Posted by: xsurfer Jan 28 2007, 08:29 PM
I'm a new 914-6 owner. I need to drop the engine but don't know the height required to get the engine and trans out. Anybody know if ramps are ok vs. axle stands?
Posted by: Jeffs9146 Jan 28 2007, 08:38 PM
It depends on the motor and the jack you are using! See the attached photo! I couldn't lower the motor very far with this type of jack so I had to raise the car.
Jeff
Posted by: dflesburg Jan 28 2007, 08:51 PM
Good Grief man,
Bad jack! Bad! Bad!
Posted by: mikez Jan 28 2007, 08:59 PM
Not too tall, Clay can do it.....
Posted by: Jeffs9146 Jan 28 2007, 09:15 PM
Good Grief man,
Bad jack! Bad! Bad!
I had to do it like that because I was working alone and I needed a stable surface to roll the motor around on!
Next time will be different!
Jeff
Posted by: mikez Jan 28 2007, 09:31 PM
Why did you pull the swing arms?
Posted by: jimkelly Jan 28 2007, 09:34 PM
can't you just use a furniture dolly and lower the car to the motor. i suppose removing the rear wheels would allow an even lower drop to motor if needed?
this is how we did a v8 install and this is an easy/safe way to do a type4 install too.
jim
Posted by: Jeffs9146 Jan 28 2007, 09:35 PM
One was bent so I took everything off, replaced and powder coated everything. Now it is all nice and new!
Jeff
Posted by: So.Cal.914 Jan 28 2007, 09:59 PM
QUOTE(jimkelly @ Jan 28 2007, 07:34 PM)
jim
It's really hard to bolt the engine in when the car is sitting on the ground. A
couple jackstands and a floor jack and your rocking.
Mike I am shocked by your avatar, why didn't you put in the rest of her?
