So this "quick" brake fix job has turned into another real headache. What's new?
Screwed up two of the rear brake hard lines when I was replacing the rubber lines. So we went down and bought some new metric hard lines at a FLAPS, they fit nicely, blah blah blah.
Now it appears that the threading for the right brake line IN the proportioning valve is stripped, and the brake line will screw into it but has a lot of play, is very loose and basically will for sure be leaking.
So now what do you think I should do? I've already spent so much on this brake fix job and I would *really* hate to spend 200 bucks on another P valve. The adjustable ones listed on PP say they're for track use only too. What about replacing with a T fitting? I've read of others doing that. Street car, stock brakes....
Thanks for any help...
im sure someone has a stock one somewhere for free...
i threw mine away...
do a T if you have bigger than stock front brakes....
You probably didnt buy the adapters you need for a prop valve.
None of the cheapo Summit or Wilwood prop valves will screw together with our lines.
Anyone figure out from this "why" I tell people to put a "T" in place?
B
I didn't know there are adapters
It's ok. I wasnt aiming that directly at you.
You dont need a prop valve.
One of the most common mistakes made is thinking that the 914 has a prop valve in it..when in fact it does not. It is just a "damper" it does not restrict flow to the rear calipers.
Honestly.. it only works in emergency situations, otherwise it passes fluid JUST LIKE A TEE.
B
Put in a Tee, you'll be much happier!
From what I can remember they used to advertize it as some sort of anti lock device. They used to say you can push on the petal as had as you can and the brakes should not lock up.
Emergency situations meaning..... Sudden slam on the brakes in wet weather? Hard stop and they lock up... or??
Where can I find a T fitting? I'm thinking a bug shop?
tee can be found at bug shop...
or CIP1.com, or james adams here on the baord
I just went out and looked at the stripper.
nice shape factory Proprtioning valve. DAPO re did the entire system before dumping car.
Let me know I'll ship it Monday early. Make me an offer provide mailing address.
I have T's in stock. $6 clams.
Me no likes taking the P-Valve out unless ness...
The stock valve is a proportioning valve (pressure regulatiing valve). Here is the factory pressure curve.
Correct.
In a panic situation. The graph shows the relatively high pressure it takes before it slows down the fluid to the rear calipers.
Porsche calls this a "damper'
B
Looks the same when?
When the Wilwood and others are wide open?
Every single time I have installed an adjustable brake bias valve (Wilwood etc) Every time.... I have had to run them wide open. At that point, why run one in a stock system?
