This is a spark plug tool from a 911 -914-6 tool kit. It’s missing the rubber insert. Anyone know where to source the insert?
Do you need the 'official' insert? Mine has a slightly different spark plug tool, not sure where it is from. But I think it is more of a sponge rubber type.
Maybe buy a cheap plug socket from your FLAPs and take the insert out?
Socket and insert from a FLAPS. It is not 'necked down' though like yours. Might have to trim the insert-it is high density sponge rubber.
This is the plug tool I have. Anyone recognize it?
I didn't want to pull the insert, but it looks like a harder rubber. As suggested, like a plug wire boot. Maybe make a junkyard trip and pull a couple?
I have the whole tool, but the rubber fails to grab any more, so
I pulled out the rubber. So this is what it looks like.
Sierra Madre is selling new spark plug wrenches but they don't really
match the old ones, so like everybody else, I think I want to find a cheap
new generic one and grab the insert if it matches well enough.
Maybe try some fuel hose or heater hose. A bit of hot glue to hold it.
I know it doesn't answer your question, but I like to use a short length of fuel hose around the top of the plug to twist it out / in. I only use the socket to break it loose or torque it down. So maybe you don't need the insert
