So I figure I better start contributing with some real content rather than stupid jokes and snide remarks. So here goes.
I purchased my 1973 1.7L for $300.00. Damn good thing to because there was about 8 thousand times the rust that I could see (duh!)
Before I tore the car apart I got the engine running. PO said fuel pump was bad. Turned out the relay was bad and in his attempts to fix the problem he reversed the fuel lines. Put a new relay fired right up...ran like crap but still it ran.
After stripping all interior, electrical and accesories from the car the real work started. Nothing more than expected just a long list.
Some of the problem area identified.
1) Rust in longs
2) Rear trunk and valance panel totally rusted out
3) Floorboards very rusted out - quite a few holes
4) Sill plates and door jams very questionable
5) Typical battery tray and engine shelf damage
6) Front trunk rusted around AC unit
7) Sail panels - bad PO repair with Bondo
Just one note for the rest of this, I am not CptTripps... these pic's are over a years time span. The reason I am finally posting all this is to motivate me to get 'er done.
It may not be realistic but I am still shooting for the FFC this year. I really have to get moving NOW!
First task at hand was to cut the trunk and valance panel out. Lid was scrap. Got a few used pieces for replacement.
All buttoned up... still needs finishing and rear trunk pan.
Man...you really have your work cut out for you...(No pun intended)
We'll motivate you...just you wait.
Next Task...
Drop the engine. Easy job took my brother and I about three hours.
Damn that engine looks big when it is not in the car
Hell Hole after engine removal
Big Problem when removing the engine... had to cut the engine bar. YIKES
Next Task.
Longs are solid but have some major patches of rust. Cut it out and patch new metal in. Oh the carnage
Thanks to Dr. Evil for the clam shells... Just what the Dr ordered.
A little test fitting
My buddy Dave (acting like a dork). Leveling the car before welding the clams on.
Finished Welding... still a little clean up to do but that will come soon.
Other side... rust was not as bad. Less patching to do Clam ON
Stripped Down. Doors and targa off now that I trust the frame rigidity. Ready for sills and door jambs.
Door jamb carnage. Also firewall damage along with inner fender damage.
Cut the door jamb out. Normally you would pull the fender. I decided not to mess with aligning the fender etc. My plan was to grind out the old and smooth in the new.
Firewall and inner fender repairs... no making fun of my welds please
New door jambs. I test fit these suckers about a million times. Normally they fit in behind the fender. I fit the flush with the fender. No problems with door clearance.
Next new door sills. Pretty easy installation.
Test fitting donor lower fender. Original was absolute shit
New fender welded in... major finishing to do.
My car needs a special ed class... it stutters PPPorsche.
Checking the final alignment
Oh BTW....
Doug when I was putting these pic together last night I saw the parts pics and remembered I forgot to send you something.
You should have mail in the next day or two... Thanks BUD!
Just some rattle can primer to protect the bare spots.
Also first coats of All Metal filler going on.
For those of you that do not know what All Metal is... well here it is.
It is a alluminum based filler. Totally waterproof, does not shrink, sands smooth and cures fast.
That's it for now. More pics at home on the Camera will post them tonight.
Great pics.
I've used the All Metal stuff on my car and love it. POR-15 sticks to it like glue.
Great job!!
QUOTE (tdgray @ Aug 10 2005, 11:18 AM) |
Doug when I was putting these pic together last night I saw the parts pics and remembered I forgot to send you something... |
QUOTE (CptTripps @ Aug 10 2005, 01:10 PM) | ||
LOL...I saw that pic and had the EXACT same thought. No worries man. I know you are good for it. Looking great...seriously. Let me know if you need me to come down and help with anything. |
Just call. I can even drive MY 914 there so your wife can see what they are supposed to look like!
Angie is on call Q5 right now, so I get 1-2 nights a week that I can come help.
QUOTE (tdgray @ Aug 10 2005, 08:10 AM) |
New door jambs. I test fit these suckers about a million times. Normally they fit in behind the fender. I fit the flush with the fender. No problems with door clearance. |
QUOTE (rdauenhauer @ Aug 10 2005, 04:46 PM) | ||
Good pics, where did you get the replacement door jam? |
Nice work Todd! That is a big project. I started working on some longs in similar condition to yours when you started. Did you end up cutting out the whole clamshell and replacing it or did those fit over top of the original?
