ok I am installing a replacement engine and going over the engine before I plop her in the teener and low an behold the fuel line to the cold start valve has been cut and I can't find an open spot for the line to go to ?! please help ...2.0L d jet
look at this pic
The side with the FP has the rail with three outlets, battery side gets the one with the plug.
The center outlet goes to the cold start valve.
If one has the screw in it, take it out and run the CSV line from it.
fuel pressure reg side..
They are the same. Which ever one you use on the pass. side is hard to access because of the MPS. To test fuel pressure, you just disconnect the cold start line and put your pressure gauge on.
well ok then...
so will the engine will still run properly even witk out the cold start valve .. except at first start ... right?!
sweet!!!
