Printable Version of Topic
914World.com _ 914World Garage _ Superlite 15x7 25+ offset 4 lug 4x130 wheels
Posted by: Gint Mar 26 2007, 07:32 PM
I had half a dozen titles for this thread in my head...
It's finally time to mount the Superlite wheels I bought in June 06. Mike Z was given a second chance offer from ebay when the auction didn't make reserve. He offered them up and I grabbed it. I bought them significantly cheaper than http://www.packracingproducts.com/acatalog/Pack_Racing_Products_Superlite_Wheels_2.html currently offers them for on their website. So it was worth it. Here's the http://www.914world.com/bbs2/index.php?showtopic=52852& There were many questions (and even a little mis-information) in that thread. I'll answer quite a few here since I now have the wheels have tires mounted on them and I'm about to use them.
BTW - 914world member http://www.914world.com/bbs2/index.php?showuser=4264 has a thread about his Superlite wheels. http://www.914world.com/bbs2/index.php?showtopic=61708&. Nick, you want to read this thread and possibly talk to Pack Racing about a set of inserts with a proper conical lug bolt/nut seat.
Posted by: Gint Mar 26 2007, 08:42 PM
I thought I was getting 2 wheels with 25mm+ offset and 2 wheels with 35mm+ offset. There was a little communication trouble because I was communicating to Pack Racing via Mike Z since it was he who received the second chance offer when the wheel didn't make reserve on ebay. Looking at the wheels, one of them is stamped 12p or 12mm+ offset and the other three are stamped 25p. And it would appear that these were all stamped 12p at one time and stamped over with 25p. Regardless, I measured them all and they are all 25mm+ offset.
I never doubted Herr http://www.914world.com/bbs2/index.php?showuser=87 as he has done a lot of work with non-factory wheels on 914s, but I now can confirm [/size]what Mike has always said. As has pointed out in the past, 35mm would be a offset for a 914 to use a 205 tire. Seeing is believing!
At this point I'll note that Pack Racing doesn't seem to offer a 15x7 wheel with a 35mm+ offset. They have 16x7's in 35mm+ offset but not 15's.
Tires...
I've now gone from running the fattest tire you can squeeze on a factory Fuchs wheel to the skinniest tire you can fit on a 7" rim.
I measured a few 205/50VR15 tires and needless to say they are all different.
- Yokohama EVS ES100 overall width is 8.2"
- Falken Azenis overall width are 7.875"
- Cheapo Nankang ex-500 overall width are 7.75"
- BFG G-force Sport overall width are 8.5625" These things are FAT!
The BFG G-force Sport are the fattest 205/50VR15 street tires I've ever seen.
I finally ordered 195/55VR15 in the BFG G-force Sport because the thread width and overall width are still as wide or wider than many other 205/50 tires. It looks like they will just barely work out. I have about 1/16" clearance on the outside and 3/4" on the inside. An extra 5mm positive offset from a 30mm+ offset wheel like the factory Fuchs would center it almost perfectly. Or a 35+mm offset wheel like Superlite's 16" could at least utilize a 5mm spacer to achieve optimal clearance on both sides.
There may be a tiny bit of fender rolling in my immediate future.
Posted by: Aaron Cox Mar 26 2007, 08:50 PM
let me interject a little. offset is a pretty useless number, as it varies by width....
Backspacing is constant. backspacing is from the inner lip of the wheel to the mounting face. on a 914, you want between 112-120mm backspacing.
every fuch wheel has almost the same backspacing even though the width changes. pretty cool.
so if you know the max back spacing you can run on your car (before wheel hits inner fender well) You can then pick a custom wheel to fit your car in ANY width you would like.
just easier to calculate IMO,
those look so sick on your car gint!
Posted by: Gint Mar 26 2007, 08:52 PM
Now, this is a piece of info that anyone wishing to order Superlite wheels for a 914 needs to be aware of. Be certain that you tell them that you are purchasing wheels for us on a Porsche 914, (and provided your car is a stock configuration) it uses 14x15mm lug bolts, a 4x130 bolt circle and the hubs are not hubcentric. This should be enough information for them to know what type of insert to install in the wheels prior to shipment. I believe they have not yet supplied many of these wheels for a 914, so they are working out some kinks.
