Printable Version of Topic
914World.com _ 914World Garage _ Windshield Washer Electric Pump
Posted by: DennisV Jan 10 2026, 08:35 PM
Testing the windshield washer in our 1970 914-6. When I pull the wiper / washer lever I can hear a slight thud or click and then the wipers cycle. I have confirmed the noise is the electric pump as I can feel it move slightly if I put my hand on it while someone else pulls the lever. Does that mean the pump is good, or does a good working pump make a different noise?
I've been through many threads about the squirters not working, but haven't found much discussion about the electric pump itself.
Thanks.
Posted by: Superhawk996 Jan 10 2026, 08:53 PM
Should be a constant hum / whirring
Clunk / thunk / click isn’t right.
Bench test it.
Posted by: porschetub Jan 10 2026, 08:54 PM
QUOTE(DennisV @ Jan 11 2026, 02:35 PM) *
Thanks.
it's cheap enough as it is a 911 part shop around for the best price ,cheers.
Posted by: johnhora Jan 10 2026, 09:06 PM
DennisV....The pumps get gummed up inside and make noise and don't do any pumping...I've actually taken them apart and removed the crud and gotten them to work. also go slow as I think I remember a little thin gasket around the perimeter of the two sides
Posted by: rgalla9146 Jan 11 2026, 07:04 AM
Original pumps are dated approximate to (but before) the cars manufacture date.
I've had good luck disassembling, cleaning and reassembling them.
Get the pump bracket and hardware plated while it's apart.
Posted by: 914Sixer Jan 11 2026, 07:30 AM
Clean the whole system if you have to take pump apart.
Posted by: DennisV Jan 19 2026, 02:19 PM
QUOTE(johnhora @ Jan 10 2026, 07:06 PM) *
Thanks for the suggestion John. I cleaned the internals and it's purring along now.
I couldn't find an existing DIY video on this, so I made one. Very utilitarian and not near the production quality of Ian, but maybe it will help someone else.
https://youtu.be/tF1Q1Qoar5c
Posted by: Cairo94507 Jan 20 2026, 08:01 AM
Hey Dennis, great job on the washer motor video. I now need to add that to my list as mine has never worked. Thanks for taking the time to make the video. beerchug.gif
Posted by: johnhora Jan 20 2026, 03:51 PM
agree.gif Nice informative video Dennis..
Posted by: NARP74 Jan 20 2026, 05:04 PM
Nice video. The grease you used will wind up in the hoses and on the windscreen, but the washer fluid should dilute it soon enough. Might get a smear initially.
Great save.
Posted by: Steve Jan 20 2026, 08:49 PM
Enlarged prostate? Jk.. I had to prime mine to get it to work.
Posted by: DennisV Apr 6 2026, 02:00 PM
A related tip on this topic. The hoses are secured to the pump with very thin wire (0.80 mm diameter) twisted around them. It broke when I removed it.
The closest I could find is https://www.menards.com/main/hardware/picture-mirror-hanging-hardware/secureline-reg-6lb-24-gauge-100-floral-wire/sa46245/p-1444437045082-c-13085.htm. It is 0.60 mm diameter and green, but worked quite well and is out of view.
Posted by: BillC Apr 6 2026, 04:06 PM
QUOTE(DennisV @ Apr 6 2026, 04:00 PM) *
That looks like safety wire. Readily available at any speed shop, as well as Summit Racing, Jegs, Amazon, etc. The twisting is done with a special pair of pliers that has a pull-twister, specifically for safety wire.
Posted by: 914Sixer Apr 6 2026, 06:49 PM
Wire is NOT stock.
Posted by: rgalla9146 Apr 6 2026, 07:38 PM
QUOTE(914Sixer @ Apr 6 2026, 08:49 PM) *
Wire is NOT stock.
fresh hose will not need it.
