Printable Version of Topic
914World.com _ 914World Garage _ 915 transaxle into 914-6 questions
Posted by: ConeDodger Oct 23 2026, 09:19 AM
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so…
What do I need? Currently running the JWest shifter for the 901.
Posted by: Steve Oct 23 2026, 10:04 AM
QUOTE(ConeDodger @ Oct 23 2026, 08:19 AM) *
Been there done that...
I reached out to JWest and converted my 901 Rennshift to a 915 Rennshift. I originally made my own shift rod with two Apex joints. PMS said it was too wimpy, so I ended up with their shift rod. I am running the Martin Bott 916 kit. If your kit is a wevo, it is a totally different animal. It is a lot of work but worth it.
Check out this link for pictures of the home made shift rods. Otherwise pay the bucks and buy all the plug and play stuff from PMS.
http://www.914world.com/bbs2/index.php?showtopic=102988
This page is from one of the PMS builds, mine is identical, except for MSDS 1 3/4" headers for my 3.6.
https://patrickmotorsports.com/blogs/news/1972-914-tangerine
Posted by: SirAndy Oct 23 2026, 10:12 AM
Many moons ago i helped Brad adding a custom cable shift solution to a 915 in a 914.
It worked surprisingly well and costs a fraction of the side-shift kits available.
I have a 915 that was meant to go with the 3.6L engine but i never got around using it.
The plan was to do the same thing and go cable shift.
Posted by: mepstein Oct 23 2026, 10:22 AM
I’m building two Martin Bott 916 kits right now. I figured I’d get to the shift rod issue when I get done the trans.
I need to sell my 915 with the Wevo kit.
Posted by: ConeDodger Oct 23 2026, 10:23 AM
QUOTE(SirAndy @ Oct 23 2026, 12:12 PM) *
Weird to think that there are maybe only a handful of us that know who you mean when you say you helped “Brad.” rolleyes.gif
Our plan (Mark) was a cable shifter set up. Glad to hear it worked well.
Posted by: Steve Oct 23 2026, 10:30 AM
I am happy with my 915/916 conversion. It also has the cool 916 history to it, but money wise it seems a Boxster S or Cayman S six speed would make more sense.
The 915 is a little balky to shift, but you get used to it.
https://forums.pelicanparts.com/porsche-911-technical-forum/1139404-no-longer-impossible-996-997-transmission-onto-air-cooled-engines.html
Posted by: Luke M Oct 23 2026, 11:49 AM
QUOTE(Steve @ Oct 23 2026, 09:04 AM) *
I have the same setup as Steve. Carrera 915 with the Bott 916 kit and all of the PMS shift linkage. I'm going to use the JWest shifter as well. All still waiting to get installed so no real world experience on how it all works. PMS did the Bott 916 conversion several years ago. It was not cheap then so I can't imagine what it would cost today.
Posted by: mepstein Oct 23 2026, 12:54 PM
QUOTE(Luke M @ Oct 23 2026, 01:49 PM) *
The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car.
Posted by: SirAndy Oct 23 2026, 01:37 PM
QUOTE(mepstein @ Oct 23 2026, 11:54 AM) *
Posted by: mepstein Oct 23 2026, 02:01 PM
QUOTE(SirAndy @ Oct 23 2026, 03:37 PM) *
Round numbers. I’m probably a bit less. PMS is probably more. There’s no way to do it cheap. Just like when we bought engines years ago for single digits.
I did just buy the Martin Bott kits so they are real world numbers, not just make believe. Martin won’t ship the kit until you send him the core parts from the 915 trans so it’s a bit of a commitment to get started.
Posted by: SirAndy Oct 23 2026, 03:30 PM
QUOTE(mepstein @ Oct 23 2026, 01:01 PM) *
I don't doubt the numbers, just can't believe what this stuff costs these days.
Posted by: Steve Oct 23 2026, 03:34 PM
QUOTE(SirAndy @ Oct 23 2026, 02:30 PM) *
I’m glad I did the 916 trans when I did. I probably have around $10k in my trans. It was awesome to have a matching trans to my 3.2 and even better with the 3.6.
