Anyone remember if we ever had an indepth discussion regarding this tranaxle option?
I have one here, but don't think its strong enough for real V8 use. ITs fine for four cylinder and maybe some V6 uses, but its too weak for a V8 with any real power.
Maybe this one,
http://www.914world.com/bbs2/index.php?showtopic=293429
@http://www.914world.com/bbs2/index.php?showuser=172 has a trans comparo vid on his Budget Outlaw channel, below.
There is an Audi box (012) that is essentailly the same as the Boxster 5 speed. Not as torque proof as the Boxster S but if you're not launching hard, probably it'd work fine.
https://www.youtube.com/watch?v=SrHfruXDcuw
I wonder if an Audi A7/A8 box from Europe would work?
I think the A7 has some serious power…
Nvm….brain fart on the mid engine side axle bit….
I have an Audi 01E 6 speed paired with my V8. Can’t recall at the moment what it is out of, but a European FWD diesel IIRC.
The 01E gearbox and other derivatives are commonly used over here for Ford GT40 replica builds and they seem to hold up for that. (guessing 300-400 hp is a common range)
Then again you can abuse anything to breakage if you are determined enough but I dont think many 914's run wide enough tires for this to be a problem. The tires will break loose before anything in the gearbox gives up.
255/50/16
I have a 01e transaxle behind my LS1 (255-40-17). No issues thus far, but I'm also gentle with it. I have read that the GT40 replica guys run up to 500HP through them and opine that that's about the limit.
Andys
