75 2.0... only seen one towards the front.. I assume there are more??
Thanks
Yup, and one at the back too. The same one that stumped me.
I believe it's three. Two toward the front, that bolt up to a couple of the engine tin screws. (One toward the left-front, one toward the right-front.) Plus the one at the back, that uses one of the crankcase through-bolts to hold it in place.
--DD
Great thanks guys... any kind of seal or anything ill need when it goes back on?
Here's a pic that "MAY" help. It is 3 bolts like Dave said. If you pull the throttle body off of the plenumn you'll need a new gasket and they are nla BUT, I took my throttle body to the local vw parts house here in town and they were able to fit it with one off of a t-1 that only required a little cutting.
Gadd's, Dave the human 914 encyclopedia.
Okay Dave (or whoever), is it easy enough to remove the whole plenum since it is
almost impossible to install the throttle body to the plenum? This is a 1.8 L-Jet.
How many bolts are there?
Thanks,
Jeff
Thanks Allan for taking the time for the photo. Answers my question
I haven't worked with a 1.8 plenum (I never messed with the one on my old 1.8). The one pictured above, and the one we've been talking about, is a 2.0 one.
I would guess (and it's only a guess!) that there are similar connections on a 1.8, but I don't really know. It might be easier to pull the plenum (though I have found I have to pull the intake runner pipes off the motor to remove the 2.0 plenum), but I don't even know how the 1.7/1.8 throttle body is held to the plenum at all.
Damn long way of saying, "I dunno!"
--DD
The gasket for the TB is NOT NLA. There was a post today that mentioned picking one up at the dealer. The T1 gasket is much smaller, and the 1.7 and 1.8s use a rubber or plastic cone. Those are NLA, and have been for years. The Cap'n
Cpt, would a 2.0 engine gasket kit contain a new TB gasket?
Plenium???
I opened the thread to find what it was....geez, must be bored....
The 2 bolts on the top of the plentium are they competely necessary for a proper install. I have the plentium mounted as a preassembly of the motor. The is no where on this case for the bolts to thread into, I have the other 3 connecting points connected. Just wondering about the 2 long bolts that fit into the top of the plentium.
Tod...thought your car was in storage, what's up?
...or what are you up to...