Posted by: Steve Oct 23 2026, 09:45 PM
QUOTE(SirAndy @ Oct 23 2026, 09:12 AM) *
Cable shift is still in business, but I don’t know if anyone still makes the rear mount for a 914.
https://cableshift.com/product/ols/products/porsche-930
I noticed PMS also sells the cable shifters. Curious if they sell the rear mount.
Posted by: mepstein Oct 24 2026, 05:40 AM
QUOTE(Steve @ Oct 23 2026, 11:45 PM) *
To the best of my knowledge, PMS stopped selling the cable shift for the 915 conversion cars. Years ago I bought one new from a pelican member. Tried it out on a test stand. It was a joke. Sold it. There’s a reason nobody uses them. If anyone here has a working example, I’ll be shocked and surprised.
Posted by: Steve Oct 24 2026, 06:41 PM
QUOTE(mepstein @ Oct 24 2026, 04:40 AM) *
beerchug.gif too funny Mark!! I have been around 914’s since the late 70’s and have never seen a cable shift 915. Only wevo, velios and factory 916 or factory 916 replica.. Vellios past away and too small of a market for wevo to make new molds, so that leaves the 916 kit by either Martin Bott or the other firm in Switzerland. I thought they were the UK, but the link says Switzerland.
https://www.elevenparts.com/viewer.php?id=880&img=pictures/880/elevenp0
Posted by: mepstein Oct 25 2026, 07:30 AM
I had the cable shifter and a PMS tubular transmission mount. It wasn’t even close to working so I ditched it all.
Posted by: Maltese Falcon Oct 25 2026, 08:42 AM
Jaide Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff.
Picture coming in a day or two.
Looks like when installed, the mechanism would sit 10" past the license plate blink.gif
Posted by: mepstein Oct 25 2026, 10:17 AM
QUOTE(Maltese Falcon @ Oct 25 2026, 10:42 AM) *
Jade Car Co. or very early Rengade also had an adapter mechanism which attached to the tail shifter of the 915 transaxle. I discovered it in my shop racks the other day while re-arranging shop stuff.
That was another challenge with the cable shift. I didn’t really want independent mufflers.
The Martin Bott kit is really pricey but if you want the equivalent of a 914 side shift trans, it’s really the best way to go.
I’m custom gearing both the 915 trans in my 67 and my 914. Peter Dawe told me it’s the best performance upgrade you can make on a car. We’ve done it on a couple customers cars and it’s true. It takes the whole driving experience to another level. It doesn’t sound like it should but having the right gear for every shift is amazing.
Posted by: Steve Oct 25 2026, 10:47 AM
QUOTE(mepstein @ Oct 25 2026, 09:17 AM) *
agree.gif I had PMS go through my 916 trans, the previous two well known Porsche shops in so cal, could not figure it out. The car now shifts better than my 901 trans ever did. I just finished my second autocross with it. What a blast with the 3.6. But... I am curious if the Boxster S / Caymen S six speed kit would be a better option now for bigger motors.
Posted by: mepstein Oct 25 2026, 11:33 AM
QUOTE(Steve @ Oct 25 2026, 12:47 PM) *
I don’t know. I’ve never done one. A buddy of mine does sell a conversion kit to put a 996 trans behind a 3.6. Tyler at top tuning. https://www.topperformancetuning.com/shop
Posted by: Maltese Falcon Oct 25 2026, 02:05 PM
The 20th Century Jaide kit for 915 trans, into the 914.
'Mechanical shift linkage adapter for use with 911 SC/ or Carrera shift console. They also sold the rear 915 to 914 rear undercar bracket to hold 915 into position. I actually saw one on a working /driving 914 at an Aase Motors open house long ago.
Posted by: Maltese Falcon Oct 25 2026, 02:32 PM
...now I'm thinking that the original design for this nosecone shift adapter was from Rod Simpson Hybrids (v8 914/ 911 conversions) in WLA CA. He pre-dated the first Gen Renegade kits. Jaide must have just carbon copied it.
Posted by: mepstein Oct 25 2026, 03:18 PM
QUOTE(Maltese Falcon @ Oct 25 2026, 04:05 PM) *
I can’t imagine that gave a satisfactory shifting experience. Cool that you still had it in your parts archives.