Jerry,
These are designed to fit over top of the existing longs.
I cut out the bad sections of the now "inner" longs metal. Replaced it with sheet metal and then fitted the clams over it.
Was kinda nice, didn't have to make the "inner" repairs look nice... just strong.
Thanks for posting the pictures Todd. I have most of the bad parts cut out so I guess I'll be looking for a set of those.
Great progress, keep the pictures coming.
QUOTE (JerryP @ Aug 11 2005, 12:13 PM) |
Thanks for posting the pictures Todd. I have most of the bad parts cut out so I guess I'll be looking for a set of those. |
One small victory this week.
No more side markers... personally I feel the stupidist thing on the 914. Absolutely ruins the lines... so gone!
I finally took a couple of vacation days this coming Monday and Tuesday. I have not been able to get away from work this year. One freakin vaction day since April 2004 DOES NOT CUT IT. I said it. Twelve hour days for over a year striaght are not condusive to a 914 restoration.
Hopefully I can get some serious work done this long weekend
My helper...
She is my tool wench, if I drop a wrench she is on it like stink on
Also, my best friend. Hard to see in pictures, first all black Cocker I've had, don't photograph well
I like the cooking show nature of your trunk repair pics.. you know, pulling the finished one out of the oven..
Insane work man! Looks great!
M
QUOTE (redshift @ Aug 12 2005, 07:04 PM) |
I like the cooking show nature of your trunk repair pics.. you know, pulling the finished one out of the oven.. Insane work man! Looks great! M |
My simple fix for this was that I have a digital camera thats not allowed to leave the garage. I keep the charger out there, and put it on top of the car/bench so I'm sure to see it, and take pics.
Great work man...
I'm jealous. You guys get all the rust!
Nice job!
To all those in the far off land of no rust - this is what we deal with in the midwest and east coast. This is a real nice job of saving what would be a 'parts car' in the land of no rust.
Now 'git r' done' and come to the FFC05! You must make it!
So far (and i will not disclose anything yet) there is well over $1000 in just give aways.
M
Well... my two days off came and went.
I spent half the first day fielding phone calls from work and spending time with the family. Cooked a mean breakfast of chorizo sausage omlets though
Actually, went very well. Doesn't look like I got a whole of progress but believe me this was the hardest part yet. Crawling in and out of the engine bay with various and many tools is a total PITA
This next project was engine bay prep time. Not for the faint of heart.
Typical battery tray rust.
I had already cut ( in a previous work session) most of what remained of the engine shelf out.
This is the "other half" of the rust I encountered when replacing the door jambs and sill plates.
Time to make with my crappy welding skills
Other nastyness from this side.
Amazingly the other side (drivers side) is solid as a rock.
Fabricated and started welding in patch... and no obviously my welding skills have not got any better since the last posting.
I treated the area with Ospho (you can see the black sections starting to form. This will take a few coats. Ospho is a rust converter and a primer. I treated the rest of the engine bay with it later (don't really like to apply this stuff and weld around it).
Sorry for the somewhat " Andy" quality pics.
My arthritis was giving me some serious fits this day. I know, I know... I am not that old... just a bad break from the inheritance fairy. Early onset. sucks
Here is a fitting of the new engine shelf piece.
Notice the rear part.
Although this piece is high in quality from RD, as with all rustoration pieces they will need "customized".
This one was pretty easy. Just a little hand wrenching and a few hammer taps.
Although the end was a bit short, I'm sure that the seal will fill the gap properly
Tacking the rest in.
I am such a freaking baby when it comes to welding. I get the whole " gee I better not put too many welds in just in case I screw the rest of it up".
I really am getting better at it though ( I know it doesn't show but at least they're easier to grind )
On to the battery damage.
Most of which was caused by taking out.
Pics is slightly deceiving., I saw this pic and said WOW it didn't look that bad. Actually it was. Lot's of grinding. Came out nice and smooth.
And in my usual style (read: yes I went like hell and forgot to take pics).
