I have always loved the 914/6 GT's and will be converting this orig 6 (below) to an updated GT plus try to build a TTOD capable AX’r.
It will be pretty much be a straight up racer, no heat, no radio, no nuthin, almost a full GT car but with no roll cage. To get to TTOD I felt that I needed a few things I did not already have, such as more rubber beneath me, more low end torque, closer gear ratios, LS diff, more tuneable suspension, body stiffening, yadda yadda, you get the drift.
This first pic is when I bought her in August 02, she's a factory six with a 3.2 and 915 trans, 911s suspension, was PCASDR 99 & 2000 AX champ for class HI.
Ya need slicks for TTOD....
buuut...
Cool stuff!!!
Same thing im doing... cept I got a lowly v8... and I KNOW that I cant get TTOD with the 50k 911's and 914's running around...
Marv! A teener guy in Murrieta!! Cool shit man! I will be home in a couple of weeks, definately would love to stop by and check out your project and shoot the shit!
-Jared
QUOTE (Marv's3.6six @ Nov 16 2005, 10:08 PM) |
straight up racer, no heat, no radio, no nuthin, almost a full GT car but with no roll cage.... I bought her in August 02, she's a factory six with a 3.2 and 915 trans, 911s suspension, was PCASDR 99 & 2000 AX champ for class HI. |
Very nice!
My car came close to TTOD SCCA locally with a street legal car....and a damn good driver(not to be confused with me).
Your car is too damn pretty to do what I did in my continuing attemtps for TTOD. It would also be very uncomfortable to drive anywhere. You prolly don't have enuff fender to get the tire you need.....that's just a guess.
You risk breaking up your chassis without the stiffness required by monster tires.
Having said that, if you have a small enuff pond, it can be done with a street car, me thinks. Trekkor has done it...no offense, Trek.
March 2005, Car is stripped except for wheels & steering wheel. Going to the sandblast booth here. We found that this car had 7 paint layers, mucho bondo, and a couple of really hack body repairs. We estmate that we removed over 100 lbs in paint, the paint was 3/16" thick! (Go back to the first post for a clue as to who did this custom (HACK) paint work.
my .02: black adds needed detail and makes a nice contrast to the silver you've chosen - hence black sail panel trim, rockers, and valences. Also, black between the fuchs spokes. Agree? Otherwise it reminds me of this crappy apt when I was in school. Between tenants they would shoot another layer of paint. But they wouldn't mask anything. Everything got coated with the same cheap shiny paint - walls, doors, trim, light switches, cat and dog...
March 2005, Here 99% of paint has been sandblasted off. Metal work to start. Guy in pic is Brian from Temecula Rod & Custom, he is a master metal worker, claim to fame is he appeared on early Monster Garage episodes.
May 2005 Some of the metal work completed. Note how the steel front spoiler is custom flared at the end to match the GT flares.
Pic: Rocker panels custom flared to match GT flare, extra structural bracing added to fight cone damage at AX's.
July 2005 Finished metal work, tub on rotissere with some body filler & being prepped for paint.
11/22/2005 Paint on tub finished, Carrera GT Silver. Tub to go on lift this Friday, assembly starting yay!
Looks beautiful. Love the color!
I was wanting the same silver (w/ flares even), looks awesome!
How well did they get in the area under the headlight buckets? That looks like it would be a total PITA.
Andrew (the paint meister) is an artist, for hard to get areas I think he used a wand tip, kinda like a garden sprayer, plus he could turn the tub upside down purty easily.
Next pic: full shot of painted tub, on rotissere.
Pic: shot of rear suspension seam welding.
Brake porn: Brembo GTP lightweights, 12.3" full floating rotors.
Can't wait to see this at the track.
Love to have those Brembos as a spare set
How much coin for the body work and paint if I may ask?
I would rather not say, but I probably could of bought a pretty nice original 6 for the amount spent, just on paint & body work alone.
Heres the wheels I'm gonna run, HRE311 17X9 & 17X8, custom offset/backspace for early 911, should fit perfect, I hope. These will goto Al Reed for a repaint and makeover after fit up checks out.
Thanks I have a guesstimate now which does indeed help. How long did it take to get it back to a roller?
I'm just bringing y'all up to speed right now.
Its kinda a roller so to speek right now, she's on a "rolling cart" and will go up on a lift at my buddys shop this Friday for final assembly to begin.
After a few weeks wait she is finally on four wheels.
Work has started , removed tar for new undercoat/linex type coating. Checkout the welding on the engman long kit install.
Starting on setrab front oil cooler install.
Update, wiring loom modified & installed. 12/21
Undercoating as floor sealer. 12/21
lookin' good!!!!
youre insane
Very Nice.
I love seeing a project coming together.
Way to move on this
KT
Looks Great.
What is the brand of the undercoating that you used on the interior, how was it applied, and how thick is it? Is it for sound deadining?
Sound deadning for undercoat. Forgot to look at brand name.
12/23 Installed Engman fuse panel, back side pic.
12/23 Center tunnel wiring loom finished. Tunnel painted to match outside of car, will remain exposed like shown.
marv - title changed
You are doing one unbelievable job!
QUOTE |
marv - title changed |
QUOTE |
You are doing one unbelievable job! |
Marv That looks GREAT. When will it be complete??
Mark
QUOTE |
Marv That looks GREAT. When will it be complete?? Mark |
Cool
The pictures look GREAT. Once I get a few more miles on my car and the weather is nicer we will have to come down.
Have a good New Year
Mark
12/31/2005 Got some good work done, cut several holes in the car for oil lines, modified fuel cell & rubber mounts, finished fabricating rubber mount oil cooler bracket plate.
Pedals assembled, they look wicked! BTW anybody know what those two bracket pieces are on the right? I had them powder coated for some reason, now I don't remember where they go.
Happy New Year all.
the bracket things look like the ones on the rear trunk hinge pivots/rollers....
1/7/06 Bulkhead fittings and -12 45AN fittings test fit. I decided to run the oil lines thru here instead of inside the cab. these will snake down next to the wiring harness by the fuel cell in a heat sleeve.
1/7/06 Inside wheel well. -12 bulkheads and AN 90's Small hole is radio antennae wire hole.
1/7/06 Time to make a big hole.
1/7/06 The biggest cut I have done on a teener 9X18" hole. This exit hole is 20% larger than the entrance hole in the front of the tub, for mo better flow baby.
1/7/06 Mount oil cooler to custom fab rubber mount base plate and installed thermostat.
1/7/06 fab custom -12AN lines from oil cooler to Tstat. You can see the rubber isolator mount for the oil cooler base plate on the right.
1/07/06 Passenger side mono ball.
1/7/06 Bilstein RSR drop spindle strut mounted to elephant racing decambered ball joint.
1/7/06 Tom's thumb
1/7/06 Carbon fiber air deflector test fit.