Posted by: Maltese Falcon Oct 25 2026, 06:58 PM
QUOTE(mepstein @ Oct 25 2026, 02:18 PM) *
I've know a few techs at different independent Air Cooled shops in those days: some of them wrestled with the Velios 915-to-914 shift kits...constantly adjust + re adjust. Adequate gear selection at best.
Posted by: mepstein Oct 25 2026, 07:21 PM
QUOTE(Maltese Falcon @ Oct 25 2026, 08:58 PM) *
A friend of mine (914dave) has a Velios kit behind his 3.2. I think it works really well for him. But he’s a machinist and told me he did a good amount of custom work on the internals.
Posted by: East coaster Oct 25 2026, 07:22 PM
Is Wevo still a thing? I had a Wevo converted 915 in my 3.6 teener and it worked well with my Renshift shifter.
Posted by: mepstein Oct 25 2026, 08:09 PM
QUOTE(East coaster @ Oct 25 2026, 09:22 PM) *
Wevo as a company is still in business. They no longer make the 914/915 conversion kit
Posted by: erwan914 Oct 26 2026, 12:38 AM
15 years ago, I put together this setup using the original gear lever from a Porsche 914 2.0.
Posted by: SirAndy Oct 26 2026, 11:18 AM
QUOTE(erwan914 @ Oct 25 2026, 11:38 PM) *
That looks interesting!
Posted by: Krieger Oct 26 2026, 12:33 PM
I like that! Maybe with a better cable shifter?
Posted by: gereed75 Oct 26 2026, 06:44 PM
Erwan. That looks really slick. Fully adjustable and tightly restrained.
How did it work?
Where there is a will there is a way! Elegant piece of engineering there!
Posted by: erwan914 Oct 27 2026, 12:56 AM
QUOTE(gereed75 @ Oct 26 2026, 04:44 PM) *
How did it work?
I had spent a lot of time putting this assembly together, but the results were very successful.
Posted by: sixnotfour Oct 27 2026, 03:55 AM
one Obstacle....no bannana mufflers
Posted by: sixnotfour Oct 27 2026, 04:49 AM
Porsche gearbox Ferrari twin Turb0 308 Custom..
PatrickMS cable shifter.. I made a shifter gate ,,because owner Couldnt find Gears..
In his defense He was racing A Corvette and a AC Cobra a 312 Ferrari... jumping in and out..at the Track.. driving.gif and I converted it to Dry Sump so it had oil pressure while cornering beer.gif
Posted by: brant Oct 27 2026, 10:51 AM
Dang that car looks awesome Jeff!
Posted by: live free & drive Oct 28 2026, 09:47 AM
Cheap solution?
https://www.ebay.com/itm/237142485729?_trkparms=amclksrc%3DITM%26aid%3D1110028%26algo%3DHOMESPLICE.EXPLORE%26ao%3D1%26asc%3D20240513110749%26meid%3D3083f740930f45769b67630d21d9653f%26pid%3D102140%26rk%3D17%26rkt%3D22%26itm%3D237142485729%26pmt%3D0%26noa%3D1%26pg%3D3959035%26algv%3DExploreForYouSavedFeedV1%26brand%3DUnbranded%26fpg%3D0&_trksid=p3959035.c102140.m167418
Posted by: rgalla9146 Oct 28 2026, 02:48 PM
I have Martin Bott 916 conversion kit in my GT project on a
magnesium case 1972 915 trans.
I had a friend flip the differential and rebuild the ZF limited slip.
I rebuilt the rest of the trans and located and mounted a bracket inside that is a
necessary part of of the conversion
It as now in my car and working.
I have two issues.
I'm using a 1972 911 shifter which is a 'one year only 'item, it looks the
same as a 914 rear shifter but is quite different in detail to suit the 915 shift pattern.
The linkage between the shifter and trans is similar to a 914 rear shift
and is adjusted in the same way. Adjustment is difficult and is still not perfect.
I supplied the 915 shifter parts Bott needed to modify for the kit.
I also provided the stock 911 speedo drive parts.
