Printable Version of Topic
914World.com _ 914World Garage _ facet fuel pump
Posted by: doobie123 Aug 2 2022, 05:17 PM
hi all,
i'm working on a 1975 914, 1.8.
there is a facet fuel pump in the car that needs replacimg. i wanted to order one from auto atlanta, (great place by the way) but they have discontinued them.
looking on mine, i can't find a model number.
anyone out there know which one is the correct one?
thanks
Posted by: nditiz1 Aug 2 2022, 05:40 PM
QUOTE(doobie123 @ Aug 2 2022, 04:17 PM)
hi all,
thanks
I'm going to assume you are running carbs?
Posted by: SirAndy Aug 2 2022, 06:02 PM
There is no correct one since no 914 ever came with one.
When i had my carbed 2056, i ran a CB Performance rotary pump which was much, much quieter.
https://www.cbperformance.com/product-p/3193.htm
Posted by: bbrock Aug 2 2022, 06:06 PM
I think Facet pumps were outlawed under the Geneva Convention against torture.
Posted by: nditiz1 Aug 2 2022, 06:10 PM
@http://www.914world.com/bbs2/index.php?showuser=179 - that's where I was going with that, this is probably the best pump to run whether you are in a 4 or a 6 and have carbs.
Posted by: URY914 Aug 2 2022, 06:16 PM
Andy is spot on.
Posted by: mb911 Aug 2 2022, 06:51 PM
QUOTE(nditiz1 @ Aug 2 2022, 04:10 PM)
Yup I run the same one.
Posted by: theer Aug 3 2022, 07:21 AM
I agree with the others on fuel pumps- I have the same on my carbed 1.9l, but I do have a Facet pump you can have for the cost of shipping, if you’re just trying to get it running.
The Facet I have will only work for carbs, by the way. FI needs much higher pressure and a return line.
Posted by: 930cabman Aug 3 2022, 07:39 AM
has anyone used the Mr Gasket 3psi pump?
Posted by: rhodyguy Aug 3 2022, 08:47 AM
Remember to purchase a fuel pressure regulator when you buy the facet. Figure out a way to isolate the pump if mounted on a metal surface. The rattling is very annoying.
Posted by: Ansbacher Aug 3 2022, 01:20 PM
Two questions:
Why are they still manufacturing freaking Facet Fuel Pumps! ???
Why are people still buying them???
Ansbacher
Posted by: parrish911 Aug 3 2022, 01:47 PM
In my humble opinion, best to run a rotary pump, a fuel pressure regulator (I used the one from PMO) and a return line. I did this with a dual carb set-up (40 IDF)
Posted by: dr914@autoatlanta.com Aug 3 2022, 03:17 PM
we have them under a different part number now r90160810600
hi all,
thanks
Posted by: Dave_Darling Aug 3 2022, 10:57 PM
QUOTE(Ansbacher @ Aug 3 2022, 12:20 PM)
Because people buy them.
Because they're cheap.
--DD
Posted by: doobie123 Aug 5 2022, 05:25 PM
hey ya'll thanks for the replies.
so i'm thinking that the thing to do is ditch the facet and go with the rotary.
got it!
thanks for helpin the new guy out!
Posted by: SKL1 Aug 5 2022, 11:12 PM
Definitely the rotary pump as mentioned, and a fuel regulator.
(and we don't need another 10 page thread carbs vs FI)