On to the details...
Apparently, Pack Racing modifies these wheels and adds inserts into the mounting holes to provide the correct size lug bolt/stud hole and a conical seat. The bolt hole is 17mm, so a 14x1.5 lug bolt or stud will float in the hole. And since these wheels are lugcentric, there is no way without these inserts (or a reasonable substitute) to locate or center the wheel.
I'll spare you the long story, but with the help of Terry from Pack Racing, we figured out that these wheels had shipped without the inserts. I'm going to either get a set of these inserts from Terry or make some of my own. I haven't really decided yet. If P.R. will send me the inserts for free I'll liekly go ahead and get a full set. I'll update this thread when that's been determined.
The lug bolt/nut mating surface as supplied from the manufacturer is flat.
Close up
Insert rear view
Insert front view
Posted by: Gint Mar 26 2007, 08:58 PM
QUOTE(Aaron Cox @ Mar 26 2007, 07:50 PM)
Actually, I disagree. Offset in it's simplest form is the distance from the wheel's centerline to the hub mating surface regardless of the wheel's width. And I like to have all of the numbers. I have no issue with calculating the offset in order to know what I'm dealing with. But that's just me...
Details:
Factory 5.5" 4x130 Fuchs wheel
- Overall wheel width - 6.250"
- Wheel width (between the inner beads) 5.5"
- Backspace 4.6875"
- Offset 1.5625"+ (39.6mm)
Performance Superlite 15x7 4x130 wheel
- Overall width 8"
- Wheel width (between the inner beads) 7"
- Backspace 5"
- Offset 1"+ (25.4mm)
Edit:
I cheesed the Fuchs measurements. They have been corrected 3/28/07. Factory 4 lug (4x130 bolt pattern) Fuchs wheel has an positive offset of 39.6mm.
Good information about wheel backspace and offset from Yokohama's web siteQUOTE
High Performance Wheels
The following are various high performance wheel measurements that play an important role in determining tire and wheel fitment:
Wheel Backspace
This is the distance from the back edge of the wheel to the hub mounting surface. To determine the wheel backspace:
1. Position the wheel face down.
2. Lay a straight-edge across the back of the wheel. Measure the distance from the straight-edge to the wheel's hub mounting surface.
Wheel Offset
The wheel's offset is the distance from its hub mounting surface to the centerline of the wheel. The offset of a wheel can be one of three settings:
* Zero offset: The hub mounting surface is even with the centerline of the wheel.
* Positive offset: The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front-wheel drive cars.
* Negative offset: The hub mounting surface is toward the back or brake side of the wheel's centerline. "Deep dish" wheels are typically negative offset. Offset can be calculated by positioning the wheel on a flat surface and measuring its overall width and backspace as shown below. Divide the overall width by two, then subtract this result from the backspace value.
Offset = Backspace - (Rim Width ÷ 2)
Here's a drawing from Fikse that I especially like.QUOTE
Posted by: nebreitling Mar 26 2007, 10:09 PM
QUOTE(Gint @ Mar 26 2007, 07:52 PM)
Tires...
The BFG G-force Sport are the fattest 205/50VR15 tires I've ever seen.
Hoosiers are 8.7" across!
Posted by: Gint Mar 26 2007, 10:11 PM
QUOTE(nebreitling @ Mar 26 2007, 09:09 PM)
There's one in every crowd!
I'll modify that bit of text. Street tires...
Posted by: Joe Ricard Mar 27 2007, 02:10 PM
Hmm My Hoosiers are 11" across. with a tread compound of 25.
and with 4.5" of backspace they Just freaking barely rub the inner fenderwell and I can nearly get my pinky finger between the outer flared fender lip and tire.
Posted by: Tobra Mar 27 2007, 09:22 PM
More tires in 195-55-15 than you would think;
nice wheels, pretty green car
Posted by: Borderline Mar 27 2007, 11:40 PM
How much do these "superlite" wheels weigh??? They look gud! OK just looked it up.
they weigh about 18.9 lbs! Not exactly super lite.