My cable driven speedo indicates 50 percent too high. At 50 mph (gps) it indicates
~ 100 mph I've tried different speedos. Same result.
No solution yet, but haven't chased it too much either. Ideas ?
Posted by: dr914@autoatlanta.com Oct 28 2026, 03:12 PM
Martin Bott, in Germany or cable shift, we just listed a 915 cable shift assembly we removed from a car that Jim Patrick built in favor of the Martin Bott kit
Posted by: 914werke Oct 28 2026, 07:25 PM
QUOTE(sixnotfour @ Oct 27 2026, 03:49 AM) *
owner Couldnt find Gears..In his defense He was racing A Corvette and a AC Cobra a 312 Ferrari... jumping in and out..at the Track.. Attached Image
Posted by: Luke M Oct 29 2026, 04:48 AM
QUOTE(rgalla9146 @ Oct 28 2026, 01:48 PM) *
I have two issues.
Hi Rory,
When PMS did my Bott 915/916 conversion they also installed a sensor for an electric speedo. I'd have to dig through some paperwork to find out what they ended up using. The bracket and sensor mount right on the trans/cv output shaft. Then you'd have to run wires to and from the speedo/sensor. I'll see if I have pics of the bracket and sensor.
Posted by: Steve Oct 29 2026, 07:42 AM
QUOTE(Luke M @ Oct 29 2026, 03:48 AM) *
I have two issues.
Hi Rory,
If the trans is an electronic speedo trans then it should of been part of the flipped differential required for the 914. Wevo makes the side cover for the electronic speedo sensor. https://www.wevo.com/Products/TransmissionProducts/WevoTransmissionProducts-External_TransmissionSideCovers.htm
I don't miss the bouncy cable speedometer. Easy to wire up to a stock 911 Electronic speedo. I also just used a straight bracket connected to one of the side bolts to prevent the sensor from popping out. I will look for a picture.
Posted by: mepstein Oct 29 2026, 09:58 AM
Rory’s is a 72. First year use of 915 trans. Mechanical speedo. I’m curious since I’m also building one mechanical, one electronic
Posted by: rgalla9146 Oct 29 2026, 04:06 PM
[quote name='Luke M' date='Oct 29 2026, 06:48 AM' post='3276756']
[quote name='rgalla9146' post='3276716' date='Oct 28 2026, 01:48 PM']
I have two issues.
[/quote]
Hi Rory,
[/quote
Hey Steve
Thank you for the offer.
Part of me wants to stick with OEM parts and solve this problem as I've always
done.
I don't know my differential ratio or if the speedo drive parts are correct and
compatable. I didn't think these unknowns would becone an issue.
I'm not too keen on disassembling the trans only to find nothing is wrong and the
problem still exists.
Your solution might be the most sensible way forward.
Any information is appreciated.
Thanks again
Rory
Posted by: Luke M Oct 29 2026, 04:17 PM
Here's what my sensor looks like. The sensor bracket gets mounted to the side cover then wires run from sensor to electric speedo. The wheel gets mounted on the cv.
PMS did not send me any installation instructions so if anyone has some out there that may help too.
Posted by: scallyk9 Oct 29 2026, 04:32 PM
[quote name='rgalla9146' date='Oct 29 2026, 03:06 PM' post='3276816']
I have two issues.
[/quote]
Hi Rory,
[/quote
Hey Steve
done.
Thanks again
Rory
[/quote]
Something to check is the final drive ration on your 915 because the early 915 FDRs were different from the later versions.
I have a 1979 915 transaxle (aluminum case) in my 3.2L conversion using the Martin Bott kit. I have a CPS side plate with a standard electronic sensor wired to a 1987 Carrera speedometer and it is very accurate except for a change in tire size.
Posted by: rgalla9146 Oct 29 2026, 05:25 PM
[quote name='scallyk9' date='Oct 29 2026, 06:32 PM' post='3276819']
I have two issues.
[/quote]
Hi Rory,
[/quote
Hey Steve
done.
Thanks again
Rory
[/quote]
[/quote]
Hi Scally
What is a CPS side cover ?
By 'standard' electronic sensor do you mean a 911 part ? or an aftermarket sensor
getting a signal from a wheel attached to a CV ?
