Evening 914 World!
I’ve been gathering parts over the past few months and have finally reached critical mass. So, let the project thread begin!
After working on the FI through the winter, I’m satisfied that the engine remains in good health with it’s original 53k miles. However, the rubber and plastic holding everything together is a different story.
Which brings me to the scope and objective of this project. In short, I am looking for what I will call, “Improved Original”. What the phrase means to me is that I want to maintain the character and feel of the original car, but still take advantage of any and all modern improvements that will either, improve reliability, safety, operability, or any combination there of. This will include a suspension and chassis rebuild, power train reseal and refinishing, brake system rebuild, and fuel system overhaul.
When I’m done, I want to have a car that drives like it’s nearly new, but doesn’t look over restored. Because the car is a survivor, I think it’s important to keep the stories and history of the car intact.
Finally, I’d like to post my thanks to the community and vendors that make it possible to enjoy this hobby. Stay tuned!
Van
Day 1: removed the engine
Anxious to follow your exploits, Van, particularly the original but better improvement choices. These have been tough to make but safety (fuel pump to front, 3rd brake light, 19mm MC) and reliability (warm start solenoid changeout, modern bushings) are always good choices.
Let the fun begin!!
Good luck van! Everytime I dig around in mine I say to myself "well, it's lasted 50 years already..." And cross my fingers.
Thanks guys! @http://www.914world.com/bbs2/index.php?showuser=10753 most of those choices have already been made. But I’ll do my best to document the choices on this thread. You might see the first choice I made bolted to the transmission. I went with the firmer 911 mounts and was very pleased.
These guys: https://www.fcpeuro.com/products/porsche-engine-mount-german-91137504307
you and your car will enjoy those bilsteins i see on the table of goodies.
I will watching this for sure! This is very much the philosophy I've followed on my build which is still a work in progress. Some thoughts from my own journey down this path:
For the most part, I decided to restore the car to like new condition because it was so well engineered to begin with. Suspension and brakes remain stock but I did upgrade to Bilstein shocks and turbo tie rods. The engine (2.0L) was rebuilt to european stock specs so displacement remained stock but compression raised. The exception was an unfortunate decision in the late 1980s when bottom end of the engine was rebuilt to install a carb cam. A mild one, but not a decision I'd make today. As a result, the car is currently carbed but I'll return to that later. Other than the carbs, I don't regret any of this. I've taken several 300+ mile trips this summer and the car as Porsche designed performs and handles fantastic. It is just a wonderfully balanced package and I have not wished for more or less of anything.
Now for the mods. First, my rule on mods is they should be as stealth as possible. Invisible is even better. Visible mods should look as if they came from the factory down to the wiring. Mods also need to be non-destructive so no drilling allowed. I want them to be easily reversible in case someone wants to go purist some day. With that philosophy, here are mods I did or plan to do in order of priority.
Safety First - I wanted to leave no compromise here within reasonable limits. Nothing crazy like adding airbags or anything, but there were a number of mods.
@http://www.914world.com/bbs2/index.php?showuser=20845 I’d say your plans are an order of magnitude beyond mine. I’m loving the L-Jetronic now that I’ve got it working so, that’s staying.
I’m going with LEDs too, but that’s not within scope of this round… daytime VFR for now lol…
Audio is also beyond scope for this phase, but it is in my crosscheck. To that end, I’ve been eyeballing these for a while: https://www.retromanufacturing.com/products/1970-76-porsche-914-hermosa-radio
Will solve Bluetooth and charging requirements.
You only need to loosen it enough to slip the mount and long bolt out of the channel on the transmission support bracket. Remove the two bolts/nuts holding the mount to the chassis, loosen the long bolt from the mount to the transmission and take out the whole thing. Then install the same way.
@http://www.914world.com/bbs2/index.php?showuser=26011
are you going to install sway bars?
@http://www.914world.com/bbs2/index.php?showuser=10753 - you undo the 2 smaller M8 bolts on each mount as well and slide the whole thing out towards front of car. you loosen the centre bolt only enough allow it to slide through the forked mount and get it out.
then you can take the mount out and take it apart. take a photo. get all the washers and everything back in correctly in sequence with the new mount.
install reverse order or removal.
thats why you need the torque setting of that big central bolt.
normally when you drop engine and trans as unit you just undo the 2 M8 bolts either side and leave the central bolt alone and leave the mounts on the gearbox.
the nuts would be down on yours (as they are on mine) because whoever did it wanted to torque them up with a torque wrench from the bottom. (i realise there are contrary views on that - would be interested to know how the install was done with the nuts up ).
No worries @http://www.914world.com/bbs2/index.php?showuser=10753 . You’re over thinking it. Get under there with your wrenches and it will become clear real quick. @http://www.914world.com/bbs2/index.php?showuser=24231 I did find the torque value and I remember that it was in an odd place. I’ll look it up again.
[/quote]
Van; Rats. Looked under there and the center bolts are upside down (nut on bottom) - must have happened when engine out at 70k miles. So, no way to change out mounts without dropping trans?
[/quote]
one more thing @http://www.914world.com/bbs2/index.php?showuser=10753
i don't think Van B minds me expanding on esoterica - cause he knows i am a sceptic and contrarian (ie trouble making upside down a-hole )
it is my firm opinion your bolts aren't on "upside down".
its a myth that someone has come up with based on the PET diagram?
i'll explain why. its coming back to me because i ghosted these forums when i was recommissioning the wallaby 3 years back and read it all in some long lost thread here were a bunch of guys went at each other about those mounts.
1)
mine were on apparently "upside down". ie nuts at bottom bolt facing down.
photo before we started work. you can see them.
2. here is the top of the mount we removed.
still liberally goobered with original undercoating that got sprayed all around in there by some kook toking on a stoobie back in 74. it had never been off. the evidence was fairly compelling.
so the mounts before we started where "upside down" and had been so called "upside down" since the day it was built. 99% certain on that.
granted. some stoned german could have screwed it up the wrong way on the assembly line. or they dropped the motor in the workshop before they sold it new or sent it off to the undercoaters for some reason. but i very much doubt it.
additionally if you look through the factory manuals there are photos of the mounts in question in situ in the car with the nuts on the bottom.
so.....if you ask me yours are not upside down at all.
i think where the myth comes from is the early cars up to 73. they have forward engine mounts for a solid mounted cross bar. similar or identical mounts to gearbox. and if i am not mistaken the only way you can get the bolt in is from below and do the nut up on top. but i could be wrong. don't have an early car to know. i think they just followed the same convention for the rear mounts. but i can assure you its academic. it makes no difference to the rear mounts because you slide them out through the forked transmission casting. and we don't have forward mounts on our later cars. they are smaller rubber mounts in the centre of the bar where it is joined to the engine.
i also now remember the factory manual is real skinny on the engine mount issue.
seems to have been written for the 70-72 cars with different mounts.
probably the manual i have was supposed to have a revision and its been lost.
we might have just tightened up the transmission mount centre bolt firmly.
i can't remember but i can ask mike next monday for you.
i left that to him. he knows 911s backwards so he probably didn't think twice about it whatever he did.
this might also give you pause to think @http://www.914world.com/bbs2/index.php?showuser=10753 before you fret to much about those bolts.
from the L jet files.