It does not look like much was done today but we got about 20 hours worth of labor done, lots of stuff not seen like the shift linkage, misc bracketry, clearencing on the tub for oil lines, etc. etc. a very good day!!!!!!!! Its moving along.
Marv........Looks killer!
Are you running your oil lines through the tunnel?? I haven't decided where to run mine yet and I'm still thinking there has to be a cleaner way than most of what I've seen.
No not thru the tunnel. Running along the outside GT style, but where most peeps go in the cab & around the pedals I did not want the lines inside. So I went up and inside the left front wheel well then thru the bulkhead panel where the radio antennae wire goes in, then down by the fuel cell, following the wiring harness.
Keep up the good work Marv.
Keep us posted on the cooler install, as many of us are doing the same.
I also do not want to run the oil lines inside the cab.
MMMM more pics of the routing please?
Luke
I ran my lines the same way. It was way better than running them inside. It
also helps with the cooling.
Sure is looking good, keep the pictures coming. insert: smiley face with camera
Hey, Marv
Question on your wire harness. Is it new or did you make one up.
My wire harness is shot and need a new one.
Luke
Looks Good Marv. Is the fuel cell going where the old tank was or in the front?
Mark
QUOTE |
Question on your wire harness. Is it new or did you make one up. |
QUOTE |
Is the fuel cell going where the old tank was or in the front? |
1/11/06 Oil lines finished in front trunk, top view.
01/11/06 Oil lines lower view, to Tstat.
01/11/06 23mm Brake master cylinder install.
God this project is sexy, I love reading the thread and looking at the pictures. keep it coming man! That's top notch work.
Eric
marv,
any worries about the hot oil lines running next to your brake fluid resevoir?
AA
QUOTE |
any worries about the hot oil lines running next to your brake fluid resevoir? |
QUOTE |
God this project is sexy, I love reading the thread and looking at the pictures. keep it coming man! That's top notch work. |
QUOTE (Marv's3.6six @ Jan 12 2006, 01:44 PM) | ||
No cuz I am using an aftermarket reservoir from Patrick Motorsports that mounts on the cross member wall. Also using a heat sleeve that will wrap the oil lines by the fuel cell & wire harness. |
Marv,
Looking good! I am very happy with my PatrickMotorSports fuel cell. Do you know how much fuel it will hold? I have only put in about 10 gallons at a time.
Dan
1/21/06 Battery mount
1/21/06 Changed my mind and decided to mount the rese in the stock location. Fabricated a brake fluid resevoir mount to go in factory location
1/21/06 Grinded out existing holes for oil lines to run under rocker panels.
1/25/06 Brake fluid rese mounted, hood hinges mounted.
1/25/06 rear wheel test fit. Gonna have them refinnished, have to decide, whether to make them black, or Iron glimmer (the darker gray you see on the suspension arm) or red? Hmmm
the rims...have them match the exterior paint scheme..that would look very stealthy!
1/28/06 Front wheel test fit. The wheel looks pretty mean in black! hmmm, the car looks crazy in person, I'm getting excited.
1/28/06 suspension installed, brake hard lines installed, the hard lines are a pia to bend correctly.
1/28/06 Brake bias valve installed.
I think this is the cleanest project I've ever seen. Wayyy nice. Good Job Marv!
seems like an odd place for the thermostat. the pump, ergo your engine, has to work pretty hard to shove cold oil all the way up to the front, only to find its not hot enough yet, and goin' all the way back. what if the safety valve in the case didn't work right? rank speculation on my part, but I'd wait til it was warmed up before driving it.
re: the wheel color: imho, red would divert attention from the beautiful body work, especially with a neutral color like silver.
QUOTE (brp914 @ Jan 29 2006, 12:03 PM) |
seems like an odd place for the thermostat. the pump, ergo your engine, has to work pretty hard to shove cold oil all the way up to the front, only to find its not hot enough yet, and goin' all the way back. what if the safety valve in the case didn't work right? rank speculation on my part, but I'd wait til it was warmed up before driving it. |
Here's mine. I've seen one mounted behind the front bumper, visible through the fog light grill.
I've never heard of any actual problems with this set up.
Only speculation and debate.
The oil goes into the tank from this circuit which already has 8 or more qts, depending on the tank you will use.
Starvation is a non-issue.
KT
wow!!! your car is looking great!!!
1/29/06 Fabricating lower valence, ABS spoiler.
1/29/06 Lower valence with spoiler, front view.
1/29/06 Side view. Turned out wicked looking!
Looks Great!!!!! close attention to detail! keep the pics coming
nice!
Is that a regular GT front valence? Or some kind of spoiler?
Where did you get it?
QUOTE |
Jeroen: Is that a regular GT front valence? Or some kind of spoiler? Where did you get it? |
QUOTE |
nein14: Looks Great!!!!! close attention to detail! keep the pics coming |
QUOTE |
brp914:seems like an odd place for the thermostat. the pump, ergo |
QUOTE |
fiid: I think this is the cleanest project I've ever seen. Wayyy nice. Good Job Marv! |
Absolutely beautiful.
Marv,
Love the front valance and spoiler. Too bad someone can't take a mold and reproduce. I need one like that.
Van914
Marv any thought of fabricating front valances and bumpers like that I would be interested if the $$$ was right.
Steve
The car looks great by the way, love the the silver!!!
Beauty! Hey, what are you putting along the bottom of that spoiler? Rubber? Source, etc...?
That will be one gorgeous car
1/30/06 Front baloney skin test fit, perfecto!!!! no spacers needed
01/30/06 Rear tire test fit, 1/4 or 3/8 spacer needed!! Car looks tuff with tires. Time to send the wheels off to Al Reed for a little love.
Where did you get the braided covering for the wire loom?
QUOTE |
Where did you get the braided covering for the wire loom? |
QUOTE |
Beauty! Hey, what are you putting along the bottom of that spoiler? Rubber? Source, etc...? |
QUOTE |
Marv any thought of fabricating front valances and bumpers like that I would be interested if the $$$ was right. |
QUOTE (Marv's3.6six @ Jan 30 2006, 11:39 PM) | ||
02/04/06 New custom fiberglass bumper test fit.
02/04/06 23mm master cylinder installed.
02/04/06 Brake fluid resevoir finished.
QUOTE (Marv's3.6six @ Jan 30 2006, 07:35 PM) |
1/30/06 Front baloney skin test fit, perfecto!!!! no spacers needed ![]() |
Yesterdays work included a final test fit for the wheels. I find that things are different then when I first test fitted the wheels, because the Brembo calipers are pretty big and necessitate a 3/8" spacer up front. However the rear wheels are a perfect fit, the brake hat adds about 1/4" spacer.
