Printable Version of Topic
914World.com _ 914World Garage _ Color code 2210
Posted by: Blown59 Feb 6 2024, 05:52 PM
I just snagged a 71 I plan on using for parts. The car looks to have been repainted twice. A yellow and then covered in a red. It also seems the rocker covers and sill covers have never been removed as they still have all the plastic rivets attaching them.
2210 is the color code shown as pictured below
I can't seem to find any info on this color code.... Or have I just not searched hard enough?
Posted by: wonkipop Feb 6 2024, 08:51 PM
even google image search can't get me an answer on that one?
could number be 7210?
is that yellow original factory paint?
Posted by: Blown59 Feb 7 2024, 05:01 AM
QUOTE(wonkipop @ Feb 6 2024, 08:51 PM)
I was wondering the same things. I even looked for a 7210 and 2270 code and couldn't find them. And not certain on the yellow being factory. Some indicators lead me to believe it's possible.
I have not stripped or pulled all carpet back yet. But yellow is what seems to be the base color. And as I mentioned previously, the rocker covers and sill plates still have all the original plastic rivets installed. It looks like they were masked off when painted red. They masked those areas, the vin sticker on the drives door, Karman plate, front trunk ID plate and seemingly took their time in doing so. Then it seems no time was taken to mask the harness and painted over most of the exposed side of it.
Posted by: wonkipop Feb 7 2024, 02:59 PM
@http://www.914world.com/bbs2/index.php?showuser=23315
i did come across this.
the porsche and in some cases VW paint code is on the left side of the swatch.
on the far right column are some other alternative VW or Porsche codes used for the same color.
(all the other codes to right of swatch are alternative manufacturers codes for the color - eg ppg, dupont etc but not the original factory paint supplier).
if the yellow paint in your photo is the factory paint its possible its canary yellow and the factory plate is mis-stamped. there are other examples of mistake plates on cars.
might have been meant to be 2910.
Posted by: Blown59 Feb 8 2024, 06:46 AM
QUOTE(wonkipop @ Feb 7 2024, 02:59 PM)
@http://www.914world.com/bbs2/index.php?showuser=23315 i did come across this.
That's an interesting theory. I was not aware of mis-stamped plates, but I guess it stands to reason. And IF that were to be the case, it would be an even better end to the story if the car were to have same kind of value as an error coin or baseball card.
Posted by: Literati914 Feb 8 2024, 11:48 AM
Mopar’s ‘plum crazy’ is code 2210, maybe done as a PTS one off , any sign of purple anywhere?
Posted by: davep Feb 8 2024, 01:25 PM
First, that paint code is not the correct format for a 914 (4 or 6); it should start with an L for a 914/4. So, since it looks like 7210 which is Signal Yellow, and not a standard 914 color, then it must have been a "custom" paint request. This is well worth documenting with a certificate of some sort.
What is the VIN of this 71 you have; I know it is not 4712900978 that has code L11E
Posted by: Blown59 Feb 11 2024, 04:22 PM
QUOTE(Literati914 @ Feb 8 2024, 11:48 AM)
I learned that as well when I did my Google search.
QUOTE(davep @ Feb 8 2024, 01:25 PM)
Upon further review, it seems youre correct. I had to take about 20 pics to get the camera to focus in the jamb to get a somewhat clear pic. Here are some photos of the car and its ID locations.
Posted by: Blown59 Feb 11 2024, 04:24 PM
Posted by: Blown59 Feb 11 2024, 04:26 PM
Posted by: Blown59 Feb 11 2024, 04:33 PM
Posted by: Blown59 Feb 11 2024, 04:34 PM
Posted by: SirAndy Feb 11 2024, 06:11 PM
QUOTE(davep @ Feb 8 2024, 11:25 AM)
Posted by: Blown59 Feb 11 2024, 06:37 PM
Correct me if Im wrong, but Porsche does not do COA's anymore, correct? How would one go about finding out if this was a special/custom order color/paint to sample? I really want/need this for a parts car as its the reason behind the aquisition. But now Im feeling nostalgic and like Im doing something wrong by wanting to strip it for parts...
Posted by: SirAndy Feb 11 2024, 09:40 PM
QUOTE(Blown59 @ Feb 11 2024, 04:37 PM)
... special/custom order color/paint to sample ...
Thing is, even if it was "special/custom/paint to sample", this is still an incorrectly stamped plate, which is why it is so intriguing.
Porsche still sort of does a COA of sorts, but you basically have to supply all the information, which defeats the whole purpose.
Maybe
@http://www.914world.com/bbs2/index.php?showuser=1244 can help with his services?
Posted by: davep Feb 11 2024, 10:47 PM
From Karmann's perspective, this was the way that they did 911 paint codes at that time, and this was a 911 color. It is a VERY nice color. I can definitely assist with getting the data for my CoA type of document. Since these custom colors are so rare, and I do not know of another signal yellow 914, perhaps someone should consider restoring this car.