TIA
Rory
Posted by: mepstein Oct 29 2026, 05:33 PM
Probably CMS - California Motorsports
https://californiamotorsports.net/products/cms-915-billet-side-plate
Posted by: Steve Oct 30 2026, 11:50 AM
I have two issues.
@http://www.914world.com/bbs2/index.php?showuser=5176
Rory,
Curious what motor are you running? Most of the time people switch to the 915 for 3.2 or bigger motors, even though the factory 916's also used the early 7:31 ring & pinion 915 trans with up to 2.9 liter motors (Brutus and the Recaro fire engine 914-6GT), but that's all that was available at the time. The 914/901 trans is also 7:31, so what is the advantage of a 7:31 915? More reliable 1st gear? Better stock gearing? Period correct? Just curious. I know that some 911 owners switch to the earlier 7:31 915 trans because it was better for the track. Lower gears and close ratio shifting.
For me, I went with a 1986 915 8:31 ring & pinion trans for gearing that matched my 3.2. The 914 trans with the 3.2 drove me up the wall, since all the gears were too short for the street and I felt like I was shifting all the time. The later 915 trans also has an electronic speedometer and omega spring. The stock 8:31 Ring & Pinion 915 is awesome with the 3.6. The gears feel a little short compared to the 3.2, but it makes the car very quick. I still plan on changing 5th gear to the tallest 5th which is a TL 29:21 gear. This gear is the same as the stock G50 five speed 5th in a 964. It's also easy to change, since its in the nose cone. You don't have to remove the trans.
Posted by: sixnotfour Oct 30 2026, 08:11 PM
Rory Said...
Martins website says...
In case of mechanical speedo drive we need the OEM speedo drive parts out of your 915 gear cover.
Modifications to gearbox and kit have to be made. Speedometer has to be adjusted.
I have a mech. speedo, mag case.. Kit Too..
and an sc 915 with factory eletronic speedo..
Posted by: rgalla9146 Oct 31 2026, 09:54 AM
QUOTE(Steve @ Oct 30 2026, 01:50 PM) *
I have two issues.
Rory,
Hey Steve
I went with the 915/916 because I intended to install a bigger 911 engine.
I've been delayed (big time) with what is now a 3.2 short stroke.
To keep the car mobil in the meantime a stock '68 911 2.0 is installed in front of
the 916 !
The 3.2 is almost ready.
My '72 915 most likely has the stock 7:31 ...I never thought to count the teeth
when it was apart .
Based on my experience driving the current combo I know a longer 5th gear is in
my future . 3800 rpm at 70 mph. Maybe other ratios as well.
When I first drove the car with the 916 the speed was obviously way off. I wrote to
Martin Bott but received no reply.
Did Bott say to someone here that a 'speedo adjustment' will be necessary ?
Do you know of anyone with a 916 and an operating mechanical speedo ?
I was told by an instrument specialist thay my speedo error is too great to be
corrected in the instrument.
TIA Rory
Any info from anyone is appreciated. A mechanical solution would be my first choice.
Posted by: Steve Oct 31 2026, 10:09 AM
Rory,
Did you try reaching out to the guys in this thread with the mechanical speedo option?
Otherwise my electronic speedo is pretty accurate but I am also running stock 25” height tires.
Posted by: mepstein Oct 31 2026, 10:35 AM
QUOTE(rgalla9146 @ Oct 31 2026, 11:54 AM) *
I have two issues.
Rory,
Hey Steve
the 916 !
when it was apart .
TIA Rory
Rory - when you originally purchased the kit, did you send the speedo gear and other exchange pieces to the place in NJ. That was a requirement for my mechanical kit before Martin shipped from Germany.
Posted by: rgalla9146 Oct 31 2026, 04:04 PM
QUOTE(mepstein @ Oct 31 2026, 12:35 PM) *
I have two issues.
Rory,
Hey Steve
the 916 !
when it was apart .
TIA Rory
Hey Mark
Yes, I sent the speedo gears and shifter parts that would be modified to suit
the relocated selector mechanism.
Martin Bott has an assaciate here in New Jersey... Oliveri ?