I wheeled the car outside and gave the engine bay a degreasing bath with the pressure washer. Let it dry for a couple of hours and then Ospho'd the lving crap out of it.
Got up the next morning and did this.
Don't worry... this is only "Rock Guard"
It is basically a textured spray that insulates sound and provides a chip resistant surface.
It is totally paintable. The engine bay will be white just like the rest of the car.
I did realize after I got this on that some of my welds from the previous day looked a little rough... to say the least.
At this point I went and bought an angle die grinder. SHIT if I knew how much better that worked I would have bought one long ago. OH WELL live and learn.
More after the bay is painted... next weekend hopefully.
Oh forgot to add one more thing.
Before everybody goes "Well shit he didn't do the bottom of the bay"
I know this is going to be POR-15'd shortly (notice the making tape around all the channels and other surfaces)
Will do before painting.
Also, I am not totally committed to moving the battery to the front trunk. I still reserve the right buy a new battery tray and grind and weld it in.
Will advise.
Man, looks like good work, but I can't believe you guys do this. For about $1500 (including shipping from So Cal) you could just start with a much stronger tub!!! That car needed a lot of work!!!
-Steve
QUOTE (siverson @ Aug 17 2005, 09:23 PM) |
Man, looks like good work, but I can't believe you guys do this. For about $1500 (including shipping from So Cal) you could just start with a much stronger tub!!! That car needed a lot of work!!! -Steve |
QUOTE (siverson @ Aug 17 2005, 08:23 PM) |
A bit of bad news to go along with all of this
I was sorting through the engine components so I could put an order together today. Just misc stuff like vacuum hose, grommets and such.
As I was sorting and cleaning I came across my MPS, hmm I had a thought let's see if it still holds a vacuum. I had tested it when I first got the car, very breifly. This was when I was chasing down fuel and vacuum connections. I remember that it did at least "pump up" but I didn't take it any farther than that.
Well short story long here... I put the vac pump on and NOTHING. NOT A DAMN THING
This is going to be a major problem.
coughCARBScough
QUOTE (CptTripps @ Aug 18 2005, 08:08 AM) |
coughCARBScough |
Well....I've got the dress for your pig if you are interested. YOU KNOW where I got them.
I've emailed Geoff (Bleyseng) to ask for divine assistance.
If anybody has seen him give him a and direct him to me.
THANKS
Sorry Guys, it's been awhile
I have been working on the car... just not as much as I want to, DAMN JOB!
Here is two weeks ago. Talked the right side door jamb and sill. Easier than first since I been there done that.
Here is final fitting before finish welding. Fender is original. Makes life much easier.
All welded up (hah.. I forgot to take pics so you cannot make fun of my welds).
First coat of all-metal.
Here is the really UGLY ... my eyes...my eyes.
This is actually a donor door I got from Doug H. Believe or not my orginal was worse.
That is a pretty deep smack in the door. Some A-hole had filled it with plastic filler.
The rest of the door is pretty straight. I have no doubt that the All Metal will be just fine. Shouldn't take more than three coats to egt it smoothed out.
Took a little break from body work to work on the front valance.
Just a wire brush to remove some scale.
Again, this is rock guard. It will be painted whiet with the rest of the car.
Oops forgot the pic. That's enough for me tonight
Wow...that's some serious progress....
Want to come help with the body work on mine?
This is this last weekend. I dod quite a bit of body work. Mostly sandind filler and ID'ing spots for repair. No pics of this as it is pretty boring.
Body is totally roughed in. Mainly just finish filling to go. Almost ready for some high build primer and lots of blocking.
I decided to take a break on Monday and work on the engine, I would like to get it back in the car in the next ten days.
BEFORE
QUOTE (CptTripps @ Sep 6 2005, 09:22 PM) |
Wow...that's some serious progress.... Want to come help with the body work on mine? |
Let the tear down begin
Oh BTW... the tool box in the prevoius pic belongs to my little mechanic... he lost interest about fifteen minutes into the tear down. He took a "break" to play baseball.
