on the a road run with the guys last month on back roads not even taken it easy i got 29.5mpg.
i'm trying something this tank while drivin to an fro to work, 8 miles of surface streets and a little freeway. short shift [edit; i ment skip shift] using 1st , 3rd, and 5th.
all on flat easy roads. use brakes only not down shifting while decel. or stopping.
its hard to not just row through the gears, but i'll try my best.
Downshifting while decelerating does not use gas, but not downshifting wears brakes faster.
I haven't checked my mileage....but not using nearly as much as my pickup, so i don't care... Gassed up today... $1.29 for a litre of 92 grade! 4.55 litres per imperial gallon. Yikes!
0 miles
1 gallon of gas
2 jackstands
Back in the 70's on a trip from New Jersey to Lynchburg Virginia I went 550 miles on one tank full in my 1973 914 2.0.
QUOTE (Pugbug @ Sep 12 2005, 08:59 PM) |
Downshifting while decelerating does not use gas, but not downshifting wears brakes faster. I haven't checked my mileage....but not using nearly as much as my pickup, so i don't care... Gassed up today... $1.29 for a litre of 92 grade! 4.55 litres per imperial gallon. Yikes! |
Well....the worst gas milage I got was when a gas line poped of, the motor shut off, I tried to start the car a couple of times....yup the ground was covered in gas, a nice big puddle.....but yippie ...no fire,
sorry for the
Soo,,, What is this, most of us don't have wdorking odometers and the rest are too embarassed to say?????
:PERMAGRIN: Joe
if i understand l-jet f/i correctly the air valve senses fuel demand by how much air goes thru it. there for even when the throttle is closed there is still air going by the the throttle plate for idle. now under the high "vaccum" of decel. the engine is pulling more air passed the throttle plate even though its closed and this greater volume of air being sensed by the air valve and is firing longer fuel pulses to the injectors.
do i have this right or wrong
I dunno... I cheat.
I had this Saab, with all that information up to the second.. I loved doing the back side of hills in that thing... "Ahhh 143 miles per gallon.. I rock"...
M
QUOTE (messix @ Sep 13 2005, 01:38 AM) |
do i have this right or wrong |
With my recently transplanted injected 2056 I think I got in the neighborhood of 23mpg, mixed driving. Engine had sat for a year, then before that it sat longer - so I think I have some crap in the injectors, all other components check out fine (mps was tested and charted by Brad Anders).
With the injected 1.7 I got 34mpg going out to WCC.
Gotta figure out why the mileage isn't that great in the 2.0
After, all these years, collecting speedo's, I finally got one with a working odometer, and I just checked it the other day, 21.4, and thats with a 2.6 4 cyl with 48 Dell's and I would get more if I could keep my foot out of it
if someone could tell me the conversion from liter to gallon I could calculate ...
normally my 1.8 L-Jet is about 8.5 - 9.0 liter on 100 km*
but I didn't try to save on fuel yet - the teener is my hobby, not my daily driver
* 100 km = 62.5 miles (AFAIK)
My '74 2.0L got 50.7 mpg on a 180 mile leg of a trip from Chicago to St. Louis...all highway. After I fixed all of the vacuum leaks it got significantly worse (time to start pokin' some holes in stuff!)
QUOTE (lapuwali @ Sep 12 2005, 10:20 PM) | ||
So, would you rather use brake pads to slow the car, or use the clutch to slow the car? SOMETHING has to slip, and brake pads are a lot easier and cheaper to replace than clutches... |
QUOTE (Gustl @ Sep 12 2005, 11:23 PM) |
if someone could tell me the conversion from liter to gallon I could calculate ... normally my 1.8 L-Jet is about 8.5 - 9.0 liter on 100 km* but I didn't try to save on fuel yet - the teener is my hobby, not my daily driver * 100 km = 62.5 miles (AFAIK) |
I was able to get 72 while averaging 90 to 105 mph on a cross country trip.
From Maumee to Effingham Ill. for the Fun Fest 37 MPG
Return 39 MPG about 400 miles each leg all but 50 miles Xway.
Iam leaving Fri For Kerrys event in Eastern Pa. Map Quest says 502 miles all turnpike will post results Mon.
1.7with small Webers 34's Dave
Bay area to Denver, all highway, averaged 44 mpg in a 72 1.7.