Posted by: DennisV Apr 7 2026, 06:48 AM
QUOTE(914Sixer @ Apr 6 2026, 05:49 PM) *
Wire is NOT stock.
Thank you for pointing this out.
Posted by: aturboman Apr 9 2026, 11:09 AM
As mentioned the original pumps have date markings on the bottom plate. This is an original pump which a also disassembled and cleaned by removing the 4 cover screws.
This is a very simple gear pump so if the motor runs your pump should work fine.
Here is an image of all the original check valves and fittings with new hose.
Again the new hose will be very tight on the pump nipples and no clamps required.
I find that heating the hose end slightly with a head gun and a little shot of silicon spray will allow them to easily slip on, once cooled it will be tight and not leak.
Lastly make sure you have the connections correct at the washer reservoir, they are easily reversed.
Only one nipple has the pick-up tube running to the bottom, this has to go to the suction side of the pump, the other is the return for the pressure circuit. If the are reversed you're pumping air not water.
Posted by: DennisV May 26 2026, 05:04 AM
QUOTE(aturboman @ Apr 9 2026, 10:09 AM) *
Well after all that it still doesn't squirt. I hear it spinning away, but no result. I ran it several long bursts thinking it might need to prime it self, but nothing. I pulled the hoses and put my finger on the I don't feel any suction or pressure. I assume it should be strong enough to feel something.
Maybe this was a wasted effort, as the date code on ours appears to be 3 77. So vintage, but not original to the car anyway.
Posted by: Superhawk996 May 26 2026, 11:05 AM
Bench test rather than playing with it in car. Air must be leaking in somewhere.
Or . . . $30 for a new one.
I’d you want to keep going with this one, make sure the rubber gasket isn’t torn and allowing air in.
If it were me I’d put a dollop of a water soluble gel on the gears (KY or similar) to help it prime. Pump needs to be lower than reservoir. Don’t count on suction to lift washer fluid to it but bench testing will confirm how high it will lift.
Posted by: Cairo94507 Jul 7 2026, 04:08 PM
I just spent the afternoon trying to sort my washer pump not working. It made noise like the pump was working but no water coming out the nozzles. Pulled the bottle out and removed the washer pump. Disassembled and it looks perfect. Bench tested and it pumps out water.
Then pressurized the water lines to make sure they were not somehow kinked. They seemed fine.
Looked at the bottle and saw the water pickup lying in the bottom. Pulled it out and it was dirty. Cleaned it, cut a new piece of tubing and then had to get the hose attachment piece off the bottle so I could put the new hose with pickup on it. That popped off the bottle with little drama and the new case went on with no problem and then reattached it to the bottle.
Now I have to sort the lines.... I forgot where they were connected. There are 2 connections to the bottle and 2 connections to the pump. Couldn't be that tough, right? I tested the system by inserting one line into a water bottle and the washers squirt quite nicely. So, in theory, once I hook everything up correctly, that will be job done.
Posted by: Cairo94507 Jul 8 2026, 07:17 AM
Look what I found using the search function:
Posted by: Cairo94507 Jul 11 2026, 11:28 AM
Jesus! This windshield washer system is making me crazy. I found the intake tube lying in the bottom of the washer reservoir so I reinstalled it with a new hose and made sure the little filter that sucks up the water was clean. I verified the pump pumps water by bench testing with a bottle of water, couple hoses and a 9V battery. I installed it all and connected the lines exactly like the diagram. I can not get water to squirt out of the nozzles! Any suggestions? I believe the lines to the nozzles are correct as at one point when testing with a bottle of water, the squirters worked nicely. beerchug.gif
Posted by: DennisV Jul 11 2026, 11:52 AM
QUOTE(Cairo94507 @ Jul 11 2026, 10:28 AM) *
My car is in a similar state Michael. Unless you uncover a key tip my next visit to the car, my plan is:
1. Remove and soak the squirters. Vinegar?
2. Blast compressed air through the hose lines with nozzles removed.
P.S. I can see the reservoir cap has an intake tube inside the tank connected. I started to remove the cap, but I could hear the plastic cracking as I tried to pull or pry it off. I'm not sure how to get it off without breaking it.
