Printable Version of Topic
914World.com _ 914World Garage _ Muffler shield
Posted by: NARP74 Sep 29 2022, 01:51 PM
Mine is missing and what is left behind looks like someone took a pair of pliers and yanked it off during a pit stop.
Is this part available just as a shield or part of a trunk patch? I looked at a couple of suppliers but I am not finding anything.
Posted by: worn Sep 29 2022, 02:19 PM
QUOTE(NARP74 @ Sep 29 2022, 12:51 PM)
Also, if you have one, are the different versions interchangeable? If I backdate the exhaust on a 76 can I use the earlier version? Not to hijack the thread, but if new ones are made, which version?
Posted by: 914werke Sep 29 2022, 10:17 PM
I dont know of anyone reproducing them but I have one or more late ones.
The early version seems to be harder to come by.
Posted by: NARP74 Sep 30 2022, 09:12 AM
QUOTE(914werke @ Sep 29 2022, 10:17 PM)
I don't know of anyone reproducing them but I have one or more late ones.
Mine is a 74, I assume late? Got any pics?
Posted by: dr914@autoatlanta.com Sep 30 2022, 01:34 PM
actually they had 91450159410 superseded by 59411, the 914-6 was screwed in, the fours were welded in
Posted by: NARP74 Sep 30 2022, 01:39 PM
Heat protection plate, that is why it did not turn up in any of my searches under all the other names I tried.
Posted by: 914werke Sep 30 2022, 01:46 PM
It (was) available https://914werke.com/shop/ols/products/muffler-heat-shield/v/MUF-HT-SHL-LT
Posted by: NARP74 Sep 30 2022, 01:55 PM
@http://www.914world.com/bbs2/index.php?showuser=453 send me a PM
Posted by: NARP74 Sep 30 2022, 02:03 PM
QUOTE(NARP74 @ Sep 30 2022, 01:55 PM)
Thanks, never mind about the PM...
Posted by: Mikey914 Sep 30 2022, 05:13 PM
I know when I had some work done on my car Cary made it so that it could screw in. No need to weld it, and easier to service.
Posted by: NARP74 Sep 30 2022, 06:50 PM
QUOTE(Mikey914 @ Sep 30 2022, 05:13 PM)
Got any pics? That sounds doable. This car is not very nice and I don't weld.
Posted by: nathanxnathan Sep 30 2022, 07:40 PM
70 model year 4 cylinder cars, they screwed on. I know 72's they are welded. I'm not sure about 71's
Posted by: NARP74 Oct 4 2022, 02:21 PM
Looking for pics of early bolt on heat protection plates, AKA muffler heat shield.
Posted by: SA-914 Oct 4 2022, 02:47 PM
I ended up welding nuts to the underside of the shield, everywhere there was a welded tab. I have small, countersunk screws in the truck....
Posted by: NARP74 Oct 5 2022, 08:45 AM
I don't weld, but I could do nutserts or something similar.
Posted by: dr914@autoatlanta.com Oct 5 2022, 08:52 AM
there are plenty of the used ones available
Posted by: DaveB Oct 6 2022, 01:09 AM
QUOTE(914werke @ Sep 30 2022, 12:46 PM)
Thanks for posting the link. An hour after I clicked the buy button you sent the shipping tracker and its delivered tomorrow. I thought Mark was fast at 914Rubber. You're more like 914Amazon.
DaveB
Posted by: 914werke Oct 6 2022, 08:54 AM
just the luck of the day (go buy a loto ticket!) to catch me on the computer rather than wrenching on a cust car.
Posted by: Mikey914 Oct 6 2022, 09:29 AM
QUOTE(DaveB @ Oct 6 2022, 12:09 AM)
DaveB
Sorry guys the day job has kept me busy. I was checking my photos and don't know if I have one. He used tinnerman nuts on the body and drilled the shield to screw through adding a lock washer.
I miss Cary
I haven't had a chance to get out to the car yet.