The parts boxes grow
Stripped down naked... or almost. This is as far as she goes
You would think with a valve cover this bad... the damage inside would be VERY BAD
Not too bad... in definite need of adjustment. but pretty clean otherwise
Here she is after a nice bath. Took me an hour to get the driveway clean after this.
The rest of the yuck should come off with a stiff wire brush.
Tonight's progress
They could be better but, hey it's just a driver. The rest of the tin will be done this week.
I ordered some parts this AM. Maybe just maybe if all goes right the engine can go back in next week.
Still have to decide what to do about the battery tray and paint the engine bay.
Enough for tonight... the wife is giving me the "are still doing that" look.
One more and it's crash time.
Todd, you are rockin' bud.
Really great work. I love these threads. Did you resolve your MPS problem?
I have to say "I am totally in awe".......
keep it up!
steve
QUOTE (aircooledboy @ Sep 6 2005, 09:58 PM) |
Todd, you are rockin' bud. Really great work. I love these threads. Did you resolve your MPS problem? |
OK... While waiting on parts for the engine and a few misc other things...
Look what the sheet metal fairy brought me.
'nother
This is where they go.
I have to tell ya. This was the freaking hardest job on this car.
I know there is not alot of pictures for this progress... mainly because it was a tremendous amount of backbreaking work and not much to show until the end.
This was not the worst rusted part of the car.. but definitley the hardest to work on. I ruined more of the good metal getting the pans out than was rusted.
You absolutley want a good jack and at least five hands, unfortunatley I only have two.
If I had to do it all again, I would build a rottisere to do this.
Passenger side pans * mostly * welded in.
I went back to flux core wire for this job. I knew there would be tons of welding and I would go through like 3 bottles of MIG gas if I went with mig on this.
Quite a bit of black scaring and ugly welds but they're in... plenty of grinding to do as well.
Biggest thing I hate about flux core is the shit popping all over the place. My arms are covered in pink spots (I know, idiot put on long sleeves).
I add this pic only to tell of the horror that is getting off a rusted on hand brake lever.
I cranked the air compressor to 95 psi and went at this thing several times with an air hammer and ball joint removal tool. WHAT AN F'IN BITCH. I could not imagine trying to get this off with a pry bar and hand tools.
OH and obligatory rust holes
Drivers back. Tacked in.
Ran out of welding wire and steam at this point....
Ultimate F'in bitch this job. I figure one more day to go and we will be done.
Sheesh.
Sooo... it's been awhile.
I have been working pretty much non stop, well at least for the last 14 days in a row. I have had virtually zero garage time.
After I got home this last Monday, I felt I needed to unwind... so off to the garage I went. Wnated to keep it light, how about a valve adjustment???
Using the Cap'ns method, very easy. Worst part was figuring out the true point of "rocking" Messed a few up at first but went pretty well after a little nogin noodling.
After a little more cleaning and some new valve cover gaskets... time for reassemble. (this is Tues BTW).
Little Further.
Yeah I know... you asking jeez those FI intake tubes are awful shiney.
WELL... I bought this paint. I thought it looked like dull alluminum. Then I started painting. DAMN stuff looks like chrome when wet, it did dull down a little.
Obviously a little mix up at the paint mfg or store. I was going to repaint them but the kids said it was "NICE BLING DAD"
I still reserve the right to yankthem off and repaint
Mostly together.
Needs..... vacuum hoses.
QUOTE |
I have to tell ya. This was the freaking hardest job on this car. |
You will never, never , ever get me to tell you where I purchased these
But I did measure and record each hose and where it goes. I will post a VH diagram for 1.7's when I get some time so no one has to do the unthinkable like I did.
UNCLEAN.... AUUUUUUUUUUUGH
my own thread.
Hey Doug ... long time no see... where ya been. How was China?
Pretty soon my man, hopefully a put it back together party eh?
Last one for tonight....
Looky what the parts fairy brought me. HUGE thank to Eric Shea. NICE JOB MAN.
Eric... core go bye-bye today. Thanks buddy.
Wow. I just went through the entire thread. Some good work you're getting done there.
Don't stop now.
Thanks Gint, 'preciate the words of encouragement
good work. Glad to see one being saved. you're my hero
Man, You are doing a great job, Body Work is very nice and Car is coming along great! Keep up the good work!!!!