Posted by: Cairo94507 Jul 11 2026, 05:07 PM
Dennis - I was able to use a couple of putty knifes to pry it up and then it just popped off- no damage. I would definitely set it out in the sun to warm it up first. I already blew air through my lines- they were replaced new in 2019. I also have seen them squirt water out the nozzles. Just need to get that all to work once assembled. I am sure I will figure it out; it is just making me crazy right now. Cheers, Michael
Posted by: rgalla9146 Jul 12 2026, 04:58 AM
The check valves at the squirters get stuck and will not allow the fluid to flow.
I've removed them back in the day and either left them out or removed the works
inside each one and reinstalled.
By the way, don't striggle to attach the hose to the squirter under the cowl.
If you eliminate the check valves push the hose up through the mounting hole,
slip the hose on, then lower squirter and push /pull untill seated.
Gently use a straight pin to aim the nozzles.
I don't know if the check valves are available anymore ...anyone ?
Posted by: Cairo94507 Jul 12 2026, 07:38 AM
Ohhhh, that is interesting. Stuck check valves may just be the problem. I will have to see if anyone has them new. Thanks for the info @http://www.914world.com/bbs2/index.php?showuser=5176 . beerchug.gif
Posted by: DennisV Aug 21 2026, 10:11 AM
QUOTE(Cairo94507 @ Jul 12 2026, 06:38 AM) *
Did you get yours working?
I finally got the cap off our reservoir and discovered the pickup tube had a small ball valve at the end that was stuck.
Posted by: Cairo94507 Aug 21 2026, 02:47 PM
Hi Dennis,
What did you do to free up that valve in the reservoir? I did get mine working. I replaced one squirter and added some new line and made sure both check valves were good. Squirts really well. Enough water that if I were still a kid, I would aim the outside squirters towards the cars next to me for fun. beerchug.gif
Posted by: DennisV Aug 21 2026, 02:52 PM
QUOTE(Cairo94507 @ Aug 21 2026, 01:47 PM) *
Hi Dennis,
I soaked the valve in carburetor cleaner, then used a brass brush on it, and poked at it with a dental pick until I could hear the ball rattle when I shook it.
Glad you got yours sorted. That's a totally hilarious idea to point the squirters sideways. I might be asking for trouble with that knowledge. happy11.gif
Posted by: wonkipop Aug 21 2026, 06:52 PM
QUOTE(rgalla9146 @ Jul 12 2026, 04:58 AM) *
the check valves were still available about 5 years ago.
and from porsche. standard old school 911 gear even on the VW system 4s.
i renewed mine - they were preventing flow to the nozzles.
installed new ones. presto my system worked again.
though now i live in constant fear of the hose coming off the steering wheel switch and strategically aiming itself at my crutch while i am driving with the result all old air-cooled VW drivers know too well. biggrin.gif
Posted by: jim_hoyland Aug 21 2026, 07:20 PM
Had the same issue. I removed the vent cap and drilled a small hole so air could get in freely. biggrin.gif
Posted by: wonkipop Aug 21 2026, 08:07 PM
looking at parts diagram above and made me think.
checked the PET diagrams.
the later cars like mine with the black squirters have an inline check valve.
not part of the squirter.
i could get the inline valves from porsche.
if i recall correctly they are 2 straight inline valves and not a single t valve as shown on the parts diagram for later cars. i dunno whether they changed it again or i put inline valves in it way back 35 years ago when i was preparing the car for road registration in australia and i got the windscreen washer system up and running way back then.
and i dunno if the earlier squirters come apart and the check valve can be removed from the bottom of it. but you definitely could get the inline valve. tube in and tube out. and the valves can misbehave and stop the system squirting.