Posted by: wonkipop Feb 12 2024, 12:32 AM
QUOTE(davep @ Feb 11 2024, 10:47 PM)
reckon you are right mate.
its not really a custom color. its a customer request for a porsche color rather than a VW color. 914s were painted VW colors. so makes sense its got a porsche color code
#. standard porsche color. not really custom.
i would bet my bottom dollar there are a few other or were a few other 914/4s floating about out there that had similar specs. just you don;t or would not come across them often.
at least i had that guess right about a million posts ago that it was 7210.
but i did not find anything that connected 7210 to porsche yellow.
Posted by: wonkipop Feb 12 2024, 12:34 AM
QUOTE(Blown59 @ Feb 11 2024, 04:34 PM)
got a few other tasty porkers in your garage there. nice.
Posted by: Blown59 Feb 12 2024, 02:44 PM
duplicate
Posted by: Blown59 Feb 12 2024, 02:45 PM
duplicate
Posted by: Blown59 Feb 12 2024, 02:48 PM
duplicate
Posted by: Blown59 Feb 12 2024, 02:52 PM
With the help of @http://www.914world.com/bbs2/index.php?showuser=1244 and @http://www.914world.com/bbs2/index.php?showuser=4947 @autoatlanta.com I think we have pretty much concluded we have a special order color.
Karmann plate seems to be original and the body numbers confirm.
George has a special order color card but a later model year. The Karmann plate in his car has a "99" for the color code. He said the Porsche color code was new to him too.
I guess its time to get a COA or the newer version of the COA to document the color.
Im not wanting to do a factory restoration, I like to restomod/hotrod/customize/bastardize my cars to my liking. So, this will probably be going up for sale in the near future. If youre looking for a 1 of 1 car, let me know. I know a guy...
click the photo and it wont read upside down.
Posted by: Blown59 Feb 12 2024, 02:55 PM
Body number matches the Karmann plate
Posted by: Blown59 Feb 12 2024, 02:58 PM
A better pic of the yellow paint
Posted by: davep Feb 12 2024, 07:25 PM
That rear trunk appears to be in great condition; if the rest of the car is as nice, then it is a good candidate.
Posted by: davep Feb 12 2024, 07:26 PM
actual paint code, according to the badge, is 7210. That code means Signal yellow (72) with a Black Targa top (10)
Posted by: Blown59 Feb 29 2024, 03:44 PM
It seems that this is actually a pretty unique vehicle. Sara Edie of Porsche Classic was able to help further this investigation along. Unfortunately, there is no Kardex available as they ended in 69. But there is some information available from the build sheet and it seems this is a "custom" color car but the build sheet did not verify which color it was. Hoping some help from Germany will clarify this even more.
At this point, I cannot see chopping this car for the parts car for which I intended it. It should be saved, but I am not a factory restoration kinda guy. I much prefer my custom and modified cars. So, this will be going up for sale.
If anyone has any interest and needs more pictures, please feel free to message me for more information. I will be placing this in the classified section as well.
Posted by: BENBRO02 Mar 1 2024, 08:04 AM
QUOTE(Blown59 @ Feb 29 2024, 04:44 PM)
Because it is a custom color, I believe you’re making the correct decision to sell it to someone that will restore it to stock and you can buy another to modify.
Posted by: rgalla9146 Mar 1 2024, 08:17 AM
In the trunk it looks juat like Canary yellow... which is a standard attractive choice.
In the crash pics it looks a little more like Signal orange.
Puzzling.
Strange to choose and pay for a color so close to what was readily available.
Posted by: davep Mar 3 2024, 02:06 PM
In 1970 & 71 the only yellow was Lemon yellow (aka Canary, but in German it was Zitron). So Signal yellow was a significant departure in shade.
Signal yellow
Lemon yellow
Posted by: Blown59 Mar 4 2024, 08:47 PM
QUOTE(rgalla9146 @ Mar 1 2024, 08:17 AM)
Puzzling.
The colors do seem different in my pics, but I attribute that to the lighting and angles.
Posted by: Blown59 Mar 4 2024, 08:57 PM
QUOTE(wonkipop @ Feb 12 2024, 12:34 AM)
Thank you! There an '01 986, '87 951 with some Lindsey Racing goods, '70 & '71 914s and '02 Outback now as it is my EZ30 H6 donor for the '70 914.
I'm definitely running out of room and really would to move this Signal Yellow to a new home where it will get the attention it deserves. Someone has to want or be intrigued by this car.... bring me an offer and let's get a deal done!!
Posted by: VaccaRabite Mar 5 2024, 10:39 AM
Man... Signal Yellow is such a cool color! I've never thought of it on a 914 but I bet it would look KILLER. I can't imagine someone painting over it with RED.
No accounting for taste, I suppose.
Zach
