Decided to remove my dual coolers from the rear and locate new big cooler up front.
Production car rules will not allow cutting up front sheetmetal for GT style cooling.
Think we could fit a big cooler in this spoiler "without" cutting metal behind? Also worried about getting enought flow thru the cooler without ducted exit from cooler.
And if anyone know, is this spoiler legal in production class?
GT racing.... nice.
Iamchappy had that on a previous car if i recall.... not sure if he cut the tub....
BTW - can you do something exotic like Brant's fog grill coolers or Chris Foley's headlight ones???
A colorado guy... Dale Tuety runs a cooler in his spoiler with no cutting.
Probably will see him tomorrow at a club race.
I'll try to get pictures of it if he is there.
His is a trailered race car, and man that cooler is down low... but it works and works well.
I wouldn't do it on a street car is such a volunerable low location, but on a race car like yours its very doable.
brant
At a club race last year, I saw a 911 that had a similar front-mount setup. The front valence was damanged in an accident, so the guy ripped it off and ran without. The oil cooler was undamaged though, and you could plainly see that it was just mounted but there wasn't any ducting/venting behind it, and as far as I could tell, the body of the car wasn't cut out. The car faired very well in multiple 45 minute races, so it must keep things cool (enough)....and if it worked for a bigger, heavier 911, I would guess that in a 914 you should be good to go as well....
QUOTE (Aaron Cox @ Sep 15 2005, 01:23 PM) |
BTW - can you do something exotic like Brant's fog grill coolers or Chris Foley's headlight ones??? |
QUOTE (brant @ Sep 15 2005, 01:37 PM) |
Probably will see him tomorrow at a club race. I'll try to get pictures of it if he is there. His is a trailered race car, and man that cooler is down low... but it works and works well. |
I had that one one my car for about 20 years, works great until you hit something.
I thought SCCA rules allowed ducting for an oil cooler in front to be added? Cooling the oil used to be in the realm of "safety items"? When I checked with them years ago about my added dry sump/front oil cooler, I was okay'd since it was "not a downforce device". The ones that exit the top of the hood I was told were not legal as they added substantial front downforce. I think there are some vintage organizations that do not allow it but they usually don't let 914s in either??!!
QUOTE (synthesisdv @ Sep 15 2005, 11:21 AM) |
Think we could fit a big cooler in this spoiler "without" cutting metal behind? Also worried about getting enought flow thru the cooler without ducted exit from cooler. |
I had my guy make a mold incorporating the bumper and spoiler into one peice. Easy off and easy on!
Great until you have to bump that idiot in front of you for blocking your line when he parks it in the corners.
QUOTE (Brett W @ Sep 15 2005, 04:49 PM) |
Great until you have to bump that idiot in front of you for blocking your line when he parks it in the corners. |
Xit,
Can you furnish a close up?
Your front end appears to be two piece ? I can replicate for members if you have the mold...
JT
QUOTE (street legal go-kart @ Sep 15 2005, 07:29 PM) |
Xit, Can you furnish a close up? Your front end appears to be two piece ? I can replicate for members if you have the mold... JT |
Sweet car xitspd!
Personally I would be really hesitant to hang the cooler out front, esp down low near the spoiler. Way too easy to get trashed in an "off". Up behind a late-style bumper like Bradholio did years ago seems a little safer to me.
Many sanctioning bodies won't allow you to cut the bumper
for a oil cooler air intake.....which is why Brant & others went to all the trouble with thedualcoolersintheheadlightbuckets. Sheridan's late model glass bumper gets around this by having the intake below the bumper.....but is a 75/76 bumper allowed in vintage racing?
Dan, are you thinking of making/selling the bumper/spoiler combo through 555? Looks great!
QUOTE (J P Stein @ Sep 16 2005, 12:19 AM) |
...but is a 75/76 bumper allowed in vintage racing? |
David,
I let you down.
I had multiple mechanical failures throught out the weekend and spent 1/2 of my weekend on my back on dirt.. replacing a rocker arm shaft, rewelding a shift rod, etc..
I didn't get your picture and I'm sorry.
but basically, Dale's spoiler is home made. Aluminum sheeting I think. Lower than most purchased units. He just cut a hole in the center and plumbed a (not tall) oil cooler into the center. No ducting needed behind it.
Check with your race club and if they will let you run any front spoiler besides a stock valance. then it would be easy to take even an LE style and cut a hole in the center and mount the cooler to the metal of the chassis.
I did see a home made type like this on a 911 this weekend also. And that driver went off track and broke his fiberglass spoiler in to two pieces. His cooler survived unharmed and I heard him talking about it (next pit over)
he was telling someone that he mounted it in such a way so as to allow the mounts to fold back (crush zones) in case he went off road. The cooler was folded a few inches towards the rear of the car, but no leaks and no damage.
sorry for not getting pictures.
rough weekend.
brant
Sorry to hear about your troubles Brant. That sucks.
Thanks Ben..
but its ok.
I still beat my personal record for the track by .3 seconds.
so that kinda made it all worth while.
I still got both sunday races in.
and I put the car 4 wheels off track for my first time (sideways in corner 1 at 100mph.....) where I was able to down shift from 4th to 3rd and pull back on with only loosing 1 position.
so although it was a rough and stressful weekend, it still went ok really.
brant
QUOTE (brant @ Sep 19 2005, 10:03 AM) |
David, I let you down. |
QUOTE (brant @ Sep 15 2005, 12:37 PM) |
A colorado guy... Dale Tuety runs a cooler in his spoiler with no cutting. Probably will see him tomorrow at a club race. I'll try to get pictures of it if he is there. His is a trailered race car, and man that cooler is down low... but it works and works well. I wouldn't do it on a street car is such a volunerable low location, but on a race car like yours its very doable. brant |
thanks kurt,
I was thinking about cutting the stock valence like that and fg in a cooler grille.
pic helps alot..
QUOTE (synthesisdv @ Sep 19 2005, 07:01 PM) |
thanks kurt, I was thinking about cutting the stock valence like that and fg in a cooler grille. pic helps alot.. |