I'm up for another put-together party for sure...
...then we can do a 'take apart' party on mine.
I've got a plan
Great job.
On sept 12, 2005, you have a photo showing the driver's back floor welded in, what is the red thing with the wire attached? Is it for the ground to your welder? If it is, what is it called, I could use something like that...
-- Rob
Rob...
Yes it is a magnetic ground for the welder.... very handy. A couple of bucks at Harbor Freight. Beats trying to find someplace to clamp on to. Just have to make sure it is clean, if not major sparks a'flyin.
Well, I took a half day off work yesterday to prime. Got the first coat on her before the kids came home from school.
Damn I forgot how smelly all that crap was.... my neighbors loved it I'm sure
BEFORE.
'NOTHER
VIOLA... AFTER
MORE AFTER
FRONT AFTER.... NO MARKER LIGHTS YEA!
LAST ONE.... WOW IT IS SUPER HARD TO GET UNDER / IN THE ENGINE BAY ETC.
looking sharp man...
I Love when they are all primed like that....thinking about using a darker grey like that on my next one...
Nuthin like a tub in bare primer. Looks almost... new.
OK Guys just a little sneak preview.
I am soooo far behind it not funny. Work is just getting more hectic. But I managed last Sat and Sun to paint the body. No engine bay or rear tunk yet. Door and Lids need finished. If I get time this weekend I will finish. It is getting cold here... need to finish before it gets really cold.
A little teaser
NOTHER
I don't know why I love this shot.... I just love '14 without the damn side markers. SHWWWWING.
I am sooo pissed that I could not get this done in time to attend the FFC.
Hopefully next year will be a much calmer year and I can attend some car related events.
I have only been to one MG car related event this year... no seat time in either car. SUCKS!
QUOTE (tdgray @ Sep 29 2005, 07:15 PM) |
Last one for tonight.... Looky what the parts fairy brought me. HUGE thank to Eric Shea. NICE JOB MAN. Eric... core go bye-bye today. Thanks buddy. |
Look in the vendor section. Eric Shea rebuilds and plates them.... I know he will have a core available... as soon as I get off my ass and send it back to him.
Nice work Todd...let me know if you need me to come down there and stand around in your garage pointing at things with you.
::: Sound of Crickets :::
Anyone here?
QUOTE (CptTripps @ Dec 1 2005, 06:00 PM) |
::: Sound of Crickets ::: Anyone here? |
I can't believe I've never seen this thread before. Great work.
Todd - How you makin out? MORE PICS!
Sorry Guys... it's been a long time. To tell you the truth I burned myself out trying to make the FFC and then there was the big rift in the club. I am still a little bitter over that whole mess so I have not been participating latley.
Here are a few updated pic's.
The weather got pretty bad here pretty quick.
On my last post I had painted the car but still had the doors, hoods and engine lid to do. I went out on a Sunday to paint them, got three coats of paint down and waited for my flash time to clear. Went back out to the garage and KA-FREAKIN-BLOOOOWIE the air compressor went out. Got a replacement the next weekend. Only problem was that I was not used to it or knowlegeable of the correct pressures etc. Result= A shit load of orange peel in the clear on the doors and hoods. Oh well I guess I'll be sanding and buffing come spring.
I had to get the garage back to some sense of order so that my wife could pull the crumb-cruncher van back in. So time to put the engine back in. Well it was interesting... you'll see.
That's about it... it's peacfully resting until I get some more energy to tackle it again. Seeing as it is the end of the year and this is when I am the most busy at work it may be awhile... gotta get those books closed and profit (hah!) booked.
Ladies and Germs the sad progress follows.
Parts-a-hangin.
This was after the aircompressor fiasco.
More linching of pieces parts.
Ooooh new seals from GPR - $80.00 for the set. money well spent.
OK this is my... BOY AM I A DUMB FUCK MOMENT.
I knew I was putting the seals in upside down. I am not really sure why I did this. Just had to take picture of my absolute fucking stupidity.
BTW... took me an half an hour to correct this.
Seals Fixed!
Ready to lower the boat cap'n
This was a bit of a chore with one person...but not impossible...just go slow.