44 K mile car we pulled down material on from BAT last year that was a big clincher for the 1.8 L jet research. sold back in 2016. just about one of the best most original 1.8s i've come across documented. Big Len would probably agree with me. you would be hard pressed to question this one.
to me don't look like anyone has been near the trans mounts since abba entered eurovision. they are "upside down" according to 914 myth. or are they?
this is from the alleged 29K mile blue car.
don't think it was 29K miles but along with Big Len i don't share everyone's else's scepticism about it and dismissing it as a 129 K car either. not as compelling as the green car.
but......they are "upside - down".
i didn't give ground on the charcoal can plumbing and its not that i was right about it.
but my car (as an artefact) was right. same with the plumbing on throttle bodies and dist vac cans. not saying i am right 100% here, but i'm not falling for the "rules" either.
i'm calling this one as problematic in terms of what the "experts" say.
have hijacked enough, but i think Van likes it when we get into a bit of heresy at his expense. those cold start threads he started up were some of the best explorations of 1.8 misery ever.
by the way @http://www.914world.com/bbs2/index.php?showuser=26011 thats a pretty clean looking engine you got there when its out of the car. tin ware looks to be in outstanding shape. tends to verify you got hold of a real good car, just getting a bit creaky in the joints after half a century.
If it’s good enough for @http://www.914world.com/bbs2/index.php?showuser=24231 , it’s good enough for me. I’m sufficiently convinced. Onward!
Van; would these be the torques you mentioned? #2 Not specific to the center bolt?
Steve, for the life of me, I can’t find the M12 bolt reference. But, I use charts like this when I need a standard spec for grade, size, pitch: https://www.fastenermart.com/files/metric_tighten_torques.pdf
So, ~40ft-lbs is a safe bet for the long bolt unless you can confirm the grade as higher than 5.
The small M8 carrier bolts for the transmission mounts are listed in the engine section attached.
Oh and Wonki, I can’t possibly complain about one of the few guys who responds to my cries for help lol!
Onward! Thanks and back to the real thread…..
So the theme of today is: Better lucky than good any day of the week!
I saw some rust chips under the firewall pad when I pulled the engine so I knew that needed an investigation. But while assessing that, I also saw some inclusions in the coating in the hell hole. Unbelievably, all of the metal is still solid!
I have a lot of grinding still to do before I can phosphate and seal… but man did I get lucky.
Another lesson for folks: Don’t use spray adhesive on your firewall pad! You’ll just trap moisture and cause unnecessary and avoidable rust
car gets better the deeper you go.
It’s original zeibart coating and it was sprayed all over the car when new. But to me the hell hole looks like it started rusting and was given a casual derusting and then another thick coat of water proofing.
When I got the car both sides were filled with acorns so, there was at least a year where moisture sat down there and couldn’t drain.
Electrolysis for the win. Only had a couple hours to work today, but I made the most of it. So glad I took out the home made kit, otherwise I wouldn’t have been able to expose that inclusion.
still a lucky man.
have you taken the sill rocker panels off yet to look in around jacking posts?
Haven’t taken the rockers off yet, but I’m reasonably confident they are fine.
However, I did take the day off and I guess if yesterday was the hell hole, then today was spent in purgatory… turns out, purgatory is worse lol!
I made sure to take a pic of the electrolysis magic today. Gotta love science!
Bottom line, for the engine bay, I have a few pinholes to deal with. Nothing bad enough to justify cutting metal, but they still need to be plugged all permanent like.
there is one place left after you look behind the rockers.
you will see it after you pull the fuel tank.
You mean that little box section reinforcement down in the tank cavity? I've already spotted some surface rust there... I may have to get a bead blaster to clean that up.
quick question for you @http://www.914world.com/bbs2/index.php?showuser=26011 while i think of it.
what colour are the plastic headlight motor guards in the front trunk of your car.
black of grey?
tracking back the change to grey and have it all the way to very early jan 74.
Black on my car.
My only gripe about the 74 1.8 is that emissions forced so many changes in the L-Jet that results in a lot of NLA parts for us that would otherwise be simple parts to replace.
thanks @http://www.914world.com/bbs2/index.php?showuser=16126
apologies @http://www.914world.com/bbs2/index.php?showuser=26011 (predicting you have as per starbear)
Wonki, this is mine. Glued down and doesn’t come up… I tried but it feels very old lol.
@http://www.914world.com/bbs2/index.php?showuser=1244 sorry for the delay, this is for your interlock research:
thanks @http://www.914world.com/bbs2/index.php?showuser=26011
(ah the interlock, the horror, the...... )
That is a great photo set. The painted male spade is just the same as mine; paint does not make for the best of connections.
It ain’t listed there either @http://www.914world.com/bbs2/index.php?showuser=10753 , but if you’re going to reuse the original bolts, go with the same torque listed for the engine support nuts, 21.7ft/lbs.
Almost everything new you can buy will be 8.8 at least. As I've been going through my car, I'm finding a lot of grade 5.
Been spending a lot of time LARPing as a type 4 engine these past weekends lol…. But, I want to uncover any and all issues as well as set myself up for a quality finish with my high dollar 3M undercoating. Today I spent the afternoon soaking the 50yr old Ziebart in mineral spirits and using all manner of tools and rags to remove it.
Pretty pleased with how much I removed today and the condition of the metal and paint underneath. I learned that the battery tray was replaced some time ago… and not properly primed or painted lol.
Yuck. Keep up the great work, Van!
So true!
How come you took it apart. It only had 53k.
Basically because the car was 100% original in all the wrong ways. Every bit of rubber was leaking pretty aggressively or nearly disintegrated. Then, I found rust that was about to get out of hand.
