Posted by: mgphoto Oct 30 2026, 09:50 PM
The neck of the fuel tank has a nipple on the rear the hose attaches there.
Posted by: wonkipop Nov 2 2026, 02:58 PM
QUOTE(DennisV @ Oct 30 2026, 07:38 PM)
Where is the end of this hose coming off the expansion tank meant to connect? I can't find anywhere that it would reach.
The parts catalog just lists its size and length: Hose 4 X 2,5 - 290 MM
Thank you.
second picture posted. a 6 that did not have a charcoal canister?
can see T connection in the drain tube that connects in the fume line from the expansion tank. the euro set up all ROW (except late japanese spec) had.
as others have posted short hose goes from the nipple on exp tank at front and connects to filler. how the expansion tank is connected to the fuel tank. in your set up the expansion tank is not in a closed circuit. its venting via the longer tube into the drain tube and fumes leave under the car - rather than go into the charcoal can circuit.
good for stinking up the garage.
given the drain tube set up - do you know if this 6 was delivered 49 states when new and a 70MY?
Posted by: fixer34 Nov 2 2026, 05:27 PM
Wonki, the second pictures posted (green car) is mine. I've had it since July 1977 and it never had a charcoal canister. No holes/brackets/extra hoses for one.
COA says it is a US car, March 1970 VIN.
First part of its life is pretty much unknown, it has a door service sticker from a dealer outside Boston, Mass but the writing is too faded to read. Tried researching the dealer, they were bought out years ago and the current dealer doesn't have records that far back.
I bought it from a private owner in the Chicago, IL suburbs. Where it spent those 6-7 years in between I have no idea. No records/receipts came with the car besides the owner manual.
Strange thing is the guys that have access to Porsche records cannot find the VIN or delivery info.
Posted by: wonkipop Nov 3 2026, 05:10 AM
QUOTE(fixer34 @ Nov 2 2026, 05:27 PM)
i'm looking at dennisv's second photo in his original post fixer. he has two images in his first post.
if you look closely you can see his drain tube has a t in it and the line out of the right hand side of the expansion tank goes into this drain hose at the t. as per euro cars.
but just the same its interesting your car does not have a charcoal can either.
i have read of a few 70MY sixes lacking the can. curious if there were any fours delivered like that? i'm thinking its a 49 states thing. though all info i can find on evap emissions says its a USA wide DOT requirement for calendar year 1970. but beginning to think that even that far back all emissions regs were staged. california first and rest of USA the year after. so 70MY 914s would have escaped the evap systems while california cars had it?
Posted by: DennisV Nov 4 2026, 06:59 AM
QUOTE(wonkipop @ Nov 2 2026, 12:58 PM)
Correct. No charcoal canister.
I am lucky to have the original maintenance record book. It was delivered to IL in May 1970.
Posted by: fixer34 Nov 4 2026, 06:54 PM
QUOTE(wonkipop @ Nov 3 2026, 06:10 AM)
Sorry, misunderstood. Didn't get a picture but the expansion tank on mine has a small hose connection on each side. Driver's (right?) side loops underneath and goes to a 'T' on the large drain tube (gas tank overflow?). The passenger side goes to the tank fill housing.
Posted by: wonkipop Nov 4 2026, 08:58 PM
QUOTE(fixer34 @ Nov 4 2026, 06:54 PM)
yeah - thats the standard ROW set up fixer. (as well as those early 914s that went stateside in 70MY).
my old mate who owned the crayfords 73 2.0 had the same set up. no evap system in the ROW cars throughout all years. interestingly the japanese brought evap in for 73 i believe. and australia in 74. which is believe it or not what shut down private imporation of 914s via the UK and crayfords conversion to RHD. seems silly that no one thought back then to simply install the system on a UK delivered car bound for australia. would have been pretty simple to do - esp since the interior would have been gutted for the conversion to RHD. but they didn't.
so the two 73 models that came here were the last ones in to go on the road at that time when the cars were new.
