After having my second door handle break, I decided to do something different.
I made a lever out of a piece of tubing. Drilled a hole through one end that fits over a pin that I welded to the door. Flattened the other end and smoothed it out.
Welded a hook to the lever that goes inward. A wire loop runs between the hook and the release latch inside...
Lift up on the lever to open, the spring returns it to the bottom stop...
Weld a piece of sheet metal across the surface to shave the door handle, and the crude design is hidden for a clean look. Keeping the recess behind the door makes it convenient to reach a finger behind and lift the latch. It releases easier than ever and won't break.
(Ok, I figure someone will ask, so... No, I don't miss the door locks. I never lock the doors. I keep valuables locked in the trunk and have a hidden ignition cut off switch for theft protection. )
pretty ingenious !!!!!
I like it....the wire looks a little on the thin side.....
Yeah, the wire in the photo seems a bit hoaky. I was planning on making a nicer piece there... maybe washers welded to the ends of a piece of small rod. But it lifts so easily that my temporary wire isn't stressing at all. Maybe I'll get around to upgrading that piece later.
And we wonder why people say 914 owners are cheap?
Good work, the factory should have done that in the first place.
Paul
Frugal, not cheap.
You keep valuables in your car? Right now, my tires are the most valuable thing in the vicinity of my car.
What do you do about securing the car (un/locking doors)? Guess you could use a remote entry system (and pray the battery never dies...).
Oh, but neat idea!
I don't miss the door locks. I have never locked the doors. I keep valuables locked in the trunk and have a hidden ignition cut off switch for theft protection.
That looks really cool!!!!!
This is an idea with some legs on it...
Nicely done!
pete
great idea to bad VW oops i mean PORSCHE didn't think of it first
QUOTE (Air_Cooled_Nut @ Oct 11 2005, 12:47 PM) |
What do you do about securing the car (un/locking doors)? Guess you could use a remote entry system (and pray the battery never dies...). |
Typically a solenoid type keyless\handle-less entry system has a "Hidden" button for a manual release. Anyone who puts one of those on their car (Honda or whatever) should always incorporate this.