The wheels really are just about perfect with over 9" of rubber on the front and 10.2" on the rear at "full bottom" out nothing touches anywhere and there is plenty of clearence, even the front fit turning lock to lock bottom out great.
To answer your question Michel the wheels are HRE311 and were custom made for early 911, and the flares are GT replicas from AA.
What size cable organizer stuff? I'm getting ready to order. Thanks for the link.
How much did you need? I could get a roll of someone else wants some...
Eric I will have to look at the sizes Tom purchased, he really bought it to use on his Northstar V8 dune buggy, he has several different sizes and also used various sizes of shrink tube to end the sleeves on the 914.
That's what I was thinking... might be a couple sizes. And, ditto the shrink tubing... that looked like the clean route.
Thanks for going out of the way... YOUR PROJECT'S SCREAMIN!
E.
QUOTE |
Marv's3.6six Posted on Feb 5 2006, 09:18 AM -------------------------------------------------------------------------------- Eric I will have to look at the sizes Tom purchased, he really bought it to use on his Northstar V8 dune buggy, he has several different sizes and also used various sizes of shrink tube to end the sleeves on the 914. Eric_Shea Posted on Feb 5 2006, 09:04 AM -------------------------------------------------------------------------------- What size cable organizer stuff? I'm getting ready to order. Thanks for the link. How much did you need? I could get a roll of someone else wants some... |
While you So Cal guys were BBQ'n at Joe Sharps I was doin this. Fuel pump install above shot.
Fuel pump install below shot
Rear suspension final installation, bearings, hubs, brakes etc. Safety wireb brake brackets.
Front brake bracket install.
Right front corner complete (xcept sway bar) brake rotor to hub, bearings packed & installed all bolted up tight n good. Not shown, I forgot to take pic is I had to remove the RSR struts & chop 1/2 inch of thread off the top, the struts were way too long & would of poked thru the hood! Per Jim at PMS a common issue using 911 struts for 914's.
Right rear corner complete
Left rear corner complete
Left front corner complete All in all a very productive day.
Marv,
Thanks for the tour last week, your car is absolutly gorgeous at the rate you're going, you should have the car on the road soon.
Marv, very nice, everything is looking great. One question. Is the fuel tank going in and over the fuel pump?? I would think you would want it out in the front trunk area where it would be easier to access if there were a problem with pump?
CCLINHYPERLINK
QUOTE (Marv's3.6six @ Feb 19 2006, 09:23 AM) |
Front brake bracket install. |
hey Marv,
beautiful work. coupla ?'s:
1. there was a thread recently re: threaded collars for rear suspension. There was concern that the collars fit too loosely on the shock and potentially allowing the collar to skip over the retainer - not fun. Did you encounter this? If not, mind telling your source?
2. looks like bils front, koni rear. any problem matching characteristics?
3. will this car be street legal?
thanks
QUOTE |
Lou W: Thanks for the tour last week......... |
QUOTE |
boxstr: fuel tank going in and over the fuel pump?? |
QUOTE |
messix: is this pict. flipped? looks like the saftey wire isn't on rotation tension. righty tighty-lefty loosey. |
QUOTE |
brp914: 1. there was a thread recently re: threaded collars for rear suspension. There was concern that the collars fit too loosely on the shock and potentially allowing the collar to skip over the retainer - not fun. Did you encounter this? If not, mind telling your source? 2. looks like bils front, koni rear. any problem matching characteristics? 3. will this car be street legal? |
http://www.914world.com/bbs2/index.php?act=ST&f=2&t=44758&hl=coleman
never posted link before - hope it works
2/22/06 No pics. Installed engine bay seals, a surprisingly easy job when using silicone lubricant and the correct tools!
R&R the steering column, bunch o grit & sand from sandblasting,.....clean & lubed, ready to install............Need to find new upper & lower clamshell plastics for steering column for 914-6, will put add on parts forum.
Worked on modifying dash panel, R installing a boat bilge blower as an air delivery vent system that will blow cool air towards my face. Early teeners suck for air flow & ventilation.
QUOTE |
2/22/06 No pics |
Impressive! Love the color as well.
Marv,
I'm enjoying the show....keep it up!!!
The rear brake adapter look like it says "Brembo" on it. Where did you source the adapters? Are the calipers Big Reds, 928S4, etc.?
Also, what MM torsion bars are you running in the front since you're not running coil-overs? Do you know the spring rates you're using for the front and rear?
Thanks
QUOTE |
The rear brake adapter look like it says "Brembo" on it. Where did you source the adapters? Are the calipers Big Reds, 928S4, etc.? |
QUOTE |
Also, what MM torsion bars are you running in the front since you're not running coil-overs? Do you know the spring rates you're using for the front and rear? |
Last friday 2/24 cleaned 3.6 long block, looks purty good in front of a 993 huh?
02/24/06 Under side of engine, gone is 60k km of cosmoline mixed with canadian dirt and gunk, she's clean as a whistle.
don't know when I have enjoyed a thread this much. appreciate the effort to show us what you are doing on top of all the work on the car.
One of my favoriate threads !. Are you changing the cams out? Looks like your at least replacing them? How much power is this sucker gona have?
Eric
that is one sweet looking power plant....the 993 behind ain't too shabby either.
Incredible work! You have me thinking of stipping my /6 down and redoing everything. Now I just have to find about 1500 spare hours....
QUOTE |
Are you changing the cams out? |
02/28/06 front & rear CF decklids installed. Rear bumper & lower valence installed. Rear end shot, do these flares make my butt look big?
02/28/06 right rear quarter panel shot of new flared wide a$s steel valence install
Close up of GT flare to lower valence metal work, it turned out great Just wait til U see the rocker panels installed
It really looks like a 930 and 914 mated.
Man, that looks good!
Keep up the good work! Thanks for posting all of your photos.
Fantastic work Marv.
Can't believe I did not see this thread before. You 're amazing dude.
QUOTE (Marv's3.6six @ Mar 3 2006, 11:36 PM) |
02/28/06 right rear quarter panel shot of new flared wide a$s steel valence install ![]() |
QUOTE |
Your butt looks great |
That is really, really nice. Can't wait to see it finished...
QUOTE (Marv's3.6six @ Mar 4 2006, 11:22 AM) | ||
QUOTE (Marv's3.6six @ Mar 4 2006, 10:22 AM) |
Here's what I do to keep the butt the correct size to fit the lil Recaro seat. Believe it or not ![]() |
QUOTE |
How do you like that 29 inch mtn bike? & do you work for gary fisher? |
03/08/06 Received the finished fiberglass work on the front bumper, with installed brackets and reworked the glass on wrap around end edge, on the right.
03/08/06 Test fit front bumper for gaps, lots of sanding work done to get gaps right, gaps are looking really good especially since this is a carbon fiber hood, more sanding/fitting work to be done, want gaps perfect. Right side headlight cover test fit, ..............................look ma no eyebrows
What are you using for a bracket in your bumper photo?