QUOTE (cbenitah @ Sep 13 2005, 11:13 AM) | ||
1 L = 10 DL = 100 CL = 1000 ML 1 Gallon = 3.7854118 L Little help from Sweden |
Salem, Oregon to the east bay (Oakland),,,non stop, all highway: 42 mpg, all stock 72 1.7. it was about 600+ miles. Part of Oregon and Nor Cal are really BORING!
I got 31mpg when I picked up my car, from Altanta to DC. That's with a 2.0 with webber 40's and going about 72mph the whole trip. Not so bad for a new-buy that hadn't been tuned up correctly.
Back in the old days I used to calculate my mileage. With a '73 1.7 I used to get about 37 mpg on average. On long trips I could get around 50 mpg. I agree with Steve, 550 miles per tank was not unknown. One trip I calculated that on a portion of it I got close to 60 mpg.
1.8 with L-Jet. Changed to early 2.0 exhaust, no muffler, took off the 'snorkel' to my airbox and that's it. Valves are seriously out of adjustment.
I still average 28.4 mpg highway driving only (keepin the tach between 3000 & 3200 RPMs).
Much less for stop & go street traffic, of course. Somewhere around 18-22 (I get the RPMs up to 4500 & 5000 in 2nd and 3rd alot in street traffic).
1.7 D-Jet: 32 mpg mixed driving
2.4 carbed six: 21 mpg mixed (very hard not to put your foot down)
I got 31.5mpg coming back from Aminity, Ore a few yrs ago. That was driving 80-90 mph at night on I-5
I'm shocked at how many working odometers there are on this thread.
Maybe everybody just estimates like me!
QUOTE (Pugbug @ Sep 12 2005, 11:59 PM) |
Downshifting while decelerating does not use gas, but not downshifting wears brakes faster. |
QUOTE |
I personally would rather replace brake pads. |
There are some tall tales about milage. Some of ya'll are full of it.
My red Neck Racer gets such good gas milage that every 100 miles I have to take gas out so it don't spill out the filler neck.
If you get more than 27mpg then you are either running lean or you drive too slow.
Last summer I was doing tuning on the turbo and got 4mpg one afternoon (20 miles/ 5 gal.). Basically 20 miles at full throttle. I can understand why Jake needs so much fuel for his dyno runs. Under normal driving I get about 27mpg highway.
-Ben M.
QUOTE (Joe Ricard @ Sep 13 2005, 11:30 AM) |
There are some tall tales about milage. Some of ya'll are full of it. |
The Year was1970
1970 Porsche 914 1.7 (less than a month old)
Memphis TN to Panama City FL
via Jackson MS to Hattiesburg MS to Mobile AL to PC Florida
Distance of route taken =565 miles
914 Fuel tank 16.4
answer = 34 mpg using Premium gas
Total one way cost for fuel for the trip was about $6 or less.
And most thought the years 2000 on were going to be the good old days..... Flying cars, fueled by atoms.
I drove my 1.7 FI from Seattle to Reno and averaged 36 mpg for the trip.
My new 2.0 with webbers gets 29 when I don't get into it and 22-24 when "I drive it like I stole it!".
I put my motor in overrun.. it's still going to last around 90-100k before it needs a new car.. just like all the ones before it. (hopefully)
Oh, and on the teener miles per gallon, usually averaged, over 20 years, prolly about 20mpg.
M
....sounds like fishing stories to me - my Weber carburated 2.2 6cyl makes about 240 -260 miles on one tank - on a good day
Seems like a lot of people with carbs are getting good mileage. Too good. Sounds like lean mixtures to me.
-Ben M.
QUOTE (davep @ Sep 13 2005, 10:09 AM) |
Back in the old days I used to calculate my mileage. With a '73 1.7 I used to get about 37 mpg on average. On long trips I could get around 50 mpg. I agree with Steve, 550 miles per tank was not unknown. One trip I calculated that on a portion of it I got close to 60 mpg. |
QUOTE (Travis Neff @ Sep 12 2005, 10:00 PM) |
With the injected 1.7 I got 34mpg going out to WCC. Gotta figure out why the mileage isn't that great in the 2.0 |
QUOTE (Joe Ricard @ Sep 13 2005, 03:30 PM) |
There are some tall tales about milage. Some of ya'll are full of it. My red Neck Racer gets such good gas milage that every 100 miles I have to take gas out so it don't spill out the filler neck. |
QUOTE (Flat VW @ Sep 13 2005, 04:54 PM) |
The 1.7 cars are great like that, NOT drag racers, without a doubt, but fantastic range, 34-35mpg Highway with a 75-80 Mph cruise. |
I drove from cincinnati Oh to Daytona beach fl back in 1979 for spring break. Gas was .69 a gallon(which was outrageous) It cost us $14.00 to drive 900 miles..... You do the math.
