Printable Version of Topic
914World.com _ 914World Garage _ Air box connection
Posted by: Motosan Feb 4 2023, 12:57 PM
I have noticed that the air box connection is loose after getting to work on the car. Took the box off, changed the filter and vacuum hoses but noticed the connection isn’t tight after getting everything back together. I’m not married to the stock box if there is a better solution but just not sure if this connection is a wear item or I’m missing a way to tighten this connection.
Thanks!
Posted by: emerygt350 Feb 4 2023, 12:58 PM
You mean you can't tighten that flat head bolt enough for a tight fit?
You can use pliers to massage that bent metal piece to increase the clamping pressure, but it doesn't need to be particularly tight.
Posted by: emerygt350 Feb 4 2023, 01:01 PM
Are you doing new hoses or something?
Posted by: Motosan Feb 4 2023, 01:05 PM
QUOTE(emerygt350 @ Feb 4 2023, 10:58 AM)
It’s loose on the top connection where there isn’t a way to tighten beyond just pushing it on, and yes I’m changing hoses.
This arrow better represents where it’s lose.
Posted by: rhodyguy Feb 4 2023, 01:12 PM
I would WTB a dif clamp. Your’s looks bent to the point that the bolt portions of the clamp make contact before it fully tightens.
Posted by: Motosan Feb 4 2023, 01:20 PM
QUOTE(rhodyguy @ Feb 4 2023, 11:12 AM)
Yeah. It has seen better days.
Posted by: r_towle Feb 4 2023, 02:08 PM
Add a clamp, or new adhesive.
It should be tight to aid in not having a leak
Posted by: Cairo94507 Feb 4 2023, 02:13 PM
I thought (on my '73 2.0) there was a rubber sleeve that went into the airbox and made a secure, seal when tightened.
Posted by: emerygt350 Feb 4 2023, 02:40 PM
I would just bend that metal piece back into shape. No need to go crazy with it.
Also, be careful as you replace the hoses. Many of the diagrams out there do not show the correct piping. Particularly for the decel valve.
Posted by: 914sgofast2 Feb 4 2023, 04:30 PM
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface.
Posted by: Superhawk996 Feb 4 2023, 06:10 PM
QUOTE(emerygt350 @ Feb 4 2023, 03:40 PM)
That bend in the metal clamp is the OEM bend - it’s a snubber.
Posted by: Superhawk996 Feb 4 2023, 06:17 PM
QUOTE(914sgofast2 @ Feb 4 2023, 05:30 PM)
Tried to find part in PET - it is vague as can be on the air box throttle body for the various engines - no clear pictures or part number
Posted by: emerygt350 Feb 5 2023, 07:17 AM
QUOTE(Superhawk996 @ Feb 4 2023, 07:10 PM)
Yes, but it has gotten flattened. They need to get it so that flange does its job again.
Posted by: 914sgofast2 Feb 5 2023, 01:09 PM
914Rubber sells them. It’s called a 2 liter flange gasket for the air cleaner.
Posted by: Superhawk996 Feb 5 2023, 01:26 PM
QUOTE(914sgofast2 @ Feb 5 2023, 02:09 PM)
Posted by: mgphoto Feb 8 2023, 06:06 PM
Mine has a habit of popping out of the flange, I added a loop of lock wire to keep it in position.
