I have a 1.7L. The pump I have looks like this. https://www.lceperformance.com/ProductDetails.asp?ProductCode=1035046& amp;gclid=Cj0KCQjwi7GnBhDXARIsAFLvH4lGGW4PFDPEuNsmAsYnKh5UVYNnja3Chwzd4lEz2Zm4Ia
HpCBzu1eUaAvWtEALw_wcB
Where I see it says it is 5psi and recommends a pressure regulator. But I don't see one.
I have this single carb.
How bad is that? Do I really need a regulator? What is going on without it?
Related is that the PO said they recently gave up on FI. But I assume no engine work was done.
I found this pump in the trunk.
Recommendations?
1. The lower fuel pump you saw was the original FI fuel pump with around 30 psi.
2. Looks like previous owner replaced the fuel pump to low psi. If it indicated 5psi. You need pressure regulator that can lower it to 2 psi.
3. Single carb usually need only between 2 to 3 psi.
your question about whether you need the regulator:
the needle and seat in the carb stops the fuel from flowing in.
they can stop and handle pressure around 3psi... sometime 4psi
but much higher and they will blow the needle open and continue to add fuel to the carb even if the bowl is full already. So the bowl can overflow and start a fire if the leaking gasoline hits the headers or another source of ignition.
Did the PO give you the FI stuff, too? If so, consider putting it back on the car. Single carb is the least optimal config.
Its probably an internally regulated pump thats pushing 5psi fuel.
Note I said PROBABLY. You really do want to put a regulator in line. There are many around that are 1-5psi for carb use. Get one and use it.
Zach