Also, who's bumpers are these and did they fit?
Thanks.
03/08/06 Testing carbon kevlar cover plates..............what do you think? Yes...no...
03/08/06 Modified fuel cell, upsized fittings from -6 to -8 on supply side to pump, and return size from -4 to -6.
03/08/06 Installed mod plate in fuel cell.
QUOTE |
What are you using for a bracket in your bumper photo? Also, who's bumpers are these and did they fit? |
been following this thread for a bit - your car is awesome! The no-eyebrow idea looks pretty slick in the closed position - I like it since those pieces just never seem to line up nicely on the seams with those rubber mounts. I bolted mine in so I could get them to line up and stay. Look forward to seeing the finished product!
03/12/06 Test fit install of front toe eye, will powder coat it red.
04/01/06 First time workin on the car for three weeks.
Front tow eye finished, ready to install.
Bracket installed.
Carbon fiber hood prop installed for carbon fiber hood.
04/01/06 front grill test fit.
got a pic with the headlights up?
looks great marv!!
I stopped by last week to look. Very nice it will be one of nicest cars around.
Bernie
04/13/06 got some little things done, bead blasted and painted & installed headlight buckets.
04/13/06 Installed exhaust heat sheild, it has a special high temp powder coat thats a really cool looking finish, I am thinking about using it on a few other parts.
04/13/06 Finish install of brake/clutch pedal assembly. Had to wait for a special plunger for the 23mm MC.
04/13/06 Installed rear trunk latch assembly. Actually keyed it to match the ignition key!
04/13/06 Off the subject of the GT I just sealed the deal on a new daily driver today.... AND.... its a P car!
(hint) Its a pepper under pressure. I am so so stoked.
Perfect timing, thanks for posting the picture of your headlights, I was trying to figure out how to put mine back together.
That pedal assembly is awesome, was that done by Eric? your car sure looks good, your're doing a great job on it.
Marv, Where did you bring your DME harness through to the passenger compartment? Did you incorporate it into the stock 914 harness? I didn't see any large new holes in your firewall, just curious?? I haven't figured out where/how to bring mine in yet.
That pedel cluster turned out exactly like mine...sweet!
-Britain
Marv great project I noticed something studin' the pictures. You have a rear toe plate stiffener like Brant runsruns, you got some details of this better pictures etc...
Thanks, Stephen
Your car is one Bad Mo Fo. The attn. to detail is staggering, it's almost better than sex. Nice Job!
08/02/2006 Finally some new progress, have not worked on car since April (been very busy at work) just rec'd HRE311 wheel centers that have been powder coated a luscious "cosmic grey metallic" pics don't begin to show how good they look.
08/02/2006 Dash has been reworked, radio & vent controls removed. Have new vent where the ash tray was made from a 03 ford f150 truck vent angled toward the driver. This will be powered by a 12v boat bilge blower that will be mounted under the dash.
The dash vinyl has a carbon fiber weave effect.
marv...you're nuts
and absolutely insane
this has got to be one of the neatest, cleanest, no holds barred,projects i have ever seen!!!
pic 1 Me in the cockpit, taken 9/14/6. (with harness on for broken collarbone)
pic 2 New lic plate.
pic 3 dash installed.
pic 1 brake line installed
pic 2 dash complete
pic 3 doors installed, major bummer here door gaps are shiite. the car seems to have moved while installing engman inner long kit. both doors will have to reworked and repainted to get gaps right.
I've been wondering what happened to this project
Can't wait to see it completed!
Sure is looking good ...
So what about the collarbone? Biking accident?
Bummer about the doors Marv.
Looks great. Can you give me a run down on the CF hood prop? This is exactly what I've been looking for.
http://www.seinesystems.com/Ult-Strut-Home.htm
Looks great!
-Steve
Marv,
Intense! Beautiful and done right. I look forward to seeing the finished product. Your attention to detail is outstanding. I live off the Palms to Pines 74 in Valle Vista, let's do it!
Dan
Strut on order. Thanks
Marv,
I know this is going back into your thread a bit, but what is the source/application of the master cylinder reservoir you used for your car?
Great work, BTW!!
Andys
Fernando...stop stuttering (DBL post).
When I received the last 3 fr coolers from them there were NO instructions in the boxes. I install the coolers with the in/ out ends on the right (pass side) for T4 eng...and the left (driver) for a six. Then cover it up with a GT (aftermarket) shroud- or fab one.
I need to put up some more pics on my 2.0 build, but Trekkor should have this jpeg on his build history--check archives .
EZ job !
Marty
Here ya go, I knew I had this at work. It is self explanatary.
The diagram may or may not be accurate for his installation. For instance, why add another filter? On a 95 3.6, that would give you 3 filters. I ran my lines down the right, not the left and installed the thermostat very close to the scavenge side of the pump on the right side of the motor mount. Very clean that way
Yep, I agree with the use of a extra filter with a race car. Not too many 6's blow on the street though. The oil comes out of the engine on the right side and depending on your cooler, your lines may exit on the right side as well. Personally, I like the thermostat as close to the engine discharge point as possible to quickly respond to engine temps, so I mounted the thermostat there. I just feel it responds better there. Maybe I worry too much.
Mounting it up front works for a race car since they rarely do stop and go driving and are open most of the time. It is for sure easier to mount the thermostat up front and avoid additional plumbing in the back.
Bottom line is there are 50 different ways to plumb them depending on the use and the hardware used. I only suggest considering the application and hardware before using a generic picture. The picture gives a great overview of the theory. There is nothing wrong with the pic, but there just might be better alternatives depending on the application and was the point I was trying to make.......
Buh-ling Bling! Wheels are done, Thanks Al Reed. HRE311's centers powdercoated cosmic grey & lips polished! Looks wicked!
OOOOOHHHHH, Those are beautiful
She's a roller, kindof.......what you guys think? Still a long way 2 go.
way cool!
That is looking great Marv!
It's going to sit sooo nice. Really coming out great.
Who did you get your fuel cell from?
Really cool....just add some wheelie bars!!!
just kidding....really looks nice. Wow.
The photo above of the front wheel reminds me of a funny car front end, the body is so low over the tire.
I think your car looks great. This thread has been really enjoyable. More photos, please.
marv that view looks to be from Bear Creek. very nice place the car looks very nice.
Bernie
Sweet rid Clid. Please post it on jackstands just to simmer down the envy factor please?
Hey what size of brakes do you have?? i was looking to upgrade mine with some nice brembos but i dont know what size will fit, i have 15 inch fuchs, what size are yours and how big are the discs??
Nice car by the way!!! its looking great
What size are your rims and tires and there offset.
Thanks, I will keep my eyes open for simular. The Linsey or Mirage fuch wheels are another option Im looking at.
