Rob at DC just posted this, in case anyone is feeling lucky!
So close
Looking for 6404159 ...
@http://www.914world.com/bbs2/index.php?showuser=179 .... Man, that is so so so close. I would be tempted to try to buy that case just so you at least have an almost spot-on case and at least it is the period correct 914-6 case.
I have a '71 914-6 case that is about 20 numbers off my original case just to have a correct 914-6 '71 case in the event I ever sell the car or decide to do another engine.
2 digits. I could pull the trigger on that one. If I needed a 6 case. Anyone inquire about pricing?
Close 4371
I will caution anyone thinking about doing business with DC Auto and Rob, their idea of a rebuildable motor is different then mine. In fact the only usable part my engines came with were the cases.
after the engines arrived I immediately pulled them apart and here is what I found
cam tower so twisted the rocker arms were stick
The other cam tower was junk, both sides were Left cams still wet and rusty
webers were seized and missing jets and jet holders
and the engine I paid an additional $500 for had a melted filter housing
When the point is to get the right case number so that you can burn into a $pendy concour$e re$to to sell your 914/6 to a big money collector for stoopit money...well, dem's the breaks...
Edit: after all, those engines were pulled from their original home for a reason: no one wanted them, most wanted to swap in a bigger engine. So it seems reasonable that they led a pretty ugly life...
bearing surface scared
every cylinder was rusted but then sanded with about 120 grit sand paper to fit the pistons back in.
I sent this to Rob and he sent me a set of 80 mm heads without valves and some useless pistons pistons
Engine 1
914/6 air cleaner- melted
Air cleaner snap cans – rusted thru
Weber IDA carbs – broken air correction screw, seized throttle shafts
Missing linkage cross bar, reverse lever and mounting brackets
Cam shafts pitted
Both cam towers – gouged cam bearing areas, second twisted
Oil Cooler – crushed & does not hold pressure
Heads (2.0 L1819d 911T) fly cut to 2.2L, inconsistent combustion chamber volumes, many studs missing
2.2L pistons and cylinders – water damaged, cylinders sanded
Missing 2 rear engine transmission mounting studs m10x105mm (999.062.099.02)
Engine 2
Only 1 K&N filter
Zenith cards - seized throttle shafts, incorrect for 914/6
Alternator ring cracked (fan and alternator acceptable)
fiberglass engine shroud - broken mounting holes, Incorrect version
Oil Cooler – AN? fitting welded to bottom
2.2L pistons and cylinders – mismatched set, water damaged, cylinders sanded
Oil pump - Seized
Missing flywheel
Missing 2 rear transmission mounting studs m10x105mm (999.062.099.02)
Thanks for the heads-up about DC Auto and Rob. Finding trusted suppliers is always a gamble and anxiety ridden. I have been burned a couple of times while gathering parts for my car. Fortunately for me the parts I was burned on were not that expensive.
I have 3 also ...Bare Cases
6414053
6404034
6405482
1k each offer..
I've done well at DC, but I left with a truckload of cars.
Adam, you had a better result due to ton's of experience and inspecting in person while making the purchase. Meanwhile Glenn got a pig in a poke.