Posted by: sean_v8_914 Mar 28 2007, 01:18 AM
vcb
Posted by: Gint Mar 28 2007, 08:43 AM
QUOTE(Borderline @ Mar 27 2007, 10:40 PM)
Weight wasn't a major factor for me. This is a street car. I just wanted something different and these wheels certainly provide that!
Posted by: sk8kat1 Mar 28 2007, 11:24 AM
I really like those!! so what is the proper wheel size ( bolt spacing ... back spacing , offset... 15x ?? ) for a 914 then ?! I have 4 lug fuchs and would like a direct replacement for them and so could I swap my 195-50-15 's to them... or another size that would work well with the tires I already
Posted by: Gint Mar 28 2007, 11:39 AM
Mine are 15x7 25mm+ offset.
IMHO, In a 15" wheel your best option is the 15x6 in 24mm+ offset or the 15x7 in 25mm+ offset. Ideally, the best Superlite wheel for a narrow body 914 would probably be the 16x7 35+ offset.
http://www.packracingproducts.com/acatalog/Pack_Racing_Products_Superlite_Street_Wheels_2.html
Posted by: sean_v8_914 Mar 28 2007, 11:53 AM
good info about backspacing and offset here
Posted by: sk8kat1 Mar 28 2007, 11:57 AM
QUOTE(Gint @ Mar 28 2007, 09:39 AM)
...so those 15" opions I would be able to direct swap my current 195/50/15's?
what tire size would be needed for the 16x7 to get them to fit .....
I have never bought aftermarket wheels for the car .. I guess I will pull the newbie role on this one and ask straight out .. what is the best set up wheel /tire size and possible spacer for these for use on a narrow body teener........ and which lug bolts would be required for those set ups
... sorry but I really am not wanting to get a tire rub blow out or have the wrong size blots and loose a wheel while cruising along
Posted by: Aaron Cox Mar 28 2007, 12:30 PM
QUOTE(sk8kat1 @ Mar 28 2007, 10:57 AM)
if you are ordering custom wheels... why use a spacer? get em to fit without a spacer!
fuchs 7" wheels have a 23mm offset. the 25mm offset gint used got them to sit 2mm more inward...
Posted by: Gint Mar 28 2007, 12:36 PM
QUOTE(Aaron Cox @ Mar 28 2007, 11:30 AM)
They aren't *that* custom Aaron. They only have a few sizes and they don't offer a 15" in 30 or 35 offset.
Posted by: Aaron Cox Mar 28 2007, 12:40 PM
QUOTE(Gint @ Mar 28 2007, 11:36 AM)
preaching to the choir.... i KNOW that. did you require a spacer? nope. use a 23mm or your 25mm if thats all they make it in.
im advocating doing the homework and research (find out what your camber is and how far inboard you can go to dictate offset and backspacing...)
Posted by: sk8kat1 Mar 28 2007, 12:50 PM
arron if you are trying to make me do my " homework " then say so .. but I already know that I am lacking in that area knowlage wise and that is why I asked ... not to pawn off on the folks that post here . yea I took the short cut to get to the best set up as a starting point and freely admitted to my taking that short cut .
gint thanks for the info
Posted by: Aaron Cox Mar 28 2007, 12:53 PM
not what i meant. i believe all the info was is in this thread. 7" wheels that fit the fenders.....
not all 7" wheels will fit... thats why i asked you to come back with a camber number... as that neg camber will make the wheel clear the outside fender lip but get into the inner fender dictating rim width, a flare, or a camber change.
Posted by: sk8kat1 Mar 28 2007, 01:33 PM
QUOTE(Aaron Cox @ Mar 28 2007, 10:53 AM)
I am not real sure how to find camber ... I took it to the shop of a guy the has a good reputation setting up P-cars for racing ..... mainly he was the only guy around that could get a car that sits as low as mine on the rack, he asked me what I was using the car for .. I said sprited driving no racing and better tire wear .. he did the rest.
