How much fender clearance is a safe distance for the inner fender wells and the tire.
Right now I'm measuring about 1" between tire and fender well on 25" tires. I'll have pics of it tomorrow.
I'm talking about the rear.
QUOTE |
fender well on 25" tires. |
well... their 295/30/18
Put the car on jack stands, unbolt the lower shock mount, and then push the wheel/tire up (with a floor jack) and see how much clearance you have when the suspension is under compression. The inner fenderwell clearance will reduce as the compression increases.
-Ben M.
Remil,
We can meet at TC Design in Milpitas and you can check out the clearance (or lack of) on neo914-6. My rears are very close to the inner fender and flare. I will worry when I get "street" springs on it...
Felix,
When are you goin to TC Design next?
I unscrewed the thread collar(sp) off the threaded body and slowly let it down till the shock bout bottomed out. It looks like I've got enough spacing.
I'd say 1inch is enough. I have 1/2 and it works ok.
Alright it's tomorrow already.
here's what it looks like at the ride height that I plan on using.
Here it is with the suspension bottomed out (well the shocks anyway).
Here's a shot from behind. Still seeing some light.
That looks okay to me. What is that, about 3/4" gap (in the shock bottomed possition)? Nice wheel/tire combo.
-Ben M.
Won't you hit the control arm before the inner fender?
3/4" is what was left.
QUOTE (bondo @ Dec 30 2005, 10:19 AM) |
Won't you hit the control arm before the inner fender? |
probably meant the "trailing" arm...
In Andrew's words "it'll fit?"
I will stop by TC today to drop off some bolts, give me a call...
QUOTE (neo914-6 @ Dec 30 2005, 10:47 AM) |
probably meant the "trailing" arm... In Andrew's words "it'll fit?" I will stop by TC today to drop off some bolts, give me a call... |
To check full suspension travel in the rear, ya gotta take the spring out of the equation so's you can bottom the shock....a PITA. You gain negative camber as the suspension compresses. You need more room than is obivious for side wall flex.
Having said that, 1 inch clearance at static ride height should be plenty. When you get down below 1/2 in, it gets iffy. I've got big crecent shaped marks on my inner fenderwalls to prove this
I do this routine on the front also. Full compression, lock to lock
on the steering.
I haven't even got to checking the fronts yet for clearance.
QUOTE (sj914 @ Dec 30 2005, 11:06 AM) | ||
Felix I'll see if I can make. What do you plan on getting there? Is that pic of your car? That looks alot less clearance than mine. |
I had an 1/8th of an inch of clearance and it rubbed.. It rubbed on the fender wells on the inside. So I do not believe it will hit the trailing arm first.
QUOTE (neo914-6 @ Dec 30 2005, 11:47 AM) |
probably meant the "trailing" arm... |
QUOTE (Andyrew @ Dec 30 2005, 01:30 PM) |
I had an 1/8th of an inch of clearance and it rubbed.. It rubbed on the fender wells on the inside. So I do not believe it will hit the trailing arm first. |
The part I was worried about most was the section of the fender well near the trailing arm mount. The long seems to flare out in that section making the fender well smaller in that section. Right now the suspension is setup with a noticable amount of toe-in. I never really thought much of it, because my last car had the same noticeble toe-in. From what I can measure at that section I've got at least 3/4" of clearance.
JP,
QUOTE |
You need more room than is obivious for side wall flex |
I can barely slip my index finger b/t the tire and inner fender. It has never rubbed against the fender. Eddy
The worst point of contact is the lower RH coner of the pic...out of the frame cause I blew it.
This is with a tight (3/8 in) finger of clearance at static height.
Camber change, side wall flex....whatever, uses up space pretty qiuck..... there it is at the top of the tiar also.