I will only reseal and refinish the engine though, no rebuild. I want to enjoy the engine for its full lifespan.
@http://www.914world.com/bbs2/index.php?showuser=3348
Mark, in the pic I posted yesterday, the grommet in question is for the hole between the rain tube and the fuel line ports. That's where the hard vent line goes through on my 74. And yes I agree replacing the hard line is a good call. Let me know how to add that to my order
Thanks
Van
Man… such an absolutely tedious task. But I know I will be glad I did it in the years to come. The problem with Ziebart and other traditional undercoatings is that when it’s not sprayed properly, it foams… And that traps moisture.
The new stuff, like 3M Dyna-Pro 544, is vastly more expensive, but it doesn’t trap air bubbles and is paintable. After seeing all this yellow for the first time in 50yrs, I’m considering the idea of painting the bay yellow. But also, my original plan was for a smooth satin black finish that would let the refinished engine be the star.
It’s important to me the car should keep its stories. It is a survivor after all.
I think a lot of it has to do with the car itself. One day, there will be no Chrysler K cars. Mostly because they were crap, but also because there was nothing about them that made them worth owning or keeping.
Oh I forgot to mention the bird shit on the trunk hinge pin bracket I now get to grind off and weld up correctly lol
So, last weekend I bought an abrasive blaster tank to deal with the engine bay only to learn that I need way more drying action on my air lines lol… So, I’ll be dealing with that tomorrow hopefully. Today, however, was dedicated to buying another classic Porsche design. And quite possibly the slowest Porsche ever!
I was perusing Craigslist, as I often do. And I found a beautiful FA Porsche table and chair set. The owners DID NOT know what they had, only that it was a hand-me-down and good quality. So, $550 dollars, an adventure through Washington DC, and a few hours of polishing later, we have a new breakfast table!
I’ll be back on task soon, I just thou you all might like to see one of the last furniture designs by the man who penned the 911
I like that table and chairs; good find and buy.
Thanks guys. I really like the idea that this thing is old enough that old man Ferdinand likely signed off on this design himself.
Score!!
I did some sand blasting in the engine bay yesterday and realized that I will need to learn how to do body soldering/tinning/leading or whatever you want to call it. I’ll post more on that tomorrow if I get the blasting all done. For today though, I cleaned up my mess from poor taping, retaped the car, and took the rockers off… more acorns! The PO tried his damnedest to kill this car. 90% of the rust issues I’ve found were under piles of acorns.
Both sides had a decent stash, but the passenger side still had one bedroom apartment in there. The Ziebart gave its life to save the longs
Did some fine grit soda blasting on the longs… definitely got lucky there!
As for the engine bay, I’ve finally reached the bottom of the rabbit hole… and I found some Swiss cheese on the drivers side. I’ve spent a lot of time in there and despite the perforations, the metal is still strong. So, I’ve decided to do some tinning (lead free). Nothing is structural, thank you Lord! I even ran a scope down into the longs and everything is very clean on the inside.
some people are lucky.
blessed with it.
you are one of them.
what a great car.
if i burn my one and only rev limited rotor i'll hop on a plane and bang on your door and demand one of the 2 you have.
Getting a little behind on updates here. I know this thread is pretty boring up to this point, but I’m also recording here for posterity. Hopefully soon, I can get to some more enjoyable phases and provide some better spectating lol.
I decided that welding was going to be required in a few spots. I decided to start with the firewall just because it was easier access. Unfortunately, what I thought was going to be one spot expanded rapidly once I was both sides. I’m not real happy with how it turned out and will probably go back in there with correct thickness metal in the future. It for now, it’s super solid and will have its ugliness hidden.
After the firewall, a lightbulb came on that resulted in a trip to harbor freight for a punch and die set. I adopted the technique of making plugs. I reamed out the larger holes and welded in perfectly fit plugs. I used some aluminum angle and some magnets to keep them from falling through. You have to watch out with how close the magnet is to the welding arc or the magnetic field will destabilize your arc. 6” of aluminum gave enough separation though. And, it also did a pretty good job of holding onto some backing gas. I really like this method if you want to save a panel.
Thanks Tom lol… it’s a tall order to ever get my car as nice as yours
Been working on the trunk hinges:
It was super difficult to to but I managed to tack a nut in place by threading a bolt through the original hinge. I couldn’t get photos because I was struggling so bad to make those tacks through such a tight space. After I got those in I had to repair some tears that had been hiding behind the poor hinge repair.
Then I decided it would be wise to test out this fancy copper based weld-through primer I bought. I’m actually very impressed! It burns away real clean under the tig arc and holds up pretty well around the weld.
New hinge assembly time:
Decided to radius the outside edges for aesthetics and to hopefully even out the torsional forces on the hinge.
And of course, I had to deal with nasty zinc
And this is where I ended up tonight:
I got the hub welded in, and managed a test fit… very pleased. These replacements are 23mm tall while the originals were 22mm, but I’m sure it’ll work fine.
The last thing I did was spray everything in the weld through primer. Tomorrow I’ll weld it all up.
Glad I thought of the nut as an alignment tool, definitely made setup a breeze
On the other hand, welding was a real challenge I had more blowouts than a Florida highway in July!
No doubt those birdshit welds put a lot of trash into the metal… like soviet landmines long forgotten lol…
copper weld through primer is good stuff.
used a lot of it on the falcon ute.
nice work on the hinge plates.
Evening all! Thanks Andy for bringing the forum back to life!
I came up with an answer to 50yr old undercoating that doesn’t involve gallons of mineral spirits or dozens of rags. A steam pressure washer! This little monster just saved me weeks or scraping and scrubbing! I just wish I’d thought of buying one sooner!
Didn’t get any proper before shots because I was full effort to get this done in a cold afternoon. But here’s a before shot when I was sorting my fuel pump wiring:
My cleaning job dislodged enough rust from the weep hole in the jack plates that I decided I need to have a look. Glad I did. This thing was as nasty on the inside as barbra streisand lol!
I did get lucky however and the top half of the jack plate still had most of its coating on and only superficial rust. The misery of this bottom half is certainly due to the mud nests that were inside for who knows how long.
Done right and will stop the hidden tin worm from continued feasting behind the jack pyramid.
Thanks brother, that means a lot coming from you. I can definitely see how so many restorations go wrong when people run out of patience, time, or money.
i see you are keeping up with the copper weld through primer.
vastly improving on the flawed original.
nice view from the driveway.
trees? what are they? its bitumen and bluestone around my inner city bunker.