I am running koni yellows and 140# springs , if that says anything
he told me he setup pretty close to stock ... just getting an idea of what I would need
Posted by: nein14 Mar 28 2007, 06:41 PM
here are my 15 x 8 on yoko advanta r 032 soft compound for the track
Posted by: Aaron Cox Mar 28 2007, 06:46 PM
i got the same ADVAN A032R's in harder compound john. mine have to go on 8" bbs or 8" fuchs....
your wheels look sick
Posted by: Gint Mar 28 2007, 10:48 PM
QUOTE(sean_v8_914 @ Mar 28 2007, 10:53 AM)
That was one of the reasons I wanted to do this thread.
- I wanted to provide some information to folks insterested in Superlite wheels
- There is a lot of mis-information and arguement about methods for determining backspace and offset.
- I searched this site for a long time looking for the offset of a 4x130 Fuchs wheel and could not find it.
I have made a good deal of edits to my first few posts. They are as follows:
- I moved the original content from post #4 to post #2.
- I added information regarding Pack Racing's lub bolt/nut inserts into post #4
- I corrected my Fuchs offset measurements.
- I gave Herr Mueller credit for 35mm postive offset after I fixed my Fuchs measurements.
- I added some wheel backspace and offset information and a diagram from Yokohama's site and also a Fikse diagram to post #5
Posted by: nein14 Mar 29 2007, 08:07 AM
I actually work with Barry the owner of Pack Racing with several machine modified wheels to get the back spacing,lug pattern and offset correct on the Superlite Wheels on both the 16lb. Track Wheel and 22lb. street wheels.
Before the mfg. Performance started production on the Porsche version of the wheel Barry had made several trip to Austalia were Performance factory is located to ensure they would work on 914 & 911's.
Barry is a great guy to work with , the wheel are a great value at twice the price.
Posted by: Gint Mar 29 2007, 08:28 AM
QUOTE(nein14 @ Mar 29 2007, 07:07 AM)
I've had nothing but good experiences with Pack Racing to this point. Gret folks and very helpful. Hopefully this information will help them understand the idoiosyncracies of the 914 with regard to fitment of Superlite wheels. That's one of my other goals in this project.
Posted by: Gint Apr 2 2007, 02:48 PM
I talked with Terry from Pack Racing Friday. Even though I bought these as basically used wheels, he is sending me a set of inserts for the cost of shipping. And the 914 fitment issues as outlined in this thread.
Pack Racing is a great place to do business with IMO.
Posted by: Gint Apr 20 2007, 01:00 PM
I'm finally getting around to installing these inserts today. I received them from Pack Racing 3 weeks or so ago, but the car falling on my face slowed my progress.
I've searched all over town for 14x1.5mm lug bolts to no avail. So this morning I ordered a set of conical seat bolts from http://www.eurosportacc.com/hr_wheel_bolts_studs.htm. I also ordered 1 ball seat 40mm 14x1.5x40mm lug bolt to check if these are the proper ball seat for a Fuchs alloy wheel. I'll let you all kow when they get here if it is or not. They should all be here by the end of next week or the Monday following.
Posted by: Gint Apr 20 2007, 06:11 PM
Dammit I can't win!
So I took the wheels/tires to the Big O Tire shop where I bought the tires originally to have the tires dismounted so I could drill the Superlight wheels for the inserts. Got the wheels all drilled, sent an email to the local gang looking for a shop press to install them (since my press is at Kevin's). Turns out the tire shop has a press and will let me use it. So I go back down there and start pressing inserts into wheels. As I finish each wheel, they are mounting and rebalancing tires on them. Everything's goin great, I'm on the last insert on the last wheel...
*CRACK*!!!!!!!!!!!!!
I put one crank too much on the press and the damn wheel cracked!
I ordered a $175 replacement. That puts my total investment into these things at $560. Still a deal considering they cost $175 each for these wheels new. This cracked wheel will look great on the garage wall next to my "labor of love" polished Fuchs wheel.
The wheel and the lug bolts should all be here before next weekend. I might get these wheels on the zambeziteen yet!