First work on the project in quite a while. I got recharged after Ron & Glens windy swapmeet last Sunday. There are so many cool people in this (914)world, I am stoked to be a part of this community.
Two almost perfect turn sig housings made into one perfect one, thanks Hershel.
Finished rear turn sigs complete & installed.
keep the pics coming!
Hi Marv, glad to see that you are back at it. Keep the pictures coming.
haha marv! yeah buddy! get on that car!!!
Good seein you again man.
Now finish your damn car!
Where did you pick up those bumpers? I believe you said that they were FG? I was looking for the source the other day but turned up nothing.
Thanks for the comments guys. Lou you missed a good time at R&G swapmeet.
Eric...r/e bumpers: the rear one was on the car when I bought it I donot know from where it came. The front one is my own, I have (own) the mold for it. No plans to make them commercially.
Here is something you don't see every day..............a real GT headlight kit, Armando Serrano and I got together and bought them from Germany earlier this year. I plan to be installing soon.
that is quite... INTENSE marv
Here is some fabrication from earlier this week. Modified oil cooler mounting bracket, orig bracket was hack. Fabricated some more block offs from carbon/kevlar sheet. a good week for my teener.
Thanks for the info. Keep on updating your thread. I (and I am sure many others) are living vicariously through your project b/c I know I will never have the time (or $) to go through my 914 the way you are. At this point this thread is more like art than anything else.
Beautiful work. Are there any pics of the oil lines transitioning from the rear of the long into the engine bay? I'm assuming this takes place in front of the oil tank? I'm doing a /6 conversion and I'm having trouble visualizing this transition and a pic or two would be great.
Marv, Here are your signals. I have the gasket you needed, I cleaned an extra up, looks like new. I've sent an e-mail your way as well.
Martin
Glad to see you back at it, your build thread was one I could not put down.
pic 1 Todays fabrication. Aluminum grill for oil cooler exit air flow, this was more complicated than than it looks.
pic 2 Carbon kevlar block offs installed.
pic 3 NHS (North Hollywood Speedo) beautiful art work. The thought behind this was to have the needle straight up and down when at red line . Looks sick! They also made me a great combo gauge with oil temp, oil pressure, and fuel
Very Cool!
Sweet! It's been a while since I have checked up on this thread. The car is looking great!
Very nice.
Back to paint shop Saturday 12/15. Been waiting since the last summer for an opening. Doors get completely re-worked gaps get addressed. New front FG bumper gets paint. Some new touch up for welded brackets for 914 GT headlight openers.
Ferg
marv,
keep on it You know your gonna love it in the end!
Just spent a really enjoyable hour reading through this thread. Wow, what amazing work! Very impressive, surely progress has beenn made in the last year or so Such a shame it stopped so abruptly....
That will so be worth it.
For one of my favorite threads
Can't wait to see this car done
Anyone know what happened to Marv?
I just went through this thread for the first time ( a lot of good pointers for me), but no Happy Ending
T.C.
Very nice Marv! I can't wait to see some video!
Hi Marv. Missed you at the G&R. I think you should buy this one and save yourself some trouble.
I would have finished it for nothing, but I take a year and 5,000 miles just to make sure I have all the bugs worked out
So what is the latest on this rebuild???
Awesome !!!
Nevermind....................
reading his thread, I don't think it's at PMS.
http://www.autorepair.ca.gov/
The California - Bureau Of Automotive Repair can usually get the results you are looking for. Am I to understand that you do not have a signed repair order for the work done so far? Is it still in Temecula?
Jim put my motor in, and I was very happy with the work done. He also called me everytime there was an additional charge required.
yeah, explain how bad publicity affects business!
I will pay for shipping to Series 9 so that I may complete this beautiful car.
I have 3.6 experience.
Give me the address of the "mechanic" and I'll send the carrier.
Marvelous Marv!! Love this thread. It was great to read all the pages with progress day by day in 2006, now it 2011...I hope you get re-inspired and are able to get some work done on the car. Honestly it looks pretty much close to completion, just a little more work and I think you are done. Everybody is looking forward to seeing you complete the car. I hope you are able to do it and wish you all the best
Screw bad blood, how long has the car been there? Half a decade? What a fucking joke, think about it. Threaten to move the car; schedule a uhaul trailer and truck for all the parts. If that doesn't light a fire under his ass, then pull your car out.
Reading through the thread, it looks like the longs are bowed due to a reinforcement that was overdone. Maybe that is what is holding up the build.
I'll I have to say is don't give up and contact me if you need some encouragement.
I had a problem like that but it only took 6 months of non work, for me to start picking up the stray parts 'first' so that nothing gets left behind ........... then went over there and had triple A to tow the car outa there. We are still friends after all that but now he gets my work done quicker .
So go over there and start segregating parts that you know are yours and putting them in totes ....... and bring them home ...... if anyone asks why you are taking your parts ....... tell them they are yours and need to be worked on .......
5 years is waaaaaaaaaaaaay tooooooo long for anyone to get 'upset' at you ............... pay what ever you legitimately owe and get your teener outa there ......... if anyone gives you any serious problems ........ bring the title to the car and the cops .............
Alright Marv,
I guess I will give my favorite thread its yearly bump. I hope you eventually find a way to motivate your mechanic or atleast get it out of there. This car is to awesome to not see finished. 2012 is only 3 months away!!!!
Kyle
Come to the G&R Marv. Be good to see you again.
Cheers, Elliot
Marv,
Its good to hear that you atleast have it again. What's left on the to-do list? From the pictures the car looks close to being ready to assemble. California build party?
Kyle
Well folks it has certainly been a while since there was work done... I am glad to announce I finally have forward progress. yay.
After a lot of searching I found who I consider one of the best in my region to finish my car. Don Kravig of Precision Motion Porsche. Don is a master porsche mechanic has decades of aircooled flat six AND much 914 race car building experience. Don has had my 993 engine for several weeks and has been prepping it for the car. Upon inspection of the exhaust valve guides it was decided to pull the heads and have at it. While we are in there we will add some performance mods.... I will post up some pics soon of the trick ass work being done.
Excellent news! I can't wait to see the progress. Congrats on the restart of this project.
Great news!
This is probably the progress thread that I always wanted to see finished!
Glad to see you moving on it again Marv......its going to be a beautiful -6!!!!
This is Soooo good to hear!!!!
95 3.6 with heads removed. Inspection of cylinders, ring gap, big end of rods....check, check, check all good, all seals good, engine appears to be as advertised a low mileage 993 engine in excellent shape.
New goodies. freshening up gaskets n seals.
New exhaust valve guides, 3 angle racing cut valve job, cylinder head milled a few thou to increase compression.... all good stuff.
Sooo happy to see this thread again
3 angle valve grind and head work up close.
Awesome looking head, you can see that .010 has been shaved off to increase compression ratio.