Nice Barcelona, and the foam core takes me back a few years. We have not figured out an elegant rainwater recapture solution here.
This pushes my buttons in several levels:
https://www.dwell.com/home/mid-century-modern-restovation-192b588f
Wow! You guys are really speaking my design language here!
I sketched this guy many years ago when I was considering buying and old city lot. I envisioned the first floor being all shop space with 2nd floor living and 3rd floor bedrooms… but then I moved to MD and lived in a few multi floor houses and decided I hate it lol. I’m a single floor guy.
Oh and Happy new year wonki!
ah yes @http://www.914world.com/bbs2/index.php?showuser=104 .
whats not to like about the translation of mid century singular homes the Case Study program did into mass market homes by Streng Brothers and others. there were also the Eichler Homes? back when being progressive meant being progressive!
All the case study architects were my heroes when i was first an architecture student. i was going against the flow - michael graves was at the height of his powers. Later when i was a grad student i got to meet Craig Elwood but thats another story.
just do blunt rainwater storage systems here though flying downpipes are my speciality.
i stack everything on circular concrete tanks. pv cells. heat exchangers. etc.
half the tank is for fire fighting with the country houses.
most architects try to hide the rainwater tanks. why bother is my philosophy. the lunar module is my inspiration when it comes to buildings these days. far as i am concerned the earth is an alien planet. or soon will be.
happy new year.
@http://www.914world.com/bbs2/index.php?showuser=18995
yikes.
i confess i carry around a scissor jack with my car.
i hadn't thought about the jack receiver failing like that but.
my distrust is of the VW jack itself.
i once had my squareback fall of the jack when i was changing the tyre.
i was young. i was way the F#$k in the flinders ranges in the outback miles from anyone. an aboriginal ranger drove past me after a couple of hours and pulled a scissor jack out of his toyota and we managed to get the car back up and change the wheel.
cracked a couple of beers out of my esky with him.
never trusted the VW jack again.
I’ve never used them and hadn’t planned on replacing them, but I suppose now is the time!
Maybe I’ll cut the top and weld in a double thick top plate?
@http://www.914world.com/bbs2/index.php?showuser=24231 a small lift as in just big enough for one car? Ha!
promise not to "hijack" the thread further.
but i know you are a design and chair "perv" @http://www.914world.com/bbs2/index.php?showuser=26011 with your F A Porsche breakfast table and chairs.
and i can see where @http://www.914world.com/bbs2/index.php?showuser=104 's tastes are, namely the right stuff.
california once ruled the world (but not anymore).
i put it down to aerospace industries and the skunk works before sillycone valley took over.
here are a couple of other interesting ones i have.
ray and charles eames chairs.
(out of WW2 plywood splint technology for wounded soldiers and straight into post war high end west coast suburbia).
the ones that have with chrome legs are the USA herman miller "originals".
the black painted leg version is the made under license in australia "copy" from the late 50s. the late Harry Seidler, a famous australian modernist took out the license for local manufacture. they are slightly adjusted - or as Harry would say "improved" for australia. the shells are slightly smaller for smaller australian bodies (backsides) back then (though these days australians have taken over the title of the worlds most obese population - sorry Winsconsin). and the legs are slightly taller. this had something to do with preferred ht of australian dining tables in the late 50s, early 60s believe it or not. or thats the story.
most interesting part is they were made in sydney by the same company that was going to do the full bore/out of this world plywood interior for the Sydney Opera House before Jorn Utzon met his fate at the hands of that most unique breed of human beings,
the Australian Politician. Utzon left before that interior could be manufactured and installed and the whole plan was kyboshed, leaving the Opera House to receive a tacky interior by some third rate hacks from the public works department in sydney who took over the task of "finishing" that masterpiece.
A little later around 77/78 that same plywood company started building skateboard decks for Tony Alva, the famous californian swimming pool skater. these were beautiful plywood skateboard decks, the first high performance skateboard decks. I had a contact in sydney when i was a kid and we used to get the blank decks out the back door before they received their famous SCRATCH graphics and shipped back to the USA. we got em cheap, like we could actually afford them as kids. i still have one somewhere on my shelves.
i found the harry seidler eames chairs on the side of the road broken on a hard rubbish day in one of our posh suburbs back in the late 70s and threw them in my girlfriend's hi-lux ute.
then restored them. still have them. designed a table to go with them a bit later on when i had some money briefly in life.
a bit like the jack receivers on 914s, the rubber shock pads which are glue bonded to the plywood shells always fail on the eames chairs. back in the 80s i managed to score a box full of shock pads from a guy connected with the original manufacturer in sydney.
i routinely have to replace the shock pads about once a decade.
a bit like 914 maintenance. you are always dealing with a slightly flawed but nevertheless magnificent design.
Never knew the connection to proper skateboard decks, pretty cool!
Found some ugliness in the back edge of the trunk that needed to be cleaned up. So, I thought I’d show off how easy the steam power washer dispenses with ziebart by way of a little before and after shot:
From there all you need is some acetone and a rag to remove the leftover residue.
not too bad.
a little bit of that went on in my rear trunk.
i did a bit of touch up rust converting 30 years ago - seemed to paralyse it.
think foam pad under carpet traps condensation?
not a problem in aus in second half of cars existence - don't have cold enough conditions.
have never wanted to attack mine aggressively.
still got a cute little stamp and piece of half century old paper tag there.
good idea to rip into yours and get that zeibart off - kill it stone dead.
we have steam pressure washer at the workshop.
they come in handy.
though i have to be careful with it as it will actually tear paint off if you get it too close to the surface being cleaned.
I think these issues were driven by tail light gaskets being 50yrs old and showing daylight between the housing and the panel.
I’m starting to like this lead free tinning to fill in rust pits that don’t rise to the level of panel replacement:
Well Sh!t:
I saw a repair order in the records to “repair and repaint parking damage”. I guess I just found it.
The color is off anyway, it’s missing that light green hue that you can see under certain light. So, I won’t bother with a localized repaint.
Basically I’m on the fence at the moment. I suppose I need to see how easily I could source some glasurit 22 line single stage paint.
given you are a perfectionist.
(as proven by the cold start discussions)
you might need to hold back.
or otherwise you will have a bare body shell on jack stands.
could be good but will take a bit of time to plough through.
