OK, I've got my vaccumm advance plugged and my timing light hooked up with the inductive lead on cylinder 1. I've read the pelican article on timing and it contradicts my Clymer shop manual. Pelican says you time a 1.8 at 800-900 rpm at 7.5BTDC, while 1.7 and 2.0s you time at 3500 rpm. My manual says its 3500 rpm for all 4s??? Which is it??
Secondly, I'm having a difficult time finding TDC. With the cap off I've rotated the engine until the rotor is pointing at the TDC notch on the distributor. The marks on my housing/pulley are not to be seen. Is it suppose to be near the one flatten blade on the fan? Yes, I rotated the engine 180 degrees as well.
Does this picture look like I've got the right idea for finding 7.5 BTDC?
This might help
for a 1.8l it should be 7.5 degrees
you really need to be looking. the marks tend to be toward the rear of the fan (ie closest to the block) vs being on the pulley part. put a blanket down and lay on your trunklid to see.
it also helps to go get an adjustable timing light. it delays the spark X degrees so the only mark you need is the TDC. go get a thing of your wifes nail polish or a paint pen, find TDC and make it visible with aforementioned marking devices.
then take the timing light, set it to desired advance, and rotate dizzyy until you see the TDC mark.
The diagram I posted is very accurate. Note the flat wide bar (shown at the 32 degree mark in the diagram) and count 4 1/2 fan blades to the right to find TDC.
Just installed electronic ignition and had engine tuned to the following specs.. runs great!
• Adjust valves: 3 – 4 thousandths
• Installed compufire electronic ignition
• Adjust timing : 32 degrees Full Advance @ 3 thousandths +
Chrome Molly Steel Pushrods
Stroker Crank
78 Stroker; 96 Bore
Port matched manifolds
2 Liter heads with some port work
Chrome moly pushrods take ZERO lash last time I checked..
Twystd1
Ditto on the chrome moly pushrods. Mine are set to 0 lash.
I added a little advance near and at WOT in the mid RPM range from the drivers seat. A few key strokes on the laptop and hit the burn button. Crankfire will blow your mind.
Dave
