Single weber carb found in a box of parts with a parts car I had. Looked on the web, but really didn't find anything that says this carb is XYZ. So now I ask the 914 gods WTF is it.
next
last
The toss-able kind. at least for a 914 anyway.
I'm not sure what Weber called them, but it looks like the one Holley built under liscence and called it a 5200. Weber may have called it the same thing...
They were used on just about every four banger and some six cyls that Ford, and just about everyone else, built up to the late seventies or early eighties. I used to build up Capris and Pintos back in the day, so I've seen a few 5200s.... Great little carbs, for what they were. I have a book about those things somewhere, I'll try to dig it out...
QUOTE (Joe Ricard @ Mar 13 2006, 10:31 AM) |
The toss-able kind. at least for a 914 anyway. |
32/34 DFT Emission Carb....should be stamped on the square base. Similar to the 32/34 DGAV....just more vacuum ports
Okay, Weber called it a 32/36 DGV, 32/36 denoting the primary and secondary bore diameters. It seems it was also available with smaller bores. Holly built them for the US manufacturers, the rest of the world got them from Weber.
It was considered a fairly high performance carb back in the day. Some guys used to run 'em with a single carb set-up on Type 1 V-dubs with some success.
As far as a 914 is concerned though, Joe is right; it's tossable...
Thank you! It goes on ebay in 2 min unless someone here wants it
QUOTE (itsa914 @ Mar 13 2006, 11:13 AM) |
Thank you! It goes on ebay in 2 min unless someone here wants it |
Not heavy enuff by itself to be a boat anchor....but ten or twenty welded together would suffice......may they sleep with fishes....
QUOTE (Joe Ricard @ Mar 13 2006, 12:30 PM) | ||
BRITT ???? |
QUOTE (itsa914 @ Mar 13 2006, 10:57 AM) | ||
I agree. I'm going to toss in on ebay, someone might want it. |
i'll take it, i'm building a vw powered lawnmower this summer!
b
QUOTE (bd1308 @ Mar 13 2006, 11:41 AM) |
i'll take it, i'm building a vw powered lawnmower this summer! b |
Uh, joe....you're not going to outbid me on this are you?
joe....my lawnmower.
b
QUOTE (bd1308 @ Mar 13 2006, 12:41 PM) |
hey man, dont they scare you at one point or another?
look at that huge spring!
b