Incredible 904 replica at Precision Motion Porsche.
This SC is a car that Don from PMP built some time ago..... 2400lbs with a 97 Varioram engine, RS cams.... with a G50 and coil overs all around.... I was given a ride in this baby.... Holy Schnikes it is insanely quick and very well sorted.
Those engine pics are effin' gorgeous!
Congrats on restarting the build (again)!
More progress. Completed heads being assembled on to cylinders.
Congrats on the forward momentum
Today the new RS cams were installed and timed. Intake and fuel injection system assembly began. sorry no pics.
Gave her a little bath today, first time I have washed it since 2005. If all go's well the engine and trans install will begin in the next couple weeks.
Congrats.
That is a great looking car you got there.
Lovely car
She's looking better than ever Marv.
SOON!
Simply unbelievable!
My baby on her way to Precision Motion for the fun to begin. Engine and trans fitment to body begins next. I have waited so so long for this.
I don't think I could sleep until I got it back.
Such a great looking car.
SO HAVE WE!
I spent quite a while yesterday with Don from PMP. We discussed many aspects of the car.
One thing I am considering is running some beautiful 16" 930 Fuchs I have had for a long time instead of the 17" HRE that are on the car. I am thinking the 16's will look more period correct to the car with 50 and 55 series sidewall versus the super skinny on the car now??
Progress...... Patrick Motorsports front engine mount being welded in. The stock 6 front mount would be tortured with all the torque from the 3.6, ....had to go for the big guns.
I have the 9" 930 wheels on mine and they fit fine. What if you trimmed or rolled the lip on the flare? You could gain 1/2 inch or so.
And here she is fresh as a daisy ready to go. She is a ROW 993 3.6 with RS cams, Patrick lightweight flywheel, RS Eng. match flowed fuel injectors, new valve guides, new racing valve job, new fly cut heads...... all ready to run the snot out of. Can't wait.
Last photo of the day. Here is my front valence/spoiler... On the left side is new 5mm alum black ano button head screws on the right the stainless hardware... the black ano looks sooooo much better.
Your wheels might look much more time period correct if only the outer rims were clear anodized instead of high polish. Here is a picture of the last set of 3 piece 17" fuchs I restored. jdorociak@gmail.com Jim
If I were to restore a set again I would use black bolts so they would disappear. jim
Just an FYI.....I started off with a Patrick crank pulley. It was the only single 993 pulley I was aware of at the time of my build and I didn't like it's smaller diameter and resulting slower fan and alternator speed. I later learned that the 993 RS had a single pulley system and the diameter was the right size. As you already know, every 3.6 needs a valve job and I believe it is because of the high heat generated by these engines and the smaller pulley is just an invitation to aggravate valve guide wear for little HP gain.
I have just installed the RS pulley in preparation of this summer.
Anyway, I only mention this in case you weren't aware of the availability of the larger Porsche pulley.
Front suspension completed and tight. check.
Brake work done. Hard lines, T's, Braided lines all finished. Brembo GTPLW brake system completed and ready to roll. check.
Engine and trans test fit. Looks good. Fit good. Getting closer. There is much more work to be done. Install throttle cable assembly etc. Fab a false bulkhead for the battery and 993 ECU wiring loom. I also did not like how the painted intakes turned out so I am redoing those.
Customized Porsche gauges installed. North Hollywood Speedo makes incredible stuff. check.
That's a really great car Marv. Whos is it?
New windshield installed. check.
This is the second windhield I have bought for this project. The first one was purchased in 2005 by my (not any more) friend Tom, we wrapped it up in blankets and stored it for future installation. Well Don from PMP went to install it and he discovered that it was a mercedes windshield! Tom f***ed me again! Anyway new windshield yay.
Looking good. Interesting oil tank ... who makes those?
WOW
Looking good!
I am loving this car....except for the wheels thus far (sorry). That aside, this is a terrific build and car.
Maybe it's the angle, lighting or shadowing in the shot - it looked like an external tank sitting in the engine bay ... Just my old eyes playing tricks on me
RSR finish......love it.
8/10 The car as it looks today. Is all covered up for fabrication of custom roll bar.
Roll bar is a quasi replica of the factory 914-6 GT roll bar. Note that the bar is recessed back into the body and is well out of the way from a collision with my nugget. Roll bar fab by Don from PMP. very nice work, very.
Up close shot of roll bar a tight fit.
Battery now mounted next to the engine near factory location.
Make sure you can get the back glass in. Looks like a PITA with butyl rubber...
OK its time to post up recent work on my GT... I know its been a while so here are some pics.
1) New custom made (by Don) long wheel studs
2) Front suspension near completion
3) New high torque starter and with rebuilt CV's and freshly painted axles.
4) Beauty shot of headers & valve covers
5) pic of installed muffler & 2 beautiful 356's (The black one has a six stuffed in it)
Pics
1) Front suspension with sway bar completed. Drop spindle struts with decambered ball joints turbo tie rods bump steer kit. Sexy looking.
2) Another view of the muffler customized bracketry work and ceramic coated
3) Lower baffle for oil cooler
4) Pedal cluster installed and fine tuned.
5) Baffle shot
1) Recaro drivers seat installed. Lower rear seat mounting brackets modified rewelded to tub and seat lowered.
2) 930 steering rack completed
3) Porsche factory fuel filter installed
4) Patrick motorsports super beefy front engine mount completed
5) Clutch cable system installed and tuned
6) Oil lines completed and pressure tested
Now that is the way I like to start my day. Your car is looking beautiful. Very nice work
I think we all know that isn't Marvs car. Nice try Marv.
Nice looking stuff
Very nice! Are you going to put it on the track?
Are you going to the moon with that thing?
Marv - Love the build. Glad to see it's getting finished. What did you do to fix the door gap?
Sweet. Looks like you are getting close.
-Steve
Someday my 6 will look this nice.
More updates please....
Marv-any more updates?
I just found your thread and what a history--
I got a 914-6 similar to yours...well... minus the full steroids/hormones that your car is on.. looks awesome...
Live here near your work and home... would love to connect!
Would love to meet up with you guys....but I want a running car first.
There has been work, but has been slow going. Have the ECU sorted and installed. Have turned over the engine with the tiny battery and I am impressed with the juice that little guy has, really cranks. Oil pressure comes up good while cranking (with zero leaks) a really good sign. Have not yet started the engine.
Purchased some additional Patrick 3.6 modified parts to make the intake system fit and look like a porsche factory installation.
Have invested in some serious seat belts Schroth Racing PROFI II 4 point with ASM technology. These are one of the only street legal DOT approved systems available.
The project has had a delay due to Don having to move his shop a few blocks, he lost his lease. I think the building was sold. He had to be out by June 1 so worked stopped some time ago and should resume in a few more weeks.
I am hoping to be complete by late summer.
