Printable Version of Topic
914World.com _ 914World Garage _ Six Conversion and the Voltage Regulator
Posted by: Mike D. May 15 2007, 05:43 PM
My last six conversion was with an early 2.0 6 so I was fine with the stock 914 4 regulator on the relay board. The engine I am installing now is a 3.0 sc with the internal reg. alt. so now I'm a little confused as to what I should do on the relay board. Do I need to run a jumper wire somewhere?
I know someone out there has BTDT.
Thanks,
Posted by: iamchappy May 15 2007, 06:16 PM
I just run it without the relay board voltage regulator, everything seems to work fine without it.
Posted by: john rogers May 15 2007, 06:33 PM
After waiting for a couple of years, I finally replaced mine with a pair of water proof electrical connectors so that all the connectors from the input side were still connected to the output side as I use them for other things. If you use the diagram on the Pelican site or in the Haynes manual you can match color to color.
Posted by: Series9 May 15 2007, 08:09 PM
It's not hard. Remove the board and regulator and sell that boat anchor on eBay.
Buy a female version of the 14-pin connector. Call Patrick Motorsports or Porsche. Patrick sells them for around $38.
Pull out the wiring diagram and replace either the male on the car side or the one on the engine harness. It requires some simple soldering. When you're finished, the car and engine 14-pin plugs will simply connect together.
All you need to know about the internally regulated alternator:
Large red: Starter + or battery +.
Small blue: Alt. light on the dash.
Posted by: Series9 May 15 2007, 08:16 PM
Here's a picture of the male 14-pin on Waide's engine harness.
I have the cap removed so I can rearrange the pins to match the 914.
I then removed the 14-pin male connector from the 914 harness where it used to plug into the firewall side of the relay board and replaced it with a female with the pins arranged to match the engine pin-out.
Posted by: Series9 May 15 2007, 08:34 PM
The finished connection:
Posted by: Mike D. May 16 2007, 01:29 PM
QUOTE(Series9 @ May 15 2007, 07:34 PM)
Thanks Joe!
Posted by: Eric_Shea May 16 2007, 01:51 PM
Excellent info
Posted by: SLITS May 16 2007, 02:48 PM
If you get the Porsche Technical Bulletin 1, Model 1974 - 1983 911T, "New Alternator has Integrated Regulator" on replacing external with internal ..... it will tell you exactly what to do.****
**** Just in case you want to retain the /4 relay board.
Posted by: Eric_Shea May 16 2007, 02:51 PM
Can you post it?
Posted by: Gint May 16 2007, 02:56 PM
QUOTE(john rogers @ May 15 2007, 05:33 PM)
Question...
Rather than buy an expensive female connector to match that very expensive male connector, why not replace it with a modern alternative?
Posted by: SLITS May 16 2007, 03:07 PM
QUOTE(Eric_Shea @ May 16 2007, 01:51 PM)
Can you post it?
I'll see if it will scan tonight ...... don't have a scanner at work (that's hooked up)
Posted by: Series9 May 16 2007, 03:08 PM
QUOTE(Gint @ May 16 2007, 02:56 PM)
Question...
1. $38 isn't very expensive.
2. It's a VERY high quality connector.
3. I've never seen another that will accept the differing sizes of wires necessary to do the job.
4. You would have to replace both sides, instead of one.
5. Most new connectors require a specialized crimping tool to crimp the pins to the wires.
That's why.
Posted by: Eric_Shea May 16 2007, 03:11 PM
Just re-type it...
Posted by: Series9 May 16 2007, 03:11 PM
QUOTE(Eric_Shea @ May 16 2007, 02:51 PM)
Can you post it?
Posted by: Series9 May 16 2007, 03:12 PM
and:
Posted by: Eric_Shea May 16 2007, 03:13 PM
Once again, Joe saves yur ass...
Posted by: Series9 May 16 2007, 03:21 PM
QUOTE(Eric_Shea @ May 16 2007, 03:13 PM)
I owe him plenty more 'saves' than that.
Posted by: Eric_Shea May 16 2007, 03:27 PM
Don't tell him that... he'll get all cocky and... then Slits will come out and then... P9 will hit the thread and then... you know
Posted by: Gint May 16 2007, 04:15 PM
QUOTE(Series9 @ May 16 2007, 02:08 PM)
Question...
That's why.
Ok then... Where can I get a male version?
Posted by: Series9 May 16 2007, 04:38 PM
QUOTE(Gint @ May 16 2007, 04:15 PM)
I'll give you one at the AR.
Posted by: johnlush May 16 2007, 05:54 PM
Mike, FYI I got one from Tom at Carquip in Boulder P/N 911.612.113.05. Also you can scavenge a nifty bracket from an SC vintage 911 that mounts above connector to the firewall.
Joe's deal sounds hard to beat though!
Posted by: Gint May 16 2007, 06:06 PM
QUOTE(Series9 @ May 16 2007, 03:38 PM)
That's a deal I can't refuse. Sold. See ya in 10 days or so.
