Printable Version of Topic
914World.com _ 914World Garage _ Picked up a 73 2.0 project
Posted by: Luke M Aug 14 2026, 07:08 PM
I added another 914 to my collection. It's not that I don't have enough work to do on my 914-6 but this is more of a father and son project. I found this 73 2.0 appearance package is the southern tier of NY. I worked out a deal with the p/o and I picked it up today. I believe the org 2.0 engine was sold to a person in PA. I didn't care too much about that as I'm going to be installing a 6 into it. The car is pretty much complete other then the missing engine. It needs work in the usual spots but otherwise the chassis is in good shape. I took a few quick shots when I got it home but I'll take a few more on Sat.
Posted by: mepstein Aug 14 2026, 08:22 PM
Posted by: rick 918-S Aug 15 2026, 03:54 AM
Posted by: 930cabman Aug 15 2026, 06:42 AM
money shot(s)
another /6 project?
Posted by: aharder Aug 15 2026, 06:49 AM
Posted by: Luke M Aug 15 2026, 06:17 PM
I took a quick look at the 73 2.0 today. The right engine shelve needs to be replaced as there's lots of pin holes and rust there. The hell hole looks ok but I need to really get in there and dig around. Both jack points are bad and the p/o cut them out. Front and rear trunks look good. The floor pans are in pretty great shape minus a few dents from someone jacking the chassis up. The interior is in pretty good shape and just needs a cleanup. The seats will need some work. Each fender and q-panel has an issue so it's a good candidate for a set of steel flares. The good news is the car came with some of new RD metal for the repairs.
The plan for this one is a 6 conversion, 5 lug setup, steel flares, and a paint job back to the org silver paint.
All of the 4 lug stuff is going up for sale, wheels/tires, and anything 2.0 4 engine stuff that's left in the engine bay.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Posted by: sixnotfour Aug 16 2026, 01:42 AM
Are those ..No Crash Beam, Late window mechanism, Doors??
Posted by: sixnotfour Aug 16 2026, 01:43 AM
Posted by: mepstein Aug 16 2026, 05:16 AM
“The plan for this one is a 6 conversion, 5 lug setup, steel flares, and a paint job back to the org silver paint.”
$100k decision?
Posted by: Luke M Aug 16 2026, 06:33 AM
QUOTE(mepstein @ Aug 16 2026, 04:16 AM) *
$100k decision?
I have 90 to 95% of the parts needed to convert this one to a 6.
I have the front and rear 5 lug suspension, RD steel flares, wheels/tires, 2.7 RS and a rebuilt side shift trans, oil tank/lines, motor mount, and gauges. Mainly what I'm missing is some new misc RD sheet metal, steel fuel lines, new rubber seals, bushings, and some miscellaneous hardware. The body and paint work will be my biggest expense. Sounds easy enough doesn't it... laugh.gif
And no I'm not taking any parts away from my 6 build to supply this one.
All of my other 6 parts are in their own bins awaiting for the day to go back on.
These are just parts that I've purchased and stashed away because I wanted to build a 914-6 conv with my son. I just had to find the right 914 to buy first. Compared to some of the other 914's that I've looked at this one believe it or not isn't in bad shape. I can easily deal with the metal work that needs to be done on this one.
Posted by: Luke M Aug 16 2026, 06:38 AM
QUOTE(sixnotfour @ Aug 16 2026, 12:43 AM) *
I'll take a look and report back. I just jammed some cardboard between the windows and door frame so the glass wouldn't get damaged in transport.
Posted by: mepstein Aug 16 2026, 07:22 AM
QUOTE(Luke M @ Aug 16 2026, 08:33 AM) *
$100k decision?
I’m in no way saying it’s a bad decision. I think it’s great that you will restore and modify that car into something special.
Posted by: Luke M Aug 16 2026, 02:58 PM
QUOTE(mepstein @ Aug 16 2026, 06:22 AM) *
$100k decision?
Hi Mark, I didn't take it in a bad way. I know it's crazy expensive to do a conversion now a days. It seams the cost of parts have gone through the roof. I've always wanted to do another conversion. I've been lucky enough to be able to buy and stash away most of the parts needed.
I've also checked the doors and they are the late style window mechanism without the later crash bars. I hope they will be good enough to use.
Posted by: 930cabman Aug 17 2026, 01:15 PM
hate to ask, but this will increase your collection to _? or is it double digits
Posted by: Luke M Aug 17 2026, 01:23 PM
QUOTE(930cabman @ Aug 17 2026, 12:15 PM) *
Hi John,
Three total Porsche vehicles. Two 914's and a Cayenne S.
I started cleaning out the interior today. I hate when people butcher the chassis to make things fit. I'd have to take a good pic of what I found today.
I need to check the passenger side to see if it has the same issues.
