I'm doing a fairly large project on the interior of my 1971 914-6 GT clone this winter. I'm converting to 911 steering and ignition, adding a GT roll bar and harness mounts and a few other bits and bobs.
While it's open, should I cut an access panel? Is there any impact on the structural integrity of the firewall? How difficult is it to lean over the engine and adjust timing without the access panel? While it would be more convenient, I wonder if it's really needed to properly time the car every few years. It's a '71 2.2 liter "E" cam engine.
Thanks for any advice. John
If you have a factory 914-6, I would not cut the firewall; did not cut mine either. I have modded my 6 but the body is still essentially stock with the exception of my louvered front trunk floor to vent the oil cooler. I think the biggest hassle is if you need to change your fan belt or alternator. It can be done in the car, but it's a task best left to young, thin mechanics with long arms. The best plan for these cars is to just drop the motor for maintenance. Valve adjustment, address any leaks, new fan belt, etc. Timing them is a slight pain, but manageable with the engine in the car.
I think structurally, if you cut an opening in the firewall, make a nice metal panel that seals tightly when installed - maybe riv-nuts. I do not believe it is going to weaken the firewall.
There are lots of threads and lots of opinions on this
http://www.914world.com/bbs2/index.php?showtopic=81727
Race car - absolutely. Street car ??? Remember, you have to cut fabricate fasten. For use you gotta remove seats and backpad.
For me a “no”. For others a “why not”. Timing is not a big deal. For as much as these cars typically get driven, belts last a long time. Engine likely coming out for valve adjustment and other maintenance. Service the belt then.
Drop the motor for valve adjustment
Geez. I do the valves 6-8 times every summer and never drop the motor for it
I haven’t read that thread in a while.
Here’s the thing that isn’t even discussed in that thread. An air cooled engine is way louder than a water pumper.
OEMs go to great lengths to seal even the tiniest holes in a modern firewall? Why?
NVH (Noise Vibration Harshness)
It is amazing how much sound can be transmitted through even the smallest holes, unsealed weld seams, and past rubber grommets, and foam. All modern cars have multi layer NVH solutions to help quiet things down. But it all starts with minimizing protrusions through the sheetmetal.
I've had my 914-6 conversion since 1986 and only recently cut the firewall to replace the alternator with my 3.2. Otherwise getting to the belt, distributor and valves has never been a problem.
I bought the PMS fiberglass cover, versus finding someone to cut up their firewall for a cover plate. https://patrickmotorsports.com/collections/patrick-ms-parts/products/bod914bhcpms?_pos=3&_sid=ca3958367&_ss=r
Do my valves routinely in car also. I guess I was thinking about next time. Engine coming out for a bunch of other work.
Not sure there is a best answer for street cars. No in an original six, owner preferences on a conversion.
I think if I were doing it I would maybe try to make a clean cut and then fab and weld in a bolt ring/flange and use the cutout to reseal the hole.
IF you choose to put the access hole in, there is no better cover than a piece
cut out of a junked car .
It will fit perfectly and look like it grew there.
Timing and valve adjustment can be made much easier by marking your flywheel
as done on original 914 6s Use the marks on your crank pulley to position the flywheel
for marking.
No need to be young, thin or acrobatic.
Changing / adjusting your fanbelt is a challenge. Get the right tools.
If using an aftermarket front mount be sure there is clearance to remove /install
the V belt
Practice replacing and adjusting before leaving on long journeys.
I cut mine for the /6 conversion. It's a simple patch to put things back together
Ya all must be changing fan belts like underwear to need that much easy access.
I’m wondering how many of you are driving modern cars where you can’t even see the serpentine belt?
I put one in my GT Tribute, helps a lot with service. I built the car for myself, not to worried about resale. Best, Mark
Ours
I'm planning to do it on my GT conversion but will not even think of doing that on my -6 for obvious reasons.
I cut and saved a section from Frankencarcass back when I was parting it out.
NO WAY!!!!!!
@http://www.914world.com/bbs2/index.php?showuser=27202
I have what you want. I was going to put in my V8 car body but went a different route.
I have 2, the bigger one may be better. Super clean part. I will list it in parts for sale.
Best Bob B Burton
Boxed in a 24x24x5 box. 10 lb for the big one as it cam from Garold a few years ago
I cut mine, and found a firewall section to make the cover from. Haven’t finished it yet, but it will have a bead-rolled recess around the cover edges locate a seal.
My version. Had a section from a donor car. Added weather stripping to inside of cover for noise/odor control. Works well, especially when I changed out the cast iron distributor for a 123.
Yes it’s called a firewall. Yes a plate that’s screwed into the back will secure the firewall. It’s been done on many race and street cars for years.
Definitely worth changing up to stainless fuel lines from tangerine racing.
I have always been tempted but have stayed away from cutting the hole. Its to risky for me when my kids ride in the already small car with plenty of associated risks
I don't get it. If you have a engine fire isn't the rear window going to go first. I think the fire wall is just for flying parts, kidding. Mark
Several years ago I was in the market for a 355, mid engine V8 5 valve engine. Virtually all of maintainance was completed with the engine out. A part of having a mid engine machine.
I couldn't justify $80.k, a couple years later I fell into the 914 abyss
I’m with Team Firewall Access bay!!!!
Wow, nice Dave.
Doesn't the firewall consist of two layers with a 1/2" gap in between? A hole might be a good place for a sub-woofer. I saw a 911 years ago with this set-up. I have no idea how he isolated the engine noise.
Track car…..all the stuff about what can be done by pulling the engine doesn’t make sense to me. Break a belt at the track …..and a well done access plate means you are back in business without much hassle.
