I'm only 44 so both me and the car outa be hard (it's the car that has the problems).
I'm stumped! I just replaced all the brake parts on my car... Lines, calipers, pads, and rotors. I have bleed the lines like Eric's articles says to do and adjusted the rear calipers (.004). Everything has gone real smooth -- except for one thing. I still have a mushy pedal. I have bleed the lines 3 different times starting with the RR, LR, RF, LF and doing the bottom bleeder first on each caliper.
I have read the threads about adjusting the proportioning valve. The Haynes manual calls it the Brake Pressure Regulator? The problem I'm having is that I can't find the darned thing!
Where is this thing? Is it possible I don't have one and have done something else wrong?
Any help, pictures, etc. would be real helpful.
It is in front of the engine, behind the driver's seat, on the lower firewall. You can only get to it from under the car.
Does it actually have a bleeder on it?
my vote is no....
just have to bleed the air through it, cant directly bleed the valve...
Well, I don't see anything there other than a brass tee that seems to go to both rear calipers.
Do some cars come without this device?
Maybe it's like Microsoft Windows and I just have an "unnannounced feature"!
Here you go, upper left of picture;
QUOTE (ratrustle @ Aug 28 2005, 12:05 AM) |
Well, I don't see anything there other than a brass tee that seems to go to both rear calipers. Do some cars come without this device? |
OK, so I didn't have a proportioning valve until today. I had one in the box of spare parts that came with the car. I thought it was a spare master cylinder.
I only spent 3 and a half hours installing this thing and getting the extra air out of the lines.
I really appreciate everyones help with this. I would have never found what I didn't have without the assistance.
RR
QUOTE (bd1308 @ Aug 27 2005, 11:04 PM) |
my vote is no.... just have to bleed the air through it, cant directly bleed the valve... |
