....getting ready to paint the tub. I am going to detail rockers, etc with satin black. I also am replacing all the vinyl on the targa top and sides. My question is what to do with my targa top? I've seen many people paint them black, but I'm not to sure I want to do that--nor do I want to paint everything the car color. I want the top to compliment the new vinyl in color and texture. From what I've seen, many tops that have been painted stand out (too shiny,etc) from the vinyl.
I am also concerned that if I paint the top, taking the top off and on might lead to the paint cracking as the top flexes being removed??
Is there a way to bring the top back to life without paint?? If not, what paint would you recommend for durability, flexibility, and color to achieve the look I'm after?
Much appreciated,
Mark
This may be a bit out of the ordinary, but has anyone considered covering the top with matching vinyl? Three pieces of vinyl, one wide piece down the center, over lapping two narrow pieces, one on each edge.
That would certainly tie the top to the sail planes.
I know there's an additive for painting plastic that allows the paint to flex a ton. I don't know if you can use paint with that in it on a fiberglass roof, but seems like it would be plausable.
The guys at Los Ponchos in Tijuana use some sort of paint that does not crack or peel and they duplicate that spackle like finish pretty well. Might be worth a drive south?
GTeener's got a vinyl covered top. Looks pretty nice IMHO.
I "refreashed" mine by doing a cocktail -- mothers back to black then wiping down well with mild soap and water ---- then I used forever black then let dry and hand buffed to a stain shine by hand with microfibre cloth
a bit of work but worked out very nicely
Ive used black vinyl dye, works great and matches the stock finish. Best to buy a quart of it and lay it down with a gun, I have used the spray can stuff with good results if it is cool out, no wind and you are able to lay it out wet enough.
QUOTE (STL914 @ Jan 16 2006, 09:49 AM) |
has anyone considered covering the top with matching vinyl? I "refreashed" mine by doing a cocktail -- mothers back to black then wiping down well with mild soap and water ---- then I used forever black then let dry and hand buffed to a stain shine by hand with microfibre cloth a bit of work but worked out very nicely Ive used black vinyl dye, works great and matches the stock finish. Best to buy a quart of it and lay it down with a gun, I have used the spray can stuff with good results if it is cool out, no wind and you are able to lay it out wet enough. |
They hold up fine after painting. Be real carful when you put in the trunk: I added stick-backed felt to the trunk top holders and I put a towl over the top whenever it's in the trunk.
When I inquired about refinishing my targa top on the Rennlist forum,Martin Baker replied:
"Texture comes from 'Body Shutz' which is basically a rubber coating that is sprayed on the top and then painted satin black. The last one I did I used 3M Body Schutz, heavy texture.I had to lightly sand the high points to make it smooth. Wurth also sells the gun and the Shutz (as well as 3M).
Hope this helps!
Pick up truck bed liner applicators do a nice job to restore to original.
If it doesn't turn out right I have an extra I will sell....
I have the info on how to re-finish the top correctly, which is what I would do. The texture is shot with a schutz gun, using Wurth or 3M body schutz, painted, and the color is a satin black, I can't remember the name of the German company, but is still available now. I think its Spies Hecker. My boss just showed me the color the other day, as I want to re-shoot mine. I work in a body shop. Mine is to glossy for my taste. Are you in Nor-Cal?
Martin, If you are talking about the top on that red creampuff that I saw in Sacramento, I think it looked just great. If it is too shiney for you, leave it out in the sun(MIght have to wait a few months to do that though
BTW, got the concave mirror, thanks, will have time to install it in a few weeks.
North Bay 914 - I plan to have my 914 in the shop all next week for rust repair and if you are going to re-shoot your targa top I would jump at the chance to get mine in there.
It appears to have old, black paint on it, so prep work is in order. I have been reading this thread with a lot of interest, as getting the targa top looki right sure would be nice. Maybe send a PM if this might work, either next week or in the near future.
Haven't received my mirrors yet, should be here soon
I heard that rubber undercoating works quite well,like wurths or some name like that,and it comes in spray cans.
QUOTE (ChrisNPDrider @ Jan 17 2006, 12:39 PM) |
North Bay 914 - I plan to have my 914 in the shop all next week for rust repair and if you are going to re-shoot your targa top I would jump at the chance to get mine in there. It appears to have old, black paint on it, so prep work is in order. I have been reading this thread with a lot of interest, as getting the targa top looki right sure would be nice. Maybe send a PM if this might work, either next week or in the near future. Haven't received my mirrors yet, should be here soon |
QUOTE (Tobra @ Jan 17 2006, 07:39 AM) |
Martin, If you are talking about the top on that red creampuff that I saw in Sacramento, I think it looked just great. BTW, got the concave mirror, thanks, will have time to install it in a few weeks. |
Here's mine, it was really bad before I recoated it. Areas in the back had cracked and there were some waves (highs and lows) in it. Sorry I didn't take before pics. I sanded it all out with an airfile then took it over to the truck bed liner guy "LineX". He did in a day for $75. I really like it. Durable and looks good.
QUOTE (North Bay 914 @ Jan 16 2006, 10:21 PM) |
I have the info on how to re-finish the top correctly, which is what I would do. The texture is shot with a schutz gun, using Wurth or 3M body schutz, painted, and the color is a satin black, I can't remember the name of the German company, but is still available now. I think its Spies Hecker. My boss just showed me the color the other day, as I want to re-shoot mine. I work in a body shop. Mine is to glossy for my taste. Are you in Nor-Cal? |
I've used Wurth Stone Guard which you can purchase http://www.carcareonline.com/detail.asp?product_id=11336. It's also in an aerosol spray can which I've never used. The last top I retextured I used regular urethane clearcoat. I sprayed it on with the HVLP gun deliberately set down to a low pressure and a larger tip to get a maximum 'orange peel' effect. I experimented with the gun settings to get a texture very close to the original finish. After letting it set overnight I scuff sanded it with 800 grit, then sprayed SEM products trim black for a satin finish. It can be left alone for a glossy finish.
That bottle screws right to the gun I have. Sato makes it. No adjustment. The good gun Wurth dealers sell is $250.00. They normally give it free to shops who use Wurth products.
