but if it was a kaput barn find i'd be going full modern. mine isn't kaput barn find so i persevere.
Never call out "Beetlejuice" unless you really want to talk to him...
Yes,https://tgadrivel.blogspot.com/2020/03/on-microsquirting-porsche-914-part-1.html: philosophies, processes, tools, techniques, parts, wiring diagrams. So the general engineering is already there.
However, as I cautioned you via email, Jeff is spot-on that this is not a plug-n-play system (except for https://thedubshop.com/dual-throttle-body-fuel-injection-package-with-ignition-type-4/) and this project does require a range of knowledge in terms of engineering/mounting the components, building a wiring harness, and subsequent tuning. I agree with his contention that fabbing something like this requires "...[skills] with custom fabrication, electronics and software and have significant hours available to...build a harness" (I have removed the "design" part, as I think I've done that for you.)
However, as Jeff implies, selecting and mounting the components was the easy part of the project. The most significant amount of time was spent designing and fabbing the wiring harness. I didn't keep track of hours, but I do recall wiring diagrams taped to all my cabinets around the garage pretty much all winter as I worked with the engine on the stand wiring it up, wire by wire, terminal by terminal, connector by connector. It being winter, with nothing else to do exept drink beer, helped a lot in my continuing the project to completion, and not having it become a garage queen (but there were moments...)
I will stray with Jeff that it requires "exceptional" skills, as I don't think I necessarily possess that, but it does require good skills. If we could find someone to fabricate wiring harnesses in bulk to my design, then this conversion would be dramatically easier (almost "easy"). But that's not something I'm interested in doing myself.
In the end, the Microsquirt is a good little system that, honestly, is only a few generations improvement from D-Jet. Both D-Jet and Microsquirt are "Speed Density" systems (L-Jet - "Luft" - is Mass Air Flow), both are batch injection (and MS does wasted spark), but what the MS offers is a better MAP sensor and finer-measurement TPS, wideband feedback, and user tunability.
But in the end, they're the same general technology...
Glad to help as I can...but you better really want to do it. - GA
Hey Greg,
If the harness is the hardest part of the swap can you post a bit of information it, or links to previosu posts? Do you have a few photos depicting the overall layout and a few of the connections?
I'll PM you. But here's a link to the Google folder:
https://drive.google.com/open?id=17R-SCgJaHIP_RxMj7v0GYk4MgYwoSayv
I have always wondered if you could just slap this kind of thing on that plenum and call it a win?
https://www.holley.com/products/fuel_systems/fuel_injection/sniper_efi/sniper_efi_autolite_1100_one_barrel/parts/550-552
Gents,
One of the major concerns with each of the aftermarket FI systems I have seen is the harness which needs to be custom designed and built for each vehicle application, and to accommodate its required parts which are also not commonly repetitive from vehicle to vehicle enough to be cost efficient. The wire terminals are what they need to be to match a component - everything else is pretty much up to be designed and custom fabricated. A customized, servicable, durable harness in our open-to-the-weather engine bays is a challenging thing to acheive, because it needs to:
1. Protect the contained and routed wiring from physical abrasion and thermal extremes. In many locations in the engine bay the harness lays directly on the engine. Factory harnesses do this effectively with heat shrink tubing, which provides a liquid tight assembly at every juncture. No wiring is left exposed unless it is not in a high heat location. A primary failure point of factory engine bay harnesses is the exposed ground wires, or where rubber boots have deteriorated leaving the wires exposed to heat and liquid contamination. What I generically call casing (i.e heat shrink tubing, slit corrugated tubing, PVC, braided sleeving, etc.) needs to be a watertight system once installed and some of the materials available and used for this purpose are not liquidtight.
2. Protect the electrical connections from contamination and provide stress relief at wires-to-component connections. A liquidtight sealed system = from the ECU to the last component. Most if not all the aftermarket solutions do not achieve this. Exposed wires galore. Individual seals on individual wires with some connector designs may help but they often do not provide adequate stress relief and typically leave a portion of the wiring exposed adjacent to the connector housing. Factory style rubber boots are designed to satisfy these two functions.
A part of this problem is the hardware provided on certain components - they are often but not always, computer type electronic parts adapted for the aftermarket FI. DB25-style connections and others, may not be inherently watertight and if so, should only exist in a weather-protected protected environment. That may be as simple as locating the ECU at an interior location (in the cabin for example) or building a separate watertight case if it must be in the engine bay.
How much would a proper harness cost? I'd be your first customer!
Not agreeing to design or build this but there are two main costs:
1. The constructed harness. Assuming the harness is a single design, no modifications for a standardized application, fuel only - then somewhere in the $600.-1,000. range feels about right as a ROM.
2. Cost to research, document and develop the harness design in every technical detail - from layout to parts selection, possibly engineering or at least design of adapters for the TPS and other component mounting brackets and template development. The upfront investment to purchase bulk materials to produce these in quantity. Assume at least 10 harnesses as an initial offering to amortize costs - my hunch is that finding 10 buyers will be a high hurdle to cross. Budget $3-5K for this front end effort feels about right as a ROM. Amortizing this front end cost over 10 harnesses could add $3-500 per harness, and thats only if 10 buyers are willing.
Add increased cost for customized options that some will undoubtedly want to include in their system - ignition control, locating the components differently, special cases for water sensitive components, etc. - or simply do not offer these options. Offering preprogrammed ECUs would be significant to organizing a viable system with wide appeal and plug N play capability for 914 applications.
...all the reasonable economic and financial decisions I have already made (Part 10 in the blog) choosing not to replicate it except for myself.
I'll give away the blueprints, but ya gotta build it yourself.
If you want a plug-n-play Megasquirt system, buy https://thedubshop.com/dual-throttle-body-fuel-injection-package-with-ignition-type-4/. It's a nice piece of kit, and all ya gotta do it bolt it in. I may end up doing just that for the street car, and transferring the D-Jet based system to the race car (SCCA reuqires use of stock throttle body). Or maybe I'll just build another one of these; I know the guy that's already done it...
- GA
There is also this option:
https://www.allzim.com/store/356-parts/efi-conversion-parts/356-efi-conversion-faq.html
This is an EFI kit developed for the 356 engine. It would work on a 914-4 but you would have to do things like extend the battery lead, supply spark plug wires, intake manifolds (weber carb manifolds) and extend the fuel pump wire to the 914 relay board. It should start and run out of the box, but it will require tweaking for the larger displacement of the 914 motor. The harness is built with the proper weather tight connectors and proper strain relief incorporated into the harness.
I have actually driven a 356 with this kit installed. It is way better than carbs, and will start by turning the key through the window.
Aaron ( @http://www.914world.com/bbs2/index.php?showuser=21587 ) is the person who did the development. I have been urging him to do a complete drop in for a 914. Honestly, I have seen how they are built. It is done right. I figure to install it and adapt it to an 914 would take about 10 hours of work.
Clay
And…. After all that, the compression test came back with 90, 82, 76 and 56, 1-4 respectively. Based on that, it sitting for 10-12+ years and the unknown history - am going to go with a full rebuild. So much for a quick fix and go… I even found my old single 2-barrel progressive setup from the 90’s (not going to use it!)…. The L-Jet wiring harness doesn’t look horrible - not brittle, just dirty. Am cleaning and inventorying parts. Thanks for everyone’s inputs and great conversation/information!