QUOTE (buck toenges @ Sep 13 2005, 09:05 PM) |
I drove from cincinnati Oh to Daytona beach fl back in 1979 for spring break. Gas was .69 a gallon(which was outrageous) It cost us $14.00 to drive 900 miles..... You do the math. |
San Jose to San Diego with a friend driving...26 MPG. San Diego to Denver...24 MPG...wife driving. She drives like she stole it. I don't know the speed, but she was clocking 26 - 32 second miles for hours. we made a 400 mile run in 4 hours 15 minutes....Yes, I take lessons from her!
That's nuttin'! One trip to Willow Springs I averaged 9750 mpg with the 2.0.
Send me $5 for setup and pictures.
Duh! I was towing it, ya nitwits. 97.5 miles estimate 1/10 of a gallon evaporation.
QUOTE (SirAndy @ Sep 13 2005, 03:46 PM) |
now, 35 years later (!) i just saw a commercial for some totally redesigned, totally new and totally fuel economical honda and they boast that it gets 30 mpg like this was pure magick ... 35 freaking years later! am i the only one thinking this is nuts? Andy |
QUOTE (airsix @ Sep 13 2005, 08:30 PM) |
but the problem is the cars now weigh 7,000 pounds |
SUV - nearly 6000 lbs.
Our cars... 1800 - 2200 lbs.
Get down to the 1800lb mark, a nice 200HP motor... you'll get good fuel economy cruising
Speaking of fuel milage .... Jake when are we going to see some results from the the Super 2 liter. 50MPG in a bug would be pretty cool.
Just don't let the Government find out they will make you stop and start driving a an SUV.
keep in mind in the good ole days before gasoline became oxygenated, the BTU content of the gasoline was higher, and thus you could travel more per gallon. When oxygenated gas was forced in californazia we were told in the news to expect 10-15% drop in MPG. Sure enough, I lost 3-5 MPG on all my cars that had been getting 30 -35 mpg.
So keep in mind the type of gasoline you use in your MPG comparisions.
The 1.7 engine gets considerably better mileage than the 2.0 engine
I took my dad to the Doctor today in Atlanta in the 912E... Running the RAT/ SDS EFI leaned a bit I was able to get almost 38 MPG while running 75-85 MPH!!!!
Anyway- The Super 2 Liter is finished and is only wairting on detail and powdercoat before it'll hit the dyno.
QUOTE (dmenche914 @ Sep 14 2005, 11:22 AM) |
keep in mind in the good ole days before gasoline became oxygenated, the BTU content of the gasoline was higher, and thus you could travel more per gallon. When oxygenated gas was forced in californazia we were told in the news to expect 10-15% drop in MPG. Sure enough, I lost 3-5 MPG on all my cars that had been getting 30 -35 mpg. So keep in mind the type of gasoline you use in your MPG comparisions. The 1.7 engine gets considerably better mileage than the 2.0 engine |
QUOTE |
If a modern car weighed 2,000 pounds and the driver and passenger each weighed 150 that Honda would get 45mpg. |
What you need to pick up from what i lay down is that the "new" gas in california that is oxygenated has about 10-15% less enegy per gallon than did the old gas. This means more gallons burned to do the same work. On non-feedback cars (pre-O2 sensors), the engines would run lean on this mixure, thus it was widely recommended on carbed cars to up the jet size if car ran too lean. or tweek FI as needed. Cars with feed back (O2 sensors) would automatically make this adjustment. At anyrate, you would lose about 10-15% mpg with this new gas. I experinced the decrease in milage on my cars as predicted in the news when this new gas came out. Other issues with the new gas was incompatibility with some of the materials used in older fuel systems, resulting in gas leaks in older cars (I had no personnal experience with this.)
The oxygenated gas added O2, but O2 has no BTU value. The added O2 resulted in less fuel (ie BTU's) per a gallon of gas, hence less power and mileage.
Footnote: we also got a price increase with the new less efficient gas.
I posed this question on the Pelican board too: If you wanted to configure a 914 for maximum fuel economy, what would you do? Assume a 1.7 gas engine...or some other nearly bolt-in VW/Porsche power.
