Hey guys what is fair price for a 914-6 hand throttle? The handle and rod (missing the pedal assembly piece)
check for a 912 piece... might be more common.
I'd say $50.00
Alsooooooooo... I have a throttle crank I made that is almost identical. Let me know if your interested.
E.
PM sent
QUOTE (Eric_Shea @ Mar 13 2006, 04:01 PM) |
check for a 912 piece... might be more common. I'd say $50.00 |
912s didn't have a hand-throttle, Eric. They had the heater control where the 914/6 hand throttle is located.
Fabricating a hand throttle wouldn't be hard. A heater knob will work for the one part that would be difficult to fab up. The rest would be pretty straightforward.
From what I understand, the early 912's 'did' have a hand throttle there. (Martin, in-coming, in-coming, I need some cover over here) The one I have came out of an early 912 (so I've been told), has the lever marked "Throttle" and all. Bolts right up to the ole 914/901 shift lever and has the appropriate size/length rod (which is more than I can say for... oooooops, sorry)
I just had to make an L-bracket with a bronze bushing in it. Welded a 10mm nut on it and bolted that up to the stock location as well. Pronto, finished, done...
Tell me what you Brainiacs know...
QUOTE (Eric_Shea @ Mar 13 2006, 06:50 PM) |
From what I understand, the early 912's 'did' have a hand throttle there. (Martin, in-coming, in-coming, I need some cover over here) The one I have came out of an early 912 (so I've been told), has the lever marked "Throttle" and all. Bolts right up to the ole 914/901 shift lever and has the appropriate size/length rod (which is more than I can say for... oooooops, sorry) I just had to make an L-bracket with a bronze bushing in it. Welded a 10mm nut on it and bolted that up to the stock location as well. Pronto, finished, done... Tell me what you Brainiacs know... |
OK... back to my first post then:
"check for a 911 piece... might be more common."
Here's a picture of the hand throttle crank I made for mine. It's available if you're interested Kerry...
here is a bunch o pictures its the same as the 914 heater lover, see here,
http://www.914world.com/bbs2/index.php?act=ST&f=2&t=46013&hl=hand+throttle
Thanks for the linky Jeff
Eric, you have a PM
