I'm looking at possibly getting a 3.0 but it has no F.I. So I would just run it with webbers.
Does anyone out there have this set up now? Are You running the CIS cam or was it changed out to a early T,E or S?
Bruce Andersons book says it's an easy 200HP with Webbers (set correctly) and headers, and the stock CIS cam.
Any thoughts?
TIA,
Mike D.
The CIS cam is fine....the 964 cam is better. If I recall, most anything else requires head work.
906 cams!
Not very streetable but fun.
Actually I'm with mike on the 964 cams.
The problem is that valves will hit the pistons with the more aggressive cam grinds.
So change pistons and cams if you want something like S or Solex profiles, or go with 964s for the easy (but milder) setup.
Keep in mind that the 964 cams will work better with the higher compression of the later 3.0L (80-83). They really aren't the ideal choice with the 78-79 lower compression motors. If you are planning to eventually upgrade the pistons anyway, it probably makes sense to do the cam at the same time. You'd want something more aggressive than the 964's when you upgrade the pistions.
I have webcam 20/21's in my 3.2 six.. stock CR and no issues with clearance. I suspect the 3.0 is a similar animal.
Uhhh, Mike, whatya going to do with your 6?
Kevin
The 'E' Cams are the hot setup for a 3.0 with Webers. Ton's of Tourqe down low. I get 200 HP with as much torque to the rear wheels. The valve clearance is close, I think it still has the CIS pistons.
Here's the dyno at the wheels:
I agree...my engine builder used "E" cams and cosworth pistons. Topped my 3.0L off with some 46 webers. Love it..................
My six had a stock 82 3.0 with the Webber's off the original six, with lots of changes to the jets and K&N air filters.
my 83 SC has the 964 cams in it. Both engines are terrific.
I have ยด79 3.0 with Solex cams and Webers. Pistons needed valve pockets. Runs fine and strong, but fuel consumpion is baaaaaaaaaad. As soon as I have time I will chance to programmable FI.
I run a 2.7L w/Carbs and I also use "E" cams that replaced the "S" Cams. E Cams will give you more Tourque. The motor has around 240 HP and about 240 ft. lbs. of Tourque. Compression is 10.9 to 1. I did have to replace the pistons, and now they are correctly domed. I would say the "E" cams are the way to go. The motor with S cams before was not as much fun to drive.
Thanks all...
Eric, that is the exactly what I was going for. I can get it in the car for summer and start stock piling parts for a future rebuild. I probably only put around 3k miles per year on the 914 anyway so it should get me through a couple of years.
BTW, I committed to buy the engine this morning, so...
2.0 E spec six for sale very low miles, very fun, come drive before you buy...
sorry, I'll take to the classifieds...