Posted by: 930cabman Aug 17 2026, 02:59 PM
QUOTE(Luke M @ Aug 17 2026, 01:23 PM) *
Hi John,
Thank you for the invite, I am planning a trip to visit Phil at Batavia Starter soon, please PM your address. I will let you know when I will be heading out
Posted by: Luke M Aug 19 2026, 05:35 PM
We started the disassembly portion of this build. The interior is about done. The dash and harness needs to be removed yet. I found some sketchy stuff done to the wire harness so that'll have to be addressed. The sound pad/tar paper or whatever it's called now a days needs to be removed from the floor pan. That's a special job set aside for my son to get done. Front trunk is about done too. Fuel tank, fresh air box, and wiper motor is out. Still need to get the headlight assemblies out and move the harness back to the bulkhead for removal. Rear trunk is done. The engine bay is getting there. I have a few more items to remove. I took a look at the hell hole and it needs a little work. The right engine shelve will need to be replaced but that's easy enough to do. I'll see what tomorrows schedule looks like and hopefully get some of these items above taken care of. I also posted a pic behind the speaker grills. Both sides look like this.. blink.gif
I do not know why people butcher cars like this.
Posted by: bkrantz Aug 19 2026, 08:14 PM
Looks like buying a 914 with the sills already cut open is a good way to judge rust problems.
Posted by: Luke M Aug 21 2026, 05:44 AM
We got the 73 pretty much stripped minus the suspension. We found a few old mice nests while removing the wire harness. Next we will roll it outside and pressure wash the heck out of it. Once that's done it's time to brace it and get it onto the rotisserie. Then the suspension will come off. So far we aren't finding anything major to repair minus the jack points and drivers door post. The headlight buckets, trunk channels, floor pans, and trunk floors all look too darn good to be true. This is a decent chassis for being 53 years old. It must have been a garage kept 914 from what I'm seeing. The wire harness has a few problems and will need some wires replaced thanks to the mice damage... chowtime.gif ....
Time to cleanup the shop and get parts labeled and into bins.
Posted by: 914Sixer Aug 21 2026, 06:01 AM
Posted by: mepstein Aug 21 2026, 06:51 AM
QUOTE(914Sixer @ Aug 21 2026, 08:01 AM) *
agree.gif choosing the right chassis is most of the battle.
Posted by: Luke M Aug 24 2026, 01:37 PM
QUOTE(mepstein @ Aug 21 2026, 05:51 AM) *
So true. Just look at the amount of time and work I've put into my 6. It still needs more time and parts. I'm waiting on a few metal parts to show up so I can move forward in the rear trunk repair of that car. So far on the 73 it's been kinda of an easy go at it.
I need to make up some cross braces before I can mount it on my rotisserie. My son and I have spent the last several days tagging and boxing up parts from the 73. We finished up that portion today so the real work starts next.
Posted by: Luke M Aug 27 2026, 03:02 PM
Got the door braces made up and installed. Started removing the tar paper from the floor pan. We got the drivers side rear section done and called it a day. Once the tar paper is off it goes on the rotisserie.
Posted by: Luke M Sep 2 2026, 05:07 PM
The 73 is on the rotisserie. We got the rear control arms and shocks off. Thursday we will take the front end off. Looks like Bilstein struts are installed. These will be going up for sale here soon.
Posted by: MikeK Sep 3 2026, 09:12 AM
I like how you braced the door openings so that you can trial fit the doors.
Can you post some more details and pics of what you did?
Thanks!
Posted by: Luke M Sep 3 2026, 03:12 PM
QUOTE(MikeK @ Sep 3 2026, 08:12 AM) *
Thanks!
This setup works really well and yes you can open and close the doors. I like this setup especially when doing door post installs. Makes it very easy to test door gaps too. The upper braces have left hand and right hand heim rod joints. The lowers are just square tube drilled to fit at the mounting points. I think that I'll add a few extra braces from the cross tube to the chassis. It may not need it but I don't think it'll hurt. I'll get you better pictures and info on Friday.
Posted by: Luke M Sep 4 2026, 08:00 AM
The front suspension is off. I'll be posting the struts and calipers for sale at some point.
The rotors are rough so they will be removed.
Posted by: Luke M Sep 4 2026, 07:48 PM
We got the 73 outside and pressure washed. A lot of media and insulation came out of the chassis. The p/o started to media blast the chassis so I knew there would be some around. The mice helped in hiding the insulation all around. She's nice and clean now. It's time to start cutting and welding.
Posted by: sixnotfour Sep 4 2026, 08:21 PM
Nice..plus Factory sway bars and Bilstien struts...
Posted by: mepstein Sep 5 2026, 04:44 AM
QUOTE(sixnotfour @ Sep 4 2026, 10:21 PM) *
Posted by: sixnotfour Sep 5 2026, 09:30 AM
QUOTE(mepstein @ Sep 5 2026, 04:44 AM) *
Posted by: Luke M Sep 10 2026, 05:02 AM
I spent a little time yesterday looking over the right side long and rear q-panel so I could come up with a repair plan. Looking at this r/r q-panel I figured it would be best to remove and replace it. It has dents and rusted out sections in several spots. Someone also drilled a few holes through a dent and slapped some bondo on it. I figured no big deal I have a r/r q-panel that's in great shape on hand. It would also save me hours of cutting and welding in new metal to repair it. It also gives me a chance to take a better look at the inner fender by the hell hole and take care of any possible issues. I got the spot weld drill bit/tools out and off she came. I found a few minor issues but otherwise pretty solid. It's now time to deal with the right inner rocker and jack point repairs.