Posted by: mepstein Oct 31 2026, 04:51 PM
QUOTE(rgalla9146 @ Oct 31 2026, 06:04 PM) *
I have two issues.
Rory,
Hey Steve
the 916 !
when it was apart .
TIA Rory
Hey Mark
Yes - Alex Olaverri in Belleville NJ.
Posted by: rgalla9146 Oct 31 2026, 06:25 PM
I have two issues.
Rory,
Hey Steve
the 916 !
when it was apart .
TIA Rory
Hey Mark
My history with the 916 has been long and sporatic...ten plus years.
Distractions were frequent and important.
The trans is currently in my GT project driving and shifting better than ever.
I'm a stickler for period correct parts and appearance whenever possible.
I'll be installing the long delayed 3.2 in the near future.
My take on the speedo issue.
The cable drive is reaching the instrument. Could stock 911 speedo drive gears
inside the trans be so far off as to spin the cable 50 percent too fast ?
AFAIK my R&P is 7:31 same as every 914
My rear tires are not so short that they could be at fault. 225vr50/16"
My angle drive is 1:1 911s don't have an angle drive... so same result.
Maybe the answer is already known.
Send the instrument and the GPS info to a specialist and get it 'adjusted'
My take on the electronic solution.
AFAIK the original speedo sender for a 911 can not be used with a flipped
differential making an aftermarket sender/wheel necessary.
I don't have an electronic speedo and don't love the idea of buying one and then
having to get it backdated to match my other instruments.
A bracket /sender near a CV with wiring extending to the instrument panel ?
Not a fan.
Does anyone have or know of a working mechanical speedo on a 916 ?
TIA
Rory
Posted by: mepstein Oct 31 2026, 07:26 PM
I’m hoping the one I’m currently building will work properly but if not…
Have you tried contacting Martin about it.
I’m using an electronic speedo on mine. GPS sender.
Posted by: rgalla9146 Nov 1 2026, 05:33 PM
QUOTE(mepstein @ Oct 31 2026, 09:26 PM) *
Yes Mark, I've written to him again.
I'm hopeful he will comfirm a speedo can be made to work.
Posted by: scallyk9 Nov 1 2026, 06:39 PM
[/quote]
Hi Scally
TIA
Rory
[/quote]
Thanks to Mark for correcting me. Yes, it was a sideplate from CMS and I had called them first and discussed my needs and that we were using a new Porsche factory sensor. We chose the sensor to match the '86 Carrera 3.2L speedometer I was using although the sensor covered other '80s 911s. I don't recall if they modified the side plate but I think it was not. There is good info on the California motorsports website.
Posted by: Steve Nov 1 2026, 09:53 PM
[quote name='scallyk9' date='Nov 1 2026, 05:39 PM' post='3277223']
[/quote]
Hi Scally
TIA
Rory
[/quote]
[/quote]
Wevo also makes the side plate for an electronic speedo 915 trans. See my post 41
http://www.914world.com/bbs2/index.php?s=&showtopic=379476&view=findpost&p=3276764
Posted by: sixnotfour Nov 2 2026, 12:16 AM
Rory,, This Help ?
https://mrspeedometer.com/collections/adapters/products/ratio-adapter
Posted by: mepstein Nov 2 2026, 05:20 AM
QUOTE(sixnotfour @ Nov 2 2026, 01:16 AM) *
Rory,, This Help ?
That's a neat piece but shouldn't be needed for what Rory has.
Hopefully Martin will reply back with info.
Posted by: sixnotfour Nov 2 2026, 10:05 AM
QUOTE(mepstein @ Nov 2 2026, 04:20 AM) *
Rory,, This Help ?
Yes, Im waiting to hear too.. At this point I think the gps electronic speedo, makeover is the way to go pianning ahead popcorn[1].gif driving.gif ... one less cable hanging around. shades.gif
Posted by: mepstein Nov 2 2026, 12:43 PM
QUOTE(sixnotfour @ Nov 2 2026, 11:05 AM) *
Rory,, This Help ?
I have the parts to do it. I’ll take pics if you need the info. I think it was around $450 in electronics and the cost of an electric speedo.