Posted by: nathanxnathan Oct 6 2022, 10:27 AM
The factory removable ones, the brackets are attached/welded to the heat shield and there are speed nuts/clips on the flanges of the brackets.
When I took mine off my early 70, it may or may not have been the factory install so I can't say for sure how the factory did it, but there were Phillips head screws down through the trunk floor, and they were covered in seam sealer and painted over.
I can get a pic later of the heat shield with the brackets attached with the speed nuts in place.
Posted by: NARP74 Oct 7 2022, 08:41 AM
@http://www.914world.com/bbs2/index.php?showuser=21899 Thanks, that helps a lot.
Posted by: Montreal914 Oct 7 2022, 09:14 AM
Here is what I did (lower part of this post):
http://www.914world.com/bbs2/index.php?s=&showtopic=349463&view=findpost&p=2910494
Missing picture in the thread, holes in the trunk done using template. Shield bolts on perfectly.
Posted by: NARP74 Oct 7 2022, 09:17 AM
QUOTE(Montreal914 @ Oct 7 2022, 09:14 AM)
Thanks for showing me that.
Posted by: worn Oct 7 2022, 11:41 AM
QUOTE(worn @ Sep 29 2022, 01:19 PM)
Ahem. At the risk of repeating myself. How interchangeable are they vis a vis exhaust lines? Make any difference. With the 3.2 I decided to use machine screws cause it just made more sense.
Thanks.
Posted by: majkos1 Mar 4 2023, 12:15 PM
Of the later heat shied,
what's the purpose of notch and rounded cut out?
Posted by: NARP74 Mar 4 2023, 12:25 PM
@http://www.914world.com/bbs2/index.php?showuser=13152 did you get an answer? I don't know. @http://www.914world.com/bbs2/index.php?showuser=21338 I don't know since I don't have one yet. Still learning...
Posted by: 914werke Mar 4 2023, 12:43 PM
@http://www.914world.com/bbs2/index.php?showuser=13152 Based solely on the vast # of /6 conversions the exist & have been running around for decades Id suggest there is no real "interference" issue.
Think of it this way the 911, /6 and the /4 banana OE mufflers were/are kidney shaped not straight /right angled like the late shield ...but still fit w/o clearance issues.
So unless going for originality, a late shield should do the job intend just fine.
Posted by: 914werke Mar 4 2023, 12:46 PM
QUOTE(majkos1 @ Mar 4 2023, 10:15 AM)
Of the later heat shied, what's the purpose of notch and rounded cut out?
Its been discussed before.
Could be argued that the round cut (& wire tabs) was for the routing of the EGR wiring cept, they exist on shields prior to 75 ?
Posted by: Front yard mechanic Mar 4 2023, 12:51 PM
I prefer no shield it keeps my burritos warm
Posted by: 914werke Mar 4 2023, 12:53 PM
Just dont put your ice cream in the trunk on the way back form the grocery store.
Posted by: majkos1 Mar 4 2023, 01:02 PM
QUOTE(914werke @ Mar 4 2023, 01:46 PM)
makes sense.
I also thought since the body I have (and chopped up) was a '76 Calif. 914 so,
calif emission stuff?
Sorry Guys, the shell was severely cracked up and PO didn't want it repaired.
party!
Most of the good parts found good homes.
Posted by: worn Mar 4 2023, 05:02 PM
QUOTE(NARP74 @ Mar 4 2023, 10:25 AM)
Kind of. My ‘76 has a burned out shield and I have a replacement that looks different. Presumably i am putting an early shield on a newer car. But. The heat exchangers will be back dated. So i will just wait and pop rivet whatever fits when the painting is done
Posted by: bkrantz Mar 4 2023, 10:04 PM
Here's my 73 muffler shield bolt-on modification. Two new brackets that bolt through the shield.
Posted by: bkrantz Mar 4 2023, 10:05 PM
Brackets welded to the trunk floor.
Posted by: bkrantz Mar 4 2023, 10:07 PM
Shield bolted on. All this was before I did paint. I eventually had the shield powder-coated with high-temp powder.