Got a little more progress this weekend. Could’ve been more, but I didn’t like how the restoration design jack pads fit. They didn’t have enough curve and were slightly aft tilted. So I cut off the originals cleaned them up and fitted to the new plates.
I also decided to reinforce the eye since the old ones are clearly prone to tearing out if looked at with more than a stern glance lol.. i bought some bushings from tractor supply and welded them on each side to build up the thickness. I also tig welded the ground edge with some high tensile rod to make up for the lack of meat on that section. In all, I’m pleased with this improvement.
Ha! A four pack of bushing washers cost me about $4 at the local farm supply store. You’ll at least be lucky enough to find them in metric!
I know this is absolutely stupid, but I don’t care lol. I probably won’t ever use the jack points, but if I do, I will have total confidence. A little but of hammering, cutting, beveling, a mega difficult tig weld, and presto! Super strong jack points better than new!
@http://www.914world.com/bbs2/index.php?showuser=18995 thanks for the cautionary tale!
Keeping this public journal going:
The jack points are finally sorted and extra beefy! Man when you add up the steps, it really hits home how involved some of these repairs are.
From there I moved on to the rear sway bar. The pre fab mounts that Chris was kind enough to throw in with the rear sway bar he sold me were a no go. Spacing was off on the bolts enough that the clamp wouldn’t mount. And the leg was too tall. So, new nuts and a wide leg stance were the chosen fix.
Then it was just a matter of getting it all aligned and welded on… without too many sparks down the shirt!
Very pleased overall. But some ziebart kept melting from inside that box section and tried to ruin my welds. Not that I was going for internet famous or anything, but I still wanted to be sure of good tie in and no porosity.
Ok, so I’m working on adapting my stock 996 front sway bar to the 914. My reasons are varied, some rational, some sentimental, but mostly for the fun of it.
That said, I’d like some critical feedback from those of you who check in on this thread before I start welding.
To start off, here is how I have it mounted to the cross member supports:
Many things to annotate here. First, I chose to use the support bolt location because it will give the greatest strength against any twisting on the support bar vs welding on an extension to get the original bracket position. On the 996, the mounts are on the outside of the collar, I also thought moving them inboard a bit might soften the bar up a little bit. But on the other hand, I’m not sure it won’t induce bowing on the sway bar and thus, binding.
Next, here’s a preview on the link mount arrangement:
These are volvo sway bar links, but fit great and will make for an easy mount tab on the far end of the control arm for maximum leverage.
While checking clearances, the one limit I’ve found is that when airborne, I will only get one full wheel turn left or right before the tie rod end hits the sway bar shoulder. So, as long as I have one of the front wheels on the ground, I should be good. And, I think it looks like the turbo tie rod ends are a little slimmer… not sure I’ll get full lock at full travel. But, alternatively, I can always avoid jumps!
@http://www.914world.com/bbs2/index.php?showuser=22428 @http://www.914world.com/bbs2/index.php?showuser=10753 @http://www.914world.com/bbs2/index.php?showuser=24231 @http://www.914world.com/bbs2/index.php?showuser=25740
well well well.
thats quite a different approach.
i just have the schtandhardt faktory svay bar that goes through the fuel tank area.
with its absurdly long and small diam drop links!
i see yours will work quite a bit differently.
very short drop link.
i think i can understand the benefits of that but am not a suspension expert.
you would well outqualify me on that front.
i can see how the set up i have keeps me and the steering wheel out of trouble on that front, if the impossible ever happened and the 1.8 got enough suds up to lift off.
i can also fore see a situation where you would get airborne.
I could swap the link to the inside of the sway bar end and be about the same place as the OE bar, but I want more leverage on this stiffer bar. I’m pretty sure sway bar links are mostly strained under tension which is why a 10mm rod is plenty.
Personally, I’d never accept the tie rod hitting the anti roll bar under any circumstance. Having a tie rod get hung up even momentarily could become catastrophic.
There will be dynamic deflections that haven’t been accounted for.
1) the bar walking side to side even with stopper collars in place at the bushings.
2) Deflection of the bar as it winds up with the outside wheel moving into compression and the inside wheel moving toward rebound.
3) Deflections imparted on the suspension from lateral load.
If a sanctioning body like SCCA were to find something like that interference during a tech inspection, I don’t think it would pass tech.
Superhawk, thanks.
1.) Forgot to mention that collars are on order
2.) Compression doesn’t have a clearance issue, but I agree on full rebound.
- I’m lowering the bar mount and measuring the installed size of the turbo tie rod to see if that get me full clearance.
3.) The drop link joints will absorb those with no binding and no interference short of failure.
Basically, copy all on the need for full clearance even at the limit of movement. I’ll see what adjustments I can make.
yeah, get rid of the steering interference.
i enjoy your posts and inquiring mind.
it would be a shame to have it fall victim to an ejector seat malfunction.
i don't know enough about suspension.
nor the theory. perhaps i should since i benefit from driving some good equipment.
however my RS Clio has a rock solid front end.
admittedly its front wheel drive.
but its all incredibly solid.
sub frame. sway bar with no drop links. and in the super duper versions it had a giant front strut external reservoir shock that was like a solid pole.
so impressive that harry of harry's garage and OCTANE fame was driving one as a camera car chasing ferraris and lambos up the alps and was surprised that he could glue himself to their arses. they got away from him on the straights but he was right there again in the corners. drivers of lambos etc were equally surprised they couldn't shake him.
he immediately bought the car. the camera car. and still has it.
so.....i'm not sure about what that means for mid engine cars.
but there might be something to what you are doing.
i'd have to process it.
Yep; way beyond my wheelhouse (pun intended).
I have the original setup on mine, but I never go over 60 and most often more around 35 touring around town.
Best wishes!
I know reading books has gone out of vogue but I’m always going to recommend the Fred Puhn “how to make your car handle” book.
In keeping with the times - this is a pretty good website:
https://suspensionsecrets.co.uk/
here are stock sway bar dimensions i think (?) you were after @http://www.914world.com/bbs2/index.php?showuser=26011
or best as i can measure here in the garage.
sway bar is under fuel tank so i can't do that one but its easy for you to get off your own car if the tank is out.
you can see in photos how the end of the sway bar is forged (or however its done) into a squared section of bar that the lever bar bolts to.
@http://www.914world.com/bbs2/index.php?showuser=24231 thanks. I’m actually looking for the arm length eye to eye from the drop link to where it attaches to the sway bar itself. And the overall sway bar length as near as you can approximate. I know that might be tough to measure when installed. I’m trying to use the calculator superhawk provided to see torsion differences between what I’m attempting and the OE bar configuration.
