holy begeezus, seems things dont want to work out for me.
short vers.
cv bolt
not a torx driver
stripped...
SEARS!
bolt remover
head snapped off.
two weeks later
still stuck.
tried various things,
pb blaster, reverse bits, tap die set. drill
nothing seems to work.
if you are local and you happen to help me maybe you can get some free
Ya, heat it just a little. Someone may have used locktite. Also you may be able to weld a nut over the end of the fudged head and back it out that way. (don't ask me how I know... )
And it's definitely not a Torx head. You want an "M8 triple square", or "the Bug CV joint socket".
--DD
dave. i know that now. LMAO
MARK! thanks so much. you'd think for a future engineer id have a little more imagination than what i do....
if you are ever near me in oklahoma free case of beer to you. or whatever soda you like best!
cv's off trannys out tommorrow afternoon. hopefully be able to drive the car before it gets too hot and i have to fix the A/C! IT NEVER ENDS!!!
Dang... at this point I would have welded a 3/8 extension on it and busted that nut..
er bolt.
Like Mark suggested, I would grind it off to get the CV joint off. You could then use a locking type pliers to remove the bolt. if it is still stuck, you can get a real cheap output flange for the trans.