This is where she sits tonight (taken a few minutes ago) with my filthy Subby beside her. It snowed a bit today!
I will get back to it as soon as I can. Her sister ( the MG) is all ready for the winter and soon the 14 will get put to bed right beside her waiting for a long weekend to get pulled out and put back together.
See ya'll soon.
Nice! I've always liked bright white teeners. I know how you feel about the burnout. Truly I do. That's why my tub sites all pretty and painted and BARE! Take a break. I did. But then I bought a driver teener and now it takes up all of my time.
Will we ever learn?!?!?
nope, I bought one for my son Blair so He could join me in my pain..
Thanks for the encouragment Gint and all.
Geoff... next is to hook up the engine and test that fine MPS you rebuilt...thanks again man.
Looking good man!
I'm down in Akron 2-3 times a week lately. Let me know when you are around...I'd love to come take a look!
Getting closer!
After a long sleepy winter... last weekend it was 60 degrees.
Perfect time to pop open the garage door and take on a small task.
HUGE thanks to Alberto for the dash pad... major improvement.
Tough task too. Just takes time...and really small hands of which I do not have. But I do have a couple of bloody knuckles now
The OLD and UGLY
Anybody want some vintage tunes... at last a use for those 8 tracks in your basement.
Nice and Smoooooth
Inside... look ma no ashtray.
That's all for now. Was a short day. Got cold again pretty quick. Oh well.
Next project planned is to put in the windsheild and reaar window, then get the interior back in... oh and align the drivers side door. I think I'm going to need some shims
Hey Todd, anymore progress? I just read through this entire thread and am as impressed as everyone else. Nice work so far.
I'm over on the East side of Medina if you need any help at all. Would love to get together sometime and check out your car. I'll get my Father to bring me over in his TR3 to keep your MGA company. Lookin to get my 6 back on the road this Summer. It's been 5 years since I had fun in a 914, and the nice weather lately has me working hard to get her back on the road.
Later,
Dion
Nice lookin MGA... ... I used to live in summit county also...
Thanks for the inquiries guys...
Yes I am still working on it but not much to record in picture form.
Recently I have.
1) moved the battery to the front trunk with a jegs battery relocation kit (have pics will post)
2) replaced all fuel lines and vaccum lines
3) replaced fuel pump after the old one suddenly died. Now having fuel pressure issues, injector issues ect.
I want to get it running in some form so I can move her around a little easier. After I do that I will install the interior, windows, etc so that I can wet sand and buff...then we should be in good shape.
Oh yea I still have to weld in the rear trunk pan and decide what to do about the front trunk (re: reinstall AC or fill the hole).
When summer is offcially upon us I think we need to get some of the PA, OH, MI teeners together for a meet. We'll try to schedule something soon.
Well since the club site was down been actually getting some stuff done (actually was before then but just updating).
Here is the present the UPS man brought me one day a while back.
Jegs battery relocation kit. Nice kit all the stuff is there. Just have to make a bracket for it...so off to home depot for some angle iron etc.
After a hour or so of welding and cutting this is what I came up with.
Problem being is that while the battery box is nice and clean looking... it is also LARGE. So I have to mount it very low in the front trunk. This obviously creates a small problem.
Problem solved.
Ignore the rusty trunk pan... I have not decided if I am putting the AC back in or not so not sure if I want to fill the hole.
All painted and pretty.
Attachments to hold down the battery in the box on.
Box and battery mounted. Wire needed to be run to the back.
Well some non-picture important work ensued.
Heres what got done.
1) Ran battery wires to starter and juiced everything up.
2) Replaced all engine electrical components and plugged it all in.
3) Replaced fuel pump after it died with an MSD aftermarket from Summit Racing
4) Solved fuel pressure problem
5) installed new vacuum hoses and trouble shot all missed connections
YEA IT FINALLY RUNS. Needs timing set and some tweeking but runs strong and idles well. DAMN WHEW.
Major time for a after that one.
So with all that behind and some major projects ahead I decided to have some fun and put the interior back in.
All orginal carpets etc... not in great shape butwill do. Could use a good cleaning.