Posted by: rgalla9146 Nov 4 2026, 07:26 AM
Martin Bott replied:
Hi Rory,
you need to have a speedo adjustment, or a little gearset to adjust.
Can only give the mechanical potential to use a mechanical speedo, but can not give exact speedo result.
The parts inside the nosecone are Porsche OEM, but 915 was without this speedo drive that the 914 uses and what you probably use.
Will have to do this adjustment for my car also.
Regards
Martin Bott
Posted by: mepstein Nov 4 2026, 09:01 AM
So does that mean a mechanical speedo from a 72-77 911 will work correctly?
Posted by: rgalla9146 Nov 4 2026, 11:55 AM
QUOTE(mepstein @ Nov 4 2026, 11:01 AM) *
You'd think so right ?
I thought I answered that question but did not check the part number of the
'72 150mph speedo that I have.
Anyone know the part number of a '72 911 speedo ?
Posted by: Steve Nov 4 2026, 12:17 PM
QUOTE(rgalla9146 @ Nov 4 2026, 09:55 AM) *
https://www.ebay.com/itm/223488388370
91164150600 = 180 mph speedometer
91164150200 = 150 mph speedometer
I use Auto Atlanta to look up part numbers. https://www.autoatlanta.com/pages/911-70-73-parts/906-00
Posted by: rgalla9146 Nov 4 2026, 03:47 PM
QUOTE(Steve @ Nov 4 2026, 02:17 PM) *
Thank you Steve
This info will help me to know what is what.
I have a friend who has a dormant '72 S ... going to ask to borrow his speedo.
Also, I will probably end up removing my '916' rear cover and comparing speedo
drives with those in a typical 914 rear cover.
Onward
Posted by: sixnotfour Nov 4 2026, 03:50 PM
HELP.. @http://www.914world.com/bbs2/index.php?showuser=1875
I sent jbell an email asking him ???
Posted by: rgalla9146 Nov 4 2026, 08:24 PM
John Bell did a 10K tach and a GT fuel gauge for me a couple years ago.
I just went back through correspondence and see that he said that
with GPS mph / speedo mph info he could make my instrument work.
Someone along the way told me my speedo error was too great to correct
in the instrument. I forget who.
Looks like some remedies are possible ...
Posted by: jbell959 Nov 4 2026, 08:29 PM
The ratios of the 914 and 911 speedometers are different, but very close. The 911/912 speedometers are stamped W0.8 and the 914s are W0.77
I believe this corresponds to 800 revolutions versus 770 revolutions per mile. This difference would obviously not explain the 50Mph difference. That is actually 100% off not 50%. Sounds to me like it's an issue with the gearing inside the transmission and the cable is spinning twice as fast as it should be.
No way to compensate for that inside the speedometer.
Posted by: sixnotfour Nov 4 2026, 11:30 PM
@http://www.914world.com/bbs2/index.php?showuser=1875 ,, Thank You for your Knowledge...
Looks like this the cure,, If you have to run a cable mag915..Im not.. GPStoshortcable.
pick a ratio Trans..
Posted by: mepstein Nov 5 2026, 07:04 AM
I don’t believe the real 916 kit had that issue. I wonder what is different?
Posted by: rgalla9146 Nov 5 2026, 10:03 PM
I have disassembled 914 transmissions and rear covers with the speedo
gears included.
Does anyone have a 915 rear cover and speedo drive open to do a comparison ?
I do know that our 914 90 degree angle drive ratio is !:1
Could the 915 speedo drive gear ratios be so different ?
I also have a ('70-'71) 911 trans to compare with.
Posted by: sixnotfour Nov 6 2026, 12:00 AM
Well ,,I just got the Necessary parts from Johnny Walker..didnt think twice..
Sent em to Martin..Moved 1200 miles..6yrs later..All this came up...
What do think John ? @http://www.914world.com/bbs2/index.php?showuser=1875
Posted by: rgalla9146 Nov 6 2026, 11:01 AM
Shown with green background is the 914 speedo gear train.
The other shows the interior of a 915 rear cover which should be the same as
a replica 916 cover.
The shaft shown by 'sixnotfour' fits between the boss at upper left and the gear at
lower right.
