I just got me a powder coating system, I bought the craftsman setup, don't need a compressor to run the gun. I dedided to coat my spare wheel for my spare tire. Never done this before but it seems straight forward and pretty easy. The hardest part is preparing the piece to be coated.
Anyway heres some pics. of the process
The wheel all masked off ready to take some powder
The powder is applied and ready for the oven to cure
damn.....I thought by the 1st picture you powdercoated it green
After it cooled in the oven while the oven was cooling down, I heard this is the best way to do it, let the piece cool down in the oven as the oven is cooling down.
Now just a bit of sanding an polishing and the wheel is ready to go
so how does the powder get applied w/no compressor?
What kind of masking tape is that? I was surprised to see it go through the oven heat cycle.
The gun has its own fan system for blowing the powder out of the cup its put into, the trigger is a variable speed trigger so you can control how much powder is being applied, its a great unit it looks like a blow drier.
After reading a thread on the PP 911 board I went a bought one. Good thread on the product.
http://forums.pelicanparts.com/showthread.php?threadid=250503&highlight=powder+coating
The masking tape is high temp masking tape from 3M
The most difficult part of setting your system up is getting an oven to dedicate to power coating. I wish I had 220V in my garage. You don't want the oven in your house, the fumes are BAD.
Ok... that is 2nd on the list. First is cleaning your material, getting rid of all the crud. Sandblasting works wonderfully once the material has been scrubbed down.
Couple more items I coated over the weekend
I'll be right over.
I'm so Jealous... those pieces look awesome!
QUOTE |
You don't want the oven in your house, the fumes are BAD. |
how much is the rig to powdacoat?
QUOTE (Aaron Cox @ Feb 13 2006, 05:44 PM) |
how much is the rig to powdacoat? |
Stratplayer... how did you do the intake plenum? Did u take it down to bare metal? Or scrape off the gunk and powder over the existing paint?
Huh? I want green fuches now.
how much powder is needed to do a wheel?
i want to do my cookie cutters in bright red.....
QUOTE (Aaron Cox @ Feb 13 2006, 08:55 PM) |
how much powder is needed to do a wheel? i want to do my cookie cutters in bright red..... |
I got a nifty powder coater from harbor freight for about 90 bucks. Got my hands on an oven and the most beatiful looking pieces came out. The only problem is that paint usually comes in 25 and 50 pound cartons and you have to buy the whole carton. You can paint ALOT of stuff though!!
QUOTE (nbscooters @ Feb 13 2006, 09:07 PM) |
I got a nifty powder coater from harbor freight for about 90 bucks. Got my hands on an oven and the most beatiful looking pieces came out. The only problem is that paint usually comes in 25 and 50 pound cartons and you have to buy the whole carton. You can paint ALOT of stuff though!! |
I used jasco on the plenum to remove all the paint on it, I let the jasco stay on overnight. Once all the paint was gone I sprayed it with some phosphoric prep & etch, can get at home depot. Cleaned it off real good, let it dry completely and then I coated it.
You can buy as little as 2oz. of coating from columbia coatings, thats where I get all my powders from. I started with just 2 oz. so far I've coated a wheel, plenum, and gauge bezel and I still have plenty left, I'm going to order about 8 oz. of the satin black from them.
www.columbiacoatings.com
Cooking parts! Looks great.
http://www.eastwoodco.com/
You can buy their powders in various sizes from 8oz to 50lbs. No affiliation, yada yada.
Some more powder coating magic, the airbox is finished
another
Making some progess, more Stuff that is coated.
last one for now
are you coating everything you own???
dam...how did you do the air box? that isnt stock is it?
did you do fuel rails?
how did you clean the tin prior to paint?
-shag
Yes that is the stock air box, I stripped all the paint off of everything, the preping is the hardest part of the job, a good prep job will yield you a great powdercoating job. Yes I did do the fuel rails, the tin and the airbox were stripped using jasco to remove all the old paint. Once I was satisfied with the prep work then I coated everything.
Looks sharp.
Excellent results!
I like the two tone intake runners. Very nice job!
Here are pics of the stuff I did last week:
http://www.914world.com/bbs2/index.php?act=ST&f=2&t=47725&hl=powder
One thing I noticed to beware of... the intake plenum acts as a path to ground. So make sure you scrape away the required paths. I know for a fact that fast idle valve is grounded to the block through the intake manifold. That's all I could find on my setup. Just a heads up.