Very nice Marv!
Nice metallic / Ceramic exhaust headers.
Did I say Nice color match to the silver car as well?
Excellent build Marv !
Marty
Come on guys 10 more views and we are @ 50000.
12 more and it's 5100.
Extraordinary Car, and you win the award for patience and perseverance
Marvs' car? Three words. Cee, gee, eye.
waiting for more pictures
Here we go first startup documented. This baby sounds wicked, the big six sounds angry and also sounds like an early 911 S motor. A big milestone and 8 years in the making. Enjoy.
https://www.youtube.com/watch?v=RIBAqCObSiw
Congratulations! Sounded nice and of course looks nice too.
Awesome!
Very nice...congrats!
Nice work!!!! Can't wait to see this thing moving
Where did you get the exhaust system or did you have the exhaust system custom made? Sounds great and I am looking for an exhaust system for my -6
Just read the whole thing again. Fantastic car and glad you got it done.
5 days before G&R last week my car was being corner balanced, then on to an allignment, had a full detail.... It was time for the first test drive by Don.
Oh Schnit the car will only go into 2nd and 4th gears. Don tries all his tricks, no luck. Don involves Jim Patrick together they try all their tricks... no luck.
Schnit again another G&R without my car. I knew showing up at G&R without my car again I would incur the ribbing of Elliot about my imaginary car. Off I went without the car and my tail between my legs. Surprisingly Elliot was nice about it, I can only assume he was on his meds that day.
Friday before G&R Don removed my trans and was off to the river, with a side trip to Patrick Motorsport. Don had arranged with Jim Patrick to come to his shop this week and diagnose the problem on the spot. I received a text Friday from Don that the "problem solved."
Big Props to Don at PMP to go out of his way (about 200 miles and a full day) and to Jim Patrick for agreeing to meet Don and fixing the Vellios shifting issue on the spot.
Hopefully I will be driving soon.
Nice! I'm getting closer on getting my car back together as well...
Hey Marv, I bought your 3.2 back in ahem..mumble mumble...2006? I had my own setbacks, including a 2 year 915 Wevo conversion at a well known shop in Burbank! Just the box, nevermind the axles, linkage, and assorted other confusing nonsense that I had to figure out myself. Well, good to hear that your project has come to fruition and I hope to see it one day.
Marv,
Most excellent! looking forward to your first drive report!
Marv, if I can ask, what is the paint brand and color code for the Carrera GT Silver you used?
....Dude!.........
See! I told ya it would run some day. Fantastic Marv. Will we see it at the G&R finally?
Congrats! Now drive over to Best Buy and get an new video camera!
Looks like it's moving pretty good Marv!
Yes it moves. I have been waiting to see this since 2006. Kris from Precision shot the video from his phone I can only hope that he was so excited that he was shaking. I hope to go out and see the car and drive it for the first time, maybe today.
Just went through the whole thread. Congrats!
How exciting - I hope you take some good video and photos to share with all of us.
First shakedown drive yesterday 12/28/2013. Initial thoughts OMG this is going to be fun. There some issues to work out with the brakes but the car feels remarkably balanced at low to moderate speeds, there has been zero suspension setup yet. The tranny needs some braking in as it shifts a little stiff. Also the close ratio gears and LS diff in the trans are new to me. It will take some getting used to. First drive in the car since about 2005. yay.
Butt shot of the hot rod. It looks the business.
Interior shot. Love the Recaro seat. Still a bunch of work to do but a significant milestone to drive her. I will be back next Saturday to put more miles on, maybe some twisty roads.
First drive video 12/28/2013. Please excuse the quality... hand held iphone and I got a call at the end. Enjoy.
https://www.youtube.com/watch?v=JNfbnc8FFxw
Congrats! It's almost finished.
Enjoy in good health
How exciting to be able to drive it finally. This is a great looking car and done correctly. The only thing that threw me off for a second was the rear valance. With the opening only on one side it made it look unbalanced until I realized there was exhaust pipes on both sides and an opening only on the driver's side. Regardless, that is a serious machine. Can't wait to hear more as you work out the final issues and get to enjoy the car.
Marv--wow!
I can't wait to have you bring your car out for a cruise!
Glad we connected today at COSI's!
Murrieta will be well represented with your rocket ship!
Saturday 1/4/2014 Drove another 30 or so miles shakedown. Results are 1 sore neck from cornering forces. 2 ran out of gas. 3 the linkage for the 915 gear box needs work. After many many shifts to brake in the tranny, rowing thru the gears over and over it became difficult to find gears, sometimes first gear was hard to find sometimes it would not go into third, after an hour or so most gear were sloppy to find and fourth gear would not work at all and it would pop out of first.
I think the issue is the shift rods are rotating slightly in the "universal apex joint" I believe the solution will be to drill and pin the clamps.
Don at PMP has said this will be the best solution. Next week more shakedown runs. I hope to have the linkage issue fixed and so far none of the gauges are working. I have no idea how many revs I have been pulling. I can't wait to wing her out to red line.
i cant beleive i just found this thread. omg marv that car is beautiful. i had the same shifting problem in a baja i built. i pinned my linkage also. and i took a cut off wheel and grinded two slots 90 degrees of the pin holes. it helped to pinch the coupling to the shaft.
i wanna be part of the first major drive too. i live fairly close to you guys, just down the street from herschal. maybe we could get a drive in up to idylwild while the weather is still nice.
After a long read and meetings with Cheif Fraud Investigator E. Cannon, we will be seeking an indictment for false project thread.
Either that or an Academy Award for best effects in a fantasy film....
Seriously Marv, this is one bad ass build with a great (frustration) story attached.
The Patrick linkage is unmitigated garbage - with a high price. Well, atleast a few years back it was. You have a velios as I recall, and I have a wevo 915, but the kits share parts. Here's how I fixed it:
http://www.914world.com/bbs2/index.php?showtopic=101397&hl=
This was a fairly challenging job for a diy'er due to the exacting dimensions. Shifting in the neutral plane from 1-2 to 5-R amounts to 5mm of rotation as measured on ther input shaft to the box. And you need to allow for slop. So, if off by 1mm the 1-2 plane may become unreachable. At the same time you need to enter the 5-R lockout properly. I had to cut and reweld the shaft a couple times before I got it spot on.
On July 4 the car was delivered to me, yay I was a happy boy. I now had the time to look at the car and admire her for her fineness. All was good in my world....except, as I had time to enjoy a few brews and look closely....almost everywhere I looked there was something not quite right. The list of strange work is long. There are issues with electrical, brakes, trans, steering and worst of all the suspension is totally wack.
Well guys what you see here is the car being loaded up for a trip to Phoenix. I am biting the bullet here and sending her to Jim Patrick @ Patrick Motorsports because I simply do not trust how the car runs drives and brakes. Jim has offered to go thru the car and make it right. Who knows what else Jim he will find that is screwy....I know this will co$t but WTF I am in too deep anyway.