Posted by: ChrisNPDrider Apr 20 2007, 06:25 PM
Those are press in inserts to convert mag/flat seat to cone seat?
I had to machine my wheels to cone seat with a cone bit in a drill press due to lack of availability of the proper size mag/flat seat lug bolts. Lots of alloy material in there so I was OK to drill. Lots of mag seat LUG NUTS if you go to studs (I will if I ever buy "race only" wheels/tires).
Those wheels will be worth the work, they look awesome.
Posted by: Gint Apr 20 2007, 06:31 PM
Yes. Pack Racing normally installs these inserts, but since I bought these wheels used they somehow didn't get them installed originally.
I'm still only at $560 for the set. That's not much more than a set of Fuchs and it's a unique wheel. I'm looking forward to finallly getting them on the car.
Posted by: 73Phoenix20 Apr 20 2007, 07:49 PM
Interesting info...
Does anyone know if Mini Lite still sells these wheels?
15" x 6.5" and same offset as the Fuchs 2.0... weighed maybe 16 lbs.
Michelin 195/60's fit perfectly with no fender mods...
Could have gone to 205's in some brands, w/o interference...
Mini Lite sold the correct lug bolts, with a thrust washer, to fit the flat holes...
Seems like they used to be about $155 each, but everything has gone up lately...
Posted by: jim_hoyland Apr 20 2007, 09:32 PM
Gint, Thanks for the lesson; Good Stuff !
Posted by: TROJANMAN May 7 2007, 12:23 AM
That car looks faster already...........
What kind of centercaps are you going to use?
Posted by: Ferg May 7 2007, 09:29 AM
Those look fantastic!
Ferg
Posted by: boxstr May 7 2007, 10:01 AM
The best classic look in an aftermarket wheel.
CCLIN914NATION
Posted by: Gint May 7 2007, 05:13 PM
QUOTE(TROJANMAN @ May 6 2007, 11:23 PM)
Dunno...
The caps that came with the wheels are tall and fugly chrome plastic units.
I talked to Trudesign Wheels about making caps (I was thinking Fuchs caps also
) and he poopoo'd that right away. He's been burnt too many times by people wanting caps made (for 5 lug Fuchs even) and then getting blown off when the supposed buyer finds out what a one off set will cost. I proposed the idea of doing quantities and he wasn't thrilled about that either.
I need to find a machine shop I can work with. Actually a coworker has an old lathe in his garage. I may talk to him about it.
Posted by: cuca914 May 10 2007, 07:07 PM
QUOTE(Gint @ Mar 28 2007, 10:39 AM)
Nice lookin' wheels! I didn't think I liked them too much until seeing them in this thread. Thanks for the diagrams too - now I have a much better understanding of what 'offset' means.
I see that you recommend the 16x7 35+ offset for the narrow teeners and I'm inclined to agree with you. Do you or anyone else here have any suggestions for tires that would provide a good fit without having to roll any fenders?
Thanks
Posted by: majkos May 10 2007, 09:10 PM
G-man,I'm behind you!
I'm a hoping we have the same size dia. caps.
I want to dress up my ATS's.
I'll even pitch in to run productions.
Posted by: Gint May 13 2007, 03:08 AM
QUOTE(cuca914 @ May 10 2007, 06:07 PM)
Thanks
You can definitely fit a 205 section width tire on a 7" rim. People put 205's on Fuchs 5.5" wide rims all the time. On a Superlight 16X7" with 35mm offset, you *may* even be able to install a 215 and have it fit on a narrow body (no flares) 914. Whether they will fit or not will depend on different factors.
- The individual 914 - The difference in wheel well width from 914 to 914 varies. For that matter, the width usually varies between the left and right wheel wells on almost every 914.
- The tire - Tire widths vary greatly. I indicated that in this thread. The BFG g-force Sport are a very wide tire. Wider than most other brands in the same size and wider than the manufacturer's web site indicates. That's also the case with most tires and their manufacturer's publicly listed specifications. So there listings are a starting point, but don't assume they're accurate.