Back pad in good shape.
no major defects.
DUH kinda forgot this step...
BEFORE I installed the interior. I put the windsheild and rear glass back in.
Seats in... pretty good shape. One small tear in the drivers side and one worn spot on the passengers side.
This was all for that weekend.
With last weekend being mothers day I only had one day to work, so I finished installing the interior trim, seals ect. Some of the seals are in pretty bad shape, they will need replaced.
No pics from last weekend.. batteries in the camera were dead.
Here she sits tonight.
This weekend is brake work, adjust shift rod and clutch and maybe take here for an illegal but very fun ride around the hood.
how hard is it to replace/install the windshield?.
I don't mean to rain on your parade, but I feel that I should warn you about your battery support.
You either need to rethink that one, or put HUGE backup washers on the fuel tank side of that firewall. That mount will tear off that firewall eventually. (ask me how I know this)
I suggest doing something about it prior to reinstalling your fuel tank.
I just bought a battery box at walmart => $6.00
just my $0.02
Thanks Johnman,
I have some good sized washers there already but maybe I will reinforce them or cut some steel strip and make some support.
I still have to take it out once more to fix the front trunk... easy fix.
WOW... I did not realize it had been that long since I updated my progress thread.
Well here is the rest of it.
Getting it back together.
First bumpers on and door aligned.
Pass Door
Front Bumper
sans fog lights etc
Other side door
Time for some pieces parts to be painted. Fog lights and WW
Whyat to do with this ugly wheel... why paint it of course
Picked out a cool paint. Ford Cobra wheel paint...
Sweeeeeet
HL covers on and time to wet sand.
Always a good idea to cover your edges with automotive tape to prevent sand thru.
Hood after sanding.
Sorry folks camera died after this...
But .. tons of sanding and buffing followed. I still feel I should buff some more but I will let the paint "recure" before another assault.
Here we go with trim and graphics.
HUGE thanks to our own Mike Z for the stripes. I love the Neg stripes...
Back end badges.
I used 3-M emblem adhesive and ground the mounting tangs off the emblems.
That way if I want to remove them in the future... no holes to fill (can you say 3.2 baby???)
Other side graphics
I love the wheel color!
Craigs trunk shock kit so I can keep it up all night....
Sooo you thought I was close to done and driving. HAHAHAHAHAHAHAHA
After I drove it few times I quickly realized that the front end was a mess and I was running rich.
Soooo... off with the front wheel for ball joints, tie rod ends and struts (bilstiens)
and off with the engine lid cause I can't get my fat head in there to work on anything with it on.
Running much better now and front end is good as new.
Well...
Here she sits tonight....
Not totally finshed by any means but I will aquire the remainig parts over some time ( rear bumper pad, roll bar trim etc)
I had way too much fun doing this car. Even more fun driving it the little that i have so far.
HUGE THANKS TO EVERYONE, ''Specially the following
In no particular order.
Bobolli - Bob from Pittsburgh for body panels.
Eric Shea - pedal cluster.
Geoff (bleyseng) for rebuilding my MPS
Alberto - for the dash pad
Mike Z for the graphics
the Cap'n for answering my stupid questions on fuel injection
Dave Darling for the same
Dr. Evil for the clam shells for my longs
Doug H (Cpt Tripps) for my wheels and master cylinder - lets cruise Dougy
Doug Leggins for that elusive part that I now have two of the left side of
Qarl - for lending me the BJ tool. Its on it way back bud.
AND ALL the others that have given me advise and support which I cannot remember right now cause I have had a few
Thanks all and we will see you soon... I hope.
This is truly the best club around - and I have never met most of you.
Few other money shots
'Nother
Great thread. I just went through it again and it's inspiring.
Absolutely fantastic job! The car looks beautiful. Can't believe the amount of rust work you took on. Every one of us that lives west of the Mississippi should review this thread before we take a sawsall to another tub.
WOW...im practically speechless, ive been extremely dormant on my car..havent done anything in a long time...but this has really inspired me to get my butt in gear...awesome job man *applauds*
Todd, that is pure inspiration bud! Fantastic work ethics when it comes to getting it done. Turn around and take a big pat on the back.