Thanks for the help!
the lever arm off the sway bar is 120mm eye to eye.
the eye at one end being the roll bar centre and the other end being the drop link centre.
i can only give you those dimensions above for the sway bar length itself.
it protrudes those dimensions either side of the wheel well. you need to be able to measure deeper down in the wheel well to get the interior length.
no can do with fuel tank installed. but you can and then add the 75mm each end.
i would call the square ends part of the sway bar. allow a small amount for inner wheel well thickness and you have the length of the sway bar.
i hope my photo above in post before makes sense. i am measuring the distance out from the wheel well to the cl of the lever arm. all in all the sway bar is 85mm long from the wheel well out. same other side. add interior dimension across the hole that swallows the fuel tank. but lower down than top. you can see where to make the measurement from my photo. can't access roll bar from below car even if i could get myself under it, which i can't. head is too big. bottom panel is in the way.
its fully interiorized man.
realising maybe you are doing some calcs off site.
so here is a very approx dimension on interior dimension of roll bar length measure from top of fuel tank looking at edge of the cavity.
860mm.
maybe add 10mm to account for wheel well walls.
then 2 x75mm each end.
= 1020mm overall length.
good as 1000mm long give or take. the good old metre.
@http://www.914world.com/bbs2/index.php?showuser=24231 thank you kind sir. I think I can use your outside the wheel well numbers to reconfirm your length estimate. And your lever arm numbers are exactly what I need.
@http://www.914world.com/bbs2/index.php?showuser=24231 @http://www.914world.com/bbs2/index.php?showuser=22428
Thank you both for your help, looks like I’m definitely in the window for stiffness! First screenshot is the OE 914 setup, second is the 996 bar.
I think it’s likely the 914 is stiffer than predicted here. As Superhawk pointed out to me, the arms won’t flex like a single piece bar and are a clean 90 deg transition (no diff between x and z). For the 914 length, I measured the space under the tank, measured metal thickness at the pinch welds, and used wonkipop’s wheel well measurements.
Now I’ll continue working clearances and post up for further face shots from the tribe here lol!
I like it! Good attempt at a baseline understanding of what the new proposed bar is in comparison to the stock bar.
In the on-line calculator change the z dimension to something small like 0.1 and it bumps the stiffness to about 169 so not a huge change there.
Just as the online estimator will underestimate the stock bar, it will probably slightly overestimate your 996 bar which I think has a pretty substantial hump in the arm to clear the LCA.
Overall looks pretty reasonable as a starting point. Better than what my first gut instinct thought!
I may be at a dead end because of control arm clearance…
The pics http://www.914world.com/bbs2/index.php?s=&showtopic=361191&view=findpost&p=3057685 show a 20mm offset. But to clear the tie rod end at full droop and full lock requires 50mm! Which means the sway bar is the lowest thing on the car and couldn’t possibly be covered by a modified pan.
I’m trying to be pragmatic about this, but I’m also really bummed that it doesn’t seem like a reasonable mod at this point.
Raise spindles to move the tie rod end up in Z? Raised spindles are generally a good thing to help with bump steer and the lowered front ride height stance that so many like.
Just a thought
Alternatively there are the Elephant Racing bump steer spacer thing-a-Mabob - let me find the link.
Nope I’m a dope - that is moving the tie rod end down instead of the spindle going up which effectively brings the rack and tie rod down. Doh! Both are in wrong direction to improve clearance you need.
Wait what’s wrong with me trying to get you to keep that 996 bar over the elegant stock bar package.
Lol! Because the challenge is what it's all about! I'll post some pics when I get it mocked up with clearance.
While I continue to waste money and time on this front sway bar idea, I thought I would make some progress in other areas.
Got my new fuel tank retrofitted and painted:
Looking at the old tank, it faired very well for a 50yr old piece. It definitely spent some time sitting with a very low fuel level. And I think it’s interesting that the most aggressive corrosion is below the fuel line and not in the condensate region.
I’m thinking to borrow an idea from the marine (and aviation) world and add an anode to the new tank.
You could do that …. But you’ll be long gone before anyone can appreciate it. It made it 50 years without one. I’ve seen Model T’s that still had the original tank! Don’t see why a properly cared for 914 tank won’t make it to 100 too!
I know you’re right, but I can add it in for $20 and treat it as a 20yr experiment lol. $1/yr science sounds fun, right?
Commitments have been made today. But, this also means I will need a new fuel tank if I ever decide to run the car on anhydrous methanol… that magnesium anode won’t like it one bit.
BTW @http://www.914world.com/bbs2/index.php?showuser=22428 … I couldn’t even find that little device on Google anywhere… something tells me it never caught on lol!
@http://www.914world.com/bbs2/index.php?showuser=24231 , I’ve ordered a sway bar taken off an RS America… might be the closest I get to ever owning one if it works out lol!
Yeah, we didn’t get the carrera RS here so, they gave us the RS America. Lighter stripped down version with the M030 suspension setup. So, this will be a 22mm bar, but narrower at the hips than my 996 bar. The standard 964 bar is 20mm.
We’ll see how it goes next weekend.
given your fiddling around in the fuel tank region and you have the fuel pump up front already have you picked up that subtlety about the fuel pump having slightly higher flow rate in the 75s after they moved the fuel pumps to front of car.
its in the fuel injection section of the factory manual right up towards the end of the section. they list the fuel pump specs.
i'm thinking previous owner of your car moved fuel pump but left it as a standard 74 fuel pump? not sure what you have got up the front there.
makes sense that the 75s would have run a slightly more powerful pump to get the length of hose up to pressure faster.
i imagine you are going to do the tunnel fuel lines with all this work you are doing.
i wouldn't be leaving the old plastic lines in. although mine were in remarkable condition except for about the last 4 inches or so near where they exit out through the engine bay firewall. from there on they were plastic about to go snappo.
Affirm. Got some sweet tangerine racing 8mm lines and a two port Bosch. I’ve also modded a 996 fuel filter to use instead of the lawn mower filter the car would normally have.
Now I just have to figure out where to put it. No one seems to make the late model front cover + bracket, and I can’t find one used…
No argument there. If it was, then a steel tank would never be an option. But electrons do move, water does get in the fuel, and now the atoms have a feed trough lol. It only needs to work a little bit.
