installing fuel cel in forward compartment, was thinking about installing vent in the right forward parking light cutout.
where do other 914's and 911's with cel up front usually put the vent?
thanks,
dr
vent to the passenger compartment ?
Or vent it to your helmet
What about using the stock drainage hole behind the firewall? Drill a hole (gasp!) through and run a hose??
so if we go thru the firewall, can it vent down underneath the car? Are there any "rules" for fuel vents?
dr
If I remember correctly, the SCCA GCR's call for the fuel cell vent to run outside the car and have a valve to prevent fuel from running out if the car is upside down.!?? This is aceptable to the vintage groups such as HSR-West and VARA where I race. Good luck.
the cel is fuel safe's top of the line pro cel. It has a check valve built into the vent port already.
I have heard to put it under the car and then been told absolutely no because you will get dirt into the cel.
The vent allows air to escape with expansion and filling and air to enter as the fuel is consumed.
Since some fuel may be purged out the vent when it is topped off, I didn't like the idea of locating the vent near the fender which is very close to a red hot rotor. Then I was thinking about using the hole from the radio antennae but it is right in front of the driver's door, don't want fuel in there either.
Too much effort. Run the line from the tank thru the hole for the windshield washer rubber hose and leave the hose located just above the factory vent hole in the bottom of the pan. Dont poke it thru so it sits outside the car. Have it stop just short of the hole... if anything makes it out the hose.. it will go under the car.
Make sense ??
B
thanks brad,
sounds good accept that the SCCA rules say that the vent must be located outside of the car. I guess we can just run it outside and put a screen vent on it to keep dirt out. sound ok?
dr
Their definition of "outside the car" means a lot of different things.
I would'nt worry about a screen on it. Every time you over fill the fuel cell (it will happen at least once an event).. it will wash out the hose. The hose will end up several feet long.. dirt can only travel so far.
Another thought is to have it exit out in the hump behind the cell (cavity area for the steering rack).
B
