Hello,
I forgot how the clutch cable keeper is positioned. Maybe not the proper name for it. It keeps the cable from popping out of its bracket. I think... Any thoughts?
Thank you
Good job!
That is not correct. The bendable lock tab goes on the other side of the transmission bracket. Remove cable from pulley and reinstall. Use the same groove on the clutch cable where the lock tab is now. With a small hammer and punch, fold the locking tab around the trans bracket and into the hole on the bracket.
Yup
Here’s the proper setup
http://www.914world.com/bbs2/index.php?showtopic=218615
I understand that pic to be the before, or what his was setup like. He found a proper pic and corrected it per his text. I could be wrong...
Yes. I did a search. Found a photo and corrected it.
Thank you guys for all your help. If all goes good, I may be turning the ignition key this weekend.
Gordon
Good luck @http://www.914world.com/bbs2/index.php?showuser=26268