And you act like front sway bars are all over the internet. Unless you are willing to buy seriously worn set up for $600 or a racing setup for $800, you may as well find another solution. Which suits me just fine for reasons previously discussed.
Duplicate
Don’t kid yourself on price. Used setups change hands regularly for $250-$350. One went recently with all new bushings included as part of the deal.
PMB has the full blown kit brand new at $725 with all new Dansk parts. What you really need is the Elephant Racing set up - I think that one is about $1500!
I fully get you’re in it for the challenge. Carry on.
I’m about to be back on the underside front sway bar adventure, but I took a diversion from my fuel pump relocation diversion to fix the brittle cracked drain tubes on my airbox. Some roughed up copper fittings, a little reaming in the drain stubs, some epoxy, and presto! Deionizing drains lol!!!
Underbody front sway bar project is finally on a vector for success. I had to give up on the 996 bar. But an Addco bar proved to be a cost effective option and still allows me to use modern drop links. This one is a 19mm solid bar and specs out very close to what we calculated for the OE bar previously.
I’m going with the front mounted orientation as it is really the only way to avoid clearance issues… unless I want to develop a bar from scratch. But, I have talked with Addco and they are willing to make me a hollow bar if I want. So, I’m going to be thinking about it, of course.
The front trunk reinforcement turned out to be a good opportunity to deal with some rust spots too
noice, very noice.
guess who came into the workshop today?
the glasurit man. the one who gets the real stuff.
he was in to discuss paint strategy for a lancia fulvia.
interesting bloke. he is a pom. quite a character.
he reckons they have dropped manufacture of a whole lot of yellow tinters.
(not that yellow tinter is necessarily yellow paint in the end but......)
he reckons the ukraine war has upset things. apparently a number of the tints were sourced there. (eastern europe still is happy to deal in poisons which a lot of these old paint ingredients are). problems. dropping lines of colours left right and center.
he is relying on his own (now getting old) stock of tinters for some desperate folks. which he reckons are getting close to borderline to be able to mix up some classic colors.
it was an interesting conversation.
i did ask him about porsche 914 color - saturn yellow. told him it might be listed under VW and the year 1974. he said he would look into it and ring mike back if he could find out current info.
POM = Redcoat, right?
Anyone who prints the queen on their money is suspect in my opinion lol!
I may have actually found a place in Dallas, TX that still sells and stocks 22 line. My initial conversation is promising.
We'll see if I start to gather momentum soon, but maybe this summer I can undertake that challenge. I've been so pleased with the performance of my "Doney Kong" copper manifold that I decided to pull the trigger on a proper 3M spray gun setup for both paint and undercoating.
Once I get this sway bar setup complete, it will finally be time for suspension tear down.
Work has been brutal (my real job) and my progress on the car was rapidly approaching zero, but Ive managed to finalize my underbody front sway bar. I know a few of you will just wonder why I didn’t go with the OEM setup, but you’ll have to add that to your list of unanswered questions lol…
Inside the trunk, I did a base layer reinforcement of 16ga steel; hammered the edges enough to follow the curve. I wanted to distribute pressure over the widest area I could… and maybe even transfer some load into compression of the vertical sides.
Then I topped it with 1/4” plate to ensure I have no distortion or flex at the mounts. Stitch welding that much on a low heat setting took forever, and just couldn’t be made pretty like a single bead, but I did avoid warping.
After several dry fits, I was inspired the box wrench I strained to reach while I worked the ratchet underneath. Thus, I cut some sheet metal into a dog bone shape and welded the bolts into a handy removable single part. Made it low profile so it wouldn’t rub the spare tire.
And as a final touch, I got some CNC aluminum brackets. All in all, I’m pleased with the result. Modern drop links will ensure no binding and should give a long life. When I pull the control arms, I’ll finalize that mount and consider moving them out a bit more. I want to get at least 75% of the arm length to work the sway bar. If anyone knows the distance from centerline pivot, to the OE link mount, I would appreciate the reference.
175mm from c/l of torsion bar to c/l of drop link mount.
sway bar mounts look good.
be interesting to find out this works out when you are back on the road
I had hoped to post up the results of my fuel pump and filter project, but while working on it all, I discovered the dreaded tunnel rust
That leaking master cylinder I replaced last year apparently had been leaking bad for a while (DAPO) and the fluid worked its way through the tunnel.
Obviously I wasn’t expecting this and had to come up with a plan for what must be the most difficult rust repair known to the 914 world.
I decided to go full send.
I bought a chemical resistant garden sprayer… thanks COVID for making such products enter the marketplace lol…
Anyway after about a gallon of evaporust and a dozen iterations of spraying a pressure washer through the tunnel and catching the flood with a shop vac, I got a pretty impressive result!
I forgot to take a before photo… mostly because of the sheer trauma and panic lol, but you can see on the right side of this pic what the whole tunnel looked like, and worse.
Finally I sprayed some phosphoric acid to convert what was left.
After it all dries, I’ll spray some phenolic resin and from eastwood and then some epoxy sealer just to be sure…
well you might be suffering corrosion trauma (hey - it is a 914) but i am looking at above tunnel surfaces and observing a highly intact car. all those stuck on vinyl pieces on the floor just like they are supposed to be....are there. nice.
bonus - gorgeous green/yellow paint on the upper floor pan. original.
Thanks wonki. That's an important reminder.
What's frustrating with all these trouble areas is that they're all preventable with proper maintenance and repairs. Overall, I've managed to catch everything before it went real bad.
Soon, I should be back on track. I'm real close to starting the chassis/suspension rebuild.
if its any comfort i had to get stuck into mine a few years back during recommission when i had the tank out and suspension off. where we had done work on the firewall for RHD conversion 30 odd years ago was showing signs of corrosion initiation! nipped that in the bud.
i love por15 and seam sealer. (not).
its good stuff but jesus get any on your skin anywhere and you are wearing it, its not coming off.
luckily i did not have tunnel trauma syndrome. had a good look in there doing the fuel lines.
ps. as an aside i ran into the guy who did the conversion mod work on the firewall and pedals etc all those years ago a couple of months back. he is a respected mgb guy a few years older than me.
he is still alive. he was at a hillclimb event the mg club run. he asked me about the car and was very surprised and delighted i still had it. he has a mgb he bought as a twenty year old in the 1970s. getting on to 60 years of ownership.
back in the early 90s he was converting a lot of mgbs shipped out of california and then onselling to japan. a lot easier to convert an mgb than a 914.
