the outboard motor mounts that hold up the engine bar:
how did you destroy yours??
Call pelican... or find a parts car....
Use a pair of these. http://www.pelicanparts.com/catalog/images/engine/comp_mtr_mount.JPG
mount them with the boss pointed up, and the side shifter bar will bolt right up.
QUOTE (Aaron Cox @ Oct 3 2005, 01:38 PM) |
how did you destroy yours?? Call pelican... or find a parts car.... ![]() |
Or make some. Buy some square steel tubing of the right size, saw one side off. Saw and file to shape. Drill holes.
QUOTE (ClayPerrine @ Oct 3 2005, 01:39 PM) |
Use a pair of these. http://www.pelicanparts.com/catalog/images/engine/comp_mtr_mount.JPG mount them with the boss pointed up, and the side shifter bar will bolt right up. |
QUOTE (michel richard @ Oct 3 2005, 02:02 PM) |
Or make some. Buy some square steel tubing of the right size, saw one side off. Saw and file to shape. Drill holes. |
QUOTE (ClayPerrine @ Oct 3 2005, 04:39 PM) |
QUOTE (dlo914 @ Oct 3 2005, 02:14 PM) | ||
hmm good idea! |
QUOTE (michel richard @ Oct 3 2005, 02:20 PM) | ||||
I'm cheap and the hardware store is the cheapest (and quickest) source for parts! Just make sure you buy a new hacksaw blade. They're cheap too, and a new one will make a world of difference. Get 18 or 24 teeth per inch, no more. |
Mister PET says:
N 010 472 4 BOLT HEX-HD.M 10 X 85 (that's the big bolt through the middle)
900 075 085 02 BOLT HEX-HD.M 8 X 20 (those are the little ones through the sides of the mount)
--DD
QUOTE (dlo914 @ Oct 3 2005, 02:30 PM) | ||||||
sadly, ive only got a jigsaw. ![]() |
QUOTE (Dave_Darling @ Oct 3 2005, 03:17 PM) |
Mister PET says: N 010 472 4 BOLT HEX-HD.M 10 X 85 (that's the big bolt through the middle) 900 075 085 02 BOLT HEX-HD.M 8 X 20 (those are the little ones through the sides of the mount) --DD |
now for sure im gonna make these mounts rather than spending $20+ on a set
could someone get the dimensions of piece #9? TIA!
takle a piece of thick paper....
put it against theouter body mounts... and trace the 2 small holes.
then MEASURE the distance, center to cener of these holes.. and mark the middle. now drill your big hole
$20+ seems alot easier to me. i'm sure i have a box load of them. for the +, i'd even run them through the bead blaster, you pay shipping.
I PM'd you that I have the mounts minus the bolts but got no reply. Perhaps I should have mentioned that they would only cost you the actual postage.
QUOTE (dbledsoe @ Oct 4 2005, 09:10 AM) |
I PM'd you that I have the mounts minus the bolts but got no reply. Perhaps I should have mentioned that they would only cost you the actual postage. ![]() |
QUOTE (dlo914 @ Oct 4 2005, 12:27 PM) | ||
how much for shipping? ![]() |
PM'd w/ Address