Too nice a car not to have at 100%
How did you ever fix the door gaps?
In regards to the professional work done on the car. Even though nothing was said directly both Slits and Glen Sager gave me funny looks when I told them who was working on my car.... now I understand the funny looks.
Back in my garage after a stay at Patrick Motorsports. JP sorted out many issues with the car. Now need to get new tires as the Bridgestones are 10 years old, have maybe 200 miles on them and hard as a rock. Thinking Toyo Proxes R888.
Will it be ready for the G&R?
Hi Marv,
Great to see you and your car last Sunday at G&R... i think you should re read
post # 410 on fixing your shifting problem. Good Luck.. i believe the problem
is in the shift rods ... needs adjustment ..and hopefully not in the trans.
Cheers,
Harry
Hey Harry good to see you to. I am hopeful that I may have found something that will make a significant improvement in shifting. It has been ten years since I took the car apart and I am finding that I pretty much have to relearn how to use the Wevo shifter properly. I have just rediscovered a few things I forgot about shifting the Wevo. The car maybe has 100 new miles on it so at this point I hope most of the problem lies with the nut that connects the drivers seat to the steering wheel. Time and miles will tell.
Here are a few projects slash updates on the hot rod. This is a pic of the front valence. I have fabricated a bug screen for the front air inlet opening to the oil cooler. It turned out nice, one of the mount brackets I will have to redo as it is slightly out of straight.
Also have replaced the black button head fasteners on the the spoiler lip with stainless button heads. You should be able to see in previous posts on this thread those were black not silver. This change makes the car look a tad bit racy-er I think.
Here is a cool change. What you see is an in tank fuel pump installation. The tunnel lines were replaced with a single stainless line with a regulator mounted up front. The fuel is pulled up thru the top of the tank.
My car had BMW fuel hose running thru the tub. This hose was showing signs of "chafing" so when the stock carerra 3.2 pump died it was time to make a change and remove the fire hazard line and update to in tank.
Here is a cool little bauble. This is a new shift knob it's a Wevo SL knob. This knob is CNC'd from 6061 T6 billet and is very light weight.
Last item of the day. I have been tired of the lap belts and wanted something more up to date. Because the roll bar blocks the stock mounting locations I had seat belts plus make me some new belts. I found these cool billet clamps for a Polaris quad and went about making some mods and installing new belts. Works just like stock.
Ok one more. Here is a beauty shot on one of my favorite loops. There are a some fun roads up in La Cresta behind Murrieta Ca.
Terrific build and beautiful car.
I love the idea of a modern fuel pump in the tank. Can you give us some of the details?
Thanks
David
Lookin' good Marv. See you in Palm Springs?
Dang nice looking car! I don't think I've ever seen that front bumper or spoiler before. Who made them?
edit: I looked back to p. 1 of thread. La Mesa Body?
I like it.
A subtle curvature of the valance and bumper,likely as a measure for room,not merely as a stylistic exercise.
Very nice work.
Even more awesome to see in person !
Good meeting you and this car at last year's G+R
You should come out to our next Hollywood cruise in.
Marty
There have been a couple of requests for information regarding installing an in tank fuel pump. The information I looked into I was able to find on Youtube. Most of the project parts are available in a kit form.
My particular install is unique due to the fact I am running a Patrick Motorsport 914 Fuel Safe fuel cell. This is an advantage due to the fact that the top of the tank by the filler literally unbolts and comes off easily and allows access to install the pump thru the top, also that the fuel cell is already using AN fittings makes it easy peasy.
Hope this helps.
Love the eyebrow delete.
Subtle but cleans it up a lot.
John
On another thread someone was wondering if this car was ever finished. This car is done, finished and on the road. It is everything I thought it would be. This car with this power is easy to drive, you can just lug her around town or wring her neck. I have torque from about 2k revs on up to red line. She is incredibly quick even just short shifting at 3500 thru 1st 2cd and 3rd.
This 3.6 has been a wonderful engine so far. The light flywheel the RS cams. she has a mild lope when at idle, which I love. Now that it is all sorted there is virtually nothing to do except check the oil.
The 915 trans is working very well, after some initial shifter issues things are now working just fine. These transmissions can still be a little balky at times but most of the time it is a thing of beauty to row thru the gears.
The last and final big mod I did to the car was to add the 4 small fans on the front mounted oil cooler, after some initial fusing problems, and a slight redesign on the power circuit it has been perfect. She has a thermostatic switch and operates as per design, I have not seen any high oil temps since the install.
The next item to complete is a full corner balance alignment. I am curious to know what her final weight will be, she should be pretty damn light.
Is this car done, are these cars ever really done... they are a hobby and we will always find something new to work on. Love my hotrod 3.6
Very cool car.
First time reader of this thread, going to have to talk with JP about your fuel cell install.
Beyond cool. Not enough said for this car of the month. Saw Marv's 914 at the Riverside swap meet this past weekend this was the third time I've walked around this car maybe the best 914 I've seen. You hear this car arrive sounds extremely nasty turn and look and you know you need to walk over and look a little closer.
Nice! I prefer the stripes on the rockers to the door bottoms.
Wow nice car,great selection off surfboards what more could a man want
Hey Marv,
I can't thank you enough for your persistence and ultimately a build of the first order!
Like many builds here, I have learned a ton!
Grant
Hey y'all long time no post. I miss a lot of you guys. Bottom line is I don't drive my car much at all any more... So I am in process of listing my baby on BaT.
At one point in time there were peeps here on the World that had said, if you were ever interested in selling let me know, here is the notice.
Love my car, just don't use it, the wife calls it my garage ornament.
This car (for those that don't know it) was a complete over the top restomod GT on an original six chassis with the best of everything available at the time. 3.6 993 eng, 915 close radio trans, Brembos, HRE forged wheels, rotisserie done steel GT car with lots and lots of custom work.
PM me if interested, it will not be cheap.
Marv
Good luck Marv - Sorry to see you selling, but I get it. You have one beautiful car with all the right stuff for sure. If my wife would not dig a hole and throw me in it, I would be very interested.
Oh no ... she must have seen my post - I found a large hole on our property . . 9' deep!
Hi Marv,
Sad to see it go !
Definitely one of my all time favorites !
Always loved and admired your car Marv!! I know you went through many trials & tribulations to get that thing done. We will miss you at the local events. Don't be a stranger, show up anyway and say hi!!
One of the best 914s on the Planet @http://www.914world.com/bbs2/index.php?showuser=3165
I was one of those guys not sure I’m in the right position to make you a fair offer will be watching and bidding on bat
You're one of the OG members, sorry to see you two part. If the next car is half as cool as this one, I'm sure you'll have fun in it too.