After dealing with the tunnel and some excursions looking at parts, charting the way ahead, I needed some results. A few weeks ago, I got fed up looking at the lumpy stitch mig welding on my underbody sway bar mounts, so I TIG’d it up with many many tiny welds. Then I steam pressure washed the old ziebart off. Today I did the acid phosphate etch and cracked open some of my fancy 3M underbody coating and pressurized spray gun.
This stuff is gonna be awesome, but I’m gonna need more. It’s a rubberized coating, but it dries pretty hard yet stays flexible… borderline plastic like.
For the one or two 914world friends I have still following my progress, here some more of what I’ve been up to.
3M seam sealer and rubberized coating on the back wall to seal it all up
And a pretty hilarious late night find on Amazon… yes “Amazon Basics” butyl sound dampening mats.
I bought it first because it was too funny to say that I have amazon sound dampening, but also because its crazy cheap. Lets face it, everything out there is private label manufacturers anyway. And this stuff specs out pretty well, right in the middle at 1.5mm butyl with .1mm foil. And it’s priced cheaper than the 1mm stuff
https://www.amazon.com/AmazonBasics-Car-Sound-Deadener-9-Piece/dp/B07XMF3KK5
Final top off is eastwood closed cell foam. All 3 layers together are lighter than the original back pad but far more effective, mostly due to the form factor and adhesion of the amazon butyl, but there is definitely a cumulative effect to cover more frequencies of vibration
That would be really cool wonki!
I’ve got plenty of hilton honors points that I could contribute to that leg of the trip too!
Overall, I’m really pleased with the amazon stuff and I would recommend it. Get a roller though. 2mm butyl would be nice, but 1.5mm with the undercoat that will be on both sides is a superior solution IMO.
Butyl on foil doesn’t bridge well at all, obviously. So, I ended up doing a lot of cardboard templates.
I am following your build.
I'm a follower, too. Between @http://www.914world.com/bbs2/index.php?showuser=9712 Michael and me, you've got at least double what you thought you had. Now stop whining and get back on the project!
Oh man, now that I know I’m being supervised the pressure is on. But I guess since I haven’t gotten or responses from you guys, then my decisions are at least acceptable lol… or maybe just morbid curiosity to see if any of them turn into a cautionary tale
#dobetter
After laboring through the gummy nasty second layer of paint on the driver side rear quarter, a funny thing happened on the passenger side. I noticed a small section delaminating as I was working with my coating removal disc. So, I pulled on it a bit while it was still warm.
My instinct was correct, the paint was not at all bonded… anywhere.
So, I took a torch and chisel and stripped it like old house paint lol! Unfortunately, I found a terrible excuse for dent repair that was rusting away underneath. Because I have all the records for this car, I know exactly when and who did this “repair”. What I didn’t know until today, was the extent or quality.
I suppose one silver lining is that this was the fastest I’ve ever stripped the paint off a car lol… and dust free!
at this rate when i touch down in dc to check out the lunar module in the smithsonian - i won't get a ride. (i'm really going to check out the plywood german flying wing from WW2! and the Bee five two if they have one? )
@http://www.914world.com/bbs2/index.php?showuser=10753 will have to come to the rescue with his bernardsville vicinity original so i can relive my wasted youth enjoying your fine country back in the late 80s.
i shoulda stayed, married the girl and become a citizen.
then i could drop in and help you rip the paint off.
keep going. it will be great.
esp if you can reproduce that fantastic undecideable yellow or is it green.
same as phoenix red or is it orange.
its still a good car despite the minor prang in its distant past of being
i'll be demanding an up close special clearance inspection of an F117 if i have to stand around your car on jack stands drinking a beer.
ps
love the wheels. good look oh yes.
am almost ashamed of my star steelies, but you know.
got to go with the corny VW attempt at sportiness because i was born a nerd, much to my mother's despair.
Wonki, I can't fathom how many surprises hide in the small, finite space that a 914 fills. But in my case, the answer is still more lol...
Nice progress......love the wheels!
Paint delaminating is what lead me to paint my '76 too! I was able to strip the lids and large areas in other spots with a scrapper and a couple of boxes of razor blades. In retrospect I'm glad it happened or I would have missed the qtr panel repair. What is a coating removal disc Van? @http://www.914world.com/bbs2/index.php?showuser=24231 you might consider adding the Space and Air Museum in San Diego to your travel plans. https://www.sandiego.org/members/museums/san-diego-air-space-museum.aspx
@http://www.914world.com/bbs2/index.php?showuser=9964 I use these bad boys in 7” diameter on my polisher.
https://www.3m.com/3M/en_US/p/d/b40071650/
Doesn’t gouge into the metal unless you get on the edge accidentally. And with a polisher you can slow it down to control the heat you put into the panel.
The last time I looked at this thread you and Wonki were talking about furniture
Now I check in and the car is torn to bits and missing paint.
You’re on your own there wonki. I’ve never been on a skateboard in any real way. Where I grew up, roads were flat and rough and pools were above ground lol
Making problems, then solving them and declaring it an accomplishment lol…
Made a video detailing my method for preemptively solving door alignment issues.
https://www.youtube.com/watch?v=GhrzzHzztLE?si=Tt_KvG2v4HPywOqZ
https://youtu.be/GhrzzHzztLE?si=N4kM7ySNODyXjxqM
Don’t mind the red tape, I was paid a visit by my in resident auditor. I gave her the tape and said mark anything that doesn’t look right to you… she found a lot
Work and weather stalled progress for s bit, but I got some things going again. I decided a while back that I would do my own replating and what better place to start than on parts that I will paint over!
I went with the caswell kit vs making my own solution. I have made my own brew before, and had good success with electropolishing, but plating never came out cosmetically the way I would like. Other than the easter egg chromate dip on the caswell kit, which I’m struggling with, everything else is great.
I also, refit the doors again after bolting the hinges back up, just to see it all work and those pins did exactly what I needed. What a relief that I won’t have to fight that down the road!
Your plating turned out good. I may try that one day. Years back a body man told me to drill those door hinges. and trunk lid hinges with a 1/8" bit before removing them. When re-mounting the pieces insert the drill bits stub end first. It help[s to place a bevel on the stub ends. Fast forward to present day: A neighbor who was a body man years back came by to check out my work last year and gave me the business for drilling those holes. A couple of weeks ago he dropped by to lend a hand remounting the front lid. We loosened /tightened the hood several times before he sheepishly relented and let me do it my way. Now he is a believer. Can't wait to see your finished product.
