I got them mounted, but there is a gap between the top of the headlightslid, and the front of the trunk edge. Is there some sort of adjustment that I don't see, that will allow me to to bring it closer together? I'm sure it's right in front of me..
your hood is too far back to start...
Gaps should be equal all the way around. front/back/left/right. Aligning the headlights is on the short list of PITA projects. Loosen the brackets. Fiddle with it. Tighten. Repeat 1000 times. Watch out because it's possible to move it too far back and it'll scrape the back edge when opening.
Do a couple of things
Put blue masking tape on both the hood and the light cover.
Remove the arm that attaches to the motor, and active it with your hand till you get it right, that way you can stop.
There are two adjustments.
The brackets that hold the whole assembly (under fender, and in the trunk)
And the top actually can slide about 1/4 of an inch...
Go slow, get it where you want it BEFORE you hook the motor up.
Then add the wing in front of it.
Rich
Sell me the car and be done with it.
Or at least buy the 2.0 motor I have for sale. That car deserves way more than the wimpy 1.8 you have in it.