You're best bet is to find a friendly tire shop that will work with you. Most of them will try a couple of size tires so you can see which tire will fit well. They want to sell you tires, make them work a little for it. In my experience they will usually be more than happy to do it.
Posted by: JPB May 13 2007, 07:05 AM
Them there are perdy.
Posted by: orcadigital May 13 2007, 12:12 PM
Looks good Gint!
My wheels still rock, too bad they really dont fit.
Posted by: sixnotfour Jan 2 2013, 12:30 PM
Gint, some other 15inch wheels weights 5 lug
Mahle magnesium 15x5.5
BBS E30 magnesium center 15x8.5
Fuchs 15x7
American Racing aluminum 15x7
Mini-Lite aluminum 15x6.5
Revolution 15x6.5
Anaconda- Carrol Shelby 15x7
Mahle Knock Off aluminum-custom 15x6.5
Posted by: Gint Jan 2 2013, 12:36 PM
Cool. Good data. You should list what kind of wheels each one is though.
Posted by: sixnotfour Jan 2 2013, 12:40 PM
Done
Posted by: Gint Jan 2 2013, 06:25 PM
Thanks Jeff! Formatted a tad.
Posted by: last337 Jan 2 2013, 06:56 PM
I am actually looking at putting the bfg g-force sports on my Fuchs but now I'm wondering which size to go with if they are as wide as this thread says. Will 195/50s fit do you guys think?
Posted by: Gint Jan 2 2013, 09:24 PM
They should be fine on a stock alloy wheel.
Posted by: sixnotfour Jan 29 2013, 08:27 PM
Found these
Posted by: Gint Jan 30 2013, 06:56 PM
Those... are... awesome!!! Thanks!
Finished product (added 9/24/2020)
Posted by: BigFour1973 Oct 19 2016, 05:16 PM
awakening an old thread. If someone could tell me i'm correct so when i place my order with performance wheels I wont get them and cry because i got them wrong. I would greatly appreciate it.
So stock fuchs 15x5.5 with an offset of 40mm and a back spacing of 123mm or (4.8 inches)
I want to run 7s in the front and 8s in the back. I will be doing flares so protruding out the sides wont be an issue (to an extent of course)
I want to order:
16x7 with an offset of 21 mm which puts the backspacing at 123 mm as well.
16x8 with an offset of 8 mm, which will put the backspacing again at 123 mm.
If i can get them to make me 9" wheels I would have them make the wheels at
16x9 with an offset of -5 to give me the same 123 mm backspacing as the stock 2.0 fuchs
Thanks in advance
Posted by: Kansas 914 Oct 20 2016, 07:57 AM
So you are going 7" and 8" and keeping it 4 lug? I have done it with Cragar 365s. I now have 5 lug wheels on the flared car.
Posted by: BigFour1973 Oct 20 2016, 12:45 PM
QUOTE(Kansas 914 @ Oct 20 2016, 06:57 AM)
Yes, that's the plan. Do you recall the offsets you ran? Did you run spacers? If so what size were the spacers
Posted by: Kansas 914 Oct 20 2016, 03:03 PM
QUOTE(BigFour1973 @ Oct 20 2016, 12:45 PM)
The wheels are just sitting in the garage - let me go look and post back here.
Posted by: horizontally-opposed Oct 20 2016, 03:21 PM
QUOTE(Kansas 914 @ Oct 20 2016, 02:03 PM)
Hey Mike,
What tires are you running with the five-lug wheels?
I'm really curious how those BFGs are compared to modern performance rubber if you've got any impressions, mainly because they can be had in 205/60R15. How grippy were they? How predictable? How about noise, and ride comfort? Thanks!
pete
Posted by: BigFour1973 Oct 20 2016, 04:04 PM
Much appreciated! If they're collecting dust would you be willing to part with them?
Posted by: Kansas 914 Oct 20 2016, 06:52 PM
QUOTE(horizontally-opposed @ Oct 20 2016, 03:21 PM)
Hey Mike,
pete
I have Hankook Ventus 2 tires on the car now. Good tires - but I haven't really pushed them to see how grippy they are. I know AZ914 is running the same tires on his 3.2L 914 and he might have a better idea.
