my 2001 yukon xl died about 3 blocks from my house, i was able to coast home so at least its in my driveway (barely)
engine just died while driving, gas gauge says dead empty but I know it had about 1/2 tank yesterday. just put 5 more gallons in and it still says empty and will not start.
battery is good and cranks fine....when cranking gets oil pressure etc but gas gauge says empty. was thinking fuel pump but why would that effect the gas gauge? unless they are on the same circuit somehow.
so do I call AAA or is there an easy fix?
Not sure if that is one of them but GM started using fuel pump modules (sending unit and pump in one unit). That said I would check the wiring to the pump first and see if you are getting power back there.
I agree with welby, check fuses, too...although I bet you've done it already.
QUOTE (ws91420 @ Feb 7 2006, 09:54 AM) |
Not sure if that is one of them but GM started using fuel pump modules (sending unit and pump in one unit). That said I would check the wiring to the pump first and see if you are getting power back there. |
Have you ever changed the fuel filter?
The reason I ask is that the fuel filter is after the pump. If the filter is not changed, the pump strains to push fuel through it, and burns up. Sometimes the pump shorts out and burns up the wiring to the pump, taking the gas gauge wiring with it.
I have fixed a lot of GM pickups with the same problem. Put a new pump and filter in, and fix the wiring.
Good luck with it.
David,
Where have you been?
Engine back and in?
Paul
Happened to my suburban last year. Wait till you see the price of a new fuel pump.
cant be more expensive than a 600 dollar D-jet pump.
I know its cheaper now though.
b
QUOTE (URY914 @ Feb 7 2006, 10:58 AM) |
David, Where have you been? Engine back and in? Paul |
that's awsome david!
and automotive art, too!
QUOTE (seanery @ Feb 7 2006, 11:30 AM) |
that's awsome david! and automotive art, too! :trophy: |
914 parts in art! I love it!
Damn! that is great!
914's as art. Who knew?
Paul
So the thing with Playboy didn't work out?
O'well....
Just don't let SirAndy take the pictures for you......
nice art, but gawd a 5 year old truck failing like that, and a dozen recall items????? No wonder GM is near bankrupt. My fathers suburban has been the same story, huge failures on vaction trips, wheel bearing that take out the axle when they suddenly failed, engine issues, tranny issues, ventalation issues etc...
i have worked on thrity year old 914's with what appear to be the stock fuel pump still humming away. Ah the old technology.
Good luck
QUOTE (dmenche914 @ Feb 7 2006, 11:01 AM) |
nice art, but gawd a 5 year old truck failing like that, and a dozen recall items????? No wonder GM is near bankrupt. My fathers suburban has been the same story, huge failures on vaction trips, wheel bearing that take out the axle when they suddenly failed, engine issues, tranny issues, ventalation issues etc... i have worked on thrity year old 914's with what appear to be the stock fuel pump still humming away. Ah the old technology. Good luck |
So why is it that two cars come of the line one behind the other.
One has no problems and runs like a top for 200k miles.
And the other needs every little thing replace within 40k miles.
Now there is a riddle...
Paul
QUOTE (URY914 @ Feb 7 2006, 10:17 AM) |
So why is it that two cars come of the line one behind the other. One has no problems and runs like a top for 200k miles. And the other needs every little thing replace within 40k miles. Now there is a riddle... Paul |
David, what do you shoot with?
QUOTE (seanery @ Feb 7 2006, 01:02 PM) |
David, what do you shoot with? |
QUOTE (seanery @ Feb 7 2006, 04:02 PM) |
and here is the fuel pump. The dealer is charging me $438 for the part, the online price is $260 but you have to drop the tank to install it and I just don't have the time or the b*lls to pull the 33.5 gal tank out of my truck. (which is almost full by the way)
Check out the pic, you can see the fuel level sender is part of the pump assembly...
It's easier to do in the pickup version. You unplug the wiring and pull the bolts that hold the bed to the frame. Then you get 6 friends to lift the bed up and off the frame (or pick up the bed with a lift).
Total time for the fuel pump replacement.... about 30 minutes.
Now dropping a almost completely full fuel tank.
It's gonna take 3 hours. Gotta drain the tank first.
This same issue happened with my bro-in law's suburban. Seems his wife likes to drive around on 1/4 tank and reserve- too cheap to fill the tank. The pump overheats as it cooled by fuel. Today's cars should be filled at 1/4 tank. Dealer charged over $1,000.00- DH
Damn...... I use the same pump in my 914.....
Bob
