Posted by: StarBear Apr 14 2023, 03:21 PM
Finally getting around to replacing the original cork gasket under the oil filler neck.
Does it go on plain or with a light coat of oil like the oil filter and strainer?
Posted by: VaccaRabite Apr 14 2023, 03:28 PM
Always did mine dry.
Zach
Posted by: StarBear Apr 14 2023, 04:01 PM
QUOTE(VaccaRabite @ Apr 14 2023, 05:28 PM)
![*](style_images/Howard/post_snapback.gif)
Zach
Ok; thanks, Zach. See you soon!
Posted by: StarBear Apr 16 2023, 03:16 PM
Questions, as haven’t done this before:
1. How to remove that big metal clip holding the neck on - use two thumbs or two levers like screwdrivers?
2. I presume risk of 50-year old cork crumbles falling into oil reservoir? How best to prevent?
Thanks!
Posted by: L-Jet914 Apr 16 2023, 03:20 PM
QUOTE(StarBear @ Apr 16 2023, 02:16 PM)
Thanks!
I just used a flat head screw driver to pop the retainer. Lifted straight up off the oil tower. Gasket slid right off for the most part. You could use a single edge razor blade to break the adhesion to the tower then remove the gasket if it's stuck on there.
Posted by: steuspeed Apr 16 2023, 07:31 PM
QUOTE(StarBear @ Apr 16 2023, 01:16 PM)
Thanks!
It will be flat and baked to the top filler.
Posted by: StarBear Apr 17 2023, 12:44 PM
QUOTE(steuspeed @ Apr 16 2023, 09:31 PM)
Thanks!
Yep it was. Removed easily with spackling knife and in one piece. Done!
