Nelson discovered this weekend that he does not have the socket to remove his 968 wheels.
Can you ID this lock? Advice on getting the key?
If all else fails try something like this:
http://buy1.snapon.com/catalog/item.asp?store=snapon-store&item_ID=66815&group_ID=1641
I think they sell a cheap version at napa. They work great, rim thiefs love 'em.
I've used "reverse EZ outs" (sears or snap-on truck) to pull those before, not sure you have the room to get them on though....
I believe those are factory wheel locks though, maybe the stealership will have a master key?
BJH
Dammit Dana...
Could always shoot them off Joe
BJH
when i 'steal' wheels (at a junkyard)
we take a socket that almost slides on... and use a BFH to beat it on... then break em loose
kill a cheap socket....
Is that the lock with the spinning head??????
If so...... I would drill it... for sure.
If the head doesn't spin.... Either use a socket A'La'Aaron or find a buddy with the snap on removal tool.... They work like a charm.
If all else fails. Weld a big ass bolt to it and turn it off....... Tape off the wheel are before welding... Or put wet rags around weld area....
Sparks pit wheels...
C
take the plastic cap off first.
key goes in, twist, take the cap off.
if not, drill it out.
shit, nevermind...
check the glove box for the socket?