Posted by: Kansas 914 Oct 20 2016, 06:55 PM
QUOTE(BigFour1973 @ Oct 20 2016, 04:04 PM)
I definitely want to part with them. They have been in the garage for a year now. I used to run two 1/4" spacers with them. 7" X 15" (205/60) up front and 8" X 15" (225/60) in the rears.
I will measure backspacing tomorrow morning.
Posted by: BigFour1973 Oct 20 2016, 07:02 PM
QUOTE(Kansas 914 @ Oct 20 2016, 05:55 PM)
Great, thank you very much!
Posted by: horizontally-opposed Oct 20 2016, 08:43 PM
QUOTE(Kansas 914 @ Oct 20 2016, 05:52 PM)
How were the BFGs on a 914? That's what I am really curious about. Did they seem like a performance tire and appropriate for a 914, or did they feel like a floaty American car tire? Been wondering about this for a very long time, as I like their period-correct appearance on 914s. I'd probably run the black letters, but liked the white letters on your car with the black wheels. Pretty cool look.
Would be curious for your take on the BFGs
after you get a chance to push the Ventus 2s, as well.
Thanks!!!
Posted by: Kansas 914 Oct 21 2016, 07:16 AM
QUOTE(horizontally-opposed @ Oct 20 2016, 08:43 PM)
Would be curious for your take on the BFGs after you get a chance to push the Ventus 2s, as well.
Thanks!!!
Unfortunately I will never have an apples to apples comparison. When I went to 5 lug Fuchs I changed my rear shock/spring package at the same time so everything is different. I also went to a 16" wheel so I could have more tire options in the future. I also went wider tires front and rear. and went from a 60 series tire to a 50 series tire (it kept my speedometer spot on). So many changes that it is difficult to tell. I don't think I would consider the BFG a performance tire. The Hankooks maybe a little better. They are a directional tire with a more aggressive tread pattern.
When I bought the car it had the tire mounted with the raised white letters facing out. I think I would have gone black letters as well. The 914 guys at Route 66 Classic nicknamed them NASCAR tires!
Posted by: horizontally-opposed Oct 21 2016, 08:30 PM
Ah, so the car was wearing those tires when you got it? Have always thought it was kind of a cool alternative look. In any event...SHARP CAR!
Main interest in the BFGs is the desirable 205/60R15 sizing and super simple "1970s right" sidewalls. Have wondered if the construction or compound has been improved despite the vintage appearance—and have also wondered whether these are better than anything one could have gotten in the early 1970s anyway (such as XWX, etc.). I saw one early 911 running the BFG Comp T/As in Carmel during car week a few years ago. It was a stand-up car, and the tires looked very "right" on it—he had the black letters facing out. Would have loved to talk to the owner about his experiences.
I went with Avon CR6ZZ tires to get that vintage look with decent performance, and can report that they're nice—but not sure I would do them again due to $.
Posted by: Gint Sep 25 2020, 10:05 PM
QUOTE(horizontally-opposed @ Oct 21 2016, 07:30 PM)
@http://www.914world.com/bbs2/index.php?showuser=2058 Pete,
@http://www.914world.com/bbs2/index.php?showuser=1110 is running BFGs.
It occurred to me that I never posted a picture of these wheels with the caps Jeff made.
@http://www.914world.com/bbs2/index.php?showuser=2744 So here's a 13 year later follow up.
Posted by: horizontally-opposed Sep 25 2020, 11:04 PM
^ Super cool, Gint!
Center caps are one of the trickiest things with so many of the aftermarket wheels for the 914, and aftermarket wheels in general. That's a really nice solution…
Posted by: Gint Sep 26 2020, 07:52 AM
Jeff gets all the credit. He made those remotely with dimensions I gave him over the phone.
The caps that came with the wheels were cheezy, tall plastic chrome. Ick...
Posted by: Eric_Shea Oct 26 2020, 01:17 PM
QUOTE(horizontally-opposed @ Oct 21 2016, 08:30 PM)
I like them. They're better than the Pirelli's I had on there.