Posted by: Luke M Sep 11 2026, 10:21 AM
Posted by: MikeK Sep 12 2026, 11:11 AM
Thanks for detailed photos of the door struts. It seems like a much better solution putting them in a place where you can check door fitment/gaps. I'm not at the point where my car is blown apart and ready for the rack, but when I do, I'll be sure to use a similar technique. It appears that both of our cars need similar repairs.
Looking forward to seeing more good work!
Posted by: Luke M Sep 12 2026, 01:29 PM
No Problem Mike. This setup seams to work well. I adjusted the door gaps and holds well. Took measurements again and still solid. Obviously you would keep checking the measurements as your work progresses. I have this same setup on my 6 chassis and no issues there too. beerchug.gif
Posted by: Luke M Sep 14 2026, 04:02 PM
Got a few things done and off the to do list. All of the tar paper is removed from the floor pan. We found one small issue with the floor pan. There's a small rust hole by the throttle pedal mount. I need to remove the pedal support bracket then fix the rust hole.
I have a new bracket among other things on order. Moved to the firewall where I found a few spots that will need to be repaired. Gotta love the firewall engine pad that collects and holds water like a sponge. Started fixing the right targa inner support bracket flange. I made a custom piece to fit and only took about 2 hours.. blink.gif Cut, grind, test fit... repeat.....
Here's a piece of knowledge for you guys and gals.. If you ever have to replace this on a future project use an piece of an old door sill. Works like a charm and has most of the bends already there for you. The more you know... beerchug.gif
Posted by: bkrantz Sep 14 2026, 08:09 PM
BTW was that an original spare tire in the first photo set?
Posted by: Luke M Sep 15 2026, 04:35 AM
QUOTE(bkrantz @ Sep 14 2026, 07:09 PM) *
Yes, I do believe so. Michelin 165 SR 15 ZX
Posted by: Luke M Sep 15 2026, 03:19 PM
Got the right engine tray cut out and hellhole cleaned up. Looking pretty good down there but I can't say that for the firewall. It's going to need a few patches. Waiting for the new RD metal to show up so I can start welding. Lower engine side firewall is prepped for a 6 mount.
Posted by: Luke M Sep 18 2026, 03:23 PM
Removed the pass side 4 cyl mount then tested fitted the 6 firewall mount.
I'm waiting on some new sheet metal to arrive so just prepping things for now.
Posted by: Graydingo Sep 18 2026, 04:22 PM
nice work! yeah the brace system is ingenious.
Posted by: Luke M Sep 19 2026, 06:21 AM
QUOTE(Graydingo @ Sep 18 2026, 03:22 PM) *
Thanks but I can't take all of the credit for it. The brace was originally designed by Perry. I just added my own touch to it by adding the brace that mounts on the outer seat belt mount to the upper dash mount. It works pretty well and stays put. I check the measurements as I work and once in a while I have to make an adjustment. For most part once it's set it should be good. On my 6 repair I'm always checking the measurements but that whole chassis has pretty much been cut apart. On my 73 repair it's not moving... or at least not now. I'll check as the welding starts.
Posted by: Montreal914 Sep 19 2026, 10:59 AM
Just seeing this for the first time (somehow I missed it rolleyes.gif ).
Very nice project! I will be closely following. Thank you for sharing the details as usual. sunglasses.gif
Posted by: Luke M Sep 25 2026, 04:39 AM
The new sheet metal from RD was delivered. It looks like I'll have to wait til next week to start installing some of it. I did a quick test fit of the engine tray which will need some fine tuning. smash.gif welder.gif
Posted by: Luke M Oct 2 2026, 03:15 PM
I tweaked my back last weekend so no welding progress this week. Hopefully by next week I'll be in better shape.
I did however get some new parts in and got one rear control arm assembled today.
Moving slow so it took all darn day to do just one side.
I'm using factory 6 rear hubs, stubs, German made bearings, PMB 6 GT calipers, pads, hardware, and new 914rubber bushings with some re-plated shafts.
I need to get a hold of Eric at PMB about the spacer situation that I got going on here with the calipers. Looks like I need a 5 mm spacer to have the caliper centered over the rotor. I have two washers stacked right now at 4.5 mm. I'll see what Mr. Eric has for a fix. I know PMB sells the GT rotors but I already had these SC rotors on hand.
Paging Mr. Shea... @http://www.914world.com/bbs2/index.php?showuser=1110
Posted by: Luke M Oct 10 2026, 06:15 AM
Started the R/R chassis repair. I'll have to dig out the outer rocker and r/r q-panel to take some measurements for the jack point location.
Posted by: Luke M Oct 22 2026, 12:18 PM
I got the rear caliper spacing figured out. I missed the part about needing the spacer kit when using the rear GT calipers with the standard SC rear rotors. I also got the jack point location set. I need to take a few more measurements and test fit the rear q-panel. Once that's done the welding will start.