Could the correct companion gears be machined off one shaft and pressed/silver
soldered onto the other to create the ratio we need ? ... space permitting ?
Anyone ?
Posted by: sixnotfour Nov 8 2026, 10:38 AM
The exit ratio of the MB conversion versus the 914 .. more or less.. wacko.gif
gear count calculations needed...
Posted by: sixnotfour Nov 8 2026, 10:57 AM
Im Sure enjoying GRNMNEE's 8:31, aluminum case, electro. speedo.. at the momement.. driving.gif poke.gif lol-2.gif aktion035.gif
Posted by: Steve Nov 8 2026, 09:01 PM
QUOTE(sixnotfour @ Nov 8 2026, 08:57 AM) *
That's not very nice! laugh.gif but yes the 8:31 stock Electronic speedo was plug and play.
No more bouncy speedometer.
I did see that Ron also bought the mechanical speedo option and he didn't mention any issues with it. Have you tried to reach out to him? http://www.914world.com/bbs2/index.php?s=&showtopic=102988&view=findpost&p=1891436
Posted by: sixnotfour Nov 8 2026, 10:37 PM
I sent Ron a message... He maybe the simple soloution..
Posted by: rgalla9146 Nov 9 2026, 06:19 AM
QUOTE(mepstein @ Nov 4 2026, 10:01 AM) *
Yesterday I tried a '73 911 speedo. Same result 30mph GPS / 65 mph on speedo
Posted by: Steve Nov 9 2026, 08:17 AM
QUOTE(sixnotfour @ Nov 8 2026, 08:37 PM) *
I also got in on the group buy. Glad I did it when I did. The cost now is ridiculous. Let alone the current $200.00 + an hour shop rates.
Posted by: mepstein Nov 9 2026, 09:23 AM
QUOTE(Steve @ Nov 9 2026, 09:17 AM) *
The last one I purchased also had a $1000 customs bill on top of everything. sad.gif
Posted by: rgalla9146 Nov 9 2026, 11:40 AM
So... Ron, Rory, Steve and Jeff all got Martins kit many years ago.
Mark is also on board.
Anyone else ?
Who opted for cable drive speedo ?
Who has a working cable drive speedo ?
Jeff thank you for the pics. They help me to understand the layout of the
915/916 compared to the 914
The last time I saw the inside of my 916 was in 2022
Posted by: mepstein Nov 9 2026, 01:25 PM
I have the kit and core 915 trans so if you need any pics or info, let me know. I’d like to have a clear idea about this before I assemble the trans.
Posted by: rgalla9146 Nov 9 2026, 03:29 PM
QUOTE(sixnotfour @ Nov 8 2026, 11:38 AM) *
Hey Jeff
Can you give me a tooth count of the gear on the end of pinion shaft and also the
big gear and the smaller gear on other piece
TIA
Rory
Posted by: sixnotfour Nov 13 2026, 12:27 PM
I got the pics off the web,, I can get gear count for all but the end Martin cuts off... May be a Bit Though ,,My Mom is Not Well..and 1000 miles away...Lots to get squared away asap..
At least we are moving forward on the speedo question..Havent got a reply from Ron S.
Posted by: Steve Nov 13 2026, 10:35 PM
QUOTE(sixnotfour @ Nov 13 2026, 10:27 AM) *
Ron hasn't logged in since April 30th and I think email notification is dead. Unless someone else knows how to reach him outside of this site, it might be awhile.
Posted by: ConeDodger Nov 13 2026, 11:09 PM
Having purchased some parts from WEVO, I recognize the designs. A lot of it has moved to Tarrett Engineering…
Posted by: rgalla9146 Nov 14 2026, 12:47 PM
QUOTE(sixnotfour @ Nov 13 2026, 01:27 PM) *
"the end that Martin cuts off " ?? ...none of those gears are decorative.
Until I take my tailcone off I have no idea what has been done.
Here's my take;
Martin was happy to make the speedo drive rotate and that if any correction was
necessary it could be made in the speedometer.
That is not likely from what I've learned.
It looks like a GPS driven speedo will be the answer.
And to think I had it apart when first installed and didn't think to look inside the rear cover.
