Printable Version of Topic
914World.com _ 914World Garage _ Engine Lift Bracket
Posted by: DennisV Dec 11 2023, 03:05 PM
Did 914-6 engines have an engine lift bracket (aka hook or ring)? I have seen a bracket listed for some 911 engines, but perhaps that was only for later model years. I'm not finding a listing in the factory parts catalog. I realize it might not help much getting the engine in / out of the car, but it sure would be handy for getting it off the engine stand.
Posted by: sixaddict Dec 11 2023, 07:34 PM
Don’t believe there is one. Recently disassembled mine and there wasn’t one.
Posted by: porschetub Dec 12 2023, 01:41 PM
QUOTE(sixaddict @ Dec 12 2023, 01:34 PM)
A handy thing to have for fitting engine to stand for sure,I attached chain to my one and a chain to the engine mount carrier with a spreader bar ,then used a chainblock to lift it ,all heavy duty as these are bloody heavy ,I think maybe they only came on the 911 motor as mine is ? but not a 100% on that.
Certainly worth fitting one ,a request on WTB section should come up with one.
Posted by: Front yard mechanic Dec 12 2023, 09:29 PM
Don’t use a chain use a nylon 2” hd ratchet strap crisscross and lift from that easy peasy
Posted by: burton73 Dec 13 2023, 04:41 PM
QUOTE(Front yard mechanic @ Dec 12 2023, 07:29 PM)
Great idea
Best Bob B
Posted by: porschetub Dec 13 2023, 07:15 PM
QUOTE(Front yard mechanic @ Dec 13 2023, 03:29 PM)
Strange comment , I use rated chain and shackles ,chain isn't rapped around the motor ,spreader has even hanging points down to chains central to the eyelet and to lower point on mount front of the engine and simple to level by adjusting chain ,isn't that simple
Your method involves more work because you have to remove heat exchangers ,engine tins ,etc so you don't bend then inwards when the weight is that not less simple
Anyway what would I know as just an engineer of 32yrs
Have a nice day
Posted by: 930cabman Dec 13 2023, 08:03 PM
My 6 has an eyelet on the flywheel end, it with a long 1/2" eye bolt through the engine mount on the other end.
EZ button
Posted by: Front yard mechanic Dec 13 2023, 08:03 PM
Engineers are very smart
Posted by: porschetub Dec 13 2023, 08:43 PM
QUOTE(930cabman @ Dec 14 2023, 02:03 PM)
EZ button
Works good ,and real easy ,thanks , but still think it is only on rear of 911 motors ?,
Posted by: 930cabman Dec 14 2023, 05:52 AM
QUOTE(porschetub @ Dec 13 2023, 09:43 PM)
EZ button
probably true, this motor came from a 1975 911. Engine builder went though it from top to bottom
Posted by: Optimusglen Dec 14 2023, 09:26 AM
Maybe it's just a 911 motor thing, on my 6 (from a 911T) I have the eyelet by the flywheel wnd, but used a big strap for the other end.
Posted by: zoomCat Jan 5 2024, 01:27 PM
QUOTE(DennisV @ Dec 11 2023, 04:05 PM)
The PET doesn’t appear to show the lift bracket, but the shop manual does.
Listed as item 52, called an ‘eye’. The engine won’t balance on it, you need something to lift from the other end. I’ve used nylon webbing, I’d consider an eyebolt through the engine mount somewhere.
